Cubot X6
Karthan7
This model is on presell now, a few products will be delivered accordingly, full supply will begin in March 20th, thank you.
Screen Size: 5.0" IPS - 720P, OGS Full-Lamination
3G: WCDMA 850MHz, WCDMA 2100MHz
2G: GSM 1900MHz, GSM 1800MHz, GSM 900MHz, GSM 850MHz
SIM Card: 2 SIM Standby, Mini SIM Card, Standard SIM Card
Data Transfer: HSPA, EDGE, GPRS
OS: Android 4.2.2
CPU: Octa-core, MTK6592 ARMv7
CPU Frequency: 1.7GHz
RAM: 1GB
ROM: 16GB
GPU: OpenGL ES 2.0, Mali-450 MP
Storage: TF card 32GB extended
Back Camera Megapixel: Back 8.0 MP Lens & Sensor, Interpolated upto 13MP
Front Camera Megapixel: Front 5.0 MP
Camera Functions: Sontinuous shot, Self timer, Flashlight, Auto-focusing, Panorama
Screen Resolution: 1280 x 720 pixels
GPS: AGPS, GPS
Sensor: compass, Light Sensor, Proximity Sensor, Gravity Sensor
WIFI: WiFi hotspot, WiFi 802.11 b/g/n
Bluetooth: Bluetooth 2.0
OTG: Yes
Video Resolution: 1080P, 720P
Audio Format: OGG, MID, MP3, WAV
Video Format: MKV, MOV, 3GP, MP4, AVI
Picture Format: PNG, GIF, BMP, JPG
Installed Apps: Browser, Calculater, Calendar, Clock, Email, Flashlight, Google Navigation, Google Map, Google Play Store, ect.
Other Feature: LED notification, Message, VPN, Wifi Display, Scheduled Power On & Off, Sound Recorder, FM Radio
Multi-touch: Five Point Multi-touch
Language: Greek, English, Russian, Spanish, Italian, Hebrew, Malay, Catalonian, Czech, Danish, German, French, Croatian, Latvian, Lithuanian, Hungarian, Dutch, Polish, Norwegian, Portuguese, Romanian, Slovak, Slovenian, Finnish, Swedish, Vietnamese, Turkish, Greek, Bulgarian, Ukrainian, Arabic, Persian, Thai, Korean, Japanese, Chinese, Filipino
Battery: 2200mAh
Size: 145 x 74 x 9 mm
Weight: 165g (With a battery)
Σημερινη τιμη $189.99 στο tynideal και $174.99 στο pandawill. προσοχη δεν ειναι διαθεσιμο, οι τιμες ειναι για προπαραγγελια.
http://www.pandawill.com/cubot-x6-smartphone-mtk6592-50-inch-ogs-screen-1gb-16gb-android-42-black-p86114.html
http://www.tinydeal.com/presell-cubot-x6-5-ips-mtk6592-8-core-android-422-phone-p-119641.html
xda Cubot X6, Cheapest 8-Core Smartphone: Less Vibrant, but Agiler
[ame=http://www.youtube.com/watch?v=rHq8qucXONY]βιντεο - τεστ [/ame]
youtube - search
Δεν ειδα σχετικο θεμα, αν υπαρχει ας μεταφερθει :)
Χρήσιμες οδηγίες
Πως να κάνετε root!
Edited by navi55
  • Απαντήσεις 453
εδώ λέει ότι το έχει in stock 128 euro, δεν ξέρω όμως κατά ποσο είναι αξιόπιστο το μαγαζί http://www.coolicool.com/cubot-x6-mtk6592-17ghz-octa-core-50-inch-hd-screen-android-42-3g-smartphone-g-33039
Haier W910 value for money :D
XBMC/Kodi/SPMC Οδηγός σεταρίσματος Add-ons & Repository http://www.myphone.gr/forum/showthread.php?t=408974
Προτιμήστε συσκευή με 2gb ram όταν φοράει octa επεξεργαστή.
Συμφωνω αλλα σ αυτα τα λεφτα δεν υπαρχουν καλα καλα 4πυρηνα με 2GB ram.Και επειδη οι Κινεζοι ειναι γατες ,να δεις που συντομα θα βγουν 8πυρηνα στα 100$ με 512ΜΒ ram (λεω τωρα εγω...μην το παρετε τοις μετρητοις).Εχει αξιοπροσεχτα χαρακτηριστικα (HD οθονη,μεγαλη μπαταρια) απλα μενει να δουμε την ποιοτητα και την αντοχη.Και ωραια σχετικα σχεδιαση...
Οι βλάκες είναι γεμάτοι αυτοπεποίθηση και οι ευφυείς γεμάτοι αμφιβολία. Ράσελ Μπέρτραντ
Πάντως εγώ μετά την εμπειρία μου με το gt99 της ίδιας εταιρείας έχω αρχίσει να το καλοβλέπω το προηγούμενο με έχει εκπλήξει ευχάριστα
----- προσθήκη μηνύματος 13 λεπτά μετά την υποβολή του προηγούμενου -----
Παιδιά απ'ότι βλέπω δεν υπάρχει μεγάλη κινητικότητα γύρω από το συγκεκριμένο κινητό αν και φαίνεται αρκετά καλό. (απ'όσα ξέρω βέβαια)
Υπάρχει κάποιος που να το έχει; Ρωτάω γιατί θα ήθελα κάποιες παραπάνω πληροφορίες για το κινητό. Έχω το zte v967s και μου την σπάει η κάμερα του αρκετά και ψάχνω κάτι καλύτερο.
Όποια γνώμη θα βοηθούσε :)
Ευχαριστώ.
http://www.photoin.gr | all about design!
Μάλλον ολοι παραλαμβάνουν μετά τις 15 Μαρτίου (ας πούμε, το minideal τότε γράφει...), οπότε σχόλια θα διαβάσεις πριν το Πάσχα...
OnePlus 12 (16/512): - in the past: [iPhone 13 Pro], OP10Pro, OP9Pro, OP7TPro, OP7, OP6, OP3, OP2, OP1
Αυριο θα το παραγγειλω από minideal οποτε προς το τελος Μαρτιου ελπιζω να το εχω και θα γραψω εντυπώσεις.
Αισιόδοξο σε βρισκω... ακόμα και αν παραλάβουν ακριβώς στις 15 (Σάββατο), θα στείλουν 17 + 20 μέρες, πριν τις 7 Απριλίου χλωμό το κόβω...
Ευχαριστώ.
Αν ψάξεις στο net ξένα φόρουμ και YouTube. Θα μάθεις πολλά υπάρχει μεγάλη κινητικότητα. Δείχνει υποσχόμενο αρκετά designατο και γρήγορο. Δυστυχώς η κάμερα του δείχνει να είναι και το αδύνατο σημείο του όπως κατάλαβα θολές και χαμηλής ποιότητας. Σε όλα τα υπόλοιπα όμως φαίνεται να τα σπάει και να είναι και ποιοτικο
http://forum.xda-developers.com/showthread.php?t=2647933
http://www.gizchina.com/2014/02/19/exclusive-octacore-cubot-x6-hands-140e-dual-sim-smartphone/
Είμαι ανάμεσα σε αυτό και το doogee dg2014 για τη κοπελιά και έχω προβληματιστεί. Τους 8 πυρήνες τους φοβάμαι λίγο...
George Bernard Shaw
Οχι ακόμα παραγγελία γιατί αν τα βάλεις κάτω χάνεις 10 μέρες για την περίπτωση του dispute....Οταν φτάσει κοντά στις 15 τότε...ναι.
δωρεάν Cubot X6????
Now, you have a chance to win a free Cubot X6 MTK6592 Octa Core smart phone at GeekBuying. Very easy. Just click share in Facebook and ask your friends to like your share content. Then you have the chance to win the Cubot X6.
Join in the campaign here:
https://www.facebook.com/photo.php?fbid=374909482648112&set=a.210291502443245.47830.207271886078540&type=1&stream_ref=10
Justin
[big Cubot Promotion ]
Hi, Big Cubot promotion is online now. http://bit.ly/1kYf5eP
All popular models included, best price you can find.
Once you share this news then you have the chance to win Free Cubot Octa core smartphone.
Rules:
*What to offer: ONE free Cubot X6
*How to join: share this good news on facebook and let you friend click "like".
*How to pick a winner: whose share got most likes
*When to call end: the day Cubot promotion comes to end, March 20. 2014 GMT +8 18:00
*Notice: Please set your privacy to let others who are not your friends can see your share, or your share will be invalid.
cubot x6 in minideal.net,
delivery time: 15th march (300pcs available), welcome order!
Edited by minideal
Your Great Satisfaction is our Endless Motivity!
our offical skype: minideal17
For Complaints: salesminideal@gmail.com
welcome to http://www.minideal.net
http://cs627226.vk.me/v627226995/3debe/QeMl4Jpzx84.jpg
ενα review βρηκα εδω κ με την καμερουλα του στο τελος.
Το παραγγειλε κανεις;
Edited by sokos1
Phones: Samsung GT-M8910 Pixon - iPhone 3gs - HTC Desire - ZTE P752D - Jiayu G4 - Honor 3c - Honor 4x
Tablets: Lenovo A100L
Οι προδιαγραφές και το design του φαίνονται μία χαρά πάντως Edited by MORRISSEY4
Π.Α.Ο.Κ. 1926
εγω το παρήγγειλα σήμερα δεν αντιστάθηκα....:ninja:
Ψηνομαι κι εγω. Απο που το παραγγειλατε παιδια?
εγώ το πήρα από coolicool 172 δολλάρια..
Ευχαριστω, θα περιμενω να βγει απο Pre-sale και θα το παραγγειλω. :)
φιλε μου πολυ αναλιτικα τα specs σου για το x6 και ναι ψυθικα αγρια και τ παραγκειλα χθεσ :) το μονο που δεν μπορω να βρω πουθενα ωμοσ ειναι το ποσο sar εχει αυτη η συσκευη.μηπωσ ξερει κανεις να μου πει?
Το παρήγγειλα κι εγω τελικά απο coolicool.
Θηκουλα γι αυτό το κινητό έχει βρει κανείς;
Παίδες όποιος το παραλάβει πρώτος ας κάνει ένα μίνι review...
