[Επίσημο] Nokia N97
Itchrist86
σε ενα γνωστο η σε ενα hot spot θα κανεις την δουλεια σου
ευχαριστω φιλε μ να σαι καλα.αυτο θα κανω.για καμια θηκη σιλικονης εχετε να προτεινετε τπτ?π
θα βρουμε?
  • Απαντήσεις 4χιλ.
Είμαι σίγουρος πως όλο και κάτι θα βρεις στο Αξεσουάρ (memory cards, hands free & άλλα).
Repair Instruction
GPS Perfomance Improvement
2. Introduction
There are some complaints from field that GPS performance of N97 is not satisfied. There are many root causes for them. From hardware point of view, program found an improvement measure. Bigger camera cushion improves GPS performance by 2~4 dBm. This bulletin is to give instruction for this issue.
3. Identification of fault or service case
Symptom: 4213 Cellular access: No GPS connection
Symptom: 4214 Cellular access: Drops GPS connection
4. Parts or assemblies affected
Affected part:
Item code /CCT Part Number Part Description Version
I0203 02693L4 CAMERA ASSY
- 9405314 SHIELD FRAME CUSHION
5. Repair solution and procedure
Bigger camera cushion is implemented in camera assy as a running change. On the other hand, it can be ordered as individual spare part. When N97 device is returned due to above symptom, repair center should disassemble the device and check camera assy. Below are pictures for old and new camera assy.
If device has new camera cushion already, do not change any part. Follow normal repair instruction for GPS.
If device has old camera cushion, remove the cushion by tweezers or other tools. Clean the surface of camera assy by alcohol. Put new camera cushion on it.
6. Other service information or procedures
After above repair, GPS testing should be done as usual. If test fails, device should be sent to L3 for troubleshooting.
This service bulletin only applies to GPS complaint symptom.
Προσωπικα θεωρω το παραπανω ενα απο τα πιο σημαντικα αρθρα που εχω διαβασει τον τελευταιο καιρο σχετικα με το GPS του Ν97. Μεχρι τωρα σε οποιον ρωτουσε σχετικα, δινοταν η απαντηση πως οι γνωμες διιστανται για το αν φταιει το υλικο η το λογισμικο που σε μια αναβαθμιση θα διορθωθει. Στην ουσια θεωρουσαμε αδυνατο για την Νοκια να εχει κανει τετοια πατατα σε ενα απο τα πιο σημαντικα θεματα της ναυαρχιδας της και ευχομαστε να ειναι θεμα λογισμικου που θα λυθει με αναβαθμιση.
Πλεον ομολογειται καθαρα πως υπαρχει τουλαχιστον θεμα υλικου. Δεν καταλαβα δυστυχως σε τι βαθος βρισκεται αυτο το "μαξιλαρι", για να μπορεσουμε να διαπιστωσουμε μονοι μας ποιο "φοραμε". Πιστευω οτι συντομα ισως κυκλοφορησει καποιο βιντεο που θα δειχνει τον τροπο, αντιστοιχο εκεινου με το συρματακι. Ακομη δυσκολευομαι να πιστεψω την βελτιωση των 2-4 dbm που επερχονται με την αλλαγη του "μαξιλαριου".
Μετα το πρωτο θεμα με την αλλαγη του καπακιου της καμερας ειναι το δευτερο θεμα που παρουσιαζεται στο ιδιο σημειο.Αραγε εκει ειναι η αχιλειος πτερνα της συσκευης ?
Τελος θεωρω πως ανταξιο μιας εταιρειας του επιπεδου που θελει να βρισκεται η Νοκια, θα ηταν να γνωριζει ηδη ποια s/n εχουν τον συγκεκριμμενο εξοπλισμο και ποια χρειαζονται την αλλαγη και να ενημερωσει καταλληλα τα service points της, ετσι ωστε να μην χρειαζεται να ψαχνομαστε ολοι μας μονοι μας.
Γ Ι Ω Ρ Γ Ο Σ
Υπάρχει τρόπος να γίνει soft reset στο κινητό ;
soft reset νοειται καθε φορα που κανεις επανεκκινηση. Ειτε μεσω του πληκτρου on/off ειτε μεσω συγκεκριμενου προγραμματος.
Γ Ι Ω Ρ Γ Ο Σ
φανταζεσε τι προκειται να γινει αν υπαρξει εντολη να τα παμε για δωρεαν επιδιορθωση? ειναι εφιαλτικο το σεναριο. θα χρειαστει να περιμενουμε ενας θεος ξερει ποσο καιρο.
Διαβάστε πριν ρωτήσετε: S60 5th Edition Platform FAQ
http://www.myphone.gr/forum/showthread.php?p=2651205#post2651205
Εχει παρατηρησει κανεις οτι οταν ανοιγεις της φωτογραφιες απο το προεγκατεστημενο προγραμμα της συσκευης δεν τις διχνει καλα?? Εκανα μια συγκριση αναμεσα σε αυτο και στο nokia photo browser και το δευτερο τις εδειχνε πολυ πιο καθαρες, ενω το πρωτο τις εδειχνε με λιγο ποιο θολες , σαν να μην τις ειχε φορτσωση καλα......
αν περιμενεις λιγη ωρα, θα αρχισει να τις δειχνει καλυτερα.
Σκέφτομαι κι εγώ να πάρω το n97. Σε σχέση με το ν95 8GB τραβάει καλύτερης ποιότητας φωτογραφίες και βίντεο;
Καλημερα σε ολους:)
Αντιμετοπιζω ενα μαλλον σοβαρο προβλημα και δεν ειμαι βεβαιος οτι γνωριζω την λυση οποτε ζητω την γνωμη σας.....
Το προβλημα μου ειναι πως απο τοτε που το ν97 ειναι το καθημερινο μου τηλεφωνο,εχω πολυ μεγαλες χρεωσεις σε ογκο δεδομενον απο την εταιρια κινητης,με αποτελεσμα να εχω εδω και 2 μηνες τεραστιους λογαριασμους! Το περιεργο ειναι πως δεν κανω ιδιαιτερη χρηση του ιντερνετ μεσω του παροχεα μου (wind internet) η τουλαχιστον οχι τοσο οσο να δικαιολογουντε λογαριασμοι 350 ευρω....!!!:(:wacko:
Το μονο widget που δουλευα ηταν το AccuWether αλλα και αυτο με πολυ προσοχη και παντα με χρηση wifi και ποτε συνδεση παροχεα! Μαλιστα προσεχα μετα τον πρωτο φουσκομμενο λογαριασμο να εχω παντα την ''οθονη αναμονης'' ΕΚΤΟΣ συνδεσης ωστε να μη συνδεετε χωρις την ''αδεια μου'' (η τουλαχιστον ετσι νομιζα....)!!
Εχω σκεφτει να κανω παραπονα στην εταιρια κινητης για τα ποσα αλλα ειμαι πολυ επιφυλακτικος καθως πιστευω πως το προβλημα ειναι το τηλεφωνο και η wind αφου ουδεποτε ειχα τετοια προβληματα στο παρελθον!
Ζητω συγνωμη αν σας κουρασα αλλα θα ηθελα τα ''φωτα'' σας! Αισθανομαι ανοητος καθως δεν ειναι η πρωτη φορα που δουλευω με smartphones ειναι ομως η πρωτη φορα που αντιμετοπιζω κατι αναλογο! Τι ακριβως κανω λαθος?:O
Δεν θα ηθελα να διαγραψω το σημειο προσβασης ''wind internet'' απο το τηλεφωνο (αφου μου ειναι πολυ χρησιμο) και αυτο που εχω κανει ειναι να το εχω ως 4 στην λιστα με τις συνδεσεις! Με ''εξασφαλιζει'' αυτο? Επισης να σας πω πως ποτε δεν εχει τυχει να δω το τηλεφωνο συνδεδεμενο χωρις λογο...και επισης η χρηση που κανω στους χαρτες η οποιαδηποτε αλλη εφαρμογη θελει ιντερνετ γινεται μεσω ασυρματου δυκτιου η εν πασει περιπτωσει δεν ειναι τετοια ωστε να δικαιολογει τα παραπανω!
Ζητω την γνωμη και την βοηθεια σας....
Και παλι συγνωμη για το μεγεθος του μηνυματος μου!:rolleyes:
Η χρεωση ειναι πααααρα πολυ μεγαλη αν δεν εχεις καποιο προγραμμα για δωρεαν ογκο wind internet... Κι αφου η συσκευη ειναι αχρηστη χωρις ιντερνετ θα σου προτινα να βαλεις με παγια χρεωση 4 ή 8 €/μηνα, 40 ή 120ΜΒ αντιστοιχα ή και περισσοτερο και να τσεκαρεις τη χρηση απο το μητρωο αφου το εχεις μηδενησει τη μερα που βγαζεις λογαριασμο και υπολογιζοντας την αναλογια των ΜΒ τον πρωτο μηνα που θα το ενεργοποιησεις... Αλλιως θα δεις και πολυ μεγαλυτερα ποσα.. Εγω εχω προγραμμα με 500ΜΒ το μηνα για να μαι σιγουρος ;-)
Μετα απο hard reset (ή το εκανα εγω καταλαθος) εχασα το προγραμματακι που ανοιγε το YouTube που ηταν προεγκατεστημενο στη συσκευη. Βρηκα μια εκδοση 2.2.17 που λογικα ειναι η πιο νεα, αλλα δε νομιζω πως ειναι καλυτερη απο την προεγκατεστημενη, καθως η τελευταια ειχε απολυτο fullscreen (εμφανιζοταν καλυτερα το play, << , >> ) και επισης εχω την εντυπωση πως εδινε και δυνατοτητα download του βιντεο. Ξερει κανεις πια εκδοση ειναι, ειναι σε μορφη widset (δεν το βρισκω στο Ovi)?
παιδια σορυ αλλα ολα αυτα ειναι μεγαλα ρεζιλια για μενα.....
ειδικα για μια συσκευη που κοστίζει τοσο πολυ........
πο πο πο πο καλα που ειναι το φορουμ......
θα βαρουσα το κεφαλι μου στον τοίχο τωρα αν την ειχα αγορασει...!!!!!!!!!!!!!!!!
Όχι Μιχάλη, θα διατεθεί και στην Ελλάδα για Ν97-1 (RM-505) η νέα V 12.0.026, ήδη έπρεπε να διατίθεται από 10/09/2009.
Παρακάτω το επίσημο readme:
"12.0.026 is the official PR1.2 release for new production units and for care.
PR1 user who upgrades to PR1.2 via NSU/FOTA will need to upgrade Mail for Exchange through SW updates in applications folder, and widgets through Ovi store (Facebook, Accuweather, etc.) separately
Previous 12.0.024 release is already available via NSU & FOTA, but 12.0.026 provides more compatibility for HW components to increase production capabilities. All other features and functionalities are same.
For all returned devices, 12.0.026 should be reflashed as latest PR1.2 SW."
Repair Instruction
2. Introduction
Affected part:
φιλε μου αυτη η οδηγια εχει ερθει επισημα και και στην νοκια ελλαδας?,δηλαδη αν το παω θα μου το αλλαξουν?
δεν υπαρχει ακομα κατι το επισημο. αναμενουμε
Σχεδόν όλοι παραδέχονται ότι το βράδυ με φλας βγάζει χειρότερες φωτογραφίες λόγω της κακής θέσης του LED.
παιδια τι να λεμε τωρα το κινητο ειναι πολυ καλο.εγω προσωπικα δεν εχω κανενα προβλημα με το κινητο.ξερουμε ποτε θα ρθει η αναβαθμιση v20 στην ελλαδα?
Ποια Ελλάδα...
Η συγκεκριμένη έκδοση λογισμικού δεν έχει κυκλοφορήσει πουθενά.
Βιάζεσαι.
Ποια Ελλάδα...
Βιάζεσαι.
το γνωριζω οτι δεν εχει κυκλοφορησει πουθενα και αυτο ρωταω.μηπως ξερετε ποτε θα κυκλοφορησει?αρχες οκτομβρη?
παιδια το gps ειναι δωρεαν?εγω μια φορα μπικα στους χαρετες να βρω τοποθεσια και με χρεωσε 0 ευρω απο την καρτα
Καλησπέρα έχω το n97 και αναρωτιόμουν μήπως υπάρχει άλλος τρόπος ξεκλειδώματος έκτος από τα πλάγια γιατί το φοβάμαι το κουμπάκι μην τα παίξει ?
Δεν ξέρουμε...
http://www.myphone.gr/forum/showthread.php?p=2651194#post2651194
Ναι αμέ! Με την εφαρμογή MyKeyLock, που είναι και δωρέαν, θα μπορείς να ορίσεις εσύ συνδυασμό πλήκτρων για κλείδωμα και ξεκλείδωμα. Το χρησιμοποιώ 1 μήνα τώρα και δεν είχα κανένα πρόβλημα! :)
It only ends once. Anything that happens before that is just progress.
Εγω οτν πηρα το iPhone 3g ενθουσιαστηκα,αλλα μετα απο λιγο καταλαβα ποσα πραγματα κανει το Ν80 μου και τα θεωρω αυτονοητα που το iPhone δεν κανει.
Οσο για το Ν97 επειδη την εχω πατησει στο παρελθον απλα περιμενω να νεες παρτιδες που ειναι βελτιωμενες και θυμαμαι να γινετε αυτο απο την εποχη που ειχα 6260 οι πρωτες παρτιδες ολο καποιο κουσουρι ειχαν.
Εδω εχουν κουσουραι οι απλ συσκευες που η απλ βγαζει μονο μια συσκευη χαχαχαχαχ
καλησπερα σε ολους! εχω και εγω το Ν 97 και πριν λιγο εκανα αναβαθμιση του λογισμικου,δεν προλαβε ομως να τελειωσει γιατι επεσε η γραμμη.Απο τοτε το τηλεφωνο δεν ανοιγει.Εβγαλα την μπαταρια και την ξαναεβαλα αλλα τιποτε!Ειναι εντελως νεκρο.Τι να κανω? Σας παρακαλω βοηθηστε αν ξερεται
Δοκίμασε να κάνεις hard format. Φυσικά θα χάσεις τα πάντα από τη μνήμη της συσκευής, αλλά δυστυχώς δεν έχεις εναλλακτικές.
Αν δεν καταφέρεις κάτι, πήγαινε σε Nokia Shop.
ενταξει αλλα πως θα γινει αυτο αφου δεν ανοιγει καθολου η συσκευη?
