odigon Δημ. August 25, 2010 Δημ. August 25, 2010 Βρήκα αυτό. Αν κάποιος το έχει δοκιμάσει ας επιβεβαιώσει... :happy: So, you installed froyo 2.2 on your Nexus One but you are unable to save apps2sd eh? Easy! Download and install sdk files with the adb tool from Google's Developer website and run command prompt and navigate to android-sdk/tools and type in the following command while your phone is connected by usb (not mounted). > adb devices if you see a serial number starting with an "H" that means you got things working, now do the following: > adb shell pm setInstallLocation 2 This command will push ALL apps to your sd card, to revert back to saving apps to internal memory enter in: > adb shell pm setInstallLocation 0 " Phillips Diga-->Panasonic GD52-->Motorola C33-->Nokia 5210-->Nokia 6600-->HP iPaq 6515-->HP iPaq 6915-->Fujitsu Siemens T830-->HTC TyTn-->Nokia 6110 Nav-->Samsung i900 Omnia-->Nokia 5800XM-->Samsung Omnia i8910 HD-->HTC Hero-->Samsung i900 Omnia(again)-->HTC HD2 Leo-->HTC Desire-->Samsung Galaxy S2 i9100 --> :X
georgemv Δημ. August 26, 2010 Δημ. August 26, 2010 Βρήκα αυτό. Αν κάποιος το έχει δοκιμάσει ας επιβεβαιώσει... :happy: So, you installed froyo 2.2 on your Nexus One but you are unable to save apps2sd eh? Easy! Download and install sdk files with the adb tool from Google's Developer website and run command prompt and navigate to android-sdk/tools and type in the following command while your phone is connected by usb (not mounted). > adb devices if you see a serial number starting with an "H" that means you got things working, now do the following: > adb shell pm setInstallLocation 2 This command will push ALL apps to your sd card, to revert back to saving apps to internal memory enter in: > adb shell pm setInstallLocation 0 " Αν το κάνεις αυτό τότε όλα τα widgets θα εξαφανιστούν στο επόμενο reboot.
EverGreen13 Δημ. August 26, 2010 Δημ. August 26, 2010 Μετά από πολύ σκέψη αποφάσισα να πάρω το desire αντί για το wildfire κυρίως λόγω οθόνης και ανάλυσής. Ελπίζω να αξίζει τα παραπάνω λεφτά. Το βρήκα σε αυτό το σαιτ με όνομα HTC A8181 Desire GR. Δεν μπορώ να βρω τι σημαίνει το A8181. Είναι το κανονικό desire ή μήπως καμία άλλη έκδοση;
Nikos_s3 Δημ. August 26, 2010 Δημ. August 26, 2010 αυτό είναι, απλά έχουν προσθέσει και τον κωδικό της συσκευής..:)
David Δημ. August 26, 2010 Δημ. August 26, 2010 (edited) Καλησπέρα παιδιά. 1. Έχω πρόβλημα χώρου και στη Froyo. Δεν μου βγάζει σε παρά πολλά προγράμματα επιλογή για να μεταφέρω το πρόγραμμα στην sd... Υπάρχει κάποια λύση γιαυτό; 2. Υπάρχει κάποιο widget το οποίο να κλείνει και να ανοίγει το 3G για να εξοικονομώ μπαταρία; 1. Ακολούθησε αυτές τις οδηγίες http://www.lorinbute.com/posts/how-to-force-apps-to-move-to-the-sd-card-on-froyo.html. Ειναι μια μέση λύση. Για να κάνεις σωστή δουλειά θες root ROM με Αpp2SD+ και ΕΧΤ3 partition στην κάρτα. 2. Υπάρχουν widgets που σε πανε απευθειας στην οθόνη ρυθμίσεων του 2G/3G για να γλιτώνεις μερικά κλικς. Αυτόματα δυστυχώς δεν γίνεται. Εγω το έχω πάντα στο 2G, και λίγο πριν ανοίξω το ιντερνετ (απο το αντίστοιχο widget) το βάζω στο 3G. Αν το κάνεις αυτό τότε όλα τα widgets θα εξαφανιστούν στο επόμενο reboot. Θα εξαφανιστούν τα widgets που "βλέπουν" εφαρμογές στην μνήμη, και μονο αν οι εφαρμογές αυτές μεταφερθούν απο τον χρήστη στην SD. Αν το κάνει δεν θα δει καμία αλλαγή πριν αρχίσει να μεταφέρει εφαρμογές. Πάντως, καλό ειναι οι εφαρμογές που τρέχουν συνέχεια (handcect sms, gmail counter κλπ) και που έχουν widgets ενεργα, να εγκαθίστανται στην κάρτα, γιατι όποτε συνδέετε το κινητο στο pc ως "αφαιρούμενη συσκευή", γίνεται ένα μπάχαλο. Βρήκα αυτό. Αν κάποιος το έχει δοκιμάσει ας επιβεβαιώσει... :happy: So, you installed froyo 2.2 on your Nexus One but you are unable to save apps2sd eh? Easy! Download and install sdk files with the adb tool from Google's Developer website and run command prompt and navigate to android-sdk/tools and type in the following command while your phone is connected by usb (not mounted). > adb devices if you see a serial number starting with an "H" that means you got things working, now do the following: > adb shell pm setInstallLocation 2 This command will push ALL apps to your sd card, to revert back to saving apps to internal memory enter in: > adb shell pm setInstallLocation 0 " Δουλευει μια χαρά. Αλλα μη περιμένεις σπουδαία αποτελέσματα. Βαζει μονο ένα μέρος της εφαρμογής στην κάρτα. Ειναι μια λύση παντως... Edited August 26, 2010 by Nikos_s3 HTC Desire Root User
icatalan81 Δημ. August 26, 2010 Δημ. August 26, 2010 Μετά από πολύ σκέψη αποφάσισα να πάρω το desire αντί για το wildfire κυρίως λόγω οθόνης και ανάλυσής. Ελπίζω να αξίζει τα παραπάνω λεφτά. Το βρήκα σε αυτό το σαιτ με όνομα HTC A8181 Desire GR. Δεν μπορώ να βρω τι σημαίνει το A8181. Είναι το κανονικό desire ή μήπως καμία άλλη έκδοση; Το Α8181 ειναι ο κωδικος της συσκευης. Σε ολα τα desire πανω στο κουτι βρισκεις αυτον τον κωδικο. Μην ανησυχεις το κανονικο ειναι. Sent from my HTC Desire using Tapatalk
tpelek Δημ. August 26, 2010 Δημ. August 26, 2010 Μετά από αρκετό καιρό πραγματικής χρήσης του κινητού και όχι πειραματισμών με εφαρμογές κτλ. εχω κάποιες απορίες : 1) Πολλές φορές κάνοντας μία ενέργεια εμφανίζει ένα popup για να διαλέξεις με ποια εφαρμογή να εκτελέσει αυτό που θες, πχ να χρησιμοποιήσει τον δικό του browser ή τον Dolphin, να στείλεις μήνυμα με την δικιά του εφαρμογή ή το Handcent SMS , η ποιο file manager να χρησιμοποιήσεις. σε αυτό το μενού μπορείς να τσεκάρεις να κάνει σαν προεπιλογή αυτό που θα διαλέξεις εκείνη την στιγμή. Αν θές να αλλάξεις αυτήν την επιλογή αργότερα ή θέλεις να ξανά εμφανίζεται το popup πως το κάνεις; 2) Τράβηξα 5 φωτογραφίες και ήθελα να της στείλω με e-mail ή στο dropbox, δεν βρήκα όμως πως μπορώ να της στείλω με μία κίνηση και τις 5, μόνο μία μία μπορούσα να της βάλω σαν attachment, και με το Astro file manager αν επιλέξω πολλές και κρατήσω πατημένο στην τελευταία και επιλέξω από στολή με μαιλ βάζει μόνο αυτήν σαν συνημμένο και όχι όσες έχω επιλέξει. Δεν ξέρω αν είναι θέμα της HTC ή του Android, το scrolling πρέπει να γίνει ποιο smooth, όχι μόνο στην σελίδα με τα applicatios αλλά γενικά σε αρκετά μενού που θέλουν scrolling. είναι κρίμα α βλέπεις ένα τόσο καλό κινητό να χάνει frames, κάνει κακή εντύπωση σε όσους δεν ξέρουν τις δυνατότητες του.
jastonas Δημ. August 26, 2010 Δημ. August 26, 2010 παιδια βοηθεια ξαφνικα το κινητο τρελθηκε και τωρα ανοιγει μονο του και μενει στην ασπρη οθονη με το σημα της htc και δεν προχωραει. πριν γινει αυτο μου εμφανισε μια εικονα ενα μικρο αυτοκινητο στο bar Που ειναι το ρολοι ξερετε τι ειναι? πως κανουμε hard reset? τι έκανες τελικά; Δοκίμασες να βγάλεις μπαταρία και sd για λίγο και μετά ξανά reboot? Ή άνοιγμα κινητού χωρίς την sd..? Recovery image έχεις στο κινητό; Κατηγοριοποιημένη λίστα εφαρμογών Android, Ορολογία Android, Οδηγοί και forum για το Android
than_007 Δημ. August 26, 2010 Δημ. August 26, 2010 Μετά από αρκετό καιρό πραγματικής χρήσης του κινητού και όχι πειραματισμών με εφαρμογές κτλ. εχω κάποιες απορίες : 1) Πολλές φορές κάνοντας μία ενέργεια εμφανίζει ένα popup για να διαλέξεις με ποια εφαρμογή να εκτελέσει αυτό που θες, πχ να χρησιμοποιήσει τον δικό του browser ή τον Dolphin, να στείλεις μήνυμα με την δικιά του εφαρμογή ή το Handcent SMS , η ποιο file manager να χρησιμοποιήσεις. σε αυτό το μενού μπορείς να τσεκάρεις να κάνει σαν προεπιλογή αυτό που θα διαλέξεις εκείνη την στιγμή. Αν θές να αλλάξεις αυτήν την επιλογή αργότερα ή θέλεις να ξανά εμφανίζεται το popup πως το κάνεις; Αυτό έψαχνα και εγώ σήμερα;
toon Δημ. August 26, 2010 Δημ. August 26, 2010 Μετά από αρκετό καιρό πραγματικής χρήσης του κινητού και όχι πειραματισμών με εφαρμογές κτλ. εχω κάποιες απορίες : 1) Πολλές φορές κάνοντας μία ενέργεια εμφανίζει ένα popup για να διαλέξεις με ποια εφαρμογή να εκτελέσει αυτό που θες, πχ να χρησιμοποιήσει τον δικό του browser ή τον Dolphin, να στείλεις μήνυμα με την δικιά του εφαρμογή ή το Handcent SMS , η ποιο file manager να χρησιμοποιήσεις. σε αυτό το μενού μπορείς να τσεκάρεις να κάνει σαν προεπιλογή αυτό που θα διαλέξεις εκείνη την στιγμή. Αν θές να αλλάξεις αυτήν την επιλογή αργότερα ή θέλεις να ξανά εμφανίζεται το popup πως το κάνεις; . Ρυθμίσεις-Εφαρμογές-Διαχείριση εφαρμογών-εφαρμογή που έχεις σαν προεπιλογή - πατάς το κουμπί που γράφει "Εκκαθάριση προεπιλογών" έτσι σου ξαναεμφανίζεται το pop-up. ΑΕΚ, whiskey και Iron Maiden δίσκοι.
john1975 Δημ. August 26, 2010 Δημ. August 26, 2010 Καλημέρα θέλω να ρωτήσω αν κάποιος έχει Bluetooth με LCD και μπορεί όταν τον καλούν να βλέπει το όνομα (Αγγλικά) και όχι τον αριθμό. Έχω αγοράσει το sony ericsson mw 600. Ευχαριστώ.
maxximilian Δημ. August 26, 2010 Δημ. August 26, 2010 Επειδή είμαι κοντά στην αγορά του κινητού, αυτά που αναφέρονται στο update log της froyo ισχύουν? Δηλαδή: - Flash στον browser? - HD recording? - Ταχύτητα κινητού? - Wi-Fi tethering?
jpsih Δημ. August 26, 2010 Δημ. August 26, 2010 ισχυουν ολα αν και το hd recording γινεται με χαμηλο fps...
odigon Δημ. August 26, 2010 Δημ. August 26, 2010 Επειδή είμαι κοντά στην αγορά του κινητού, αυτά που αναφέρονται στο update log της froyo ισχύουν? Δηλαδή: - Flash στον browser? - HD recording? - Ταχύτητα κινητού? - Wi-Fi tethering? -Ναι έχει. -Ναι αν και οταν πας να δεις το video στο κινητό κολλάει λίγο αλλά λογικά στο εππομένο update θα λυθεί. Αν τα παίξεις τα βίντεο στο pc δεν κολλάνε φυσικά. -Εκπληκτική για μένα. Δεν κολλάει με τίποτα και 10 εφραμογές να έχεις ανοιχτές. -Ναι και έχει και πρόγραμμα μέσα από μόνο του, το wifi-hotspot. Phillips Diga-->Panasonic GD52-->Motorola C33-->Nokia 5210-->Nokia 6600-->HP iPaq 6515-->HP iPaq 6915-->Fujitsu Siemens T830-->HTC TyTn-->Nokia 6110 Nav-->Samsung i900 Omnia-->Nokia 5800XM-->Samsung Omnia i8910 HD-->HTC Hero-->Samsung i900 Omnia(again)-->HTC HD2 Leo-->HTC Desire-->Samsung Galaxy S2 i9100 --> :X
jastonas Δημ. August 26, 2010 Δημ. August 26, 2010 Αφού το hd recording γίνεται στα 15fps... κολλάει όπου και να το δεις! Τα 15 fps δεν είναι για να τραβάς βίντεο... Είμαι μεγάλος υποστηρικτής του desire αλλά και το 800χ480 νομίζω καλό είναι... ειδικά αν έχει καλά fps Κατηγοριοποιημένη λίστα εφαρμογών Android, Ορολογία Android, Οδηγοί και forum για το Android
tasgr86 Δημ. August 26, 2010 Δημ. August 26, 2010 Δε λέει το 720p στο desire.Καλύτερα να χρησιμοποιείς 480p [sIGPIC][/sIGPIC]
nnik_1969 Δημ. August 26, 2010 Δημ. August 26, 2010 Αφού το hd recording γίνεται στα 15fps... κολλάει όπου και να το δεις! Τα 15 fps δεν είναι για να τραβάς βίντεο... Είμαι μεγάλος υποστηρικτής του desire αλλά και το 800χ480 νομίζω καλό είναι... ειδικά αν έχει καλά fps Συμφωνώ απολύτως. Τύχη είναι, όταν η ικανότητα συναντά την ευκαιρία Για αποφυγή παρεξηγήσεων το όνομά μου είναι Αντώνης
PRATINAS Δημ. August 26, 2010 Δημ. August 26, 2010 Πρόβλημα... Το καπάκι δεν εφαρμόζει καλά πίσω. Πιο συγκεκριμένα απο την πλευρα που είναι τα κουμπιά στα πλάγια, υπάρχει κάτι σαν "φούσκωμα" και αυτό έχει σαν συνέπεια να μην εφαρμόζει σωστά το πίσω κάλυμα. (να κάνει στα πλάγια μια μικρή καμπύλη η συσκευή.) Τούμπα δεν έχει φάει, το έχω στα "ώπα - ώπα" το κινητό. Τι μπορεί να συμβαίνει? Διορθώνεται? :cry:
georgemv Δημ. August 26, 2010 Δημ. August 26, 2010 Συμφωνώ απολύτως. Στις custom ROMs το βίντεο είναι πλέον 24fps, οπότε πιθανόν να έρθει και στην επίσημη ROM. Επίσης, εάν θέλετε 720p καλό θα είναι να αγοράσετε μια class 6 ή και μεγαλύτερης κλάσης microSD, στις περισσότερες περιπτώσεις δεν προλαβαίνει η κάρτα να γράψει...
maxximilian Δημ. August 26, 2010 Δημ. August 26, 2010 AVI με υπότιτλους εξωτερικούς (*.srt) παίζει? MKV? WMV? Συγνώμη που ρωτάω πολλά αλλά μ'αρέσει να το ψάχνω λιγάκι πριν δώσω καμιά 500άρα ευρώ...
nnik_1969 Δημ. August 26, 2010 Δημ. August 26, 2010 AVI με υπότιτλους εξωτερικούς (*.srt) παίζει? MKV? WMV? Συγνώμη που ρωτάω πολλά αλλά μ'αρέσει να το ψάχνω λιγάκι πριν δώσω καμιά 500άρα ευρώ... Ναι.Ο rockplayer πετάει. Τύχη είναι, όταν η ικανότητα συναντά την ευκαιρία Για αποφυγή παρεξηγήσεων το όνομά μου είναι Αντώνης
scream Δημ. August 26, 2010 Δημ. August 26, 2010 Για να κολλήσει όπως λέτε πρέπει το βίντεο να είναι μεγάλης διάρκειας; Γιατί εμένα δεν κολλάει......:D:D
one_tree_hill Δημ. August 26, 2010 Δημ. August 26, 2010 (edited) Γεια σας, Θέλω να αγοράσω το Desire, μιας και εδώ και 2 χρόνια έχω iPhone και το έχω καταβαρεθεί. Android είχα και έφυγα με τις καλύτερες εντυπώσεις. Αυτό που θέλω να ρωτήσω είναι το εξής... Θέλω να βάλω την Cyanogen 6.0.0 RC2 μόλις το πάρω για να βάλω με το MetaMorph ένα θέμα. Μπορώ να το κάνω αν ήδη έχει περασμένη την 2.2; Εννοώ, μπορώ να κάνω root; Κάτι τελευταίο. Σε σύγκριση με το Galaxy S, έχει χτυπητές ελλείψεις; Η οθόνη είναι πιο ζωντανή από του 3GS; Edited August 26, 2010 by one_tree_hill Galaxy S5: Root και αναβάθμιση σε Android 5.0 με Knox 0x0
