mixtri Δημ. July 1, 2025 Δημ. July 1, 2025 On 28/6/2025 at 9:28 ΜΜ, specguard said: Oι εφαρμογες ανοιγουν και κατεβαζουν οχι το τηλεφωνο.... Ωραία. Συμφωνώ. Σε άλλα τηλέφωνα γιατί λειτουργεί λοιπόν χωρίς να πειράξει κανείς τίποτα; Όχι iphone, Android εννοώ. On 28/6/2025 at 2:39 ΜΜ, specguard said: There could be several reasons why your Android phone is unable to open certain PDFs while others work fine. Here are some common issues and potential solutions: File Corruption: The PDF files that won't open may be corrupted. Try opening them on a different device or PDF viewer to check if they work elsewhere. Unsupported Features: Some PDFs may contain features not supported by your PDF viewer app, such as certain forms, multimedia elements, or complex formatting. Consider trying a different PDF reader app like Adobe Acrobat Reader or Foxit PDF Reader. Permissions: Ensure that your PDF viewer app has the necessary permissions to access storage. You can check this in your phone's settings under Apps > [Your PDF Viewer] > Permissions. File Size: Very large PDF files might have difficulty opening on some devices due to memory limitations. If you're dealing with a large file, try reducing its size or using a more powerful PDF viewer. Outdated App: Your PDF viewer app may be outdated. Check the Google Play Store for updates to your PDF reader app. File Name Issues: Sometimes, special characters in the file name can cause issues. Rename the file to remove any unusual characters or spaces. Storage Issues: If your device is low on storage, it may struggle to open larger files. Check your device’s storage and free up some space if needed. If none of these solutions work, consider reinstalling the PDF viewer app or trying a different one to see if that resolves the issue. Ρε παιδιά μα το Θεό. Εκείνη τη στιγμή δε θα καθίσω να κάνω debug το τηλέφωνο για να δω γιατί δεν ανοίγουν pdf αρχεία... Βιάζεσαι να κάνεις τη δουλειά σου και να μην περιμένει ο υπάλληλος. Θεωρώ εντελώς ανόητο να μην μπορεί να δουλέψει μια εφαρμογή σωστά σε αυτό το τηλέφωνο χωρίς μα μου σου του. Όχι, δε θα μπω καν στην διαδικασία να δω τι φταίει. Θα το σουτάρω. Είναι λεπτή η γραμμή μεταξύ χρηστικότητας και αχρηστίας φαίνεται. Το έχω πάρει το τηλέφωνο εδώ και 14 μήνες και το χρησιμοποιώ μόνο για video call και browsing, και κανένα youtube. Όταν πάω να κάνω δουλειά... Μπαμ πρόβλημα. 1 Παράθεση Easy2Install:Easy2Integrate:Easy2Scale :: /// PD Baseband Developer [sIGPIC][/sIGPIC]
specguard Δημ. July 1, 2025 Δημ. July 1, 2025 Καταλαβαίνω πόσο ψυχοφθόρο είναι αυτό που περιγράφεις, εδώ εμένα μια φορά είχε κολλήσει η εφαρμογή του Lidl και ήμουνα μπροστά στο ταμείο, πόσο μάλλον να βρίσκεσαι μπροστά στο ταμείο μιας τράπεζας. Και πάλι όμως θεωρώ ότι δεν φταίει το τηλέφωνο αλλά η εφαρμογή της Τράπεζας. Αν οι developers της Τράπεζας δίνουν βαρύτητα στην Αpple τι να πω!!! 1 Παράθεση
tsimisde Δημ. July 1, 2025 Δημ. July 1, 2025 Πολλές φορές, με τις εφαρμογές, ανεξαρτήτως λογισμικού, παίζουν ρόλο οι αναβαθμίσεις η μη των εφαρμογών. Μπορεί να τύχει για παράδειγμα μια εφαρμογή να είναι ενημερωμένη, μια άλλη όχι και αυτό να δημιουργεί μπέρδεμα, χωρίς φυσικά να θέλω να αναιρέσω το φίλο που έχει το θέμα που έχει και είναι ξενερωμενος. Η αλήθεια είναι ότι κι εγώ κάτι είχα στην αρχή με τα pdf στο Xiaomi 15, νομίζω είναι κάτι με τις προεγκατεστημένες εφαρμογές της συσκευής και ίσως αυτό να δημιουργησε θέμα. Δεν θυμάμαι πως το ρύθμισα, ανέκαθεν έχω το Adobe Reader για να ανοίγω τα pdf και δεν έχω κανένα απολύτως θέμα έκτοτε, δοκίμασε κάποια άλλη εφαρμογή για τα pdf, μήπως με τις προεγκατεστημένες υπάρχει το θέμα.... 1 Παράθεση
specguard Δημ. July 1, 2025 Δημ. July 1, 2025 Για όποιον κύριο έχει κατεβάσει τον καινούργιο update της ευρωπαϊκής ROM μπορεί να μου στείλει όταν έχει χρόνο ποια έκδοση φορά στον Poco launcher και Security APK? Ευχαριστώ εκ των προτέρων! Παράθεση
tasos_v Δημ. July 1, 2025 Δημ. July 1, 2025 1 minute ago, specguard said: Για όποιον κύριο έχει κατεβάσει τον καινούργιο update της ευρωπαϊκής ROM μπορεί να μου στείλει όταν έχει χρόνο ποια έκδοση φορά στον Poco launcher και Security APK? Ευχαριστώ εκ των προτέρων! Αν σε βοηθάει, χρησιμοποιω απο την αρχη τον nova launcher χωρις να εχω θεμα μα κάτι. Μονο μερικές λίγες φορές κολλάει η οθόνη πατώντας το on ξεκολαει και λειτουργεί κανονικά Επίσης για τις εφαρμογές που βρίσκονται στο backround δεν τις ανοίγει παρα μόνο αν τις κλεισω και τις ανοίξω απο την αρχή. Δεν ξερω όμως αν ευθύνεται ο nova Παράθεση
Arinos Δημ. July 1, 2025 Δημ. July 1, 2025 2 ώρες πριν, specguard said: Για όποιον κύριο έχει κατεβάσει τον καινούργιο update της ευρωπαϊκής ROM μπορεί να μου στείλει όταν έχει χρόνο ποια έκδοση φορά στον Poco launcher και Security APK? Ευχαριστώ εκ των προτέρων! 5.39.40.11244-06061613 10.9.1-250528.1.1 1 Παράθεση
panos9553 Δημ. July 1, 2025 Δημ. July 1, 2025 On 28/6/2025 at 11:59 ΠΜ, mixtri said: Στην εφαρμογή της Τράπεζας μου στη Σουηδία έχει links σε pdf που δεν ανοίγουν και δεν κατεβάζουν τα αρχεία. Η εφαρμογή έχει όλα τα δικαιώματα θεωρητικά. Ο υπάλληλος της τράπεζας μου είπε να πετάξω το κινητό μου στα σκουπίδια και να πάρω iphone. Και του είπα, ναι εσένα περίμενα... Είχα μαζί μου το iphone 13 και κατάφερα να του περάσω κάποια pdf. Ρε παιδιά, μια δουλειά δεν κάνει σωστά. Πραγματικά. Είναι πολύ κουραστικό. Μετράω μέρες αντίστροφα. Καλησπέρα, τυπική ερώτηση αλλά υπάρχει λόγος που ρωτώ...έχεις ενεργοποιήσει develelopers options? Και μήπως έχεις κάνει τίποτα αλλαγές εκεί μέσα? Παράθεση
mixtri Δημ. July 1, 2025 Δημ. July 1, 2025 16 minutes ago, panos9553 said: Καλησπέρα, τυπική ερώτηση αλλά υπάρχει λόγος που ρωτώ...έχεις ενεργοποιήσει develelopers options? Και μήπως έχεις κάνει τίποτα αλλαγές εκεί μέσα? Το τηλέφωνο το έχω default. Μόνο notifications κλείνω. Παράθεση Easy2Install:Easy2Integrate:Easy2Scale :: /// PD Baseband Developer [sIGPIC][/sIGPIC]
Arinos Δημ. July 1, 2025 Δημ. July 1, 2025 Υπάρχει κάποια καλύτερη σύνθεση χρωμάτων που φέρνει την οθόνη πιο κοντά σε οθόνες realme/oppo/oneplus και f7 ultra? Αυτή την στιγμή χρησιμοποιώ saturated στο cool. 1 Παράθεση
specguard Δημ. July 2, 2025 Δημ. July 2, 2025 Πάνε στο advanced settings,P3 και παίξε με τον κέρσορα! 1 Παράθεση
s_nova Δημ. July 2, 2025 Author Δημ. July 2, 2025 13 ώρες πριν, Arinos said: Υπάρχει κάποια καλύτερη σύνθεση χρωμάτων που φέρνει την οθόνη πιο κοντά σε οθόνες realme/oppo/oneplus και f7 ultra? Αυτή την στιγμή χρησιμοποιώ saturated στο cool. Χμμμμ λιγες ειπες βαλε καμια 10αρια ακομα ...Α...και απο καμια nvidia καρτα γραφικων και samsung την καινουργια των 20.000 ευρω....Πιστευω οτι θα εχουμε καλυτερο καλιμπραρισμα... Παράθεση
stamdd Δημ. July 4, 2025 Δημ. July 4, 2025 Σας ήρθε κι σας ενημέρωση??? Παράθεση [sIGPIC][/sIGPIC] WELCOME TO THE WORLD WITH NO FUTURE... S.T.A.L.K.E.R. SHADOW OF CHERNOBYL
mixtri Δημ. July 4, 2025 Δημ. July 4, 2025 5 ώρες πριν, stamdd said: Σας ήρθε κι σας ενημέρωση??? Για τα broken APIs κάνανε κάτι; Μια ερώτηση. Χρησιμοποιείτε τα gestures ή το έχετε με κουμπιά; Με gestures έχω άπειρα προβλήματα σε διάφορες εφαρμογές πχ Instagram ωστόσο από το iphone έχω συνηθίσει με gestures και δε μπορώ τα κουμπιά... Παράθεση Easy2Install:Easy2Integrate:Easy2Scale :: /// PD Baseband Developer [sIGPIC][/sIGPIC]
minotavros Δημ. July 4, 2025 Δημ. July 4, 2025 1 ώρα πριν, mixtri said: Για τα broken APIs κάνανε κάτι; Μια ερώτηση. Χρησιμοποιείτε τα gestures ή το έχετε με κουμπιά; Με gestures έχω άπειρα προβλήματα σε διάφορες εφαρμογές πχ Instagram ωστόσο από το iphone έχω συνηθίσει με gestures και δε μπορώ τα κουμπιά... Με τα gestures δεν έχω θέμα. Μήπως φταίει κανένα τζαμακι που έχεις βάλει? Παράθεση No root->No problem
mixtri Δημ. July 4, 2025 Δημ. July 4, 2025 Just now, minotavros said: Με τα gestures δεν έχω θέμα. Μήπως φταίει κανένα τζαμακι που έχεις βάλει? Μου μαυρίζει η οθόνη και πρέπει να κλείσω την εφαρμογή. Δεν έχω τζαμάκι πλέον. Δεν ασχολούμαι καν να βάλω βασικά, ας σπάσει. Παράθεση Easy2Install:Easy2Integrate:Easy2Scale :: /// PD Baseband Developer [sIGPIC][/sIGPIC]
s_nova Δημ. July 4, 2025 Author Δημ. July 4, 2025 (edited) On 30/6/2025 at 2:28 ΜΜ, aristidis540 said: Εμείς με global να δούμε πότε θα έρθει....... Για F7 πότε θα πάμε? Μετά το καλοκαίρι? 😊 Α...κατσε να πεσει αργοτερα στα χερια μου γιατι αυτο εχει Snap-modem με αποτελεσμα δεν ξερω εαν θα ειναι ποτε καλυτερο απο το T800 του X6 Pro μη φαμε καμια πατατα με τις κλησεις και την αποδοση του ....Η Mediatek εχει προχωρησει πολυ με τα modem ειδη η google με τα μελλοντικα pixel εχει στραφει εκει και παρατησε την sammy.... Edited July 4, 2025 by s_nova 1 Παράθεση
Fulgore1 Δημ. July 5, 2025 Δημ. July 5, 2025 (edited) On 1/7/2025 at 7:37 ΠΜ, mixtri said: Το έχω πάρει το τηλέφωνο εδώ και 14 μήνες και το χρησιμοποιώ μόνο για video call και browsing, και κανένα youtube. Όταν πάω να κάνω δουλειά... Μπαμ πρόβλημα. Επρεπε ήδη να το είχες διώξει το κινητό χωρίς πολλά πολλά. Και εγώ στο X6 Pro είχα γράψει διάφορα κουλά που έβλεπα πάνω στον πρώτο χρόνο,γιαυτό και έφυγε χωρις πολλά πολλά. Από την εφαρμογή της Τράπεζας να κολλάει στο τέλος και να μην ολοκληρώνει την πληρωμή κάποιες φορές, μέχρι σε παιχνίδια να κρασάρουν οταν τα πρωτο ανοίγεις ή να μην κρατάει εφαρμογές στο παρασκήνιο η έκδοση 8GB κλπ. Στο X7 pro ως τώρα, δεν έχω πετύχει τίποτα από αυτά μέχρι τώρα, και γενικά γιαυτό ποτέ δεν θα δώσω πολλά χρήματα για Poco(400+πχ). Ειναι δυστηχώς του ύψους και του βάθους, γιαυτό και μια ζωή είχε τα περισσότερα παράπονα και στο εδώ forum(με 2ρα τα Samsung A κινητά). Τα 2 παράπονα που έχω στο X7 Pro (ίδια μετο X6 Pro) ειναι α)τα updates εξακολουθούν να έρχονται κάθε 3-4μήνες(απαράδεκτο),και η μπαταρία(κλασσικό θέμα των poco)δεν κρατάει πολύ για 6000mah. Edited July 5, 2025 by Fulgore1 1 1 Παράθεση
mixtri Δημ. July 5, 2025 Δημ. July 5, 2025 1 ώρα πριν, Fulgore1 said: Επρεπε ήδη να το είχες διώξει το κινητό χωρίς πολλά πολλά. Και εγώ στο X6 Pro είχα γράψει διάφορα κουλά που έβλεπα πάνω στον πρώτο χρόνο,γιαυτό και έφυγε χωρις πολλά πολλά. Από την εφαρμογή της Τράπεζας να κολλάει στο τέλος και να μην ολοκληρώνει την πληρωμή κάποιες φορές, μέχρι σε παιχνίδια να κρασάρουν οταν τα πρωτο ανοίγεις ή να μην κρατάει εφαρμογές στο παρασκήνιο η έκδοση 8GB κλπ. Στο X7 pro ως τώρα, δεν έχω πετύχει τίποτα από αυτά μέχρι τώρα, και γενικά γιαυτό ποτέ δεν θα δώσω πολλά χρήματα για Poco(400+πχ). Ειναι δυστηχώς του ύψους και του βάθους, γιαυτό και μια ζωή είχε τα περισσότερα παράπονα και στο εδώ forum(με 2ρα τα Samsung A κινητά). Τα 2 παράπονα που έχω στο X7 Pro (ίδια μετο X6 Pro) ειναι α)τα updates εξακολουθούν να έρχονται κάθε 3-4μήνες(απαράδεκτο),και η μπαταρία(κλασσικό θέμα των poco)δεν κρατάει πολύ για 6000mah. Αν δεν είχα το iPhone καβάτζα θα είχε φύγει. Μετράω 2 μήνες. Μετά πάει στη μαμά. Και τέλος. Παράθεση Easy2Install:Easy2Integrate:Easy2Scale :: /// PD Baseband Developer [sIGPIC][/sIGPIC]
Fulgore1 Δημ. July 5, 2025 Δημ. July 5, 2025 On 4/7/2025 at 9:27 ΜΜ, s_nova said: Η Mediatek εχει προχωρησει πολυ με τα modem ειδη η google με τα μελλοντικα pixel εχει στραφει εκει και παρατησε την sammy.... Spoiler Για να μην γράφονται ανακρίβειες περί προτιμήσεων, η Google επέλεξε την Samsung εξα αρχής αντί της Qualcomm(ή και την Mediatek),καθαρά λόγω κόστους. Γιαυτό και τα πρώτα Pixel 6 ήταν αισθητά φθηνότερα σε σχέση με τα τελευταία. Πλέον όμως που η Google έχει ανέβει σε τιμές Iphone, δεν μπορεί να συνεχίζει χρησιμοποιεί mid range επεξεργαστές σε ναυαρχίδες των 1200ευρώ, και κοιτάζει σε Mediatek γιατί πολύ απλά η Qualcomm ειναι ακριβότερη. Για τον ίδιο λόγο που και η Apple, μελλοντικά θα αφήσει την Qualcomm και θα βγάζει η ίδια τα modems όπως στο πρόσφατο Iphone 16e. Χαμηλότερο κόστος(άρα μεγαλύτερο κέρδος). 7 ώρες πριν, mixtri said: Αν δεν είχα το iPhone καβάτζα θα είχε φύγει. Μετράω 2 μήνες. Μετά πάει στη μαμά. Και τέλος. Δεν είσαι ο μόνος πάντως όπως βλέπεις και στο δίπλα θέμα Παράθεση
mixtri Δημ. July 5, 2025 Δημ. July 5, 2025 1 ώρα πριν, Fulgore1 said: Reveal hidden contents Για να μην γράφονται ανακρίβειες περί προτιμήσεων, η Google επέλεξε την Samsung εξα αρχής αντί της Qualcomm(ή και την Mediatek),καθαρά λόγω κόστους. Γιαυτό και τα πρώτα Pixel 6 ήταν αισθητά φθηνότερα σε σχέση με τα τελευταία. Πλέον όμως που η Google έχει ανέβει σε τιμές Iphone, δεν μπορεί να συνεχίζει χρησιμοποιεί mid range επεξεργαστές σε ναυαρχίδες των 1200ευρώ, και κοιτάζει σε Mediatek γιατί πολύ απλά η Qualcomm ειναι ακριβότερη. Για τον ίδιο λόγο που και η Apple, μελλοντικά θα αφήσει την Qualcomm και θα βγάζει η ίδια τα modems όπως στο πρόσφατο Iphone 16e. Χαμηλότερο κόστος(άρα μεγαλύτερο κέρδος). Δεν είσαι ο μόνος πάντως όπως βλέπεις και στο δίπλα θέμα Κρεμάνε τα APIs. Νέα ιστορία σήμερα. Ήθελα να δω μια άσκηση για agility ladder και ανοίγω YouTube, ψάχνω για άσκηση και κατά λάθος πατάω σε link διαφήμισης. Πάγωσαν τα ΠΑΝΤΑ. Ούτε το Χ δε λειτουργούσε ούτε τίποτα. Αναγκάστηκα να κλείσω εφαρμογή και να ξανανοίγω, να ψάχνω ξανά. Δηλαδή πραγματικά. Δε ξέρω πως τα κατάφεραν. Παράθεση Easy2Install:Easy2Integrate:Easy2Scale :: /// PD Baseband Developer [sIGPIC][/sIGPIC]
panos9553 Δημ. July 6, 2025 Δημ. July 6, 2025 (edited) Να κάνω και μια συγκριση το x6 pro της συζύγου με το poco F5 το δικο μου...Ειμαστε πολυ ευχαριστημενοι και απο τα δυο..Ειναι πολυ κοντα γενικα...Η οθονη του x6 pro ομως ειναι λιγο πιο φωτεινη γενικα και λογω μεγαλυτερης αναλυσης ειναι ενα τσικ καλυτερη..Καμερες ενα τσικ καλυτερο το F5...Θεωρω πως σε σημα και σε συνδεσιμοτητα με Bluetooth το F5 ειναι ξεκαθαρα καλυτερο παντως αν και περιμενα το αντιθετο... Και αυτο που μου εκανε εντυπωση...πως ειναι και πιο smooth και σπιρτοζικο γενικα το F5 αν και πιο <<φορτωμενο>> απο εφαρμογες κλπ κινητο... 20 ώρες πριν, mixtri said: Κρεμάνε τα APIs. Νέα ιστορία σήμερα. Ήθελα να δω μια άσκηση για agility ladder και ανοίγω YouTube, ψάχνω για άσκηση και κατά λάθος πατάω σε link διαφήμισης. Πάγωσαν τα ΠΑΝΤΑ. Ούτε το Χ δε λειτουργούσε ούτε τίποτα. Αναγκάστηκα να κλείσω εφαρμογή και να ξανανοίγω, να ψάχνω ξανά. Δηλαδή πραγματικά. Δε ξέρω πως τα κατάφεραν. Προφανως κατι δεν παει καλα με την συσκευη σου...Δεν μπορω να καταλαβω τι ομως... Της συζύγου εδω και κανα 6 ημηνο ειναι εξαιρετικη συσκευη και εχω βρει την ηρεμια μου.. με τα γνωστα οτι κολλησε...αργησε να ανοιξει κατι...Ολα γινονται σταθερα και γρηγορα.. Edited July 6, 2025 by panos9553 1 Παράθεση
s_nova Δημ. July 8, 2025 Author Δημ. July 8, 2025 (edited) Παντως η μπαταρια εμενα εχει καταπληκτικη αποδοση . Εχω μονιμη ακροαση ραδιο με Bt galaxy buds 2 pro απο της 20.30 εως τωρα 21.55 με ταυτοχρονη πλοηγηση νετ ,fb κτλ. και εχω υπολοιπο 92%....Αρχοντας....😁 Edited July 8, 2025 by s_nova Παράθεση
Arinos Δημ. July 8, 2025 Δημ. July 8, 2025 Κάτι έφτιαξαν με την μπαταρία πάντως με το τελευταίο update. Η διαφορά που είχα αναφέρει υπάρχει ακόμα. 1 Παράθεση
s_nova Δημ. July 9, 2025 Author Δημ. July 9, 2025 Συνεχιζω απο χθες με φουλ χρηση η μπαταρια ειναι ακομα στο 62% ...Ρε τι εγινε χεχε δεν θα το φορτισω παει για δευτερη μερα χωρις φορτιση πςςςςςςς.....😀 1 Παράθεση
