eltsele Δημ. August 2, 2010 Δημ. August 2, 2010 Έτσι λειτουργεί. Είσαι σίγουρος ότι το πατάς κανονικά? Μόλις το πετάς μετά από 2 δευτερόλεπτα αρχίζει να μετρά ο χρόνος. Knowledge isn't free. You have to pay attention.
tron13 Δημ. August 2, 2010 Δημ. August 2, 2010 Έτοιμη η νέα έκδοση της ROM μου, για το desire!!! Roufianos.com Desire V2 SUPER SUPER FAST ROOTED | A2SD+ | Full Deodoxed | Optimize Ram | http://3.bp.blogspot.com/_xvQ-TLP7MME/TEmMDcvSigI/AAAAAAAAAMY/umFVDNaLhfw/s320/snapshot.png Special Thanks to 42turkeys,AdamG and iftm Requirements: Latest Radio 32.43.00.32U_5.09.00.20 For a best running of rom should do a Wipe Factory Reset and wipe at ext partirion After the 1st boot make a reboot ITS IMPORTANT (before start installing your apps) Not required: Partition ext2/3/4 wiped (for APP2SD, IF YOU LIKE THE 2.2 A2SD DONT CREATE EXT PARTITION) What you Get: Based on the iftm rom Optimized *.APKs APP2SD (require partition ext) thanks to AdamG (if you think that your desire is slow, maybe thats the error... you haven't ext3 partition) Very fast, Clean & stable Optimizations RAM and active sysctl.conf Added Gallery 3D Nexus One Added Launcher2 original FroYo Added HTC_IME Added HTC_CIME (Chineese IME) WiFi N Deodexed Home switcher (to change the launcher between Sense and Launcer2) ES File Explorer Root Explorer Spare Parts Added Adobe Showcase Supported Languages: Greek, English, Chinese, Arabic, Czech, German, Espanol, French, Italian, Dutch, Polish, Russian, Norwegian, Japanese, Korean, Swedish, Danish, Portuguese, Finnish. Installation: -Enter to recovery, do a Wipe Factory reset, Wipe Cache, Wipe Dalvik, format/wipe partition Ext2/3/4. -Flash my ROM (REQUIRES THE LASTEST RADIO IMAGE, See Requirements) -Run rom (First time takes some time to run) Download: DOWNLOAD LINK HERE http://feeds.feedburner.com/Techwargr.1.gif
M_SAK Δημ. August 2, 2010 Δημ. August 2, 2010 Παιδιά κανείς πρόβλημα με την ταχύτητα των φωτογραφιών αντιμετωπίζει; η επειδή εχω εγώ πολλές αργεί να τις βγάλει; πριν την αναβάθμιση πήγαιναν σφαίρα. Τώρα εχω θέμα..... Sent from my HTC Desire using Tapatalk BMW POWER
cmeletis Δημ. August 2, 2010 Δημ. August 2, 2010 Παιδιά καλημέρα. Τώρα με την αναβάθμιση σε froyo ξέρετε ποσά παράθυρα ανοίγουν στον browser? πριν άνοιγαν μόνο 4!!! Ευχαριστώ.
gassim Δημ. August 2, 2010 Δημ. August 2, 2010 καλημέερα σε ολους, Έκανα την αναβάθμιση κανονικά αλλά δεν βλέπω καμία απο τις αισθητικές αλλαγές που διαβάζω στα forums. Δηλαδή ενώ τα νέα features υπάρχουν κανονικά, δεν έγινε καμία αλλαγή στην home screen ούτε και πουθενά αλλού. Απ ότι διαβάζω υπάρχουν αλλαγές στην κάμερα, στην γκαλερί στον music player κτλ.....εγω τα βλέπω όλα ακριβώς όπως πριν.......
kiloromeomike Δημ. August 2, 2010 Δημ. August 2, 2010 Μια μερα μετα την αναβαθμιση, η κριτική μου θα σταθεί στο 720p της κάμερας. Στην ουσία είναι για να χουμε να λέμε 720p που είναι και της μόδας... γιατί κατα τα άλλα ούτε 720p μοιάζει και το χαμηλότατο frame rate ακυρώνει τα πάντα. Χίλιες φορές να βελτίωναν απλά ποιοτικώς το 800χ480 παρά να δώσουν ενα αχρηστο 720p... Κατα τα άλλα οι εντυπώσεις παραμένουν καλές...
godpanos Δημ. August 2, 2010 Δημ. August 2, 2010 Μετα την αναβαθμηση δεν εχω καταφερει να μου δουλεψει gps προγραμμα .. Ειχα το sygic 10 ... δεν τρεχει καν . Ειχα το Ndrive και τωρα ενω ξεκιναει ... δεν βρισκει gps στιγμα ..( το εχω καν α20 λεπτο και ακομα δεν βρικε σημα ) . Υποψιν οτι το gps test βρισκει κανονικα 9 δορυφορους και κανει use και τους 9 . .............. Μπορω να το γυρισω οπως ήταν πριν ? Αν γινετε ας μου πειτε τον τροπο παρακαλω ... http://www.lafkos.de/Muhle_1.gif Where are you going Karamitro ??
Γιάννης Δημ. August 2, 2010 Δημ. August 2, 2010 Δοκιμασα την app 2 sd για να μεταφερω εφαρμογες απο το κινητο στην sd , αλλα μαλλον λιγες εφαρμογες μου βρηκε και μετεφερα και δεν ξερω σε ποιο σημειο της sd τις πηγε. Φιλικά Γιάννης Μέγιστο μέγεθος εικόνας υπογραφής 420x150 pixels και 16,3KBytes.
nvetsos Δημ. August 2, 2010 Δημ. August 2, 2010 Καλημέρα,προσπαθώ απο χθές να κάνω το update αλλα συνεχίζει να μου λέει οτι δεν υπάρχουν ενημερώσεις.Το κινητό το πήρα πριν 3 μέρες απο Vodafone και δεν το έχω πειράξει.Έχετε καμία ιδέα τι μπορεί να φταίει?
dkaris Δημ. August 2, 2010 Δημ. August 2, 2010 Καλημέρα,προσπαθώ απο χθές να κάνω το update αλλα συνεχίζει να μου λέει οτι δεν υπάρχουν ενημερώσεις.Το κινητό το πήρα πριν 3 μέρες απο Vodafone και δεν το έχω πειράξει.Έχετε καμία ιδέα τι μπορεί να φταίει? Καλημέρα, Έχουν πεί οτι η branded συσκευές θα καθυστερίσουν να πάρουν το update...Μήπως η συσκευή σου μιας και την πήρες απο Vodafone είναι branded; (Το πιο πιθανό)
dkaris Δημ. August 2, 2010 Δημ. August 2, 2010 Καλημέρα, Μετά την αναβάθμιση σε Froyo μου εμφανίστηκε και μια εφαρμογή Πλοήγηση (λέτε να υπήρχε και πρίν και να μην την είχα δει;). Ξέρει κανείς τι είναι αυτό; Μήπως είναι το Google navigation;
nvetsos Δημ. August 2, 2010 Δημ. August 2, 2010 Ξέρω οτι το έχετε γράψει σίγουρα πιο πρίν αλλά για να μην ψάχνω υπάρχει τρόπος να μάθω αν είναι branded?Διάβαζα τόσο καιρό οτι τα Desire που φέρνει η Vodafone δεν είναι branded.
vigilante Δημ. August 2, 2010 Δημ. August 2, 2010 Από τη στιγμή που απαιτεί σύνδεση με το διαδίκτυο το πιο πιθανό είναι πως πρόκειται για το google navigation όπως λες. Trust no one!
Global moderator Δημ. August 2, 2010 Δημ. August 2, 2010 Είναι τελικά νόμος και για την HTC. Δεν υπάρχει περίπτωση να φτιάξουν κάτι χωρίς να χαλάσουν κάτι άλλο. Αυτό το ριμάδι τον συγχρονισμό των contacts με το το fb πόσο δύσκολο είναι να το φτιάξουν? Το έχουν σαν καμάρι τους το Sense αλλά δεν μπορούν να το κάνουν να δουλέψει με τίποτα. Τις φωτογραφίες των επαφών που είχε φωρτώσει όταν τις είχα κάνει asign με το fb πριν κανα 2μήνο τις ίδιες μου εμφανίζει άσχετα αν οι περισσότεροι τις έχουν αλλάξει 10 φορές από τότε. Το έχει παρατηρήσει κάποιος αυτό? Υπάρχει κάποια εφαρμογή που να διαχειριζεται τα Contacts και να τα συγχρονίζει χωρίς πρόβλημα? Επίσης όταν πάω σε μια επαφή και επιλέγω View Facebook profile μου κρασάρει και με πετάει έξω. Το άλλο τρελό είναι όταν ανοίγω την κάμερα. Πλεόν τα δείχνει όλα υπερφωτισμένα σαν να κεντράρω στον ήλιο.. :mad: http://digitalviews.smugmug.com/photos/471912194_RABQF-Th.gif
re33m Δημ. August 2, 2010 Δημ. August 2, 2010 (edited) λοιπον παιδες τελικα το εβαλα και εγω....σε πρωτη φαση να πω την αληθεια περιμενα πιο πολλα αλλα σιγα σιγα που σκαλιζω ανακαλυπτω τις μικροδιαφορες....δεν θυμαμαι τι ειχε ακριβως σε ολα τα μενου αλλα βρισκω καινουργια....εχω μια μικρη επιθυμια αν ειναι ευκολο για να το συμμαζεψουμε για αυτους που τα εχουν 400 και αυτους που δεν θυμουνται: γινεται να παραθεσουμε τι καουνουργιο μπηκε σε αυτη την αναβαθμιση.... ξεκιναω: 1.720p(γραφει video) 2.app2sd 3.wifi hotspot 4.ομορφοτερα εικονιδια(airplane mode,bluetooth,gps,hotspot,profile,ringtone,wi-fi) 5.app sharing(δινει σε καποιον κατι που εχω και δεν εχει αυτος) (δεκτον οτι βρισκει ο καθενας....καθως και επιταγες!!!!!!χιχιχιχιχιχι) Edited August 2, 2010 by re33m
dkaris Δημ. August 2, 2010 Δημ. August 2, 2010 @re33m Θα βρείς εδώ την σχετική πληροφόρηση: http://www.myphone.gr/forum/showthread.php?t=279837 @vigilante Δεν ξέρω αν απαιτεί σύνδεση στο δίκτυο, όταν το ξεκινάω ψάχνει να βρεί δορυφόρους. Προς το παρόν δεν έχω καταφέρει να το δώ να παίζει γιατί δεν έχει βρεί δορυφόρους!!!
bujinkan Δημ. August 2, 2010 Δημ. August 2, 2010 Πρωτο προβληματακι στην Froyo-εποχη. Εχω το smooth calendar widget,ομως μου δειχνει μονο τα γενεθλια απο facebook Ειχα για αυριο μια συναντηση περασμενη στο ημερολογιο Παταω λοιπον ημερολογιο...και η συναντηση εχεο χαθει... Ωραια λεω ας την ξαναπερασω...παταω τριτη(αυριο) ολα καλα....παταω προσθηκη συμβαντος...και εκει κουφαινομαι...βγαζει ενα μυνημα που λεει...δεν εχετε ημερολογια...δεν υπαρχει ημερολογιο:wacko: http://banner.ronin.gr/img/chuck.gif
jpsih Δημ. August 2, 2010 Δημ. August 2, 2010 αφου συμπληρωσα μια μερα με το γιαουρτι εχω παρατηρησει 2 πραγματακια σχετικα με τον browser.. στη φορτωση σελιδων ειναι ακομα πιο γρηγορος (ισως να παιζει ρολο και η βελτιωση ληψης του wifi) ΟΜΩΣ το scrollαρισμα δεν το βρισκω το ιδιο smooth.. καπου ψιλοχανει σε σχεση με την 2.1 ρε γμτ... το εχει διαπιστωσει κανεις αλλος ή ιδεα μου ειναι?
MAD 13 Δημ. August 2, 2010 Δημ. August 2, 2010 Εάν θέλουμε να τερματισουμε μια κλήση ο μόνος τροπος ειναι πατωντας στην οθώνη στο συγκεκριμένο σημείο? Υπαρχει εφαρμογή ή κατι ωστε καποιο απο τα κανονικά κουμπιά (πχ optical trackbal) να τερματιζει κλησεις??
Γιάννης Δημ. August 2, 2010 Δημ. August 2, 2010 Εάν θέλουμε να τερματισουμε μια κλήση ο μόνος τροπος ειναι πατωντας στην οθώνη στο συγκεκριμένο σημείο? Υπαρχει εφαρμογή ή κατι ωστε καποιο απο τα κανονικά κουμπιά (πχ optical trackbal) να τερματιζει κλησεις?? Δυστυχως ουτε για αποδοχη , ουτε για τερματισμο , ουτε για απορριψη κλισης δεν γινεται με τα κατω κουμπια. Φιλικά Γιάννης Μέγιστο μέγεθος εικόνας υπογραφής 420x150 pixels και 16,3KBytes.
obelix0000 Δημ. August 2, 2010 Δημ. August 2, 2010 Ρε παιδια, εχω μια απορία στο συγχρονισμό. Υποτίθεται οτι πρόσθεσαν και τισ Ειδήσεις. Αλλά όταν πάω να το προσθέσω, το ποατάω και δεν κάνει τπτ. Ενώ στα υπόλοιπα, υπάρχει το τσεκαρισμένο πράσινο σηματάκι, οι ειδήσεις δεν παίρνουν χαμπάρι Device: Nexus 5 Rom: PureNexus
coa00gk Δημ. August 2, 2010 Δημ. August 2, 2010 Εχει δει καποιος αισθητικη διαφορα στην γκαλερι στην 2.2? Φανταζομαι δεν μοιαζει με το gallery 3d στο n1.
jastonas Δημ. August 2, 2010 Δημ. August 2, 2010 Έβαλε κανείς κάποια 2.2 που να έχει root και να υποστηρίζει ελληνικά;; Κατά προτίμηση deodexed... Κατηγοριοποιημένη λίστα εφαρμογών Android, Ορολογία Android, Οδηγοί και forum για το Android
Gilles27 Δημ. August 2, 2010 Δημ. August 2, 2010 Όσοι/όσες έχετε εντυπώσεις απο τη διαχείριση της μπαταρίας με το update, αναμένουμε... Και κάτι ακόμη. Τελικά για το root με τη 2.2 τι ισχύει? Σε απλά ελληνικά pls (χωρίς πολλούς τεχνικούς όρους) γιατί δεν έχω προλάβει να το ψαξω... :O Thx in advance :)
vincent_vega Δημ. August 2, 2010 Δημ. August 2, 2010 Βρίσκομαι ένα βήμα πριν από την απόκτηση του htc desire (yaaaay!!). To μοναδικό χαρακτηριστικό του όμως για το οποίο δεν έχω άποψη είναι η διάρκεια της μπαταρίας του. Η τυπική μου χρήση είναι σαν mp3 player/ραδιο και για wifi browsing. Mπορεί κάποιος που το έχει να μου πεί λίγα πράγματα για την μπαταρία του και πόσο διαρκεί με τη χρήση που του κάνει; Με 2-3 ώρες μουσική και καμια ώρα wifi browsing θα βγάζει την ημέρα η θα θέλει φόρτιση το μεσημέρι; Η μπαταρία στο 3gs είναι καλύτερη; Γιατί μόνο αυτό ίσως με κάνει να προτιμήσω το 3gs ενώ πραγματικά δε θέλω. Ευχαριστώ πολυ εκ των προτέρων, οι βοήθειά σας είναι κάθε φορά χρησιμότατη και κατατοπιστικότατη!!!
