PGM_gr Δημ. May 16, 2011 Δημ. May 16, 2011 Για battery calibration να χρησιμοποιησω τον ακολουθο οδηγο ή αυτο το προγραμμα ? ποιος τροπος ειναι πιο αξιοπιστος : Method 1 : 1. Power on your Desire then connect to your Charger and Fully charge until the LED changes Green. 2. Disconnect your phone from the charger and then power off. 3. Reconnect your phone to your charger with the power off and wait for the green LED. 4. Disconnect the phone from the charger and power it on. 5. Once the phone has fully booted / ready to use ... power off again. 6. With the power off connect the phone to the charger and wait for the green LED. 7. Disconnect from the Charger then power on and use normally. Method 2 : https://market.android.com/details?id=com.nema.batterycalibration&feature=search_result Παράθεση HTC Desire HD <<<
elthis Δημ. May 16, 2011 Δημ. May 16, 2011 Για battery calibration να χρησιμοποιησω τον ακολουθο οδηγο ή αυτο το προγραμμα ? ποιος τροπος ειναι πιο αξιοπιστος : Method 1 : 1. Power on your Desire then connect to your Charger and Fully charge until the LED changes Green. 2. Disconnect your phone from the charger and then power off. 3. Reconnect your phone to your charger with the power off and wait for the green LED. 4. Disconnect the phone from the charger and power it on. 5. Once the phone has fully booted / ready to use ... power off again. 6. With the power off connect the phone to the charger and wait for the green LED. 7. Disconnect from the Charger then power on and use normally. Method 2 : https://market.android.com/details?id=com.nema.batterycalibration&feature=search_result Mπορεις να κανεις και τα 2.Το ενα δεν αναιρει το αλλο...Η 1η μεθοδος αναφερεται και απο την htc... Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
haris88 Δημ. May 16, 2011 Δημ. May 16, 2011 Εχουν αναφερει τα παιδια με official οτι το navigation δε μας υποστηριζει ακομα... Sent from my Desire HD Ευχαριστώ πολύ. Κρίμα πάντως γιατί βολεύει αρκετά... Παράθεση Nokia 3310 | Nokia 5510 | Nokia 6100 | SE K700i | SE K500i | Motorola V3i | Samsung U700 | SE C902 | SE G900 | HTC Desire HD | Apple iPhone 4S 64GB | Apple iPhone 5 64GB | Apple iPhone 6 128GB
elthis Δημ. May 16, 2011 Δημ. May 16, 2011 Ευχαριστώ πολύ. Κρίμα πάντως γιατί βολεύει αρκετά... Κι εμενα με βολευει πολυ... Bαλε αν θες μια custom rom για να μη σου λειπει...;) Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
haris88 Δημ. May 16, 2011 Δημ. May 16, 2011 Κι εμενα με βολευει πολυ... Bαλε αν θες μια custom rom για να μη σου λειπει...;) Ναι κι αυτό γίνεται. Για την ώρα είμαι εξωτερικό όπου δουλεύει άψογα οπότε δεν έχω ιδιαίτερο πρόβλημα και δεν έχω και χρόνο να ασχολούμαι πολύ με flash-αρίσματα, bugs κτλ. Ίσως όταν γυρίσω το καλοκαίρι όμως... Παράθεση Nokia 3310 | Nokia 5510 | Nokia 6100 | SE K700i | SE K500i | Motorola V3i | Samsung U700 | SE C902 | SE G900 | HTC Desire HD | Apple iPhone 4S 64GB | Apple iPhone 5 64GB | Apple iPhone 6 128GB
spdrosin Δημ. May 16, 2011 Δημ. May 16, 2011 Όταν κάνουμε update μια ROM είναι καλό να κάνουμε wipe cache και dalvik ; Kαι format cache και system επίσης ; Παράθεση
kokos_nikos Δημ. May 16, 2011 Δημ. May 16, 2011 (edited) Αμα κάνω backup της υπάρχουσας ρομ θα κάνει και backup και σε όλες τις εφαρμογές ? Eπίσης πώς κάνουμε φορματ στην κάρτα sd ? Edited May 16, 2011 by kokos_nikos Παράθεση
Spyr0s Δημ. May 16, 2011 Δημ. May 16, 2011 CoreDroid Desire HD GingerBread 2.3.3 V6.5 (16/05/11) Lee Kernel V3.1.1 Fixed Weather Added a few more things From Pyramid (weather sounds,Weather Wallpaper Effect, etc) Added Kingdom Lockscreen and a few more things Adjusted More the Theme Adjusted some icons to fix glitches Adjusted loads of xmls to make it more clean and fix Glitches in graphics Fixed Grafic Glitchs on progress bar in Low Memory Wizard app Fixed Pulldown for 3rd pary apps (new Skin also) Fixed some scripts MMS options size changed and set as 300K by default (only takes effect with a Wipe install) Weather app Adjusted Updated Adobe Reader Updated Flash Player HUGE improvements in Performance HUGE Cleaning on Code Better Battery life Rosie Moded EXT4 SYSTEM / DATA And All Issues Fixed From Previous Versions http://coredroidroms.com/index.php?option=com_content&view=article&id=180&Itemid=227 Παράθεση
elthis Δημ. May 16, 2011 Δημ. May 16, 2011 Όταν κάνουμε update μια ROM είναι καλό να κάνουμε wipe cache και dalvik ; Kαι format cache και system επίσης ; Οταν κανεις update μια ρομ κανεις ενα wipe cache-wipe dalvic cache ΜΟΝΟ κι εισαι οκ...;) http://coredroidroms.com/index.php?option=com_content&view=article&id=180&Itemid=227 Ειναι καλη αλλα να διευκρινησουμε οτι δε μοιαζει με stock και εχει ενσωματωμενο θεμα.Απλα το λεω γιατι πολλοι τη προτιμανε stock...;) Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
kollatos Δημ. May 16, 2011 Author Δημ. May 16, 2011 Να ρωτήσω κάτι, έχει περάσει κανείς τον kernel του m-deejay? Θέλω να μου πείτε αν έχει powersave governor. Παράθεση [sIGPIC][/sIGPIC] Πωλείται: Τίποτα. Ζητείται: Τίποτα.
taneasou Δημ. May 16, 2011 Δημ. May 16, 2011 ξέρει κάποιος αν βλάπτει ή βοηθά το leedroid το κινητό. Παράθεση
stratigos30 Δημ. May 16, 2011 Δημ. May 16, 2011 Τα φώτα σας παιδιά. Έχω το τηλέφωνο μαμά με την ΟΤΑ αναβάθμιση και ενώ δούλευε μια χαρά τις τελευταίες 2 ήμερες μου βγάζει το εξής μήνυμα " Υπήρξε μη αναμενόμενη διακοπή της εφαρμογής Πλαίσιο Υπηρεσιών Google (διαδικασία com.google.process.gapps). Ξέρει κανείς τι μπορεί να το προκαλεί; Παράθεση
elthis Δημ. May 17, 2011 Δημ. May 17, 2011 (edited) Να ρωτήσω κάτι, έχει περάσει κανείς τον kernel του m-deejay? Θέλω να μου πείτε αν έχει powersave governor. Ναι Ανδρέα.Έχει...Δε το είχα παρατηρήσει... Τα φώτα σας παιδιά. Έχω το τηλέφωνο μαμά με την ΟΤΑ αναβάθμιση και ενώ δούλευε μια χαρά τις τελευταίες 2 ήμερες μου βγάζει το εξής μήνυμα " Υπήρξε μη αναμενόμενη διακοπή της εφαρμογής Πλαίσιο Υπηρεσιών Google (διαδικασία com.google.process.gapps). Ξέρει κανείς τι μπορεί να το προκαλεί; Kατι το ''κολλαει''...Καποια εφαρμογη..Δες τι περασες πριν 2 μερες. ξέρει κάποιος αν βλάπτει ή βοηθά το leedroid το κινητό. :blink: Edited May 17, 2011 by elthis Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
Villis Δημ. May 17, 2011 Δημ. May 17, 2011 ξέρει κάποιος αν βλάπτει ή βοηθά το leedroid το κινητό. Aυτο το "leedroid" που λες, είναι rom. Σα να λέμε δηλαδή μια άλλη-τροποποιημένη έκδοση του λειτουργικού συστήματος του κινητού σου. Αν δεν ξέρεις καλύτερα να μην κάνεις κάτι γιατί μπορεί να έχεις προβλήματα στο κινητό σου... Παράθεση Τhe end of an era...
sober13 Δημ. May 17, 2011 Δημ. May 17, 2011 Καλημερα παιδια..περασα την ι00 5.2.1.. Πολυ ομορφη και smooth , το μονο θεμα ειναι οτι απο χτες μου εχει κολλησει 3-4 φορες παγωνοντας και εβγαλα μπαταρια για να συνεχισω..Κανεις αλλος εχει παρατηρησει τετοιο προβλημα? Παράθεση
elthis Δημ. May 17, 2011 Δημ. May 17, 2011 Καλημερα παιδια..περασα την ι00 5.2.1.. Πολυ ομορφη και smooth , το μονο θεμα ειναι οτι απο χτες μου εχει κολλησει 3-4 φορες παγωνοντας και εβγαλα μπαταρια για να συνεχισω..Κανεις αλλος εχει παρατηρησει τετοιο προβλημα? Επειδη την εχω στο ενα κινητο 2 μερες τωρα,δε μου το εχει κανει ουτε μια φορα...Μηπως περασες κατι αλλο;Εχεις setcpu κι αν ναι τι ρυθμιση του εχεις βαλει? Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
sober13 Δημ. May 17, 2011 Δημ. May 17, 2011 Επειδη την εχω στο ενα κινητο 2 μερες τωρα,δε μου το εχει κανει ουτε μια φορα...Μηπως περασες κατι αλλο;Εχεις setcpu κι αν ναι τι ρυθμιση του εχεις βαλει? Ναι μπραβο elthis, πρωτη φορα μου εγινε οταν περασα το setcpu πανω απο 1,5 ghz.. Τωρα ειναι scalling on demand sta 1459 με τικαρισμενο set on boot.. και profiles που ξεκινουν απο 1459 και οταν η μπαταρια πεφτει κατω απο 70% 1152, κατω απο 50% 1075, κατω απο 20% 695 και screen off 230.. απλα μετα το προβλημα συνεχιστηκε σε ακυρες εφαρμογες πχ desktop vizualizer η οταν πηγα να κανω backup την ρομ Παράθεση
elthis Δημ. May 17, 2011 Δημ. May 17, 2011 Ναι μπραβο elthis, πρωτη φορα μου εγινε οταν περασα το setcpu πανω απο 1,5 ghz.. Τωρα ειναι scalling on demand sta 1459 με τικαρισμενο set on boot.. και profiles που ξεκινουν απο 1459 και οταν η μπαταρια πεφτει κατω απο 70% 1152, κατω απο 50% 1075, κατω απο 20% 695 και screen off 230.. απλα μετα το προβλημα συνεχιστηκε σε ακυρες εφαρμογες πχ desktop vizualizer η οταν πηγα να κανω backup την ρομ Εγω εχω scalling: convervative max:1152 min:230 και δεν εχω αντιμετωπισει κανενα προβλημα και η μπαταρια ειναι καλυτερη απο ποτε...Σιγουρα το προβλημα σου ερχεται απο το setcpu... Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
sober13 Δημ. May 17, 2011 Δημ. May 17, 2011 Οκ θα το δοκιμασω φιλε μου..Να σου πω την αληθεια δεν ξερω τι ειναι το scalling παντα on demand to αφηνα.. Παράθεση
elthis Δημ. May 17, 2011 Δημ. May 17, 2011 Οκ θα το δοκιμασω φιλε μου..Να σου πω την αληθεια δεν ξερω τι ειναι το scalling παντα on demand to αφηνα.. Ειναι με απλα λογια ο τροπος που θα επεμβαινει στον επεξεργαστη.Η καλυτερη ρυθμιση για μπαταρια αλλα και γενικα για καθημερινη χρηση ειναι το smartass.Δε χρειαζεται να φτιαχνεις προφιλ.Επισης καλο ειναι να μη το ανεβαζουμε πανω απο τα 1200,οχι γιατι δεν αντεχει ο επεξεργαστης,αλλα για να αποφευγουμε τα ''παγωματα'' που βιωσες κι εσυ. Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
kokos_nikos Δημ. May 17, 2011 Δημ. May 17, 2011 Ειναι με απλα λογια ο τροπος που θα επεμβαινει στον επεξεργαστη.Η καλυτερη ρυθμιση για μπαταρια αλλα και γενικα για καθημερινη χρηση ειναι το smartass.Δε χρειαζεται να φτιαχνεις προφιλ.Επισης καλο ειναι να μη το ανεβαζουμε πανω απο τα 1200,οχι γιατι δεν αντεχει ο επεξεργαστης,αλλα για να αποφευγουμε τα ''παγωματα'' που βιωσες κι εσυ. το set on boot πρεπει να είναι πάντα τικαρισμένο ? Παράθεση
gregorisvas Δημ. May 17, 2011 Δημ. May 17, 2011 (edited) Καμιά ιδέα γιατί σε CM7 τρώει φρίκες και δε στέλνει SMS? (κωδικός λάθους 500)..Κάνω reboot κλπ, τα ίδια.. edit: Ω θεέ..μου 'χε τελειώσει η κάρτα ... :shifty: Edited May 17, 2011 by gregorisvas Παράθεση
elthis Δημ. May 17, 2011 Δημ. May 17, 2011 το set on boot πρεπει να είναι πάντα τικαρισμένο ? Ναι,για να μη χρειάζεται να το ενεργοποιεις σε κάθε reboot. @gegorisvas: LoL Sent from my HTC Desire HD Παράθεση Apparently we love our own cell phones but we hate everyone else's... Follow me on XDA
PGM_gr Δημ. May 17, 2011 Δημ. May 17, 2011 (edited) ρε παιδες , οταν περναω καποια καινουργια ρομ και σεταρω τον λογαριασμο του gmail αυτομετα περνουνται καποιες εφαρμογες που εχω κατεβασει + επαφες ...δλδ επαναφερει καποιο backup που εχει παρει. Στην εγκατασταση ξετσεκαρω πλεον το backup + στο απορρητο ξετσεκαρω τις 2 τελευταιες επιλογες για επαναφορα αλλα εξακολουθει να το κανει ? Ξερετε πως μπορω να το σταματησω αυτο ή να διαγραψω το backup στο λογαριασμο gmail ? EDIT : [ROM] TRUE SENSE 3.0 - i00 ROM 5.3 - UPDATED 18/05/2011 UP Edited May 17, 2011 by PGM_gr Παράθεση HTC Desire HD <<<
sober13 Δημ. May 17, 2011 Δημ. May 17, 2011 Μιας και βλεπω πλεον οτι πολλοι χρησιμοποιουμε την ιΟΟ με sense 3,μηπως ξερει κανεις αν μπορουμε να φλασαρουμε κανενα theme ,εστω και εικονιδια για σημα wifi κτλ? Παράθεση
