Windows 10 technical preview (Insider Program)
iStewie
  • Απαντήσεις 6,8χιλ.
Τι νέο υπάρχει στην έκδοση 10512:
  • General improvement in overall stability and performance.
  • You can now set the Lock screen and background image from within the Photos app.
  • We fixed an issue where apps installed on SD cards weren’t working after a reboot.
  • We have improved Latvian and Chinese inputs.
  • We have made improvements to the Kid’s Corner tile layout.
  • We have improved reliability of Data Sense notifications.
  • Modified Shape Writing algorithm to be less aggressive in suggesting contact names over common words.
  • Resolved an issue where Camera would not launch when the phone was locked.
  • We fixed an issue where notifications for incoming text messages weren’t appearing.
  • We fixed an issue where the touch screen wouldn’t be responsive after ending a phone call on some devices.
  • And we fixed an issue where folder tiles have obviously overlapping text.
Γνωστά προβλήματα της έκδοσης 10512:
  • Mobile hotspot doesn’t work in this build. When sharing the Internet from your phone using Mobile Hotspot, devices will fail to get a valid IP address from your phone and will show no internet access.
  • Two-factor authentication for your MSA with a phone number doesn’t work in this build. If you reset your phone and go through the first run experience, you won’t be able to input more than 2 characters for validating phone or text authentication. If you have a secondary email for two-factor authentication – you can choose that. As a workaround, add secondary email for two-factor authentication.
  • Some phones might spend a long time in the post update migration experience – just let the phone sit and it should complete this migration.
  • Apps that use background audio such as Groove, Podcast, Pandora, etc. will crash when launching after receiving an app update from the Store. Rebooting the device will resolve this issue.
  • Some phones with a large number of tiles pinned to the Start screen may get stuck in a state where the device shows “Loading…”; the device will need to be reset or rolled back to Windows Phone 8.1 using Windows Phone Recovery Tool.
  • Some apps may fail to update through the Store with the error code 0x80073cf9; uninstalling the application and reinstalling it will resolve this issue.
  • The Movies & TV app will not work in this build (video playback is currently broken).
...κατεβαίνει ήδη...
...hard reset πριν & μετά...
Video playback is broken. WTF Microsoft?
...beta testing...
...έτσι κι αλλιώς χρειαζόσουνα ccplayer γιά να παίξουν οι υπότιτλοι...
Hate Me Now Bite Me Later
Παιδιά, την έβαλε κανένας..? Εμένα τώρα ξεκίνησε το download μετά απο 20λεπτά περίπου. Με αγχώνει λίγο το mobile hotspot που δεν έχει αλλά δεν πειράζει..!
SE k700i - w810i, NOKIA 5310 express music, HTC TynII (Kaiser), SE Xperia mini, Google Nexus S, Nokia Lumia 930, HTC One M8 (Gunmetal Gray), MS Lumia 950 XL White, HTC 10, LG G6, Samsung Galaxy S9
εμενα τοση ωρα κατεβαζε την προηγουμενη...οποτε αναγκαστικα εγκαταστω την 166 και παω μετα για την αλλη...οτι να ναι
απο οτι διαβασα τελικα ετσι πρεπει να γινει σε αυτους που πανε απο την 8.1 αναγκαστικα.
Edited by Chef_George_
Όταν λέμε mobile hotspot εννοούμε ότι δεν μπορούμε να μπαίνουμε internet απο τον παροχο μας η δεν μπορούμε να χρησιμοποιήσει άλλος το mobile hot spot μας:D
Το δεύτερο.. ;)
Το δεύτερο.. ;)
Ωραίος οποτε να την βάλουμε την 10 technical ;Την είχα βάλει στο 640 xl αλλά μου είπαν ότι μπορεί να χαλάσει το κινητό και την έβγαλα.Ισχύει κάτι τέτοιο;
Ε, όχι να χαλάσει δε νομίζω. Απλά μπορεί να μην είναι τόσο λειτουργικό όσο τα 8.1! Σε κάθε περίπτωση θέλει προσοχή, αλλά το σημαντικότερο είναι αυτό: Ότι ενδέχεται να είναι ασταθές και να χρειαστεί να ξαναγυρίσεις στα 8.1, αν δεν σου αρέσουν!
Το να γυρίσεις είναι το ποιο εύκολο αν και εγώ γύρισα στα 8.1 στο XL που είχα γιατί φοβήθηκα μην πάθει κάτι το κινητό μου άρεσαν πολύ τα 10
Αύριο παιδιά γράψτε όσοι την βάλατε εντυπώσεις.ειμαι σίγουρος ότι σήμερα βράδυ θα την ξεσκονισετε την έκδοση καλα
Μόλις τελείωσα και το hard reset μετά την αναβάθμιση. Πρώτη εντύπωση: πολύ γρήγορο και πολύ πιο άμεσο..! :D
Εμένα μετά από μια επανεκκίνηση μάγκωσε και δεν βλέπει την sd.
Του έκανα 3-4 soft reset αλλα τίποτα.
Βαριέμαι πάλι hard..
Ok την πέρασα και εγώ..Μια χαρά φαίνεται..Να ρωτήσω μήπως κάποιος γνωρίζει,όταν κατεβάσω το action bar το notification της ώρας αναστολής ειδοποιήσεων είναι αναμμένο και αναβοσβήνει το μισοφέγγαρο που έχει μέσα..Πως μπορώ να το απενεργοποιήσω αυτό??
Και μένα το κάνει αυτό. Λογικά μόλις θα "κάτσει" θα σβήσει. Αλλά δεν είμαι σίγουρος..!
Ρε παιδιά πια κατεβάζετε την fast h την slow??
Την επιλογή fast θα διαλέξεις αν θέλεις να περάσεις την έκδοση που βγήκε σήμερα.
Κάπου είχα δει πώς μπορούμε να φορτίσουμε με το τηλέφωνο κλειστό..Ισχύει?Γιατί στο δικό μου δεν γίνεται..
Μάλλον δεν γίνεται σε αυτήν την έκδοση.
έχω θέμα με το double tap. Δε μου κατεβάζει απο το store το touch και δεν μπορώ να το ενεργοποιήσω. Θα το αφήσω όλο το βράδυ σήμερα και βλέπουμε..!
Ας ελπίσουμε ότι στην επίσημη έκδοση δε θα ενεργοποιήτε κατά τη φόρτιση!
και εμενα μια χαρα φαινεται να τα πηγαινει μεχρι στιγμης και χωρις hard reset. σιγουρα θελει πολυ δουλεια ακομη.
αλλα εμενα μεχρι στιγμης μου φαινεται λειτουργικο αυτο το build. βεβαια ειναι νωρις ακομα...ας το δουλεψουμε παραπανω
O Gabe είπε είναι θέμα hardware και όχι os
Το έβαλα και εγώ και στις δυο συσκευές μου σήμερα θα δούμε αυτονομία και υπερθέρμανση
Ως τώρα πολύ καλό και το store επιτέλους ανοίγει σε λογικό χρονο..
Κωνσταντινος
WP7 Developer : Errorholic Developers
APPS: EZInput 2.0 Greek
TyTNii Rom:AthineOS: WM6.1 , WM6.5 , WM6.5.1 | Rhodium Rom:AthineOS: WM6.1 , WM6.5 , WM6.5.5 | LEO ROM:AthineOS: WM6.5 , WM6.5.5\
Με το Hard reset, σβήνει τα πάντα, σωστά?
1998 - 2015: Πάνω από 50 συσκευές, ουτε θυμάμαι ποιες... 2015: Nokia Lumia 930, 2016: Samsung S6 Edge Plus, 2017: LG G6, Sony Xperia XA1 Ultra, 2018: Xiaomi Mi A1, Samsung Note 8, 2019: Samsung Note 10 Plus
2023: Moving to IOS, iPhone 14 Pro Max, 2024: iPhone 15 Pro Max, 2025: iPhone 16 Pro Max
