Sony Xperia Z3
T-mobile
Άλλο ένα review.
Μπαταρία στα ίδια επίπεδα με Ζ2 λέει αυτό.
Ας λένε ότι θέλουν, εμείς έχουμε alextrela για πραγματικές συγκρίσεις :)
Κοίταξε αυτό που έχει σημασία για εμένα τουλάχιστον είναι η αυτονομία του να είναι στα επίπεδα του z2 που είναι ήδη εξαιρετική
Αν τα καταφέρνει και λίγο παραπάνω καλοδεχούμενο είναι βέβαια.
2 γεμάτες ημέρες να βγάζει αυτό είναι το ζητούμενο και λογικά θα το έχει.
Όσον αφορά αναλυτικότερα την συγκεκριμένη πρόταση πιστεύω ότι το παρακάτω συμπέρασμα ανταποκρίνεται απόλυτα στη συσκευή.
We can't blame Sony for playing it safe. Sometimes risks just don't pay off - the HTC One M8's dual camera and LG G3's battery life among the prominent examples. The company's shorter release cycle is another thing to consider. They had to be careful not to make their ex-flagship obsolete - what if you just bought the Xperia Z2?
OK, recent Z2 adopters will find little to no reason to upgrade. No matter what spin you put on it, it's a bad thing to say about a brand new flagship. Owners of the original Xperia Z and the Z1 are the main target obviously, as well as outsiders.
Here's what they'll be getting:
Top-notch build quality should be no surprise but the improved looks and handling count big time
The display is very bright, with great contrast and superior sunlight legibility
Battery life is excellent even without the rich power-saving options
It has an all-round connectivity package including LTE, USB Host and FM radio
Speaker loudness is Average, likely due to the dust and water-proofing
PS4 Remote play
Benchmark performance is flagship grade
Audio quality is good
Video player handles all the major formats except AC3 and AAC audio and AVC video
Still camera is competitive, but not quite up there with the best of them. 2160p videos come out smooth
Proprietary Album, Movies and Walkman apps
Minor touches on the outside have made the Xperia Z3 the most beautiful smartphone Sony has built to date. The curved sides not only look good but help the handling too. The phone is slimmer and the screen bezel has been reduced. The rubber finish at the edges provides better protection against accidental drops.
Pity the internals received an equally minor upgrade, which simply doesn't make that much of a difference. The quad-core processor is clocked higher at 2.5GHz, the Adreno 330 GPU is a bit faster too. Sony also upped the dust proofing to IP level 6.
This is where the list of new features ends - you get better looks and handling, higher IP rating, and a minor speed boost. A slightly better screen with improved outdoor performance should probably count too.
Και αλλά φρέσκα review που ολα τονίζουν υπεροπλια του στην αυτονομία στα χνάρια του z2 συν τις ουσιαστικές βελτιώσεις που προσφέρει που ανέφερα πάνω.
http://www.stuff.tv/sony/sony-xperia-z3/review
http://www.expertreviews.co.uk/mobile-phones/1401456/sony-xperia-z3-review
Edited by alextrela
  • Απαντήσεις 4,9χιλ.
Για μένα είναι πολύ καλή αναβάθμιση αυτή που έκανε η Sony. Στα σημεία και ουσιαστική.
Το μόνο που με φοβίζει είναι να μην έχουμε υπερθέρμανση μιας και ο επεξεργαστής είναι χρονισμένος πιο ψηλά.
Στο xda διάβασα ότι είναι αρκετά ζεστό το κινητό συνέχεια, ότι η οθόνη είναι ξεπλυμένη και ότι, σε σχέση με το Ζ2, δεν υπάρχει καμία διαφορά. Όλα αυτά από ένα χρήστη. Ο χρόνος θα δείξει όταν κυκλοφορήσει για τα καλά.
Θα το δούμε στην πράξη.
Το z2 ήταν δροσερό σε νορμσλ και φυσιολογική χρήση δηλαδή,μουσική με bt,κλήσεις σερφάρισμα και με wifi και 3G.
Μόνο σε κάμερα με πολλές φωτός ανέβαζε αισθητά χωρίς όμως να επηρεάζει αρνητικά την συσκευή η την εφαρμογή της κάμερας.
Ευελπιστώ τα ίδια να είναι και στο z3 και προπάντων να μην μας τύχει καμία αναποδιά με προβληματική παρτίδα,που βέβαια με το Amazon δεν φοβάμαι καθόλου μιας και το after sales support είναι άψογο.
Καλά για την οθόνη δεν νομίζω ξεπλυμένη σε καμία περίπτωση,απλά όπως διάβασα έχει αρκετά ψυχρό λευκό αλλά αυτό διορθώνεται εύκολα με χειροκίνητη ρύθμιση του λευκού η των άλλων χρωμάτων που πάντα παρέχει η Sony τέτοια εργαλεία.
Εγώ με το Ζ1 γιατί να μπω σε έξοδα πάλι;; :(
Επειδή προς το παρόν με καλύπτει και επειδή μπαίνω φαντάρος σε λίγους μήνες, θα το αναβάλλω όσο και αν με τρώει το χέρι! Έτσι θα έχει βγει και το Ζ4 και εγώ θα τσιμπήσω το Ζ3 σε καλύτερη τιμή και αφού φύγουν και τίποτα προβληματικές παρτίδες. Αν και δεν μπορώ να καταλάβω αν αυτή η στρογγυλοποίηση μου αρέσει περισσότερο από αυτή του Ζ1.
αμα πας φαντάρος να το προσέχεις το Ζ1 γιατί είναι πολύ δυνατό και δεν είναι φθηνό ως πρωην ναυαρχίδα sony . Δεν σημαίνει ότι επειδή βγήκε το Ζ3 χάνει την αξία του το Ζ1
Οταν μπω θα το παροπλισω. Θα εχω ενα Νοκια τελειωμενο γιατι θα φοβαμι μην μου το "φανε".
Φρεσκότατο πρωινό review της συσκευής!
http://gadgets.ndtv.com/mobiles/reviews/sony-xperia-z3-review-the-pursuit-of-refinement-597763?site=classic
http://cdn.ndtv.com/tech/images/gadgets/sony_xperia_z3_screen_ndtv.jpg
http://cdn.ndtv.com/tech/images/gadgets/sony_xperia_z3_lowerfront_ndtv.jpg
Edited by alextrela
Όπως και πέρυσι με το Ζ2,
Έτσι και φέτος έχω το πρωτότυπο στα χέρια μου.
Ο,τι θέλετε ρωτάτε
Edited by junglist
ONEPLUS 12 16/512gb: rooted
Amazon Fire stick 4k max
Ο,τι θέλετε ρωτάτε
Σε μαύρο είναι τέλειο.
Αν σου είναι εύκολο πες αν υπάρχει υπερθέρμανση όταν το δουλεύεις γενικά και ιδίως όταν είναι σε 3G/4G.
Με τέτοια μπαταρία που έχει θα μπορούσα επιτέλους να εχω το κινητό συνέχεια σε 4G :p
Επίσης αν το νιώθεις πιο εύχρηστο στο χέρι τώρα που άλλαξαν λίγο το σχέδιο.
Ο,τι θέλετε ρωτάτε
Ωραία,ας κάνω έναρξη.
Μπαταρία.
Τι λένε τα χρώματα της οθόνης?κάποιο θέμα με κιτρινιλα?
Θερμοκρασία cpu?πως τα πάει εκεί?
Κάμερα.επιτέλους έβαλαν κάτι σωστό κι αποδοτικό υπό όλες τις φυσιολογικές συνθήκες?
Στο χέρι πως το βλέπεις?
αυτά:-)
Στο review λέει ότι δεν έχει double tap να ανάβει η οθόνη. Μου κάνει εντύπωση και πιστεύω ότι κάποιο λάθος πρέπει να έχουν κάνει.
http://www.myphone.gr/forum/showthread.php?t=400377
Υπερθέρμανση δεν έχω δει, δηλαδή να καίει. Την ζεστη του την έχει σε 3g βέβαια. 4g δεν έχω.
Αν εχει πιο ωραια χρωματα με Ζ2 και G2 και αν κρατα με μεσσαια χρηση δυο μερες.
Σε σχέση με Ζ2 δεν μου κάνει μεγάλη διαφορά στα χρώματα. Για χρήση δώσε μου λίγες μέρες να το δοκιμάσω.
Μπαταρία.
αυτά:-)
Δεν βλέπω κιτρινιλα.
Θερμοκρασία cpu έχεις κάποια εφαρμογή να βάλω;
Στο χέρι σαν το Ζ2 μου κάνει.
Όπως και πέρυσι με το Ζ2....
Ο ήχος, ο ήχος τι λέει;
Ηχεία και αν το έχεις δοκιμάσει με κάποια καλά ενσύρματα ακουστικά.
3>4
Με φρενήρη ρυθμο συνεχίζονται τα review και τα διθυραμβικά σχόλια!
http://www.theguardian.com/technology/2014/sep/26/sony-xperia-z3-review-battery-life-android-smartphone
http://static.guim.co.uk/sys-images/Guardian/Pix/pictures/2014/9/26/1411730996960/d8f00cb6-5520-41e3-81b9-da43b6e9fbf5-460x276.jpeg
Edited by alextrela
Ο,τι θέλετε ρωτάτε
Πέρυσι;
Είχες Ζ2 το 2013; :blink:
Μάλλον με κεκτημένη ταχύτητα στην άκρη του μυαλού επικρατεί,ότι ανά χρόνο βλέπουμε ανανέωση ναυαρχίδων όπως συμβαίνει με άλλες εταιρίες και όχι ανά εξάμηνο όπως στην περίπτωση της Sony.
Πάντως θυμάμαι το είχε από αρχές Απριλίου το z2 κάνα μήνα πριν κυκλοφορήσει επίσημα εδώ.
Πέρυσι;
Οπότε ρε φίλε.
Κόλλησες στην διαφορά μηνών.
Αν αμφιβάλλεις για τα λεγόμενα μου, κάνε μια αναζήτηση και θα δεις τα αντίστοιχα ποστ μου για το Ζ2 .
Ήμουν από τους πρώτους που είχα δει και το ζήτημα υπερθέρμανσης τότε.
Ο junglist είχε το z2 πριν κυκλοφορήσει εδώ και τώρα έχει το z3 και είναι διατεθημένος να βοηθήσει να έχουμε περισσότερες πληροφορίες. Αντι για ευχαριστώ θα του την πούμε; Δεν νομίζω.
LG G8s - Lg g6 h870 -- Note 4 N910F(dead) stock 6.0.1 -- Sony Xperia Z 5.1.1 eXistenZ Y 4.0.0 -
Δεν του την είπα, ρώτησα για να καταλάβω τι εννοεί.
Αν κοιτάξεις το post του έχει μέσα και τη λέξη "πρωτότυπο" (αντί να γράψει ότι έχει το κινητό στα χέρια του γράφει ότι έχει το πρωτότυπο στα χέρια του) επομένως ήθελα να μάθω αν με κάποιο τρόπο έχει πρόσβαση στα πρωτότυπα της Sony πριν αυτά ανακοινωθούν και κυκλοφορήσουν.
Βέβαια δε νομίζω ότι σε αυτήν την περίπτωση θα το έγραφε στο forum, αλλά ποτέ δεν ξέρεις.
Χαλαρώστε κύριοι! Ρωτήστε ότι θέλετε κι αφήστε τα υπόλοιπα στην άκρη.
Ο,τι θέλετε ρωτάτε
Καλήμέρα φίλε μου και να χαρείς την συσκευή σου. Θέλω να ρωτήσω αν ισχύει ότι διατυπώνεται παρακάτω στο phonearena και σχετικά με την οθόνη:
Here we arrive to the Xperia Z3's screen biggest drawback. Our measurements showed the whopping 10324 Kelvins, which is very far from the reference 6500K white point, making the screen look very, very cold, with abundant blueish or greenish overcast. You can change the screen's white balance from the display settings menu, and Sony argues that the coldness is deliberate, throwing in some stats about people's perception of cold screens as brighter, but the fact is that the Xperia Z3 is off the reference white mark by default, and significantly at that
http://www.phonearena.com/reviews/Sony-Xperia-Z3-Review_id3795
Ευχαριστώ :happy:
