Motorola DEFY
tsoump
Motorola Defy
202 members have voted
  1. 1. Motorola Defy
    • Θετική ψήφος
      185
    • Αρνητική ψήφος
      17
@pificos αφου βρε η βαση της cm7 ειναι φρογιο...τι εννοεις?
αυτό δεν καταλαβαίνω......
http://forum.xda-developers.com/showthread.php?t=1065798
7) How to install CM7 and keep downgrade-ability? (Froyo or Eclair)
If you don't flash the full SBF, your downgrade-ablility is fine.
Here's the safe steps to install CM7 to keep your downgrade-ability:
- Copy nandroid backup of 3.4.2-177 to your sdcard. Uncompress it in the folder clockworkmod/backup/ of your sdcard, create this if needed.
- Enable USB Debug
- Root via SuperOneClick
- Disable USB Debugging
- Install Custom Recovery
- Reboot
- Go to app System Recovery then install Recovery and Reboot Recovery
- In Custom Recovery, go to "backup and restore", then "Backup". This will take some time, your backup will be at /clockworkmod/backup. Copy it to a safe place.
- Still in recovery, go to "backup and restore", "restore", and select the nandroid backup of 3.4.2-177-005 (not your backup!)
If you have MD5 mismatch error, try to rename the folder of the nandroid to something simple without spaces, like "nand"
- Reboot your system and immediately press and hold Volume Up to enter Bootloader Mode (if you couldn't enter, remove the battery, wait 10s, put it again with Power and Volume Up pressed)
- Flash Fixed SBF of 3.4.2-177 via RSD Lite
Now go to question 2 and do all the process to install CM7.
If you want to go back to your original ROM
- Disable USB Debuging
- Copy your nandroid backup to your SD Card, put it in /sdcard/clockworkmod/backup (must be a folder with simple name inside backup)
- Reboot phone in Bootmenu (Volume Down when the blue led lights at Motorola logo) then go to Custom Recovery
- Wipe data/factory reset, wipe cache and wipe dalvik cache (in advanced)
- Choose "backup and restore", "restore", and select your eclair nandroid backup. If your backup doesn't show in this screen, is most likely you placed it in the wrong folder.
- Reboot your system and immediately press and hold Volume Up to enter Bootloader Mode.
6. Flash the Fixed SBF of your original ROM. For a list of (fixed) SBF's you can check:
SBF - Service Flash - all files + fixed sbf + Bootloaders
[[sbf:defy]] And Developers
Οταν κανουμε hard reset η συσκευη γινεται unroot?.Αλλιως πως γινεται unroot?
με το root explorer και με το προγραμμα z4root κανεις unroot
Βήμα 1: Πάρε « Root explorer» (δεν είναι δωρεάν!)
Βήμα 2: Πηγαίνετε στο / system / app. Κάνε κλικ στο mount R/W να γίνει mount R/O που βρίσκονται στην πάνω δεξιά γωνία του προγράμματος.
Βήμα 3: Βρες το APK «Superuser.apk» και να απεγκαταστήσέ τό χειροκίνητα
Βήμα 4: Τώρα πάμε στο z4root και κάνε κλικ στο unroot.
Βήμα 5: Επανεκκίνηση του τηλεφώνου σας.
Edited by pificos
OnePlus 5t
  • Απαντήσεις 2,6χιλ.
ΟΚ αλλά αν θες να επανέλθεις σε froyo?.
Εγώ όταν πέρασα την CM7 και δεν έπαιζε (ανοιγε εφτανε στο Μ της motorola και επανεκκίνηση), έκανα reset, ξαναπέρασμα οτι μπορεις να φανταστείς και λέω το χάλασα τελειώς, σκέφτηκα και μπήκα με το power + volume up, ενωσα το usb και ξαναπέρασα με το RSD lite την ελληνική froyo και το κινητό λειτούργησε κανονικά οπότε είσαι κομπλέ οτιδήποτε κι αν γίνει μην ανησυχείς γυρναει σε froyo γιατι και μενα αυτος ηταν πο φοβος μου ηταν αν παει κατι στραβά
George Bernard Shaw
Και πάλι γεια σας!
Ξαφνικά σήμερα το μεσημέρι, και ενώ όλα πήγαιναν καλά (μετά από την εγκατάσταση της 2.2.2 και επαναφορά εργοστασιακών δεδομένων πριν από αρκετές μέρες), σταμάτησαν να λειτουργούν τα πλήκτρα home, αναζήτηση και το κλείδωμα της οθόνης!
Αναγκάστηκα να κάνω πάλι επαναφορά εργοστασιακών δεδομένων και όλα λειτουργούν, προς το παρών, κανονικά!
Είναι κάτι που πρέπει να ξέρω και το αγνοώ ή ήταν ένα τυχαίο γεγονός?
Αν ξέρει κάποιος κάτι ας μου απαντήσει.
Υ.Γ. Είχα βάλει αρκετές εφαρμογές από το android market (περίπου 10-12) και δεν ξέρω αν αυτό παίζει κάποιο ρόλο.
Ευχαριστώ εκ των προτέρων!
Και πάλι γεια σας!
η απαντηση που ψαχνεις ειναι στο υστερογραφο σου ;)
Καλησπερα παιδια
Πηγα που λετε σημερα θαλασσα και μπηκε λιγη αμμος περιμετρικα της οθονης στο μικρο περιθωριο που εχει απο το πλαστικο.
Εβαλα μολις γυρισα το κινητο λιγο κατω απο το νερο (φανταστηκα οτι το water resistant περιλαμβανει αυτη τη "διαδικασια") για να φυγει η αμμος, αλλα για καποια ωρα το ακουστικο ηταν πολυ χαμηλο. Αφου το εκανα λιγο με το πιστολακι, ειδα πολυ καλη βελτιωση στην ενταση και φανταζομαι οτι θα στρωσει μολις στεγνωσει τελειως..
Η ερωτηση που θελω να κανω ειναι μηπως δεν πρεπει να του -ξαναφερθω- ετσι, και παθω καποια μονιμη βλαβη στο ακουστικο (ή οποιαδηποτε αλλη).
Ευχαριστω!
Ανταλλακτήριο προγνωστικών στοιχήματος ποδοσφαίρου. Από τον παίκτη, για τον παίκτη!
http://www.progno.gr ;)
Καλησπερα παιδια
Ευχαριστω!
αυτή την ηλιθιότητα να αφήσουν αυτό το ελάχιστο κενό μεαξύ οθόνης και πλαστικού δε κατάλαβα γιατί τη κάνανε σε τέτοιο κινητό γιατι ακόμα και στη θάλασσα να μη πας μπαινει πολύ εύκολα άμμος και γενικότερα οτιδηποτε σε μικρό κόκκο και δε βγαινει εύκολα, επρεπε καλου κακου να καλυψεις το ακουστικό κι εσύ αν και μπορει να μην έπαιξε τίποτα απλά να ειχε μπουκώσει από το νερό προσωρινά
George Bernard Shaw
Ευχαριστώ για την απάντηση.
Τα περισσότερα από αυτά είναι widget και νόμιζα ότι δεν θα υπήρχε πρόβλημα!
Αν λοιπόν φορτώνοντας μερικά widget το τηλέφωνο παρουσιάζει προβλήματα, έχοντας και αρκετά μεγάλη εσωτερική μνήμη, τότε φοβάμαι ότι έχουμε κάποιο πρόβλημα!
Αν λοιπόν υπάρχει κάποιος που έχει αντιμετωπίσει ένα παρόμοιο πρόβλημα ας μου πει πως το έλυσε.
Ευχαριστώ!
Ισως και να εχεισ δικαιο.. Αλλα τι σοϊ water resistant ειναι αυτο; Ενα ποτηρι νερο να πεσει επανω, λογικα, παλι το ιδιο προβλημα θα εχω..
Δεν περναει νερο μεσα,αυτο εχει σημασια. Τις προαλλες ενος φιλου μου το Samsung το αδιαβροχο του επεσε στην θαλασσα και ωσπου να φυγει το νερο απο το ακουστικο δεν ακουγε τιποτα. Δεν σημαινει οτι περασε νερο!
Sent from my MB525
OnePlus 5t
Και πάλι γεια σας!
Φυσικά και δε φταίει το γεγονός ότι έβαλες 10-12 εφαρμογές από το market...
Δηλαδή εμείς που έχουμε βάλει 50-100, τι έπρεπε να πάθουμε!!!
Αν δεν το έχεις πειράξει (root-overclocking-undervolting), μάλλον ήταν κάτι τυχαίο...
Sent from my MB525
Αυτο ειναι σιγουρο ομως; Φοβαμαι μην παρω καμια μερα το ακουστικο στα χερια...
σκοπευεις να του κανεις μπανιο συχνα;
Πιθανόν δεν είναι τυχαίο γιατί το ίδιο πρόβλημα μου έκανε και σε μένα. Το έχω αναφέρει είδη στο πόστ #1897 σελίδα 127 Μόνο που σε εμένα δεν μου λειτουργούσε και το search button:blink:. Με την ίδια μέθοδο το διόρθωσα και εγώ(Επαναφορά εργοστασιακών ρυθμίσεων) . Και δεν το είχα πειράξει καθόλου όλα μαμά ήταν.
Προς το παρόν όλα λειτουργούν μιά χαρα..;).
Κοιτα, αμα δεν εχει οντως προβλημα, γιατι οχι.. Εννοω οταν θα γεμιζει λαμακιες στο κενο γυρω απο την οθονη..
ποσο πουλιουνται τα Motorola ?
αν εννοείς συγκεκριμένα το defy μπορείς να το βρείς απο 250 έως 350€
OnePlus 5t
Κάνε μια αναζήτηση στα σχετικά site αγγελιών. Η απάντηση είναι σχετική μιας και η τιμή κυμαίνεται εξαρτώμενη από πολλούς παράγοντες.
Παιδιά από τότε που έκανα την αναβάθμιση στο κινητό της αδελφής μου, όταν πάει να βγάλει φωτογραφίες και ενώ δείχνει ότι λειτουργεί το φλας, οι φωτογραφίες βγαίνουν μαύρες, λες και δεν συγχρονίζεται το κλείστρο με το φλας (όχι σκούρες, τελείως μαύρες). Και ακριβώς το ίδιο κάνει και σε ενός φίλου, μετά την froyo αναβάθμιση.
Τι παίζει? Καμία λύση!!! Hard rest δεν το έκανα, ίσως πρέπει?
Αν και εχει αναφερθει λιγα ποστ πιο πισω (σελ.122) η λυση στο προβλημα σου ειναι να πας: κεντρικο μενου - ρυθμισεις - εφαρμογες - διαχειριση εφαρμογων - καρτελα ΟΛΑ να βρεις την φωτογραφικη μηχανη, να την επιλεξεις και να πατησεις εκκαθαριση δεδομενων.
Edited by nobody4
Μπορείτε να μου πείτε πως γίνεται το hard reset και τί σβήνεται όταν το κάνεις;
Ευχαριστώ.
Ευχαριστώ.
Επανέρχεται η συσκευή στην εργοστασιακή της κατάσταση όπως όταν την πρωτοάνοιξες.
https://motorola-global-en-uk.custhelp.com/app/answers/detail/a_id/55500/~/defy---master-reset-%2F-factory-data-reset
Καλησπέρα.σήμερα πέρασα την τελευταία έκδοση όπερα 6.1 κάτι...από εκεί που δεν είχα πρόβλημα με την γραμματοσειρά, πλέον, κάτι γράμματα του αλφαβήτου αντικαταστάθηκαν με κάτι ορθογώνια πλαίσια που είναι τρομερά ενοχλητικά.
Proud HTC User!
