mol Δημ. July 15, 2009 Δημ. July 15, 2009 λιγο πιο κατω απο την τιμη εχει ενα πλαισιο. εκει μεσα γραφει "This Cell Phone works with the following GSM Frequencies: 900 MHz + 1800 MHz + 1900 MHz. Please check that the local cell network matches the phone's GSM standard. Click here to view frequencies for all major worldwide cell phone networks." πατας το "click here...." σου ανοιγει ενα νεο παραθυρο οπου ελεγχεις σε ποιες χωρες λειτουργει το ρολο'ι'/τηλεφωνο. επιλεγεις την Ελλαδα και σου δειχνει αυτο. εγω απο αυτο καταλαβα οτι λειτουργει με ολα τα δικτυα της Ελλαδας. αν κανω λαθος, διορθωστε με.:) Παράθεση
chris7_ Δημ. July 17, 2009 Δημ. July 17, 2009 http://www.mobilewhack.com/wp-content/pics/2009/07/lighter-phone-280x158.jpg I’m sure this is a feature some of you have seriously considered at least once. But would actually use a cigarette lighter phone? The phone in the picture here comes with a cigarette lighter but we doubt it’s the real thing. If you’re having any safety questions then you should know that the lighter is located on the back of the SB6309 and it comes with a protective cover. Simply slide it and light up your next cigarette. Or you could choose a smartphone instead and quit smoking. I certainly hope that nobody will actually consider creating such a phone. But just in case this proves to be more than a joke, we’ll be ready to offer you all the hidden details. In case you stumble upon the official site of the phone you should also be aware of the fact that it could potentially harm your PC. The world malware has been used more than once http://www.mobilewhack.com/cigarette-lighter-phone-anyone/ Παράθεση [sIGPIC][/sIGPIC]
stefanw595 Δημ. July 17, 2009 Δημ. July 17, 2009 Ωχ τι ειναι αυτο που σκεφτηκαν?? Αντι για καμερα αναπτηρας! Αυτο θα φανει παααρα πολυ χρησιμο σε καποιους...:lol: Παράθεση
Coolgreek Δημ. July 17, 2009 Δημ. July 17, 2009 δεν χρειάζεται κπ είδος ξεκλειδώματος όμως,ε; Τα κινητά αυτά είναι ξεκλείδωτα. Δεν χρειάζονται τίποτε άλλο. Εφόσον είναι tri-band (όπως αναφέρει ο πωλητής -GSM Frequencies: 900 MHz + 1800 MHz + 1900 MHz) θα δουλεύει κανονικά με ΟΛΑ τα Ελληνικά δίκτυα! ΣΗΜΑΝΤΙΚΟ: ΔΕΝ έχει Ελληνικά! Αυτό σημαίνει πως κατα πάσα πιθανότητα (95%+) δεν θα βλέπει καθόλου Ελληνικούς χαρακτήρες ούτε στις επαφές ούτε στα μηνύματα... Πρόσεξε το αυτό! Παράθεση Βασίλης!
trackera Δημ. July 17, 2009 Δημ. July 17, 2009 ΣΗΜΑΝΤΙΚΟ: ΔΕΝ έχει Ελληνικά! Αυτό σημαίνει πως κατα πάσα πιθανότητα (95%+) δεν θα βλέπει καθόλου Ελληνικούς χαρακτήρες ούτε στις επαφές ούτε στα μηνύματα... Πρόσεξε το αυτό! Εγώ θα πω κάτι άλλο πολύ πιο σημαντικό... Ξαναδές τις φωτογραφίες,είσαι σίγουρος ότι θα φορέσεις αυτή την πλαστικουριά; Το πιο πιθανό είναι να σε δουλεύουν όλοι οι φίλοι και γνωστοί και να το βγάλεις την πρώτη μισή ώρα και τσάμπα τα λεφτά. Αυτά δεν νομίζω ότι είναι για ηλικίες πάνω των 13-14...Χρήσιμο βέβαια ήταν στον Παλαιοκώστα,μάθαμε πιο μοντελάκι φόραγε; :p Παράθεση 斯塔夫罗斯 :O
stathis1980 Δημ. July 18, 2009 Δημ. July 18, 2009 Καλημερα, Προσφατα ειδα το Telsda 928 στο ebw.gr . Η τιμη για αυτα που παρεχει ειναι ακρως δελεαστικη. Εχει περασει απο κανενος τα χερια; Ειναι κανεις ενημερωμενος για τα συν και τα πλην; Η αληθεια ειναι οτι ψαχνω ενα chinese (καθαρα για λογους οικονομικους) με τα παραπανω χαρακτηριστικα.Εχει κανεις κατι υπ'οψην του; Ευχαριστω εκ των προταιρων Παράθεση
droulis Δημ. July 18, 2009 Δημ. July 18, 2009 δες εδω http://www.exp-chinashop.com/showproduct.asp?id=185 η τιμη του ειναι160-165 ευρω με ολα τα εξοδα Παράθεση
stathis1980 Δημ. July 18, 2009 Δημ. July 18, 2009 droulis thanks για το ενδιαφερον! Εχει support για ελληνικα sms και επαφες; (σορρυ αν κανω χαζη ερωτηση) Ειναι αρκετα δελεαστικο για την τιμη του Παράθεση
navi55 Δημ. July 18, 2009 Δημ. July 18, 2009 Μάλλον είναι πιο πρακτικό σε σχέση με τις καμερίτσες που βάζουν :lol: Βέβαια καλό θα ήταν να είχες ποστάρει το θέμα εδώ: Ποιό είναι το πιο πρωτότυπο κινέζικο τηλέφωνο; Παράθεση
droulis Δημ. July 18, 2009 Δημ. July 18, 2009 ναι ειναι οκ ερχεται με αγγλικο αλλα βαζουμε ευκολα ελληνικα μπορω να σε καθοδηγησω Παράθεση
rigasnic1982 Δημ. July 18, 2009 Δημ. July 18, 2009 γεια σας παιδαι ξερετε καποιον κωδικο για τα κινεζικο κινητα που οταν μιλαω εγω στο τηλ να ηχογρααφει την κληση μου; ευχαριστω :) Παράθεση [sIGPIC][/sIGPIC]
gkr41 Δημ. July 19, 2009 Δημ. July 19, 2009 Μάλλον είναι πιο πρακτικό σε σχέση με τις καμερίτσες που βάζουν :lol: Βέβαια καλό θα ήταν να είχες ποστάρει το θέμα εδώ: Ποιό είναι το πιο πρωτότυπο κινέζικο τηλέφωνο; Συνενώθηκαν. Παράθεση [sIGPIC][/sIGPIC] Editors@myphone.gr: Γίνετε και εσείς μέλος της Συντακτικής Ομάδας
trackera Δημ. July 21, 2009 Δημ. July 21, 2009 Σήμερα παρέλαβα ένα dual sim κινητό με ελληνικά και είπα μέχρι να κοιτάξω να το σπρώξω να κάνω μια μικρή παρουσίαση. Λοιπόν το κινητό είναι το M868+ Τα περιεχόμενα του κουτιού του είναι το κινητό τηλέφωνο,δύο μπαταρίες 1500 mah,ακουστικά,ευρωπαικός φορτιστής και καλώδιο σύνδεσης με pc Το κινητό είναι πάρα πολύ μικρό σε μέγεθος και πάρα πολύ ελαφρύ,δεν έχει οθόνη αφής και το ραδιόφωνο παίζει με την χρήση ακουστικών. Για να μπεις στο ραδιόφωνο υπάρχει ειδικό κουμπί στην πρόσοψη του κινητού ενώ με ένα κουμπί στο πλάι του κινητού ανάβουν και 2 πολύ δυνατά λαμπάκια στην κορυφή του κινητού για να χρησιμοποιηθεί ως φακός.Έχει ελληνικό μενού,μια υποτυπώδη κάμερα και παίρνει κάρτα microsd,αρκετά απλό τηλέφωνο γενικά για κάποιον που θέλει απλά κάτι βολικό. Παράθεση 斯塔夫罗斯 :O
Dimis72 Δημ. July 21, 2009 Δημ. July 21, 2009 Yπάρχει κάποιος που να έχει στην κατοχή του το συγκεκριμένο κινητό; Αν ναι ας γράψει τις εντυπώσεις του! Παράθεση
antonysx Δημ. July 23, 2009 Δημ. July 23, 2009 PAIDIA EXW TO JAGA JC 678!DEN KSERW TI PAIXNIDIA PERNEI!AN GNWRIZEI KAPOIOS AS ME VOHTHISH!THANKS! Από την 1η Σεπτεμβρίου 2009, δεν θα επιτρέπεται η χρήση των «greeklish», καθώς επίσης και η γραφή τύπου SMS. Τα μηνύματα που έχουν γραφτεί με αυτήν την πρακτική θα διαγράφονται, χωρίς προειδοποίηση. Θα θέλαμε να σας παρακαλέσουμε να χρησιμοποιείτε ελληνικούς χαρακτήρες. Για περισσότερες πληροφορίες διαβάστε τη σχετική ανακοίνωση. Παράθεση
sofos7 Δημ. July 23, 2009 Δημ. July 23, 2009 PAIDIA EXW TO JAGA JC 678!DEN KSERW TI PAIXNIDIA PERNEI!AN GNWRIZEI KAPOIOS AS ME VOHTHISH!THANKS! δεν παιρνει παιχνιδια και θεματα. αμα το πειρες απο την wind,το πειρες και πανακριβα. Παράθεση
antonysx Δημ. July 23, 2009 Δημ. July 23, 2009 TSAMPA TO PHRA!EISAI SIGOUROS OTI DEN PERNEI PAIXNIDIA? Παράθεση
sofos7 Δημ. July 23, 2009 Δημ. July 23, 2009 TSAMPA TO PHRA!EISAI SIGOUROS OTI DEN PERNEI PAIXNIDIA? ναι ειμαι σιγουρος.μαλλον τσαμπα το πειρες αφου ειναι και παρα πολυ παλιο μοντελο Παράθεση
antonysx Δημ. July 23, 2009 Δημ. July 23, 2009 OK THANKS! Από την 1η Σεπτεμβρίου 2009, δεν θα επιτρέπεται η χρήση των «greeklish», καθώς επίσης και η γραφή τύπου SMS. Τα μηνύματα που έχουν γραφτεί με αυτήν την πρακτική θα διαγράφονται, χωρίς προειδοποίηση. Θα θέλαμε να σας παρακαλέσουμε να χρησιμοποιείτε ελληνικούς χαρακτήρες. Για περισσότερες πληροφορίες διαβάστε τη σχετική ανακοίνωση. Παράθεση
galanastasia Δημ. July 23, 2009 Δημ. July 23, 2009 παιδια ενδιαφερομαι και εγω.οταν σου στελνουν μνμ στα ελληνικα τα διαβαζει κανονικα???απο ελλαδα υπαρχει τροπος να το παρω? υπαρχει καπου?καποιο αρνηκο παρατηρησατε? Παράθεση
trackera Δημ. July 23, 2009 Δημ. July 23, 2009 Νομίζω ότι αυτό το κινητό δεν υπάρχει πουθενά αλλού,μόνο σε αυτό το eshop.Θα το πάρω και εγώ πάντως αυτό το κινητό, εδώ και πολύ καιρό το έχω πει ότι μ αρέσει.Θα διαβάζει και θα στέλνει ελληνικά sms με τον περιορισμό ότι στέλνει sms με ελληνικά μέχρι και 70 χαρακτήρες.Τα ελληνικά του σίγουρα θα είναι τα κλασικά χάλια που έχουν όλα τα κινέζικα αλλά είναι πολύ όμορφο πιστεύω και λεπτό.Το μόνο που θα ήθελα να μάθω είναι αν στην τv τρώει λίγο τα κεφάλια στην κορυφη ή όχι Παράθεση 斯塔夫罗斯 :O
filzazas Δημ. July 23, 2009 Δημ. July 23, 2009 το κινητό στέλνει κ δέχεται κανονικά ελληνικά σμσ, μέχρι 70 χαρακτήρες. τα κεφάλια δεν τα τρώει. πέρα από τα κλασικά μείον που έχουν τα κινέζικα( πέρασμα επαφές,κ κινέζικα ελληνικά) δεν έχω διαπιστώσει κάποιο μείον.. ίσα ίσα όλα είναι τέλεια, έχω κ ένα handsfree samsung WEP200 κ συνεργάζεται άψογα! έχει τέλεια οθόνη σε βαθμό που ακόμα κ κάποια νοκια κτλ να μην έχουν τόσο καλή οθόνη,είναι λεπτό κ γενικά πολύ όμορφο! αν διαπιστώσω κανένα μείον θα επανέλθω! π.σ εγώ πάντως θα παραγγείλω κι άλλα...όλοι οι φίλοι κ συγγενής θέλουν από ένα :p Παράθεση Σημείωση: Η εικόνα που θα επιχειρήσετε να «ανεβάσετε» δεν θα πρέπει να είναι μεγαλύτερη από 420 x 150 pixels και δεν θα πρέπει να υπερβαίνει τα 16,3 KB.
filzazas Δημ. July 24, 2009 Δημ. July 24, 2009 καλησπέρα παιδιά! ζητάω συγνώμη έκανα ένα λάθος,τελικά στα σμσ τα Π,Σ,Ω,Ψ κτλ δεν εμφανίζονται! Παράθεση Σημείωση: Η εικόνα που θα επιχειρήσετε να «ανεβάσετε» δεν θα πρέπει να είναι μεγαλύτερη από 420 x 150 pixels και δεν θα πρέπει να υπερβαίνει τα 16,3 KB.
venividivici Δημ. July 25, 2009 Δημ. July 25, 2009 παιδια σκεφτομαι να το παρω.Η καλυτερη τιμη που εχεται βρει ποια ειναι?σαν ποιοτητα ειναι καλο? Παράθεση Ενοικιαζομενα δωμάτια και διαμερίσματα στην παραλία των Μυλων Αργολιδος δέκα λεπτά απο το Ναύπλιο σε προσιτές τιμές.
