Poco X6 Pro 5G
s_nova
Αν όπως εγω έχετε απηυδήσει με το Google dialer (δεν μπορεις να δείς ιστορικό παρα μόνο την τελευταία κλήση , για ηχογραφηση κλήσης ουτε καν κλπ κλπ) και θελετε να επαναφέρετε τον dialer της xiaomi, βρήκα αυτό στο reddit  και δουλεψε σε μένα οποτε ειπα να το μοιραστώ:
✅ 1. First, Install ADB Drivers https://xiaomifirmware.com/downloads/download-adb-installer-v1-4-3-drivers-adb-fastboot-tools/
✅ 2. Enable Developer Options on Your Phone
Go to "About Phone".
Tap "MIUI Version" 5–6 times until Developer Options are unlocked.
Go back to Settings > "Additional Settings" > "Developer Options".
Enable:
USB Debugging
Install via USB
USB Debugging (Security Settings)
Disable ADB Timeout
✅ 3. Prepare Your PC
Download and run the ADB Installer from the link above.
During setup, press Y, Y, Y when prompted.
Make sure the C:\adb folder is created or check under Program Files.
✅ 4. Connect Your Phone to PC
Connect via USB.
Open CMD or PowerShell and type:
adb devices
adb shell
✅ 5. Remove Google Dialer and Contacts
pm uninstall -k --user 0 com.google.android.dialer
pm uninstall -k --user 0 com.google.android.contacts
✅ 6. Remove MIUI Global Restriction
pm uninstall -k --user 0 com.android.phone.cust.overlay.miui
Without this step, call recording won't work.
✅ 7. Install MIUI Contacts and Dialer
pm install-existing com.android.contacts
pm install-existing com.android.incallui
✅ 8. Done Now you're using Xiaomi's native Contacts and Dialer apps, and call recording is enabled.
You can find your recordings inside the Voice Notes app.
To set Xiaomi Dialer as default:
Send any random number (e.g., 0502 000 0000) on WhatsApp.
Tap the number > press "Call".
Choose Xiaomi Dialer and tap "Always".
Still not working? Try this reset sequence:
pm uninstall -k --user 0 com.android.incallui
pm uninstall -k --user 0 com.android.contacts
Then repeat the installation steps above.
Wrote and tested this during a power outage — hope it helps. — TheCraxy
Επίσης να αλλάξετε σε μια χωρα που επιτρέπει ηχογραφηση (εγω εβαλα Ιρλανδια) και να κάνετε αυτα που λεει στο comment απο κατω για να δουλεψει σωστα:
do this : Go to Settings, tap on Apps, then go to Settings from the top right. Select Default Apps, and then tap on Reset All Default Apps. Click the Clear Defaults button, and it will be fixed. contatcs will work .
Ολο το ιστορικο δειχνει απ ολες τις μερες και οχι μονο την τελευταια κληση  ο dialer της google.
Edited by s_nova
Τι να πω εγώ μετά την αναβάθμιση στο 2.0 είχα πρόβλημα. Μπορεί κάτι να έγινε στην συσκευή μου
Όλο πνεύμα αντιλογίας αυτό το παιδί 😛
Enable:
USB Debugging
Install via USB
Disable ADB Timeout
Connect via USB.
adb devices
adb shell
Θα τιμηθεί δεόντως η πρόταση σου. Θα επανέλθω με την εμπειρία μου!
Bro, μην με αναγκάσεις να στείλω αποτελέσματα από Βουκουρέστι γιατί θα "κλάψουμε" Μόλις περάσω από το κέντρο θα δοκιμάσω!
Ρε παιδιά εγώ είμαι σε φάση την μια να το ανοίξω από το κουτί του και την άλλη να το πουλήσω. Δεν ξέρω τι να κάνω.
Εγω εαν  ειχα ενα σφραγισμενο  οπως εσυ θα το πουλουσα και θα επαιρνα το καινουργιο redmi 4 turbo pro (ετσι λεγεται μεσα στην κινα) Poco F7 για Ευρωπη οταν βγει. Οχι οτι με χαλαει το X6 Pro που εχω τωρα αλλα ετσι για αλλαγη οεοοο...   https://www.google.com/amp/s/m.gsmarena.com/xiaomi_redmi_turbo_4_pro-ampp-13617.php
Edited by s_nova
23 minutes ago, s_nova said:
Εγω εαν  ειχα ενα σφραγισμενο  οπως εσυ θα το πουλουσα και θα επαιρνα το καινουργιο redmi 4 turbo pro (ετσι λεγεται μεσα στην κινα) Poco X7 για Ευρωπη οταν βγει. Οχι οτι με χαλαει το X6 Pro που εχω τωρα αλλα ετσι για αλλαγη οεοοο...   https://www.google.com/amp/s/m.gsmarena.com/xiaomi_redmi_turbo_4_pro-ampp-13617.php
Παραδεξου το, είσαι εθισμένος στο να ανοίγεις νήματα!!!😛
Δεν θα τολεγα γιατι παλια δεχομουν απειλες απ τον "κυπριο" ηθελε να ανοιγει μονο αυτος μεχρι και τους moderator απειλουσε απο τοτε φοβηθηκα και δεν το επιχειρω απαπα...
Si/C Li-Ion 7550 mAh
Και μόνο για τη μπαταρία.....
On 22/4/2025 at 8:47 ΜΜ, Arinos said:
Με χώρα Ελλάδα ακόμα τελευταία αναβάθμιση ασφαλείας Δεκεμβρίου. Συγκεκριμένα 2.0.2.0 VNLEUXM ενώ χθες βγήκε η 2η επόμενη 2.0.103.0 VNLEUXM
On 27/4/2025 at 12:01 ΠΜ, aristidis540 said:
Έκανα τελικά την  αναβάθμιση απο hyperOs 1 σε 2 ...
αυτό με τα εικονίδια 5x9 εiναι πολύ βολικό και για τα widgets..
άντε να δούμε πως θα πάει και από μπαταρία.
Όλοι εσείς που δηλώσατε ότι κατεβάσατε την 2.0.2.0 VNLEUXM ή δεν ξέρω την 2.0.103.0 VNLEUXM από Ελλάδα έχετε Global ή Ευρωπαϊκή rom?
Τη συσκευή την αγοράσατε από Ελλάδα?
8 ώρες πριν, specguard said:
EUXM ευρωπαϊκή, ΜIXM Global
Εμένα με έχει ξεχάσει.... 🙃
Poco X7 υπάρχει εδω και καιρό,το κινέζικο Xiaomi Redmi Turbo 4 Pro θα έρθει ως Poco F7 .
Κόβεται απο βάρος και κάμερα για μένα,όταν αλλάξω θέλω τουλάχιστον μεγαλύτερο αισθητήρα.
siemens s35i->sony ericsson t100->siemens s65->sony ericsson k750->eten x600->htc diamond->htc diamond 2->xperia ray (ποτέ Nokia :cool:)
Αυτή είναι η έκδοση που ήρθε το hyper os 2 και παραμένει ακόμα και σήμερα με security patch Δεκεμβρίου με χώρα Ελλάδα.
Ήρθε ειδοποίηση στις 12 για καινούργιο update, εντωμεταξύ πριν γράψω το παραπάνω μήνυμα είχα κάνει έναν έλεγχο και δεν είχε τίποτα.
Screenshot-2025-05-06-12-44-24-305-com-a
Να μαδήσω μαργαρίτες?
Θα έρθει μου δεν μου θα έρθει μαγαπά δεν μαγαπά?
Οϊμέ!!!!!
Αμα έχεις την ευρωπαϊκή σίγουρα θα σου έρθει, πιστεύω είναι θέμα ημερών αν όχι ωρών.
..περαστηκε.ολα οκ..πωs το παθανε και μαs την εμφανισανε ετσι απλα..?..ουτε αλλαγεs region..ουτε τιποτα..ετσι μπαμ εσκασε.....
Δουλεύει...
Καλησπέρα παιδιά. Μετα το security patch χθες ειμαι στην 2.0.104.0. Δε μου έχει εμφανίσει την υγεία/ζωη της μπαταρίας. Την εχει εμφανίσει σε εσάς?
Πού εμφανίζεται η υγεία;
Η ποίηση δεν θα εξαφανιστεί.
Παύλος Παυλίδης
