Συζητήσεις / Προβλήματα / Απορίες για κινέζικα κινητά
http://i2.wp.com/www.gizchina.com/wp-content/uploads/images/IMG_2629.png
http://g02.a.alicdn.com/kf/HTB1.f29GFXXXXXqaXXXq6xXFXXX6/200341558/HTB1.f29GFXXXXXqaXXXq6xXFXXX6.jpg?size=156423&height=900&width=900&hash=e3f13e599c1a9d400c7de882d003f395
Hardware Chipset MT6582 ( Quad core 1.3Ghz Processor)
Frequency(MHZ) WCDMA 850/1900/2100 & GSM850/900/1800/1900
Sim card Support Dual sims dual standby
OS Android 4.4.4
GPS Support
FM Radio Support
Bluetooth Support
Compass Support
G-sensor Support
Light-sensor Support
Proximity sensor Support
Speaker AAC 1511
Network 3G WCDMA 3.75G (HSDPA+ 42.2Mbps, HSUPA+ 11.5Mbps), Support WIFI AP
EDGE Support
GPRS Support
WAP Support
WI-FI Support
Display Main Display 5.5'' HD IPS LCD 1280* 720
Touch Lens G+F multi-points capacitive touch
Camera Main Camera 13.0 MP
Sub Camera 5.0 MP
Memory Internal Memory 1GB+8GB
External Memory Micro SD card ( T-FLASH card), max 32GB
Batteries & IO Capacity(mAh) 3000mAh or 2500mAh
Charger USB Micro 5Pin
Connector USB Micro 5Pin
Earphone 3.5mm
Others Color Black, white,Gold
Language Bahasa lndonesia, Malay,English,Danish,Deutsch,German,
Spanish, Portuguese (Brazil), Portuguese (Portugal), Italian, Dutch, French,
Polish, Romanian, Turkish, Russian, Arabic, Indonesian, Thai, Vietnamese, Hindi,
Hebrew, Simplified Chinese, Traditional Chinese
We can support thirty six languages.
146,4x74,9x10mm
Certification CE/Rohs/Sar
τιμη 110$ http://www.to2c.com/dingding-sk3-pro.html
Ding Ding Technology Malaysia
http://www.dingdingmobile.com.my/
Edited by valanths
  • Απαντήσεις 8,4χιλ.
Σύστημα: Android 4.4 KitKat®
Επεξεργαστής: 1,5 GHz / Octa Core / Mediatek MT6752M 64-bits /
Γραφικός επεξεργαστής: Mali-T760MP2
Μνήμη: Αποθήκευση: 16 GB / Μνήμη RAM: 2 GB /
Υποδοχή: microSD /
Ισχύς: 32 GB
Εμφάνιση: 5,0" / IPS LCD /
Ανάλυση: 1280 x 720 pixels / 295 ppi
Κάμερα: 13 Mpixels / Flash: LED /
Μπροστινή κάμερα: 5 Mpixels /
Βίντεο: 1080p @ 30fps
Δίκτυα: 4G: LTE Cat. 4 / 3G: 850/900/1900/2100 MHz / GSM: 850/900/1800/1900 MHz nano SIM
Ασύρματη σύνδεση: Bluetooth: 4.0+EDR +A2DP / Wifi: IEEE 802.11 b/g/n
Συνδεσιμότητα: Jack 3.5 mm / micro USB GPS: GPS/A-GPS
Αισθητήρες: Επιταχυνσιόμετρο, Πυξίδα, Αισθητήρας εγγύτητας
Dual SIM
Μπαταρία: 2330 mAh
Βάρος: 120 γραμμάρια
Διαστάσεις: 143 x 69 x 7,8 mm
Το design που συνδυάζει στυλ και φινέτσα
Οι αποδόσεις υψηλής ποιότητας (οκταπύρηνος επεξεργαστής, 2 GB μνήμης RAM, οθόνη 5" IPS HD 720p, κάμερα 13 MP, σύνδεση 4G κατηγορία 4,...)
Άλλη μία Κινέζικη ναυαρχίδα από εταιρία που εγώ πάντως δεν έχω ξαναακούσει. Δεν τις λείπει τίποτα θα έλεγα, και έρχεται και με Android Lollipop. Αρκετά μέτριο από design, και με μεγάλη μπαταρία 3000mAh. Το εντυπωσιακότερο όμως είναι ότι έχει διπλή οθόνη, μια κανονική και μια δεύτερη πίσω, δείτε το βίντεο παρακάτω
Χαρακτηριστικά
Οθόνη: 5,5'' 1920x1080p
CPU: Octacore MTK6572 @ 1,7GHz
RAM: 3GB
ROM: 32GB, με θύρα microSD
Κάμερα: 13MP κύρια, 8ΜΡ μπροστά
OS: Android Lollipop 5.0
Μπαταρία: 3000mAh
Υποστήριξη 4G δικτύων
Dual SIM
Προσωπικά δεν θα το επέλεγα μιας και είναι από άγνωστη μάρκα, θα προτιμούσα ακόμα και σήμερα το 1+1 και ας είναι λίγο πιο παλιό.
Για όποιον ενδιαφέρεται υπάρχει για προ-παραγγελία στο efox-shop στα €274
Edited by paris_89
goto fail;
goto fail;
Με διαφορά ο πιο όμορφος κλώνος του g3. Ειλικρινά όμως, ποιος ονόμασε έτσι την κακομοιρα την εταιρία?
images?q=tbn:ANd9GcSajrrZEo6APx0nLGx13EufEf6HGZt6oIMxyclgz-36fQJFB7gC
could you do it again?
ThL W8 Beyond , OnePlus 3T
Είναι ρίσκο, αλλά και τούμπανο το άτιμο...
Εγώ δεν θα το ρίσκαρα φίλε, αν και με την ισοτιμία €-$ χαλαστήκαμε πολύ. Το 64GB OnePlus One θα κοστίζει για μερικές μέρες ακόμα €300 αλλά από την άλλη τρίτη και μετά πάει στα €350! Μεγαλώνει η τιμή.
Δεν έχω πρόβλημα να ψωνίσω Κινέζο αλλά θα πρέπει να έχει δείξει κάποια δείγματα πρώτα..
Τελικά το dual screen που έλεγε στον τίτλο το efox δεν ήταν τυπογραφικό! Είναι όντως dual screen όπως το yotaphone! Δείτε:
Edited by athanaso77
Συνεχόμενα μηνύματα
goto fail;
goto fail;
Αλλο ενα κινητο που δεν του λειπει τιποτα!
5.5" Type IPS 1080 x 1920
4x 2.0 GHz ARM Corte MediaTek MT6595M
Octa-Core FrequenGHz 2 GHz
RAM 3 GB
Antutu Score 44.225
Storage Capacity 32 GB
Camera 13 Mps Sensor Sony Exmor
Selfie Mpx 4.9 Mpx
Networks
4G LTE
1800 , 1900 , 2300 , 2600 , 800 MHz
3G
1900 , 2100 , 900 MHz
2G
1800 , 1900 , 850 , 900 MHz
SIM Dual SIM
Navigation
Supports
A-GPS , GLONASS , GPS
Others
NFC
Yes
Audio Jack
Yes
Computer sync
Yes
Infrared
Yes
OTA sync
Yes
Radio FM
Yes
Tethering.
Yes
Battery
Capacity
3350 mAh
Type
Li-Ion
Others
Non-removable
Σε τιμη απο 250 ευρω!
Τι λετε ειναι ρισκο η αγορα του? με αλλα 50 μεχρι την τριτη παίρνεις το 1+1...
http://www.devicespecifications.com/en/model/7dd332a5
Edited by THANKIN
Του λειπει.Η αξιοπιστια.Αυτη η Siswoo πεταει 2-3 συσκευες αντι να επικεντρωθει σε μια αλα Xiaomi,OnePlus.Μου θυμιζει Elephone και Doogee...
Οι βλάκες είναι γεμάτοι αυτοπεποίθηση και οι ευφυείς γεμάτοι αμφιβολία. Ράσελ Μπέρτραντ
Σίγουρα το θέμα εκει ειναι στην αξιοπιςτια. Γιατι εδω μιλάμε για ενα πολυ σεβαστό ποσο. Την ξερει κανεις ? εχει καποια παρουσία ως τώρα?
Να ποιοι ειναι μεσα απο το site τους:
Who are us
Siswoo, established in 2014 in Madrid, Spain, designs Smartphones created to make the customers feel an unique experience, throughout the interaction with innovating design and high technology.
Siswoo intends to be a global brand committed with the development of High Quality Smartphones. Currently, Siswoo, with more than 500 employees, is involved in an internationalization and expansion project, with the main object to be a global company as we consider that it is the only and best formula to commercialize with a guaranteed success all Siswoo products worldwide. Siswoo smartphones are characterized by an attractive and leading design, high speed chips with a unique wide screen resolution, High-Definition camera, a simple and update interface which combine maximum efficiency, ease of use and functionality with the essential guarantee to enjoy your smartphone.
Our Philosophy
SISWOO commitment is to meet all our customers needs by our communication channels like the call-centre, after-sale service, marketing, social media, etc. Following our corporate philosophy to reach perfection, SISWOO focuses exclusively on developing innovative and user-friendly smartphones for consumers, improving what already exists and finding new solutions to satisfy the needs and explore all the posibilities of the digital age.
Our goal is to go a step further on the smartphone industry, providing solid and functional terminals with an optimum durability as well as the latest technological advances and innovative features.
http://www.siswoo.com
Πάντως το site τους και ο τρόπος παρουσίασης των συσκευών ειναι υποδειγματικός!
Edited by THANKIN
Νομίζω πως σε αυτή την τιμή... Δεν σε νοιάζει τίποτα. Επελαυνει η siswoo εδώ και κάτι μέρες.
Τελικα αξιζει σε αυτα τα λεφτα;
Κοιτά βαςη προδιαγραφων απλα νομιζω ειναι στις 2-3 κορυφαίες επιλογές στα λεφτα του. Τωρα αν ειχε και κατω απο 200 ευρω απλα θα έκλεβες εκκλησία! Οπως γράφει υπαρχει και ευρωπαϊκή αποθήκη για οσους δεν θελουν να μπλέξουν Κίνα και αναμονές, φυσικα με το ανάλογο αντίτιμο.
Το ποσο vfm ειναι φαίνεται αν σκεφτούμε οτι στα χαρτιά ανταγωνίζεται το meizu mx4 όντας 90 ευρω φθηνότερο! Χάνει σε ποιοτητα κατασκευής εμφανιση καμερα και λίγο επιδοσεις, κερδίζει σε μπαταρια συνδεσιμότητα και εχει 3gb ram έναντι 2 , ενω εχει και τα καλούδια ntfs ir radio που δεν εχει το αλλο και φυσικα ειναι και δικαρτο
http://www.minideal.net/lenovo-vibe-x2-4g-lte-mtk6595-2-0ghz-android-4-4-5-0inch-1080p-ram-2gb-rom-32gb-13-0mp-smartphone.html
Γιατι να προτιμησει καποιος αυτο το κινητο και οχι πχ το vibe X2 ??
Γιατί μπορεί να θελει 5.5 "?!
Γιατι μπορει να θελει 3gb ram?
Για το nfs για το ir?
Δλδ για τα 40 ευρω παραπάνω που ζητά το monster παίρνεις αρκετα. Φυσικα απο την αλλη εχεις την εγγυημένη ποιοτητα κατασκευής της Lenovo! Χωρίς φυσικα να γνωρίζουμε την ποιοτητα του αλλου, αλλα λογικα για να δίνει αυτα τα specs σε αυτη την τιμη θα ειναι σκαλί ή σκαλιά κατω. Εκτός αν και εδω οπως στην 1+1 μπαίνουν μεσα!
Ένα αρκετα αναλυτικό review. Πιάνει μονο 38.000 στο antutu που δεν συμβαδίζει με τις προδιαγραφές του επεξεργαστή αλλα ποιος ξερει τι παίχτηκε.
Αυτό το χτύπησε κανενας ήρωας?
http://gizchina.it/2015/03/siswoo-r8-monster-unboxing-di-gizchina-it/
Περιμένουμε την πλήρη επισκόπηση του σε λίγες μερες για να δουμε πως τα παει!
Γιατι απο προδιαγραφές ειναι meizu mx4 killer!
--- Από Ομάδα Διαχείρισης ---
Οπότε το ερώτημα είναι.... Ρισκάρει κανείς και έχει ένα dual screen τηλέφωνο (από τα ελάχιστα στον κοσμοθ)?
Καλησπέρα. Υπάρχει εδώ Ελλάδα θήκη ή μεμβράνη;
Δεν βρήκα κάτι από Ελλάδα μόνο από ebay.
Και να τονίσουμε πως η 2η οθόνη δεν είναι ακόμη μία LCD, αλλά Ε-Ιnk. Κοινώς το κάνει ένα ebook reader για ξεκούραστο διάβασμα και τρομακτικα χαμηλή κατανάλωση.
Σύμφωνα πάντα με τα specs Που δίνει στο youtube video τους
SISWOO R9 Comes with Dual Screen,The first chinese E ink Screen 4G Smartphone.Powered by the latest 64bit MT6752 OctaCore Processor.
also equipped with 3GB Big Memory,and 32GB Total storage,
and it will pre-install Android 5.0 OS.
Highlights
- 5.5 Inch Screen, 1920*1080 Pixels
- MTK6752 1.7GHz Octa Core
- Band: GSM 850/900/1800/1900MHz, WCDMA 900/1900/2100MHz, FDD-LTE B1/B3/B20, TDD-LTE B39/B40/B41, Support 2G & 3G & 4G LTE Network
- 3GB RAM + 32GB ROM
- 13 MP Back Camera + 8 MP Front Camera
- Android 5.0 System
Το μόνο κακό είναι πως με το ρυθμό που σπάμε τις οθόνες στα τηλέφωνα μάλλον πρέπει να βρούνε τρόπο να στέκεται όρθιο για να μην γρατζουνιστεί.
Edited by Kamui
Παλικάρια, όταν λέμε ότι δεν έχει ελληνικά μενού, στις επαφές δεν έχει ελληνικά στην scroll bar δεξιά?
Highlights
Οι e ink δεν καίνε καθόλου μπαταρία όσο είναι αναμένες, μόνο όταν αλλάζει το περιεχόμενο που προβάλλουν.
Γενικά, μακάρι να δημιουργηθεί λίγη κίνηση γύρω από το κινητό, μπας και βρεθούν οι πρώτοι τολμηροι του forum.
Με 2000mah μπαταρια και FHD δεν πας πουθενα.
Εγώ πάντως βλέπω στο coolicool να λένε ότι έχει 2600mAh μπαταρία και έχει καλά χαρακτηριστικά, και η μπροστινή κάμερα είναι 5άρα, με 2GB Ram. Για 110$ δεν είναι και άσχημο για κινητό και κατ' εμέ τουλάχιστον είναι πιο αξιόπιστο εάν θέλει κάποιος να το πάρει, το Coolicool από το Pandawill. Έχουν και θέμα εδώ στο φόρουμ, οπότε τους βρίσκεις. Τώρα για το εάν θα πάει παρακάτω από jellybean, και πολλά άλλα κινητά δεν πάνε Kit Kat.
Δείτε τωρα! Στο efox το βρισκω ως 5,7 ιντσες , στο panda maxon x3 mini 5 ιντσες και στο gearbest το βρίσκουμε ως MEXON x3 5,7! Τι γίνεται;
they are different.
Για να δούμε... Ας ελπίσουμε να είναι ένα άρτιο και πλήρως smartphone, και να δημιουργηθεί μια κάποια κίνηση εδώ μέσα...
Δε βρεθηκε ακομα κανενας τολμηρος;
Jiayu G3 (a lot of time ago)...
Jiayu S3 (for spare)
Ulefone T1
Elephone S8
Xiaomi Redmi Note 8!!!
Αν δεν βγουν κάποιες σοβαρές κριτικές δεν νομιζω οτι το τολμά κανεις να το πάρει. Άλλωστε εδω μιλάμε για 250. Ειναι αρκετα τα λεφτα για να το πάρεις μονο απο τις προδιαγραφές. Για τα μόνα που μπορεις να πεις για το κινητο βάση προδιαγραφών ειναι οτι δεν ειναι 64 αρης ο επεξεργαστής, ο οποιος όμως κατα τα αλλα τα σπάει, οτι δεν τραβάει slow motion, και οτι δεν εχει δακτυλικό αποτύπωμα! Οτι αλλο παίζει στα το εχει!
Edited by THANKIN
