Τα πάντα για το Frog Mobile
sideras1985
3 ώρες πριν, Manos_Wu said:
so....if i need voice...144€ is not better then 15€ bundle card offer
The 15€ bundle card gives you unlimited data only during the summer. After the summer offer ends, it gives you around 70GBs. The 144€ offer is for 1 year.
  • Απαντήσεις 23,2χιλ.
If you want to keep your number and get the offer again, you can move your number to a different carrier's pay as you go system then return to frog getting the offer as a new number on their system, as long as you do the transfer back and yearly bundle purchase at the frog shop at the same time. If you do that, you'll need to pay the minimum renewal cost of the new carrier so ideally you should stay with them for a month to use up the money/benefits and then return, but nothing stops you from returning reverb in case the same day if you want to.
In case you don't know, q (Nova) and cu (Vodafone) both have yearly offers for data/calls/SMS.
With q it's unlimited data and calls plus 100sms monthly for 99 euros yearly but doesn't cover any EU usage and you can only order over the phone paying by bank transfer. With cu it's 300GB, unlimited calls, 100sms monthly for 95 euros. You can use your calls/SMS in the EU with 11gb/month data allowance and you can order everything online.
Note that cosmote's network (frog) is considered the best, then probably comes Nova's in regards to internet speed/quality of service and last is Vodafone but that depends on the area.
Edited by spiliot
I think cosmote is the best.
15 minutes ago, sou_d said:
Universal γίναμε. Νόμιζα πως μπήκα στο .com 🤣
Προετοιμασόμαστε για τη στιγμή που ο Trump θα εφαρμόσει τέλους για κάθε εθνικό domain 😉
if i transfer to nova for a month...How long does it take to switch? Will there be any signal interruptions in the middle?
34 minutes ago, GREGORYMO said:
Δεν με αφήνει να κάνω ανανέωση υπόλοιπου.
Ισχύει σε άλλους?
απο που προσπαθεις να κανεις ανανεωση και σε ποιο step σου κολλαει;
9 ώρες πριν, VIPdriver said:
Context please (μιας και πιάσαμε το αγγλικό)
Linguaphone; Εκμάθηση ξένων γλωσσών ενώ κοιμάστε; (υπήρχε και αυτό για όσους θυμούνται)
Πρέπει να έχεις δει την ταινία για να το καταλάβεις...
Πάει για πέσιμο ο φίλος "γύπας" σε ξένη (Ελληνίδα τελικά) και έχει ηχογραφήσει ατάκες στα αγγλικά στην κασέτα ...
"You are beautiful, i love you" 😁
On 31/7/2025 at 9:10 ΜΜ, Vasileios said:
Εχω αγοράσει από wifigreece και είναι αξιόπιστο αλλά αργει να στείλει κάρτα.
Τελευταία προτιμώ άλλο site που δίνει αμέσως κωδικό ( buypoint.gr )
Αγοράζω όμως την 15άρα που δίνει απεριόριστο internet, την 10εύρη δεν την χρησιμοποιώ.
Όταν λες αργεί να στείλει κάρτα; Κάνει μέρες ή βδομάδες; Εμένα με κάλυπτε η 10ευρη γιατί βάζω το πακέτο με τα 8,90.
Στο άλλο σαητ που λες στη 10ευρη φρογκ γράφει "Frog Mobile Internet Card 10€
10 GB Internet γενικής χρήσης
200’ προς όλους
400΄προς Frog"
Αυτά είναι δώρα με την ενεργοποίηση της κάρτας ή θα σου αφαιρέσει τα 10 της ανανέωσης για να σου τα βάλει; Δεν έχω καταλάβει. Edit: πήρα τηλ. Δεν σου βάζει 10Ε κάρτα. Σου δίνει μόνο τις παροχές που γράφει τις οποίες πληρώνεις 10Ε. Εγώ νόμιζα ότι γίνεται ανανέωση του υπολοίπου ανεξάρτητα από τα δωρα. Άρα, δεν συμφέρει με την καμία γιατί αυτά κοστολογούνται 8,90Ε στο πακέτο της φρογκ.
Edited by piter_stailad
200’ προς όλους
400΄προς Frog"
Και ποιό το νόημα αφού αυτό το πακέτο στη φρογκ κάνει 8,90 και δίνει τα ίδια;
Οπότε καλύτερα η ανανέωση των 13 ευρώ με την οποία θα πάρεις λίγο παραπάνω χρόνο και 2 ευρώ για το BOX, δεν εχει αξία να κάνεις  την 10 ευρη. Εκτός αν δεν έχει κάποιος  13 ευρώ....
Ναι δεν το συζητάμε, των 13 είναι μια χαρά. Απλά νόμιζα ότι υπήρχε και 10ευρη κάρτα η οποία σου έμενε σαν υπόλοιπο. Δεν κάνω τόσο μεγάλη χρήση, τα δεδομένα πάνε άχρηστα συνήθως. Είμαι όλη μέρα σε wifi και σταθερό τηλ.
2 ευρώ για το BOX?
31 minutes ago, greatst said:
2 ευρώ για το BOX?
με κάθε online ανανέωση πάνω από 12 ευρώ, πέρνεις 2 ευρώ για το BOX το App παραγγελιών φαγητού της Cosmote .
6 minutes ago, yyyy said:
Και πώς το παίρνεις αυτό το κουπόνι; Το βλέπεις κάπου στην εφαρμογή της Cosmote;
Στο στέλνουν με sms.
Σε μένα πώς και δεν έχει έρθει ποτέ; Πάντα κάνω online ανανέωση μέσω της εφαρμογής της Cosmote!
Από frog εφαρμογή πρέπει να κάνεις.
Online ανανεωση μονο απο το frog app και θα μαθεις το κουπονι μονο με sms. Στο frog app εχουν bug στο να το εμφανισουν σωστα.
Αν δεν λαβεις sms, μου εχει τυχει, επικοινωνησε μαζι τους.
Δεν ξερω αν θα βγαλεις ακρη καθως δεν το εκανα.
Edited by runner70
Πρέπει να κάνεις από FROG App και μόνο για τον δικό σου αριθμό με τον οποίο είναι συνδεδεμένο το App.
