mirrorofsorrow Δημ. October 9, 2009 Δημ. October 9, 2009 Και η επίσημη ανακοίνωση: http://www.nokia.com/press/press-releases/showpressrelease?newsid=1346627 Espoo, Finland - Nokia today announced the creation of the official Qt port to Maemo 5 and published an initial Technology Preview release. This port to Maemo 5 means that developers can now use Qt to target the upcoming Nokia N900 device and also ensures that applications can be easily ported to all Qt's supported platforms including the next Maemo 6 release as well as Symbian and Windows Mobile.
vasilismf Δημ. October 9, 2009 Δημ. October 9, 2009 Και η επίσημη ανακοίνωση: http://www.nokia.com/press/press-releases/showpressrelease?newsid=1346627 Espoo, Finland - Nokia today announced the creation of the official Qt port to Maemo 5 and published an initial Technology Preview release. This port to Maemo 5 means that developers can now use Qt to target the upcoming Nokia N900 device and also ensures that applications can be easily ported to all Qt's supported platforms including the next Maemo 6 release as well as Symbian and Windows Mobile. κάποιος να μου κάνει πιο λιανά τι εννοεί ότι all Qt's supported platforms including the next Maemo 6 release as well as Symbian and Windows Mobile δλδ πχ το maemo 5 θα δέχεται symbian εφαρμογές?
mirrorofsorrow Δημ. October 9, 2009 Δημ. October 9, 2009 Όχι υπάρχουσες εφαρμογές αλλά αυτές που θα αναπτύσσονται με βάση το Qt framework. Αυτό είναι πολύ θετικό γιατί πλέον, οι developers, αναπτύσσοντας εφαρμογές, θα απευθύνονται σε ένα σημαντικά μεγαλύτερο κοινό.
nervous Δημ. October 9, 2009 Δημ. October 9, 2009 [N900 unboxing at Maemo Summit] (pre-production model) [ame=http://www.youtube.com/watch?v=2nzkccfl4Y0]YouTube - N900 unboxing at Maemo Summit[/ame] [imgalign]http://i37.tinypic.com/23k3s09.jpg[/imgalign] Μην ψάξεις ποτέ να βρεις κάτι τέλειο για να το αγαπήσεις. Αγάπησε κάτι ατελές και τελειοποίησε το με την αγάπη σου! iPhone 5S Space Grey Προσοχή! Κατάργηση γραφής Greeklish
nikolasn80 Δημ. October 9, 2009 Δημ. October 9, 2009 παλι θα μασ βγαλουν την πιστη μεχρι να κυκλοφορησει "κρειττον τοις ποσιν ολισθειν ή τη γλώσση" Ειναι προτιμότερο το στραβοπάτημα με τα ποδια παρά με τη γλώσσα. ΔΙΟΓΕΝΗΣ Ο ΛΑΕΡΤΙΟΣ 66 π.Χ
TRouBLe Δημ. October 9, 2009 Δημ. October 9, 2009 Διαβάζοντας το manual του κινητού που postare ένα παιδί κάποιες σελίδες πιο πίσω, έχω να κάνω τις εξής παρατηρήσεις.... 1. Ο φορτιστής του κινητού ειναι usb. Δεν υπάρχει άλλη υποδοχή... 2. Το κινητό υποστηρίζει ad-hock WLAN συνδέσεις. Δηλαδή μπορείς να συνδεθείς σε άλλη συσσκευή που έχει Wi-fi ακόμα κι αν δεν υπάρχει Access point στην περιοχη. Αυτό που δεν κατάλαβα είναι αν η άλλη συσκευή πρέπει να υποστηρίζει και αυτή την ad-hoc σύνδεση ή αρκεί να μπορεί να συνδεθεί σε wi-fi access point. 3. Στην πρόσοψη του κινητού υπάρχει ένα λαμπάκι ειδοποίησης το οποίο ανάβει όταν το κινητό φορτίζει, όταν έχεις αδιάβαστο μύνημα κτλ. Το ωραίο είναι ότι μπορείς να το ρυθμίσεις από το αντίστοιχο μενού. 4. Υποστηρίζει ταυτόχρονες κλήσεις. Δηλαδή μπορείς να δεχθείς μια κλήση και να πάρεις άλλον και να μιλάτε και οι τρείς ταυτόχρονα. Ξέρω ότι υπάρχουν αρκετά κινητά που το υποστηρίζουν αυτό εδώ και καιρό. Πιστεύω πως το n95 μου δεν το έχει. Ευχάριστη προσθήκη. 5. Στο κομμάτι ανεφέρει ότι για να κάνει geotagging σε μια φωτογραφία χρειάζεται σύνδεση στο internet. Μάλλον εννοεί τα λίγα kilobytes του A-GPS... 6. Υπάρχει προβολή φωτογραφιών σε πλέγμα. Θα γλιτώσουμε από το άθλιο gallery του symbian. 7. FM transmitter. Παίζεις μουσική από το κινητό την οποία μπορείς να την ακούσεις από οποιοδήποτε FM δέκτη στα 3 μέτρα.:w00t: 8.Το κινητό περιλαμβάνει 4 (5 με το bounce;;; ) παιχνίδια. Blocks(tetris), Chess, Mahjong, Marbles.. Για το θέμα με τα MMS... Προσωπικά δεν με ενδιαφέρει καθόλου. Τόσα χρόνια που υπάρχει δεν έχω στείλει ούτε ένα.Στα περισσότερα κινητά μου μάλιστα δεν είχα καν περασμένες τις ριθμύσεις. Καταλαβαίνω όμως ότι υπάρχουν άτομα που το χρησιμοποιούν.Πιστεύω όμως ότι οι εξήγηση που έδωσαν οι developers είναι πολύ καλή. Το MMS χρησιμοποιεί το Wap για την αποστολή των δεδομένων, το οποίο είναι ένα πρότυπο τηλεπικοινωνοίας αρκετά ξεπερασμένο. Τα περισσότερα λογισμικά των κινητών το διατηρούν λογικά για την χρήση του MMS. Το maemo όμως το οποίο δεν υποστήριζε "τηλεφωνικά" δίκτυα μέχρι τώρα, για να υποστηρίξει το MMS θα πρέπει να προσθέσει και το WAP.Και ή δεν υπάρχει χρόνος για να γίνει αυτό ή είναι πιο δύσκολο απ'ότι ακούγεται...
vasilismf Δημ. October 9, 2009 Δημ. October 9, 2009 Όχι υπάρχουσες εφαρμογές αλλά αυτές που θα αναπτύσσονται με βάση το Qt framework. Αυτό είναι πολύ θετικό γιατί πλέον, οι developers, αναπτύσσοντας εφαρμογές, θα απευθύνονται σε ένα σημαντικά μεγαλύτερο κοινό. σαφως, πολυ καλη κινηση :D
alexis_21 Δημ. October 9, 2009 Δημ. October 9, 2009 Το κινητό υποστηρίζει ad-hock WLAN συνδέσεις. Δηλαδή μπορείς να συνδεθείς σε άλλη συσσκευή που έχει Wi-fi ακόμα κι αν δεν υπάρχει Access point στην περιοχη. Αυτό που δεν κατάλαβα είναι αν η άλλη συσκευή πρέπει να υποστηρίζει και αυτή την ad-hoc σύνδεση ή αρκεί να μπορεί να συνδεθεί σε wi-fi access point. Τι εννοείς? Το Nokia σου εμφανίζει μια λίστα με όλες τις διαθέσιμες ασύρματες συνδέσεις που εντόπισε: ad hoc και access points (ξεχωρίζουν από ένα διαφορετικό σηματάκι), και επιλέγεις όποια θέλεις. Ό,τι είδος από τα δύο και να υποστηρίζει η άλλη συσκευή σου είναι "συμβατό" με το Nokia.
pacman40_40 Δημ. October 9, 2009 Δημ. October 9, 2009 παιδια ειδα οτι θα βγει maemo 6.θα μπορει να αντικαταστησει το maemo 5?και πως θα ειναι capacitive και multitouch?μηπως βγουν αλλα μοντελα που θα τα υποστηριζουν η θα μπορουμε και στο n900?
mirrorofsorrow Δημ. October 9, 2009 Δημ. October 9, 2009 Φυσικά και θα βγουν νέα μοντέλα που θα φοράνε Maemo 6. Άλλωστε από την πρώτη κιόλας μέρα γνωρίζουμε ότι θα είναι το πρώτο μέλος μιας νέας οικογένειας συσκευών. Απλά, σύμφωνα με τα όσα μάθαμε σήμερα, οι Maemo 6 συσκευές θα έχουν το ίδιο hardware με το Ν900 με τις διαφορές να εντοπίζονται στην capacitive οθόνη, στην υποστήριξη multitouch και στην υποστήριξη portrait mode (κανένα από τα 3 δεν έχει το Ν900, πλην του τρίτου που μπορεί πολύ εύκολα να το αποχτήσει με κάποιο update). Αλλά, όλα αυτά δεν αποκλείουν το ενδεχόμενο τις εισαγωγής του 6 στο Ν900. Αλλά μέχρι τότε (να ανακοινωθεί επίσημα το 6 και να κυκλοφορήσουν οι πρώτες συσκευές που το ενσωματώνουν), έχουμε έναν χρόνο μπροστά μας να χαρούμε το 900 χωρις να μας απασχολούν τέτοια θέματα. ;)
ibiza_cupra_20vt Δημ. October 10, 2009 Δημ. October 10, 2009 εχθες το βραδυ διαβασα για καπου οτι κατα 99% το ν900 θα μπορει να φοραει το μαεμο 6...
andreas_ku990 Δημ. October 10, 2009 Δημ. October 10, 2009 εχθες το βραδυ διαβασα για καπου οτι κατα 99% το ν900 θα μπορει να φοραει το μαεμο 6... Αλλά, όλα αυτά δεν αποκλείουν το ενδεχόμενο τις εισαγωγής του 6 στο Ν900 Αφού είπαμε ότι υπάρχει πιθανότητα να μπορούμε να βάλουμε και το 6 ;) Πολύ καλό αυτό αφού δεν θα χρειάζεται να παίρνεις κάθε λίγο νέα συσκευή :) ~~They come. They fight. They destroy. They corrupt. It always ends the same.... ~~
johnsour Δημ. October 10, 2009 Δημ. October 10, 2009 Ευχάριστα νέα ανακοινώθηκαν χθες! Πιστεύω το σημαντικότερο είναι η υποστήριξη του QΤ framework! Προβληματίζε αρκετούς προγραμματιστές για το αν θα έπρεπε να ασχοληθούν με το Ν900 αφού του χρόνου με την μετάβαση σε maemo 6 δεν θα υπήρχε υποστήριξη εφαρμογών! Μπράβο στη nokia που το άλλαξε αυτό! Έτσι για τον τελικό χρήστη η συσκευή δ θα έχει ημερομηνία λήξης.. [sIGPIC][/sIGPIC] Why So Serious?
ibiza_cupra_20vt Δημ. October 10, 2009 Δημ. October 10, 2009 πιστευετε οτι η νοκια θα βγαλει αλλο κινητο,δεν ξερω λεω εγω τωρα ν920 η 9** εντος ολιγου καιρου; για πιο λογο να το κανει; αλλα ακομα κ αν το κανει δεν πιστευω οτι θα υπαρχει λογος να αλλαξεις το ν900..
TRouBLe Δημ. October 10, 2009 Δημ. October 10, 2009 Τι εννοείς? Το Nokia σου εμφανίζει μια λίστα με όλες τις διαθέσιμες ασύρματες συνδέσεις που εντόπισε: ad hoc και access points (ξεχωρίζουν από ένα διαφορετικό σηματάκι), και επιλέγεις όποια θέλεις. Ό,τι είδος από τα δύο και να υποστηρίζει η άλλη συσκευή σου είναι "συμβατό" με το Nokia. Νόμιζα ότι το κινητό θα μπορούσε να δημιουργεί ad-hoc συνδέσεις.Ξενέρωσα τώρα:lol::lol:
rafkt Δημ. October 10, 2009 Δημ. October 10, 2009 Νόμιζα ότι το κινητό θα μπορούσε να δημιουργεί ad-hoc συνδέσεις.Ξενέρωσα τώρα:lol::lol: Απ' οσο γνωρίζω γενικότερα υπάρχουν προγράμματα που δημιουργούν ad-hoc συνδέσεις... Για symbian υπάρχει καιρό τώρα, οπότε και στο maemo αν δεν υπάρχει ήδη (δεν γνωρίζω), λογικά αποκλείεται να μην βγει!!!
paravoid Δημ. October 10, 2009 Δημ. October 10, 2009 Ευχάριστα νέα ανακοινώθηκαν χθες! Πιστεύω το σημαντικότερο είναι η υποστήριξη του QΤ framework! Προβληματίζε αρκετούς προγραμματιστές για το αν θα έπρεπε να ασχοληθούν με το Ν900 αφού του χρόνου με την μετάβαση σε maemo 6 δεν θα υπήρχε υποστήριξη εφαρμογών! Μπράβο στη nokia που το άλλαξε αυτό! Έτσι για τον τελικό χρήστη η συσκευή δ θα έχει ημερομηνία λήξης.. Δεν το άλλαξε, το πλάνο ήταν αυτό πριν ανακοινωθεί καν το N900. Είχε ειπωθεί/ανακοινωθεί στο Gran Canaria Desktop Summit (GUADEC + aKademy), τον Ιούλιο.
alexis_21 Δημ. October 10, 2009 Δημ. October 10, 2009 Νόμιζα ότι το κινητό θα μπορούσε να δημιουργεί ad-hoc συνδέσεις.Ξενέρωσα τώρα:lol::lol: Μπορεί να δημιουργεί ad hoc συνδέσεις - αφού τις υποστηρίζει. Τι συσκευή ακριβώς θέλεις να συνδέσεις? Edit: τώρα κατάλαβα... μήπως εννοείς να στήνεις την ασύρματη σύνδεση στο nokia και να την βλέπουν οι άλλες συσκευές ώστε να συνδέονται αυτές ad hoc αυτόματα? Αυτό δεν το είχα δοκιμάσει αν γίνεται.
johnsour Δημ. October 10, 2009 Δημ. October 10, 2009 Δεν το άλλαξε, το πλάνο ήταν αυτό πριν ανακοινωθεί καν το N900. Είχε ειπωθεί/ανακοινωθεί στο Gran Canaria Desktop Summit (GUADEC + aKademy), τον Ιούλιο. Είναι σίγουρο αυτό; Εγώ ηξερα ότι η υποστήριξη του QΤ ήταν αμφίβολη στο maemo 5. Επίσης, σήμερα διάβασα στο maemo.org ότι χθες επιβεβαιώθηκε το παραπάνω..Ίσως κάνω λάθος αλλά πίστευα πως το 'step 5' της nokia ήταν η μετάβαση σε QΤ του χρόνου μαζί με maemο 6..Διορθώστε με αν κάνω λάθος! [sIGPIC][/sIGPIC] Why So Serious?
anapospastos Δημ. October 10, 2009 Δημ. October 10, 2009 Μια ερωτηση: Τι μεγεθος περιπου εχει μια ιστοσελιδα για το κντ? Ρωταω επειδη οταν το παρω με το καλο λεω να βαλω 40mb για περιηγηση κ μονο το μηνα. Θα μου φτανει ή θα φαω κανενα ακυρο? My name was Maemo, then it became Meego and now I'm getting a third one. I am Sailfish.
mirrorofsorrow Δημ. October 10, 2009 Δημ. October 10, 2009 Ανάλογα. Αν χρησιμοποιείς τον ενσωματωμένο browser και έχεις ενεργοποιημένα τα πάντα (εικόνες, flash, javascript κτλ), τότε θα δεις ότι μερικές σελίδες ξεπερνούν το 1ΜΒ. Αν θέλεις απλά να τσεκάρεις τα mail σου, να μπαίνεις facebook και να χρησιμοποιείς κάποιον IM, τότε δεν θα έχεις πρόβλημα. Πχ, τα widget της οθόνης αναμονής, όπως αυτό του καιρού, των rss feeds, του facebook και πάει λέγοντας, κατεβάζουν μόνο τις απαραίτητες πληροφορίες που πολλές φορές είναι ελάχιστα ΚΒ. Οπότε, ξεκίνα με ένα σχετικά περιορισμένο data plan, έλεγχε συνέχεια το σύνολο των δεδομένων και κρίνε αν χρειάζεσαι κάτι περισσότερο.
mirrorofsorrow Δημ. October 11, 2009 Δημ. October 11, 2009 Και ένα 13λεπτο video-review του browser. [ame=http://www.youtube.com/watch?v=cnfeTY5yPxk]YouTube - N900 Web Browsing Demo[/ame]
nikolasn80 Δημ. October 11, 2009 Δημ. October 11, 2009 1)το slide ειναι στιβαρο?γιατι αυτο στο ν97 ηταν πολυ καλη ποιοτητα 2)αυτο που ανησυχει μονο ειναι το θεμα της μπαταριας καθως οι εφαργμογες που τρεχει ειναι ενεργοβορες αρα μαλλον με μια μετρια χρηση παμε για 1-2 μερες "κρειττον τοις ποσιν ολισθειν ή τη γλώσση" Ειναι προτιμότερο το στραβοπάτημα με τα ποδια παρά με τη γλώσσα. ΔΙΟΓΕΝΗΣ Ο ΛΑΕΡΤΙΟΣ 66 π.Χ
alexis_21 Δημ. October 11, 2009 Δημ. October 11, 2009 Nokia N900 video Autofocus [ame=http://www.youtube.com/watch?v=TfkKfraXXKI]YouTube - Nokia N900 video Autofocus[/ame]
