[S60 3rd Edition] Εφαρμογές Symbian OS v9.1-v9.2
mirrorofsorrow
[New] Best Crypto for S60 3rd Edition
http://img147.imageshack.us/img147/1176/bestcrypto603rd017gi.gif
Best Crypto application by Smartphoneware is designed for electronic data protection. It provides you with a user-friendly graphical interface for encrypting and decrypting your sensitive data. Behind easy to use interface, its powerful cryptography engine is using industry standard secure crypto algorithms (RC6 (ECB-Mode) ciphering with 256-bits keys and MD5 algorithm) to give you absolute, almost unbreakable security. Protect your private photos, voice and sound files, videos, confidential documents - just any kind of files on your smartphone.
http://my-symbian.com/s60v3/software/applications.php?fldAuto=66&faq=15
iPhone 5S Space Grey
  • Απαντήσεις 6χιλ.
For N80:
Simple Center software
Wirelessly sync, stream, and access your music, pictures, and movies. Download Home Media Server from
http://www.simplecenter.com/hms_34/
Enabled devices :
http://www.simplecenter.com/devices.html
Καταφερα και δουλεψα το home media server με το Ν80 .
Εφοσων ειχα ηδη ετοιμη wlan connection ,το μονο που αλλαξα ηταν
να κανω enable το Upnp στον router .
http://img156.imageshack.us/img156/9369/screenshot00101dw.th.jpg http://img136.imageshack.us/img136/1789/screenshot00111no.th.jpg http://img136.imageshack.us/img136/219/screenshot00123mg.th.jpg
Ενας καλος οδηγος υπαρχει εδω για Linksys router ,εφαρμοζεται ομως και σε αλλους
http://forum2.mobile-review.com//showpost.php?p=430904&postcount=1
eheis kaneis to Taskman/handy weather spasmena?
xxxxxxxxxxxxxxxx to apo edw exei kai to key.exw kai apo to handy weather to key.;)
Εχει βρει κανεις crac k για το Alarm Manager;
[sIGPIC][/sIGPIC] N e m e s o k l a s ! ! !
Mobile History: Sony Erricson T630, Siemens S65, Qtek S100, Nokia N80 ... and finally N95!
Concise Oxford English Dictionary
http://shop.my-symbian.com/include/pictures/688076/oxford-h1.gif
This world-famous dictionary provides a comprehensive description of the English language, covering general and specialist words, literary, historical and technical terms, and new words that have recently entered the language.
Over 240,000 words, phrases and definitions - this is not a pocket dictionary, rather a medium sized dictionary for a variety of needs. It requires 12 MB of space from your phone's memory card.
http://my-symbian.com/s60v3/software/applications.php?fldAuto=67&faq=3
den to diabasa pouthena opote.....
Nokia Series 60 v3 Image Editor (Symbian 9.1)
'Αδεια χρήσης: Δωρεάν
Anoigete ena image kai apla kanete epeksergasia.....
Poly kalo!!!!
http://www.techteam.gr/index.php?act=download&file=463
http://www.fuelcell.gr
Ιστιοσελίδα εκπαιδευτικού περιεχομένου για τα Fuel Cells η μόνη στα ελληνικά!!
Poly kalo!!!!
Είναι σαν την επεξεργασία που έχει το Ν80 όταν ανοίγουμε μια φοτό και πιλέγουμε επεξεργασία από τισ επιλογές???
Επειδη πολυ εχουμε προβλημα με το κλειδωμα του πληκτρολογιου για το Ν80, αυτη η freeware εφαρμογη μας λυνει τα χερια!!
Κατεβαστε την απο εδω:
http://www.iphone-forum.org/showthread.php?&p=927122#post927122
Συμβατη με ολα τα s60 3rd edition symbian phones!!
Screenshots δεν υπαρχουν, απλα την τρεχεις και κλειδωνει το πληκτρολογιο!
τι εννοεις την τρεχεις; πρεπει να πατησεις στο εικονιδιο; :p
ακομη ενας file manager kai ftp explorer με ποικιλες αντιδρασεις στο i phone: MobyExplorer.v2.1.S60V3.SymbianOS9.1.C****d.Xavi .υπαρχει λιγο κραξιμο παντως για αυτην την app.οποιος θελει το βλεπει στο
h**p://www.iphone-forum.org/symbian-os-91-apps/t-mobyexplorerv21s60v3symbianos91c****dxavi-111307.html.
αν εχει αναφερθει ξανα, nervous delete it...
To Know the Cause Of Things!
Ναι αφου την εγκαταστησεις απλα την τρεχεις οποτε θες να κλειδωσεις το πληκτρολογιο κανοντας κλικ στο εικονιδιο! Τοσο απλα
h kalitera sintomefsi sto polipliktro tou n80, kai etsi me ena cklick klidoni to kinito
Υπογραφή εκτός κανόνων Ο.Π.Χ
Βρε παιδια μπορει καποιος να κανει μια λιστα με τις εφαρμογες που υπαρχουν καταλληλες για το Ν80 και διαθετουν ταυτοχρονα και κλειδακι????
Βγήκε το Autolock που κλειδώνει αυτόματα το πληκτρολόγιο μετά από ορισμένο χρονικό διάστημα. Είναι και freeware!
http://my-symbian.com/s60v3/grafika/autolock.png
Faith is the great cop-out, the great excuse to evade the need to think and evaluate evidence. Faith is belief in spite of, even perhaps because of, the lack of evidence.
HandyClock και εχετε αυτοματο κλειδωμα και ολα τα αλλα ταυτοχρονα!!!
Ειναι τελειως περιττο να βαζετε και αλλες εφαρμογες που κανουν το ιδιο πραγμα!!!;) :)
Η αγάπη αποτελείται απο μια μοναδική ψυχή που κατοικεί σε δύο σώματα! (Αριστοτέλης)
Proud Owner of a Xbox360 fully updated!!! (http://www.enternity.gr)
Next Generation Consoles WAR:http:// http://www.vgchartz.com/
Ρε παιδια περασα το profimail γιατι ηθελα τι profiexplorer και δεν μου εμφανηστηκε ποτε? δεν υπαρχει πλεον ενσωματομενο? Το lookup εχει βγει για Ν80?
Υπαρχει κανονικα.Μπες στο profimail και πατα το 4 και θα εμφανιστει.
προσπαθω να περασω τις επαφες μου απο το 3230 στο ν80 αλλα δεν τα καταφερνω με το pc suite!καμμια βοηθεια παιδια, εχω κουραστει τοσες ωρες!ευχαριστω
PS ΕΠΕΙΔΗ ΦΕΥΓΩ ΚΑΙ ΔΕΝ ΕΧΩ ΠΟΛΥ ΧΡΟΝΟ ΟΠΟΙΟς ΜΠΟΡΕΙ ΚΑΙ ΞΕΡΕΙ ΠΩς ΝΑ ΠΕΡΑΣΩ ΤΙς ΕΠΑΦΕς ΑΠΟ 3230 ΣΕ Ν80 ΑΣ ΜΕ ΒΟΗΘΗΣΕΙ!ΕΠΕΙΓΟΝ!!!
Δοκιμασε το Contacts Transfer
http://www.myphone.gr/forum/showthread.php?p=1419230#post1419230
Περασε την αντιστοιχη εκδοση στο καθε τηλεφωνο ,και στην συνεχεια export/import .
για την 3rd edition το βρηκα αλλα για την 1 st kai 2nd που ειναι ?ευχαριστω!
http://personal.inet.fi/private/riihimaki/s60/index.html
http://personal.inet.fi/private/riihimaki/s60/sw/PbkTrans_200.sis
