kotsianis7 Δημ. January 2, 2008 Δημ. January 2, 2008 Μα δεν το αναφερα ως προβλημα!;) Απλα προσπαθω να αναφερω τροπους σε καποιους κατοχους που ισως ΝΟΜΙΖΟΥΝ οτι εχουν προβληματικο κινητο οτι το κινητο τους ειναι μια χαρα!:D Ναι,το καταλαβα και συγνώμη για το ύφος της απάντησής μου....Απλά βαριόμουν να τη διορθώσω! :D Παράθεση
GIANNHSitia Δημ. January 2, 2008 Δημ. January 2, 2008 kalispera paidia.. telika R1DA038 einai orange version? h na tin perimenoume kai emeis? einai h ekdosi pou legane toso kairo k ka8isterouse h pali kapia enalaktiki? Ok I have been using the K850i R1DA038 for a week now so i thought it was about time to place my findings on here. My phone is a K850i with R1DA038 Western Europe (o2) 4gb M2 Sandisk card Now if i have missed anything out please either pm or post on here i will try to answer them all best i can. *********************************************** One thing that i will advise any body to do, when you update the phone to the R1DA038, I suggest master resetting the phone. When i first installed the R1DA038 GPRS didnt work and the phone was slow and camera still poor, after master reseting the phone behaved very differently. (When master resetting make sure you have backed up all your data onto a memory card and saved all you contacts etc# Master resetting your phone causes you to loose everything currnelty on the phone. *********************************************** A bit of history first, This is the 5th K850i. And i have had all the the current 3 firmwares at present. 1) The camera takes better shots all round (Inside and Out) However more noticeable that the the phone doesnt take black photos as much (This doesnt mean that its 100% perfect as its not) The phone on occasions can still take them, but its a lot less now. However the phone can still take dark shots if you are not careful. 2) Media player is much faster in browsing songs and playing music when pressed. (Big improvement over R1CA029-037). However there is still much more improvement needed. Some videos (mp4)are still out of sync by a quiet a few seconds and on occasion when playing videos (Any video formwat), the video will suddenly go into supper fast mode for no reason. 3) Java is much faster in response and I have also seen peoples comments that it takes an application a slightly longer time to load, On my phone thats not been the case. 4) Phone calls are very clear on either 2g and 3g singal and no transfer over problems from 3g to 2g 5) No video call problems at all which is the same as ther other 2 firmwares. 6) SMS and MMS icons are now shows as the same on the main screen when you receives a SMS or MMS, The Icons have also changed for T9 and Ab (Much nicer in my opion and clearer) Sms listing has also changed 7) Battery life is very good, I get on average 3 days with normal usage (eg 30 mins wap usage, 50 sms, 10-15 mins calls) The phone menu (S) in generaly is much faster in opperating. However the phone will still lag if you are asking it to do too much at once or 2 things together, but no where near as back as R1CA029 - 037. 9) I havnt had one freeze or lockup on the phone since being used. Now to some questions i know people are asking and a couple of bugs. 1) Time in the standby screen - This will never be ava on the K850i as the screen is TFT Technology, K810 and earlier models use TFD Technology. 2) Date and time isnt present on the photos which is very strange, Im not sure why SE omit this function, but there must be a reason. 3) I have still had a corruption on a couple of pics using media browser. The bottom half of the pics are showing blue lines. The pic is displayed fine using file manager and on my computer. 4) Why is alarms and not filemanager in the main menu is a puzzle, but from what i understand, SE would like us to use the media menu instead. Like i said if i have missed anything out then please let me know R1DA038 is ava at SE service centers to be updated. However SE are still placing R1DA038 on the SEUS and can take upto 4 weeks from the start to place on there. From what i understand SE are hoping to have most of the firmwares on there by W05 / W06. The current networks can be updated using SEUS O2, Voda, T-Mobile, Tim. Some Generic phones can also now be updated (Although this is still a bit uknown) HK Branded Central Euro Nordic as to metafrasi kapios giati den skampazw apo aglika :P Παράθεση
k1ng Δημ. January 2, 2008 Δημ. January 2, 2008 Η εγω ειμαι γκαντεμης η αυτο το μοντελο ειναι τελειως ελλαττωματικο!μολις σημερα παρελαβα το Κ850 απ το σερβις επειδη ειχαν ξεχασει να τ περασουν ολο το software κ περιμενα πως κ πως να χαρω το τηλεφωνο..αλλα για κακη μ τυχη τωρα δεν μ αφηνει να κανω κλησεις..καλει κ σταματα κοβοντας την γραμμη οπως κανει οταν δεν εχει σημα.Εχω απογοητευτει τελειως!παω να το φτιαξω κ να το πουλησω..λεω να στραφω σε κατι αρκετα υποδιεστερο αλλα αποτελεσματικο,W580. Παράθεση
one_tree_hill Δημ. January 2, 2008 Δημ. January 2, 2008 ναι,με τα πλήκτρα να σπάνε...:p πάρε καλύτερα το w810 και κάνε τη δουλειά σου! Παράθεση Galaxy S5: Root και αναβάθμιση σε Android 5.0 με Knox 0x0
Scottas Δημ. January 2, 2008 Δημ. January 2, 2008 Re paidia prospa8w na kanw firmware update mesw SEUS alla tpt re gamwto!!! Einai VF kai exw firmware R1CA029 enw vgike idi i 037 sto topsony!!! OMG kai twra pira simera re gam():(:(:( Παράθεση Μέγιστο μέγεθος υπογραφής 16 kiB
maxxx Δημ. January 3, 2008 Δημ. January 3, 2008 παιδιά εγώ το πείρα μόλις κυκλοφόρησε , όλα καλά ωραίο κινητό αν και έκανε ψιλό κολλήματα ,τεσπα μην πολύ λόγω ένα πρωινό το βγάζω να στείλω σμσ όλα καλά και το βάζω στην τσέπη μου περιμένοντας την απάντηση η οποία ήρθε μετά απο 2 λεπτακια το βγάζω από την τσέπη και πάω να το ξεκλειδώσω αλλά δεν ξεκλείδωνε και στην πορεία ανακάλυψα πως η οθόνη αφής είχε πάψει να λειτουργεί , το άνοιξα το έκλεισα αλλά τα ίδια!! τώρα 1 μήνα και κάτι είναι για service !! έλεος δηλαδή Παράθεση
k1ng Δημ. January 3, 2008 Δημ. January 3, 2008 Αυτο με τα πληκτρα αφης το χα παθει 4 μερες αφοτου το αγορασα...1 1/2 μηνα παιδευομαι με τα σερβις..εχουν βαρεθει να με βλεπουν,κολλητοι εχουμε γινει:)!Kaλο κ το W810 αλλα προτιμω καλυτερα το W580.Σκεφτομαι κ την αγορα του P1i αλλα φοβαμαι μην μ βγει ευπαθη κ κλαιω παλι τα $ μ!Παντως μετα απ οσα τραβηξα εγω θα συνιστουσα μακρια απο K850.Μπορει να ημουν η περιπτωση αλλα εχω ταλαιπωρηθει τοσο π χω αγανακτησει! Παράθεση
maxxx Δημ. January 3, 2008 Δημ. January 3, 2008 και τι σου λένε για την αιτία ?? θέμα λειτουργικού ? Παράθεση
Scottas Δημ. January 3, 2008 Δημ. January 3, 2008 Paidia epeidi menw stin Eparxia mporeite na mou peite an kapoio SE Point einai anoikto stin a8ina paraskeui apogeuma kai savvato prwi??? Epeidi dn menw A8ina einai ligo duskolo gia mena na to afisw ekei poso mallon na paw mexri tis 5 pou einai anoiktoi nomizw!!! Filika Scottas;) Παράθεση Μέγιστο μέγεθος υπογραφής 16 kiB
ndiam Δημ. January 3, 2008 Δημ. January 3, 2008 Πήρα το Sony Ericsson K850i αλλά, ρε παιδιά, μου φαίνεται λίγο μεγάλο για τα γούστα μου. Άσε που τα πλήκτρα αφής που έχει είναι μόνο 3! Τέλος πάντων, ξέρετε που μπορώ να το βάλω αγγελία; Αυτοί οι λόγοι λέτε να αποτρέψουν κάποιον από το να το αγοράσει μεταχειρισμένο; Κι επίσης, τί τιμή θα το βάζατε. 350 ευρώ καλά δεν είναι; Παράθεση
k1ng Δημ. January 3, 2008 Δημ. January 3, 2008 Δεν ξερω τι ειναι γιστι δεν το χω παει.Χθεσ το πηρα απ το σερβις κ την ωρα π μ εβγαλε το προβλημα ειχαν κλεισει.Θα το παω αυριο να το κοιταξουν κ μετα θα κοιταξω να το διωξω.Ολοι λενε πως το W580 εχει προβλημα γιατι σπανε τα πληκτρα.Να κοιταξω για P1i?Δωστε καμια βοηθεια γιατι δεν ειμαι διαθετημενοσ να πεταξω αλλα $! Παράθεση
arisgr0 Δημ. January 3, 2008 Δημ. January 3, 2008 Eleos! Opoios kserei as me voithisei sas parakalo! Htes to mono pou ekana itan na vgalo tin karta mnimis kai na valo mia alli kai apo tote: Den mpainei sta "ta paihnidia mou" oute stis "oi efarmoges mou"! Leei oti "I energia apetihe" Imarton!Ekana RITHMISEIS>GENIKES>EPAN.RITHMISEON alla tipota! Eho vodafone me tin 029. Piga na kano to update service mpas kai ginei tipota alla leei oti den iparhei neoteri ekdosi Παράθεση
Scottas Δημ. January 3, 2008 Δημ. January 3, 2008 Eleos! Opoios kserei as me voithisei sas parakalo! Htes to mono pou ekana itan na vgalo tin karta mnimis kai na valo mia alli kai apo tote: Den mpainei sta "ta paihnidia mou" oute stis "oi efarmoges mou"! Leei oti "I energia apetihe" Imarton!Ekana RITHMISEIS>GENIKES>EPAN.RITHMISEON alla tipota! Eho vodafone me tin 029. Piga na kano to update service mpas kai ginei tipota alla leei oti den iparhei neoteri ekdosi uparxei alla den tin kanei mesw seus distixws!!! epeidi ta xw parei me tin suskeui paw na kanw ena debrand sto 9volto aurio kai eimai wraios kai moiraios:p:happy::lol::lol: Παράθεση Μέγιστο μέγεθος υπογραφής 16 kiB
RivalGT Δημ. January 3, 2008 Δημ. January 3, 2008 Παιδιά, επειδή είμαι καινούριος, μπορει να μου πει κάποιος πώς μπορώ να κατεβάσω το καινούριο firmware(R1DA038) και πώς να το εγκαταστήσω?:rolleyes: Παράθεση [sIGPIC][/sIGPIC] ►http://www.totobay.com◄ Ολοκαίνουρια κινητά από Κίνα. Τιμές?.. Απλά δείτε!!
Scottas Δημ. January 3, 2008 Δημ. January 3, 2008 Παιδιά, επειδή είμαι καινούριος, μπορει να μου πει κάποιος πώς μπορώ να κατεβάσω το καινούριο firmware(R1DA038) και πώς να το εγκαταστήσω?:rolleyes: Dn einai dia8esimo akoma mesw seus;) opote perimene kana mina!!!:p R1DA038 is ava at SE service centers to be updated. However SE are still placing R1DA038 on the SEUS and can take upto 4 weeks from the start to place on there. From what i understand SE are hoping to have most of the firmwares on there by W05 / W06. Παράθεση Μέγιστο μέγεθος υπογραφής 16 kiB
RivalGT Δημ. January 3, 2008 Δημ. January 3, 2008 Dn einai dia8esimo akoma mesw seus;) opote perimene kana mina!!!:p Τί είναι το seus και αυτοί που το έχουν ήδη κατεβάσει πώς το κατέβασαν?:wacko::rolleyes: Παράθεση [sIGPIC][/sIGPIC] ►http://www.totobay.com◄ Ολοκαίνουρια κινητά από Κίνα. Τιμές?.. Απλά δείτε!!
Scottas Δημ. January 3, 2008 Δημ. January 3, 2008 Τί είναι το seus και αυτοί που το έχουν ήδη κατεβάσει πώς το κατέβασαν?:wacko::rolleyes: Autoi pou to perasan einai mesa stin sony ericsson;) To neo firmware einai dia8esimo MONON sta SE points!!! to SEUS einai to programma anava8misis logismikou ton swn SE!!!:lol::lol::lol::lol::lol: Παράθεση Μέγιστο μέγεθος υπογραφής 16 kiB
tzilas Δημ. January 3, 2008 Δημ. January 3, 2008 καλησπερα και καλη χρονια.ξερεις καποιος που μπορω να βρω το mobile spy η το bluetooth spy software Παράθεση
liarito Δημ. January 3, 2008 Δημ. January 3, 2008 Eleos! Opoios kserei as me voithisei sas parakalo! Htes to mono pou ekana itan na vgalo tin karta mnimis kai na valo mia alli kai apo tote: Den mpainei sta "ta paihnidia mou" oute stis "oi efarmoges mou"! Leei oti "I energia apetihe" Imarton!Ekana RITHMISEIS>GENIKES>EPAN.RITHMISEON alla tipota! Eho vodafone me tin 029. Piga na kano to update service mpas kai ginei tipota alla leei oti den iparhei neoteri ekdosi kai gw to idio exw pathei Παράθεση
kotsianis7 Δημ. January 3, 2008 Δημ. January 3, 2008 Για να λυθεί το πρόβλημα με τα παιχνίδια και τις εφαρμογές πρέπει να γίνει πλήρες φλασάρισμα του τηλεφώνου με την έκδοση λογισμικού R1CA037.Κοινώς,πρέπει να περαστεί η συγκεκριμένη έκδοση λογισμικού στη συσκευή.Διαγράφονται τα πάντα,οπότε φροντίστε να κρατήσετε αντίγραφα ασφαλείας απ'ό,τι έχετε στη συσκευή σας.Δεν υπάρχει άλλος τρόπος,ώστε να μη διαγραφεί το περιεχόμενο που έχετε στο τηλέφωνό σας.Επίσης,μπορεί να γίνει και από το σπίτι η διαδικασία με πιστωτική κάρτα και 10 ευρώ χρέωση. Παράθεση
paulos_popov Δημ. January 4, 2008 Δημ. January 4, 2008 kai pou mporoume na to kanoume plires firmarizma????egw to ekana anavathmisi apo 029 se 037 alla pali eksakolouthi na min mapinei sta paixnidia kai tis efarmoges.OMG Παράθεση
Bruno Δημ. January 4, 2008 Δημ. January 4, 2008 Καλημέρα και καλή χρονιά. Έχω εδώ και μερικές ημέρες (το έφερε ο Άγιος Βασίλης!:happy:) το κινητό με VF μενού. Δεν έχει φάει κανένα κόλλημα (έως τώρα) και γενικά η εντύπωση που μου έχει δώσει είναι καλή. Αυτό που με προβληματίζει και θα ήθελα την βοήθειά σας, είναι ότι όταν θέλω να στείλω μια επαφή μέσω μηνύματος αυτόματα το μήνυμα γίνεται MMS. Στο παλιό και αγαπημένο Κ750 έστελνε την επαφή ως "μεγάλο μήνυμα" με 2 SMS. Άν ξέρει κάποιος ας πει αν μπορούμε κάπως να αλλάξουμε αυτήν την συμπεριφορά ή είναι ένα από τα καινούρια χαρακτηριστικά του τηλεφώνου :mad: Παράθεση
Scottas Δημ. January 4, 2008 Δημ. January 4, 2008 Καλημέρα και καλή χρονιά. Έχω εδώ και μερικές ημέρες (το έφερε ο Άγιος Βασίλης!:happy:) το κινητό με VF μενού. Δεν έχει φάει κανένα κόλλημα (έως τώρα) και γενικά η εντύπωση που μου έχει δώσει είναι καλή. Αυτό που με προβληματίζει και θα ήθελα την βοήθειά σας, είναι ότι όταν θέλω να στείλω μια επαφή μέσω μηνύματος αυτόματα το μήνυμα γίνεται MMS. Στο παλιό και αγαπημένο Κ750 έστελνε την επαφή ως "μεγάλο μήνυμα" με 2 SMS. Άν ξέρει κάποιος ας πει αν μπορούμε κάπως να αλλάξουμε αυτήν την συμπεριφορά ή είναι ένα από τα καινούρια χαρακτηριστικά του τηλεφώνου :mad: Kane ena debrand sto 9volto me 25 euro kai eisai arxontas;) Kai to 8ema tis eggisis an pa8ei kati sovaro pas vazeis pali vodafone live firmware kai pali eisai arxontas:!::!: Παράθεση Μέγιστο μέγεθος υπογραφής 16 kiB
griniaris Δημ. January 4, 2008 Δημ. January 4, 2008 418 ευρώ στο ΠΛAIΣIO.τώρα το είδα. Συμφωνώ με τον giannitsia Παράθεση [sIGPIC][/sIGPIC]
Bruno Δημ. January 4, 2008 Δημ. January 4, 2008 Kane ena debrand sto 9volto me 25 euro kai eisai arxontas;) Kai to 8ema tis eggisis an pa8ei kati sovaro pas vazeis pali vodafone live firmware kai pali eisai arxontas:!::!: Σε ευχαριστώ. Είμαι σχεδόν έτοιμος να κάνω debrand από το davinci:X Μήπως ξέρεις αν με το νέο firmware θα μπορώ να κάνω τις μελλοντικές αναβαθμίσεις κανονικά από το SEUS ή πρέπει να χρησιμοποιώ πάντα κάποιο "παράλληλο" τρόπο; Παράθεση
