Android Tablets: Σχόλια, τιμές, συγκρίσεις, εντυπώσεις
rigasnic1982
Καλησπέρα,
Αν και είχα καταλήξει στο Hyundai T10 καθώς ήθελα να κάνω και τηλεφωνικές κλήσεις, λόγο του ότι σταμάτησε να παράγεται είμαι και πάλι στην αναζήτηση. Λογικά δεν υπάρχει άλλη 10άρα συσκευή να να κάνει κάτι τέτοιο, συνεπώς αυτό που ψάχνω είναι 10άρι, με 3G, GPS κάπου στα 200 ευρώ. Καμιά αξιόπιστη επιλογή;;
http://briefcase.pathfinder.gr/download/383320/234.gif
  • Απαντήσεις 5,8χιλ.
Παιδια τη λετε για αυτο
http://e-ceros.com/ceros-revolution-tablet-white-16gb/
αξιολογο το βλεπω και ολοκαινουργιο , δεν βρηκα καπου καποιο θεμα οποτε ας το ξεκινήσουμε:)
9.7 Inch Quad Core Android 4.2 Retina Screen Tablet "Ceros Revolution", which includes 2GB RAM, 1.6GHz CPU and 2048X1536 resolution is bringing the revolution to the Android tablet market. Additionally, as a limited time offer, a free protective case with a kick stand will be included with every order!
Prepare to step up against all authority and opposition with the “Ceros Revolution”, a stunning 9.7 inch of pure entertainment power that can be controlled due to the sensitive 10 point touch IPS capacitive multi touch display that detects even the slightest touch of the fingertip. The things that makes this tablet a real force to be reckon with is that not only does it have a vicious quad core 1.6GHz processor but it also has a Mali-400 graphics processing unit. The Mali 400 enables a wide range of different use cases, like with this “Ceros Revolution” tablet PC, to be addressed with just a single IP. One single driver stack for all multi-core configurations makes application porting, system integration and maintenance become easier. Multi-core scheduling and performance scaling is handled completely within the graphics system, with no special considerations necessary from the application developer. The quad core 1.6GHz processor and 2GB of RAM guarantees the “Ceros Resolution” operates faster and effectively than singular and dual core devices and as a result even the most demanding applications will operate smoothly with no lagging.
They say a picture is a thousand words but if you do the math and realize that 2048x1536 is worth a lot more than just a thousand words as this is the display resolution that the “Ceros Resolution” is. With a 3rd generation IPS (In-plane switching) retina screen and 264PPI (Pixels per inch) the end result is a fantastic quality display that will enhance your viewing experience by playing your media in the way it should be displayed. Additionally this beautiful screen is protected with an included free screen protector that will keep scratches and smudges at bay.
Never worry about the “Ceros Revolution” backing down due to limited battery power as it has a built-in 8000mAh battery that ensures this tablet has plenty of life left in it before it needs recharging. Take on a long international flight fully charge and you needn’t care if it will survive the whole flight as it has a battery time between 6 to 7 hours depending on the usage.
Capture them must see moments of the surrounding scenery, friends and family as the “Ceros Revolution” has a rear 5 megapixel camera as well as a front-facing camera that is more suit for self-portrait photos and video calling. To save these photos and your other media file the “Ceros Revolution” offers a mega 16GB of internal memory for storing data. If you find that 16GB is not enough then fear not because where there is a will there is a way, and with this tablet PC is has a cool way to expand the existing memory by up to 32GB via the built in micro SD port.
To operate this 9.7 inch tablet requires a clever and efficient operating system, therefore the “Ceros Revolution” comes with a pre-installed version of Android 4.2 Jelly Bean. This Android operating software will enable the user to change and alter the way this tablet works via settings as well as installing apps that can be selected from the Google Play store where over 700,000 apps await.
At a Glance…
9.7 Inch Android 4.2 Tablet
Quad Core 1.6GHz CPU
2GB RAM
16GB Internal Memory
2048x1536 IPS Retina Screen
8000mAh Battery
Free Protective Case with Kickstand Included (Limited Time Offer!)
Manufacturer Specifications
General
OS Version: 4.2
CPU: RK3188 Quad Core ARM Cortex-A9
GPU: Mali-400 MP Quad Core
Processor Speed (max): 1.6GHz (CPU), 533MHz (GPU)
RAM: 2GB
WiFi: 802.11 b/g/n
3G: WCDMA Via 3G WCDMA USB Dongle
Bluetooth
Adobe Flash
Portable WiFi Hotspot (3G Tethering)
Google Play
5 Megapixel Rear Camera + 0.3 Megapixel Front-Facing Camera
Mic and Speaker
Battery Size: 8000mAh
Usage Time: 6 to 7 Hours
Battery Standby: 72 Hours
Languages: Afrikaans, Amharic, Bahasa Indonesia, Dansk, German, English, Spanish, French, Italian, Magyar, Dutch, Polish, Portuguese, Vietnamese, Turkish, Greek, Russian, Arabic Thai, Korean, Chinese (Simplified), Chinese (Traditional), Japanese
Display
Display Size: 9.7 Inch IPS
Display Resolution: 2048x1536 JIA (264PPI)
Aspect Ratio: 4:3
10 Point Capacitive Multi Touch Display
Memory
Internal: 16GB
Micro SD Card up to 32GB
Media Formats:
Video: Mpeg1, Mpeg2, Mpeg4, SP, ASP, GMC, XVID, H.263, H.264, BP, MP, HP, WMV7/8, WMV9, VC1, BP, MP, AP, VP6/8, AVS, JPEG, MJPEG (1080p)
Audio: MP3, WMA, FLAC, AAC, WAV, OGG, MP2, MA4
Picture: JPG, BMP, GIF, PNG
eBook: PDF, EPUB, FB2, TXT, RTF
Ports
3.5mm Audio Out Port
Micro SD Card Slot
Mini USB
DC IN
HDMI
Sensors
Gravity Sensor
Accelerometer Sensor
Package Contents
Tablet PC
Power Adapter (Product Specific)
USB Cable (Product Specific)
User Manual (Product Specific)
OTG Cable (Product Specific)
Screen Protector (Product Specific)
Limited Time Offer Protective Case (Product Specific)
απ'ότι μου είπε χρήστης έχει και gps:!:
πρέπει όμως να έχει μεταφορικά από chinavasion,αν ξέρει κάποιος ας μας πει.
Υπομονη μεχρι Δευτερα , θα το εχω στα χερια μου και θα σας πω λεπτομεριες:)
Από που το πήρες;
Ασε...ηταν να το παρω απο καποιον που το ειχε 1 μηνα , αλλα το ακυρωσε...αλλα δεν ποναω θα το παρω απο chinavasion.
Το πρώτο 4g Κινέζικο tablet?:what:
http://pic.pandawill.com/media/banner/2014-01-14_17_57_58%E5%9B%BE%E7%89%871.png
http://pic.pandawill.com/media/banner/2014-01-14_18_00_21Allfine%20Fine9%20Glory%20a.png
:ninja:
Allfine Fine9 Glory 4G LTE RK3188 Quad-Core Android 4.2 Tablet PC with 2G RAM/32G ROM/Bluetooth/GPS/Dual-Camera/9″IPS Screen
General Specs
Product Type: Tablet PC
Brand: Allfine
Model: Fine9 Glory 4G LTE
Color: White
Operating System: Android 4.2
Network Support: 2G GSM: 850/900/1800/1900MHz;
3G WCDMA: 2100MHz
4G LTE:1800MHz / 2100MHz
CPU: Rockchip RK3188; ARM Cortex A9 Quad-Core
Processor Clock Speed: 1.6GHz
RAM/Technology: 2G DDR3
Languages: Czech, Dansk, German, English, Spanish, Russian, French, Italian, Dutch, Norwegian, Hebrew, Polski, Greek, Portuguese, Svenska, Turkey, Korean, Japanese, Simplified Chinese, Traditional Chinese
Buy CHina Cheap*Allfine Fine9*tablets pc*Wholesale
Supported Format
Video Format: MP4, AVC, WMV, AVI, SWF
Audio Format: MP3, MIDI, WMA, AMR, WAV
Image Format: JPG, HPEG, BMP, GIF, PNG
Ebook Format: PDF, TXT
Storage and Expansion
Hard Drive Type: NAND Fast Flash
Hard Drive Capacity: 32GB
External Memory: Support TF 32G MAX (not included)
Screen
Display Type: IPS
Display Size: 9″
Max Resolution: 1920*1280px
Battery & Power
Battery Type: Rechargeable 7500mAh Li-ion Battery
Power Device Type: AC Adapter
Voltage Required: 100-240V
Input/ Output Connectors
USB Ports: 1 x Micro USB2.0(Charging Port)
Audio Ports: 1 x 3.5mm Headphone Jack
HDMI Ports: 1 x Output MINI HDMI
Card Slots: 1 x TF Card Slot
SIM Slots: 1 x SIM Card Slot
Additional Features
Wi-Fi: 802.11 b/g/n
Bluetooth: Yes
GPS: Yes
4G Network: Support 4G Talk
G-sensor: Yes
Camera: front 2.0mega pixel;back 5.0 mega pixel
3D Games: Yes
Tools: 3D Games, MSN, Ebook, Android Market, MP3, MP4
Εδώ
http://dealsprime.com/tablet-pc/tablet-screen-size/9/allfine-fine9-glory-ltt-lte-tablet-pc-9-ips-1920-1280-4g-3g-gps-phone-calling-rk3188-1-6ghz-2g-ddr3-ram.html και εδώ http:// http://www.pandawill.com/allfine-fine9-glory-4g-ltefdd-tablet-pc-quad-core-90-inch-android-42-32gb-gps-white-p85549.html
Πώς σας φαίνεται? :rolleyes:
Edited by donkixoths
Προσθήκη video
General Specs
Brand: Allfine
Color: White
3G WCDMA: 2100MHz
Supported Format
Screen
Display Type: IPS
Display Size: 9″
Battery & Power
Additional Features
Wi-Fi: 802.11 b/g/n
Bluetooth: Yes
GPS: Yes
G-sensor: Yes
3D Games: Yes
Εδώ
Η allfine σε σχέση με pipo κλπ είναι καλύτερη η χειρότερη;
Δεν γνωρίζω κάτι περισσότερο για αυτή την brand
Η πλατφόρμα είναι Rockchip 3188 quad-core άρα γνωστή και με καλή υποστήριξη.
Το 4G modem είναι άγνωστο βέβαια - δεν αναφέρεται πουθενά ποιο chipset χρησιμοποιεί - και είναι το μόνο ουσιαστικά επίφοβο (κατά πόσο είναι συμβατό με τα δίκτυα εδώ).
Η AllFine είναι OEM PiPO, απλά έχει άλλο σετ ROM και GPIOs σε σχέση με τα ίδια τα PiPO.
No matter where you go, there you are!
https://www.facebook.com/net314 - http://freedrone.gr
Ναι η πλατφόρμα είναι οκ τους έστειλα email για το κατά πόσο το 4g modem που φοράει είναι συμβατό με το δικό μας 4g δίκτυο...Από ότι διάβασα υποστηρίζει και 2g/3g για χρήση του σε φωνητικές κλήσεις ;)
Call 2G/3G band : WCDMA 2100MHZ/GSM 850/900/1800/1900MHZ ( optional)
China*Mobile’s 4G Internet-enabled TD-LTE or FDD-LTE standard... αυτό που λέει δεν ξέρω αν εννοεί ότι είναι συμβατό μόνο με το Κινέζικο δίκτυο συμβατό :confused:
καταρχην πρεπει να ξεκαθαρισω μονος μου εαν θελω 3g!εχω κινητο καλο που εχει data και ξερω να κανω wifi tethering απλα μου εχει κατσει να εχει το ταμπλετ και 3g.μπορει και να μην το χρησιμοποιησω και ποτε!
http://www.minideal.net/cube-u55gt-talk79-7-9-android-4-2-quad-core-tablet-phone-ram-1g-16g-wifi-3g-gps.html
Cube u55gt talk 79... To πηρα πριν μια εβδομαδα στα 151 ευρω με τα μεταφορηκα. Ειναι τετραπυρηνο στα 1,2ghz εχει 3g ειναι και τηλεφω νο εχει οθοναρα αν και χαμηλης υποτιθεται αναλυσης εχει πολυ ομορφα χρωματα ισως καλυτερα απο το νεξους 4 που εχω, ξεκουραστο στη χρηση, μπαταρια αντεχει με φουλ φουλ χρηση και σαν τηλεφωνο και σαν ταμπλετ με παντα ανοιχτα data wifi μια μερα ανετα. Καθε βραδυ θελει φορτιση πρωι με το που ξυπναω το παιρνω στο δρομο και το βραδυ παλι φορτιση. Εχει τελεια ποιοτητα κατασκευης με μεταλικο πλαισιο και πλατη. Παιρνει καρτα sd εχει 16gb εσωτερικη μνημη. Το wifi του ειναι πολυ δυνατο και το gps κλειδωνει δορυφορους μπαμ μπαμ...
Καλορίζικο!
Απ'οτι λένε και άλλοι χρήστες είναι πολύ καλό με "μείον" την έλλειψη HDMI και την extra sd(δεν παίρνει).
Στο geekbuying το έχει πιο οικονομικά http://www.geekbuying.com/item/Cube-U55GT-MTK8389-1-2GHz-7-9-inch-Tablet-PC-Android-4-2-Quad-Core-IPS-Capacitive-Touch-Screen-1024-768-1GB-16GB-317543.html
Καλορίζικο!
OTG εχει να διαβαζει στικακια?
EDIT ακυρο ευχαριστω παιδια εχει 1gb ram εγω θελω 2gb!
http://www.minideal.net/cube-u55gt-talk79-7-9-android-4-2-quad-core-tablet-phone-ram-1g-16g-wifi-3g-gps.htmlhttp://www.minideal.net/cu...fi-3g-gps.html
έχω προσωπικό ενδιαφέρον για την κατηγορία phone tablets
(ψάχνω επειγόντως για "ελαφρύ 7 -8 ")
θα ήθελα λίγες πληροφορίες παραπάνω :)
Edited by yellowsubmarine
Καλορίζικο!
ετσι ειχα διαβασει οτι δεν εχει θυρα sd αλλα για μεγαλη μου εκπληξη εχει θυρα sd.... η μπαταρια του ειναι 4400Mah δεν τα λες και πολυ λιγα... ΗDMI ναι ειναι το μειον του. Καλωδιο otg δεν περιελαμβανε αλλα τωρα θα το κανω μια δοκιμη ενα που εχω και θα σας πω αμεσως.
Παρακαλώ τη γνώμη σας για το παρακάτω tablet
http://www.geekbuying.com/item/Ainol-Novo705KC-E1-AX3-MTK8382-1-2GHz-7-inch-3G-Tablet-PC-Android-4-2-Quad-Core-IPS-Touch-Screen-1024-600-1GB-8GB-324056.html
Υπάρχει κάποιος περιορισμός στα phone tablets ώστε να υλοποιούνται,ως επί το πλείστον, πάνω σε MKT chipsets ;
Έχω χάσει κάτι ;
έχοντας μελετήσει όλα τα θέματα σχετικά με συμβουλές αγοράς πιθανά προβλήματα και τις γενικές κατηγορίες
(αφού η κατηγορία δεν φαίνεται ιδιαίτερα δημοφιλής) δείχνει μια πλήρης αγορά ( ; )
Είμαι κάτοχος του pipo max m6 και αρκετά ευχαριστημένος απο το συγκεκριμένο tablet.
Τώρα ένα φιλαρακι ψάχνεται για αγορά tablet με παρόμοια χαρακτηριστικά υπάρχει κάποιο άλλο να μου πρότεινε? Έχω βρεί το onda v975m ξέρετε κάτι για αυτό?
Μηπως λες οτι εχει sim θυρα?γιατι σε οποιο σαιτ το βλεπω δεν εχει θυρα για καρτα μνημης!τα cube που λενε android 4.1 θα παρουν την 4.2.1 τουλαχιστον?jelly bean ποια ειναι τα 4.2 η και τα 4.1? Edited by fuorigioco1981
λιγο πιο κατω απο την θυρα της σιμ εχει και της sd. Μπορω να σου στειλω και φωτογραφιες.
το otg επισης δουλευει κανονικα. συνδεσα μολις ενα ποντικι.
Edited by GATE_1908
ωραια οποτε τωρα ειμαι μεταξυ pipo,ramos ΚΑΙ cube :lol:
Εχει θυρα για καρτσ SD το Cube U55gt παροτι παντου στα τεχνικα χαρακτηριστικα λενε οτι δεν εχει.
στο site της cube αναφερουν οτι τα πρωτα μοντελα βγηκαν χωρις και αναβαθμησαν το μποντελο αυτο με θυρα micro sd. το εργαλειο γενικα πεταει ψιλο λαγκαρισματα οκ τα εχει αλλα στα λεφτα του ειναι νομιζω κορυφη. το gps αψογο η οθονη του ειναι καλυτερη απο του νεξους 4 που εχω. Το 3g και το wifi ειναι πολυ δυνατα. Εγω το παραγγειλα και πριν το πιασω στα χερια μου καν πριν φτασει δηλαδη Ελλαδα το ειχα μετανιωσει ηθελα να το δωσω κατευθειαν για νεξους ταμπλετ. Ειλικρινα μολις το δουλεψα δεν το μετανιωσα καθολου ισα ισα το λετρεψα. Ειναι πανεμορφο και τα κανει ολα. Με ενα bluetooth ακουστικο το εχεις για τηλεφωνο ανετα.
τελικα εχει 4.2 η 4.1 android?
