[Επίσημο] Nokia E71
nervous
Nokia E71 Get a New Firmware Update V200.21.118
http://dailymobile.se/2009/01/13/nokia-e71-get-a-new-firmware-update-v20021118/
Changelog:
- Internet Radio application
- My Nokia application
- 3G power reduction for applications using keep-alive style messaging
- User experience improvements:
- Easy Dialing support for Simplified Chinese language
- Device Lock improvement: Open device lock with LSK + Fn-keys
- One key input method switch for China language
- ‘Mute’ option in Right Soft Key when wired headset / hands free is connected
- ‘Loudspeaker’ option in Right Soft Key immediately when phone call is started
- Enlarge characters in Chr-table
- NTLM v1 and v2 support for Intranet Browsing
- New black and red themes
Changes/improvements made to MCU SW version 200.21.118:
General
- Time zones updated
- Improvements to localization
- Localization fixes
- Missing localizations added
- Operator name database updated
- Startup Settings updated
- Certificates updated
- Security updates
- Stability and functionality improvements
- Barcode reader icon changed from 1D icon to 2D icon
- Windows DRM keys are not lost during NSU update from 110.07.127
Qwerty keyboard
- Keyboard mapping corrections
Browser
- Flash Lite improvements
Connectivity
- WLAN stability improvements
- EAP-FAST/TLS stability improved
- WLAN roaming functionality improved
- BT IOP and Dial-up stability improvements
Maps
- Several stability and functionality improvement
Messaging
- Performance improvement
Quickoffice
- Several stability and functionality improvements
VOIP / SIP
- Many stability and functionality improvements
Email
- Mail for Exchange upgraded from version 2.5.5 to 2.7.22
- Improved functionality when sending email via SSL/TLS SMTP server
Mobile dictionary
- Stability improvements
- Improvement for installed languages. Installed language can be removed.
Camera
- Camera image improvements & slow capture correction with certain HW’s
Music player
- General functionality and stability improvements
Java
- Update for CLDC-HI (Sun 1.1.1s Java VM)
Device encryption
- Device encryption functionality and stability improvements
Switch application
- Application updates and stability improvements
  • Απαντήσεις 2,4χιλ.
σε ελληνικο e71 δεν υπαρχει νεοτερο του 110,07,127 δηλωνει το προγραμμα.
εχεις αγγλικο ε71?
Τί εννοείς "ελληνικό"?
Υποτίθεται ότι είναι ευρωπαική η αναβάθμιση. :confused:
Κάποιος άλλος, ξέρει?
Μήπως δεν είναι διαθέσιμη ακόμα για την Ελλάδα, και θα γίνει σε μικρό χρονικό διάστημα?
το λευκο e71 απο πλαισιο αγορασμενο. με product code 0561155
Για το 0558795 (Grey steel) E71 η αναβάθμιση 200.21.118 είναι διαθέσιμη!
εχεις αγγλικο ε71?
Για το product code που αναφέρεις ως λευκό εσύ δεν είναι διαθέσιμη.
Είναι σίγουρα ελληνική η συσκευή που έχεις και όχι παράλληλη εισαγωγή;
ειναι αγορασμενο απο Πλαισιο. ελληνικο πληκτρολογιο. δε νομιζω να ειναι παραλληλη εισαγωγη του Πλαισιου, και να βαζει μονο του ελληνικο πληκτρολογιο
Δεν ξέρω για τα bugs αλλά είναι ποιο γρήγορη και σταθερή. Δεν μπορώ να πώ απόλυτα γιατι δεν το δουλεύω ως πρώτη συσκευή.....
Τετοια πράγματα μαθαινω και μου ερχεται ωρες ωρες να το σπάσω!:mad:
Εγώ από παλιά είχα την συνήθεια να έχω το μενού στα αγγλικά πάντοτε, και τις επαφές το ίδιο. Τουλάχιστον έτσι γλιτώνεις τα bugs που έχουν σχέση με την ελληνική γλώσσα...
Proud owner of Nokia E71 (από σήμερα)! :D
Πρώτες εντυπώσεις, κυριώς από το feeling της συσκευής, άριστες! Με το UI είμαι εξοικειωμένος, οπότε περιμένω απλά να "γνωρίσω" όλες τις δυνατότητες της συσκευής! :)
seventh_heaven
Καλοριζικο ! :up:
Περιμενουμε και τις δικες σου εντυπωσεις ;)
iPhone 5S Space Grey
Αυτή είναι και μία από τις δικές μου απορίες... Γενικότερα η θήκη αυτή δε μου αρέσει ιδιαίτερα και μου φαίνεται μη πρακτική.
Επίσης αν έχετε κάποια ιδέα για βάση στήριξης αυτοκινήτου, είμαι όλος αυτιά! :)
seventh_heaven
Από χθες είμαι και εγώ κάτοχος του E71! Του πέρασα σήμερα το πρωί την νέα έκδοση λογισμικού, και τώρα θα ξεκινήσω με μεταφορά τηλ. καταλόγου, wallpapers, ήχους κλπ κλπ!
Μόνο που, παραξενεύτηκα που είχε ήδη η συσκευή κάρτα μνήμης 2GB. Και είχα πάει και αγόρασα και εγώ, χωρίς να το ξέρω. Το ερώτημα είναι, είχε και εσάς όταν το αγοράσατε κάρτα μνήμης μέσα? Προσπαθώ να βρώ τί περιέχει η κάρτα μνήμης, μήπως είναι οι χάρτες για το GPS? Εντομεταξύ τώρα που το άνοιξα με το νέο λογισμικό, μου λέει ότι η κάρτα μνήμης περιέχει μή εγκεκριμένο υλικό (ή κάτι τέτοιο)...
Κοίταξε και αυτές:
http://www.beyzacases.com/cat-nokia-e71-cases-slimline-series-leather-cases---ultra-slim-type-vertical-pouch-cases.cfm
Έχει άλλα 2 είδη, εκτός από το παραπάνω. Εγώ το σκεφτόμουν για το προηγούμενό μου κινητό (P1i) αλλά τελικά δεν πήρα. Θα δω πώς θα τα πάω με την εργοστασιακή, και αν δεν μου αρέσει, θα χτυπήσω μια τέτοια. Πάντως μέχρι στιγμής, έχω μέτριες εντυπώσεις από την εργοστασιακή θήκη. Δεν μου φαίνεται και τόσο ποιοτική. Βέβαια, σε ένα βαθμό, την δουλειά της την κάνει... Τουλάχιστον το κρατάει καλά, και δεν φοβάσαι μην σου πέσει. Speaking of... χθες το βράδυ (πρώτη μέρα) έφαγε το πρώτο πέσιμο! :cry:
Από το γραφείο μου, στο πάτωμα, ενώ προσπαθούσα να το συνδέσω με το PC tower! Κόντευα να πεθάνω, αλλά το κοίταξα εξονυχιστικά, και δεν έπαθε την παραμικρή γρατζουνιά! Νομίζω είναι πολύ ποιοτικό το case της συσκευής. :)
Καλορίζικο.:)
Πιθανών να έχει περασμένους τους χάρτες, αλλά αυτό δεν χρειάζεται να σε απασχολεί. Τους κατεβάζεις όποτε θέλεις μέσω του Map Loader δωρεάν.
Δεν ξέρω τι περιέχει η κάρτα. Αυτό που σου προτείνω (το κάνω και εγώ πάντα) είναι να τη μορφοποιήσεις εφόσον τελικά χρησιμοποιήσεις αυτή και όχι τη δική σου.
Σχετικα με την θήκη, έχω αγοράσει όντως και εγώ από beyzacases, όπως είπε και ο Machester πιό πάνω και έχω μείνει απόλυτα ευχαριστημένος με την ποιότητα και την προστασία του κινητού.
Οπως μου είπαν όμως και σε Nokia Shop, θα βάλει και η Νοκια αλλη μία θήκη για το Ε71 και μόνο και θα είναι στο στύλ που είχε βγαλει και για το Ε61ι, η οποία θα έχει και κλίπ για την ζώνη.
Επίσης κάποιοι γνωστοί μου στο εξωτερικό, έχουν πάρει κάποια σχετική θήκη που κάνει για το iPhone, βέβαια χωρίς τα logo της Apple.
Θα μάθω περισσότερα νέα την επόμενη εβδομάδα για την θήκη από την Νοκια και θα ενημερώσω.
Οσο αφορά την βάση αυτοκινήτου έχω παραγγειλει την δικιά του βάση στήριξης που έχει βγάλει η Νοκια, αλλά δεν ξέρω πότε θα μου έρθει γιατί δεν υπάρχει ετοιμοπαράδοτη στην AlphaCopy, οπότε θα γίνει παραγγελία από το εξωτερικό.
Καλημέρα παιδιά!
Είμαι ευτυχής κάτοχος ενός Ε71 από προχθές....
Το μόνο πρόβλημα που έχω είναι με το gps το οποίο δεν κλειδώνει με τίποτα. με το nokia maps είναι στη μία γραμμή και αναβοσβήνει, και δοκίμασα με το google maps και βρίσκει μέχρι 3...
Το κακό είναι ότι μένω κέντρο, και θα είναι δύσκολο να κάνει το αρχικό κλείδωμα. Το γεγονός αυτό δε με πειράζει, αλλά θέλω να εξασφαλίσω ότι δεν έχει πρόβλημα το gps σα hardware....
όποιος μπορεί να βοηθήσει θα το εκτιμούσα... Ευχαριστώ!
Nothing lasts forever, but the certainty of change...
Emperistatomenos' Blog
Καλημέρα παιδιά!
Ανεβα στην ταρατσα και αστο για κανενα τεταρτο να ψαχνει για αρχη. Επισης, σιγουρεψου οτι εχεις ενεργοποιημενο το A-GPS στο μενου για ταχυτερο lock. Απο τη στιγμη που κατι βρισκει ειναι ψιλοδυσκολο να εχει δυλειτουργια το gps module
"Any sufficiently advanced technology is indistinguishable from magic"-Sir Arthur Clarke
Λοιπόν, οι πρώτες εντυπώσεις από το κινητό είναι άριστες, το θεωρώ πολύ ποιοτικό και έχω την εντύπωση ότι στο μέλλον θα έχει κορυφαία αξία μεταπώλησης, ακόμα και μετά από 1,5-2 χρόνια. Θα προσπαθήσω να το κρατήσω αρκετά αυτή την φορά σε αντίθεση με τα προηγούμενα κινητά μου, που σε 8 μήνες κάτι με έπιανε και τα πούλαγα. Θεωρώ ότι το συγκεκριμένο κινητό θα αργήσει πάρα πολύ για να θεωρηθεί ξεπερασμένο, στον τομέα του πάντα (business orientation, not multimedia).
Τώρα, στο θέμα του GPS. Την πρώτη φορά μόνο θέλει λίγο χρόνο για να βρεί τους δορυφόρους, μετά πιάνει μια χαρά.
Δύο ερωτήσεις: Ποιά έκδοση του Garmin θεωρείτε ότι τρέχει καλύτερα (το λέω γιατί διάβασα ότι οι τελευταίες είναι πολύ ενεργοβόρες σε μπαταρία)? Επίσης, ποιός χάρτης πιστεύετε ότι είναι καλύτερος για την Ελλάδα?
Είμαι σε φάση ψαξίματος στο γνωστό μαγαζάκι (ip)αλλά γίνεται χαμός εκεί μέσα. Θα κοιτάξω και το αντίστοιχο thread του myphone (Garmin Mobile XT), απλώς θέλω ένα feedback από τους χρήστες που είναι ευχαριστημένοι με το σετάρισμα τους στο Ε71, και όχι γενικά σε άλλα κινητά symbian.
Επίσης: Όπως είναι σεταρισμένο από την μαμά του, με το application Nokia Maps, υπάρχει κάποιο κουμπί για κάποια ιδιαίτερη λειτουργία, εκτός από το zoom in και zoom out που δείχνει στην οθόνη? Εννοώ χωρίς την πλοήγηση, έτσι απλά όταν σου δείχνει το στίγμα σου, ενόσω κινήσαι.
