Τρομακτικές Ιστορίες - Φαντασμάτων άπαντα
gkr41
pwpw apo proxthes pou anakalupsa to forum exw porwthei. loipon tha sas pw mia thn empeiria enos prwhn filou. tonizw oti to paidi den elege genika moufes kai skeptotan logika. kathe ti dld to anelue prwta me th logiki prwtou to apodwsei sth sfaira tou metafusikou.loipon, mia mera phge me th kopelia tou sto e3oxiko ths. htan ligo pio e3w apo nauplio kai i perioxi den einai puknokatoikhmenh. ola mia xara wspou peftoun gia upno. apenanti apo t krevati vriskotan enas megalos kathrepths opou ekei evlepes th porta ths toualetas. peftoun gia upno opou enas dunatos krotos tous 3upna kai akoune hxo apo nero pou trexei. kathws shkwnontai thelontas kai mh koitazoun sto kathrefth opou vlepoun th porta ths toualetas anoixth. kai mia morfi na steketai kai na tous koitazei. i morfi htan maurh kai eixe kitrina matia. edw shmeiwnw oti i aura tou filou m einai kitrini. antikrizontas t sugekrimeno theama ta paidia lipothimisan. anektisan tis aisthiseis tous polles wres argotera kai enw eixe 3hmerwsei. sokarismenoi anakalupsan oti oles oi portes tu spitiu htan anoixtes , opws kai oi vruses. to kaswma ths kedrikis portas to opoio htan 3ulino eixe ragisei kai ta mpoukalia apo to mini bar htan ola sto patwma orthia...kai oi 2 tous perasan arketous mhnes upo th parakolouthsh psuxologou. a3izei na shmeiwthei oti se erwthsh mou an pote eixe alles empeiries mou eipe oti kapote eixe mpei se kuklo kai eixe emfanistei kati, alla den mpike se leptomereies kathws mou eipe oti den prepei na mathw kati parapanw kai na mhn asxoloume
  • Απαντήσεις 1,3χιλ.
χμ, δν ξερω αν μπορω να διαφημισω ενα αλλο forum... αλλα πιστευω οτι θα το βρεις πολυ ενδιαφερον...
-> http://www.esoterica.gr/forums/default.asp
καντε del το ποστ αν δν πρπ να διαφημιζω αλλα forums :)
Ότι δεν σε σκοτώνει :rocket: σε κάνει δυνατότερο
Όσο ζω μαθαίνω
Δηλαδή?
And now all I do is sit in my darkened room
And on occasion break my silence to howl at the moon
To curse every nerve and neuron in my brain
That won't stop the pain I'm feeling
And let me stop thinking...
Εγω ξερω πως μονο ενας ανθρωπος στον κοσμο εχει το μηχανημα το οποιο οταν ακουμπας τα χερια σου σου δειχνει τα χρωματα της αυρα σου,,,αναλογα με τα χρωματα ειναι και τα συναισθηματα του χαρακτηρα σου....ειχε προσφατα μια εκπομπη που ανελυε αυτος ο επιστημονας την αυρα διαφορων ανθρωπων και κατα ποσο επηρεαζει τους γυρω μας...:)
τωρα πως ο φιλο σου ξερει το χρωμα της αυρας του δεν ξερω,,,εχει παει στον επιστημονα αυτον να την μετρησει ,εχει κανα δικο του μηχανημα, δεν ξερω τι να πω.
ΤΗΕΟ in normal mode
Με εκνευρίζουν οι "στόκοι"
dustuxws ton teeutaio kairo exw ''apanwtes'' empeiries se shmeio pou frikarw..
Δεν πας να κάνεις και μια αξονική εγκεφάλου... :p:p Just kidding. :lol:
To test αύρας από το φαρμακείο το πήρε? Kidding again! :rolleyes:
Ναι, γιατί θεωρείται δεδομένο ότι υπάρχει αύρα, έχει επιστημονική μεθοδολογία μέτρησης, και μόνο ένας άνθρωπος στον κόσμο έχει μηχάνημα (??) να την μετρήσει, με αποτέλεσμα το μοναδικό ερώτημα που προκύπτει είναι "πως ο φίλος ξέρεις το χρώμα της αύρας του???" (οεο?)...
Gues what: kidding again!!
p.s.: σοβαρευτείτεεεεεεεεεεεεε...
ναι η αυρα υπαρχει...(τυχαια εβαλα το λινκ.,,,υπαρχουν και αλλα πολλα που μπορεις να διαβασεις)
οσο για τον ντοκιμαντερ που ειχα δει ηταν 8 χρονων περιπου παλιο...ΒΑΣΙΚΑ αυτο το μηχανημα υπαρχει σε πολλα εργαστηρια και αυτος απλα δεχοταν οποιονδηποτε ηθελε να δει την αυρα του,,,,,,
απο τοτε μπορει να εχουν και αλλοι καποιο αναλογο μηχανημα δεν ξερω,,,
παντως η αυρα υπαρχει,,την εχουν ολοι οι ζωντανοι οργανισμοι και εξηγειται με τη φυσικη και την χημεια...:)
ΤΗΕΟ in normal mode
euxaristw gia t kra3imo:P ekleisa gia aurio radevou gia a3oniki. den exw idea, kai exw thn aisthisi oti kan den rwthsa pws proekupse auto me thn aura tou. alla genika htan psagmenos o tupos. se vash pou ithele na ''doulepsei'' ta tsakras tou kai an den apatwmai ekeinh thn periodo ginotan ena seminario sthn ispania kai ithele na t parakolouthisei. oso gia to mhxanhma prwth fora akouw gia thn upar3h tou
To μηχανημα λεγεται κατι σαν κυρλιαν νομιζω;)
Ναι υπαρχει...μαλιστα το ειχαν δοκιμασει και σε σκυλο
ΤΗΕΟ in normal mode
Το λινκ που παρέθεσες μιλάει περί "New Age μεταφυσικής"... :wacko: Να με συγχωρείς, αλλά με τέτοια βάση δεν μπορώ να λάβω τπτ στα σοβαρά!:rolleyes:
Εκτός αυτού, παρακάτω στο κείμενο του λινκ αναφέρει πως "Από την άλλη, μπορείτε να δείτε αύρες αν έχετε ημικρανίες, κάποια μορφή επιληψίας, βλάβη στο οπτικό σύστημα ή μια εγκεφαλική διαταραχή." Απο εκεί προέκυψε και το αστείο που έκανα στην fck_rocket_queen περί αξονικής! :p
http://www.supernatural.gr/files_aura.htm
παρε ενα αλλο τυχαιο λινκ...
Η αυρα υπαρχει και εξηγειται με την φυσικη και τη χημεια,,δεν ειναι κατι το υπερφυσικο....
καλυτερα ψαξε και συ ο ιδιος μονο σου γιατι για να σε πεισω πρεπει να χαλασουμε το φορουμ,,,
παντως πολλα πραγματα ειναι αληθινα ειτε τα πιστευουμε ειτε οχι
ΤΗΕΟ in normal mode
Υπάρχει κάποια μέθοδος ανίχνευσης και μέτρησης της αύρας - αν ναι (και δεν μιλώ για τις φωτογραφίες Kirlian -το γιατί, όσοι ψάχνεστε το ξέρετε και αν δεν το ξέρετε! ε! ευκαιρία να το ψάξετε και να το μάθετε! :D), αυτή η μέθοδος μπορεί να μας εξηγήσει σε πιο επίπεδο του φάσματος της ακτινοβολίας εκπέμπεται η "αύρα" ώστε να ανιχνευθεί και να καταγραφεί από τον τεχνικό εξοπλισμό που υποτίθεται ότι την ανιχνεύει; (είναι ένα πολύ εύκολο ερώτημα) *Εδώ θεωρώ ότι υπάρχει τέτοιου είδος εξοπλισμός -- απαντήσεις του στυλ "νιώθω την αύρα" κτλ. δεν με καλύπτουν.*
Υ.Γ.
Αξίζει να σημειώσω ότι, σε περιπτώσεις κρίσεων ημικρανίας ή οπτικών παραισθήσεων έχουμε να κάνουμε με Scintillating Scotoma (ψάξτε το, το "θυμούνται" ελάχιστοι Έλληνες οφθαλμίατροι) και όχι με Aura Vision ενώ όσοι άνθρωποι το έχουν βιώσει καταλαβαίνουν ότι αυτό που βλέπουν μόνο Αύρα (με την Μεταφυσική έννοια του όρου) δεν είναι -και εδώ επιτρέψτε μου να ξέρω "τι λέω" . . .
Old programmers never die. They just terminate and stay resident.
Εκτός από την μέθοδο Kirlian (που δεν μπορεί να θεωρηθεί αξιόπιστη) υπάρχει κάποια άλλη μέθοδος ανίχνευσης και μέτρησης της αύρας - αν ναι, αυτή η μέθοδος μπορεί να μας εξηγήσει σε πιο επίπεδο του φάσματος της ακτινοβολίας εκπέμπεται η "αύρα" ώστε να ανιχνευθεί και να καταγραφεί από τον τεχνικό εξοπλισμό που υποτίθεται ότι την ανιχνεύει; Εδώ θεωρώ ότι υπάρχει τέτοιου είδος εξοπλισμός -- απαντήσεις του στυλ "νιώθω την αύρα" κτλ. δεν με καλύπτουν.
Λογικα ναι! γιατι ειναι ακτινοβολια..
ΤΗΕΟ in normal mode
Επειδή φαίνεται πως το έχεις πάρει στα σοβαρα, μπορείς να μου παραθέσεις μια πηγή όπου αποδεικνύει με Φυσική και Χημεία την ύπαρξη και την ανίχνευση της αύρας? Σε ρωτάω γιατί συνεχίζεις να παραθέτεις πηγές άκρως αναξιόπιστες, αντιεπιστημονικές και μπακαλίστικες.
edit: μιας και σ'αρέσουν τα λινκς, πάρε και μερικά πρόχειρα που βρήκα:
1) Όταν βλέπεις τις αύρες ανθρώπων!
2) Το πείραμα του James Randi!
3) Η επιστήμη που στηρίζει παραφυσικά φαινόμενα όπως η αύρα!
Κοιταξε, η επιστημη (στη φυσικη και στη χημεια) εχει αποδεχτει(και νομιζω οτι εχει αποδειξει) οτι καθε οργανισμος εκπεμπει μια ακτινοβολια απο το σωμα του...απλα δεν εχει αποδειξει οτι αυτη η ακτινοβολια(αυρα) φανερωνει και στοιχεια της ψυχοσυνθεσης του ατομου...εχει καταγραφει οτι το άρρωστο παιδί νιώθει σύντομα καλύτερα, μόλις η υγιής μητέρα το πάρει αγκαλιά. Περνάει με τον τρόπο αυτό τη δική της υγιή ακτινοβολία και δυναμώνει αυτήν του παιδιού, που έχει ελαττωθεί από την αρρώστια.αυτα ειναι αληθεια,,,,,,
Εδω δεν νομιζω οτι ειναι το καταλληλο θεμα(ουτε το καταλληλο φορουμ) για να ανοιξουμε τετοια συζητηση..αυτα που λεω μπορεις να τα επιβεβαιωσεις μονο σου ψαχνοντας απλα στο google, εγω δεν εχω τον χρονο να ψαξω για κατι που εχω αποδεχτει, για να σε πεισω, επισης δεν εχει νοημα να παραθεσω λινκ γιατι λογο του εγωισμου σου (ετσι γινεται στις περισσοτερες αντιπαραθεσεις-δεν κανω επιθεση προς το ατομο σου) δεν προκειται να το αποδεχτεις αυτο που θα σου παραθεσω και ας ειναι αληθεια..
Επισης οπως ειπα ποιο πανω Κάποια πραγματα ειναι αληθινα,ειτε τα πιστευουμε ειτε οχι..
αν ψαξεις θα βρεις τις αποδειξεις που θες...καλυτερα μην το συνεχισουμε αλλο,δεν θα βγαλει πουθενα.
ΤΗΕΟ in normal mode
Κοίταξε. Όταν κάτι έχει να κάνει με το μη προφανές, την απόδειξή του πρέπει να την κάνει αυτός που προτείνει, όχι αυτός που ισχυρίζεται ότι δεν το αντιλαμβάνεται με τις 5 αισθήσεις του (και άρα το απορρίπτει). Για παράδειγμα, όταν μου λες ότι ο κάθε άνθρωπος έχει μια αύρα, η οποία είναι ακτινοβολία (αλήθεια, τι είδους ακτινοβολία είναι? φασματική περιοχή? μήκος κύματος/συχνότητα? τι σου λέω τώρα, ε...) που εξέρχεται του σώματος, τοτε θα πρέπει να μου το αποδείξεις, γιατί δεν είναι προφανές. Με το να πετάς ένα "έχει αποδειχθεί" δεν ξεμπερδεύεις.
Γι' αυτό λοιπόν σε προκαλώ, δείξε μου την μελέτη, το paper, οτιδήποτε, που να εξετάζει ΕΠΙΣΤΗΜΟΝΙΚΑ (παρατήρηση-θεωρητική θεμελίωση-πειραματική απόδειξη) και να αποδεικνύει αυτό που αποκαλείς αύρα, χωρίς μπακαλίστηκες θεωρείες και αφελή συμπεράσματα, και χωρίς αντιεπιστημονική μεθοδολογία.
Αλλά από τα λεγόμενά σου αμφιβάλλω αν έχεις ξεκάθαρη εικόνα της διαφοράς επιστήμης και ψευδοεπιστήμης.
Ti μηκος κυματος και συχνοτητα με ρωτας,,,δεν ειμαι ειδικος να σου απαντησω.;)
οπως σου εξηγησα και ποιο πανω δεν διαθετω το χρονο(επειδη διαβαζω για πανελλαδικες) να ψαξω να βρω αυτο που ειχα διαβασει οπου αποδεικνυει επιστημονικα οτι καθε ζωντανος οργανισμος εκπεμπει ακτινοβολια,,λυπαμαι αλλα δεν μπορω να θυμαμαι τοτες πληροφοριες που ανεφερε για να στις αναμεταδωσω..
Και επειδη ειμαστε off-topic ψαξε μονο σου στο google και θα βρεις αυτο που σου λεω,,,μην τα θες και με το κουταλι στο στομα,,,και σε καμια περιπτωση δεν προσπαθω να σε πεισω.(και το επαναλαμβανω για 3η φορα,καποια πραγματα ειναι αληθινα ειτε τα πιστευουμε ειτε οχι)
Επισης αν ησουν καλος μαθητητης στη βιολογια του λυκειου θα ειχες διαβασει και στο βιβλιο που λεει οτι καθε κυτταρο εκπεμπει ηλεκτρομαγνητικα κυματα..και αυτο εχει να κανει με τις εντολες που στελνει το κυταρο για να επικοινωνει,,,(νομιζω οτι ακομα και απο αυτο καταλαβαινεις οτι ειναι λογικο οτι καθε σωμα εκπεμπει ακτινοβολια προς τα εξω)
τερμα το off-topic απο μενα,... αν θες πραγματικα να μαθεις τι ισχυει ψαξτο μονο σου,,αν θες να βγαλεις τον εγωισμο σου συνεχισε να ασχολεισαι με το θεμα αυτο (που ειναι και off-topic):rolleyes:
ΤΗΕΟ in normal mode
Mercyful_Fate μπορείς να προκαλέσεις τον THEO_LEGEND στέλνοντάς του pm ή μπορείς να ανοίξεις καινούριο θέμα..
Εγώ θα έλεγα να συνεχίσουν δημόσια γιατί
1. Έχει ενδιαφέρον το θέμα
2. Δεν είναι και τόσο off-topic αφού πρόκειται για σχολιασμό προηγούμενης ιστορίας. Εντάξει καλό είναι γράφει ο καθένας τη μπούρδα του και να λέμε "αααα, ωωωω :eek:", αλλά και λίγη συζήτηση περί το κατά πόσο είναι αληθινά/εξηγούνται επιστημονικά δε βλάπτει...
Τη χρονιά 1872 ένα πλοίο,το Mary Celeste, δηλώθηκε εξαφανισμένο καθώς δεν είχε δώσει σημεία ζωής για αρκετό διάστημα και ούτε είχε καλέσει σε βοήθεια. Έτσι λοιπόν ανατέθηκε σε ένα καπετάνιο μαζί με το πλήρωμα του να βρει το χαμένο πλοίο και να το επιστρέψουνε στο κοντινότερο λιμάνι. Το πλοίο τελικά βρέθηκε κοντά στο Γιβραλτάρ να πλέει ακανόνιστα και σε χαμηλή ταχύτητα κοντά στο πλοίο του καπετάνιου. Με διαταγές του λοιπόν το πλήρωμα το πλεύρισε και αφού δεν πήρανε απάντηση στους χαιρετισμούς,ο κυβερνήτης όρισε μια ομάδα να επιβιβαστεί στο ακυβέρνητο σκάφος. Αυτό που είδανε στο Mary Celeste τους τρόμαξε πιο πολύ από οτιδήποτε θα μπορούσαν να είχαν προκαλέσει πειρατές.
Το σκάφος ήταν άθικτο,τα κρεβάτια ήταν στρωμένα και η καμπίνα του καπετάνιου ήταν γεμάτη με παιδικά παιχνίδια τα οποία πρέπει
να ανήκαν σε κάποιο κοριτσάκι. Στην τραπεζαρία το φαγητό ήταν στρωμένο και ζεστό και οι κούπες γεμάτες. Ούτε σημεία κλοπής υπήρχαν, αφού και το φορτίο ήταν άθικτο,ούτε σημεία πάλης,ούτε τίποτα που να δηλώνει προσβολή του σκάφους. Το μόνο που φαινόταν αντικανονικό πάνω στο Mary Celeste ήταν η ανεξήγητη απουσία του πληρώματος κ η παράξενη νεκρική σιωπή που απλωνόταν γύρω τους.
sth rodo legetai oti kapote enas podhlaths exase th zwh tou peftontas apo gremo. apo tote epikratei enas muthos oti kathe xrono thn hmera pou egine to atuxhma ta pada se ekeino to dromo nekrwnoun kai emfanizete o podhlaths kai peftei sto gremo. sugekrimena lene oti den prepei na kaneis tpt th stigmi pou emfanizete diaforetika uparxoun epiptwseis (.....!.....). meta ola leitourgoun kanonika....
Σενάριο ταινίας είναι αυτό!
Από Wikipedia:
Oliver Deveau, the chief mate of the Dei Gratia, led a party in a small boat to board the Mary Celeste. He found the ship in generally good condition, though he reported that "the whole ship was a thoroughly wet mess". There was only one operational pump, with a lot of water between decks and three-and-a-half feet (1.1 m) of water in the hold. The forehatch and the lazarette were both open, the clock was not functioning and the compass was destroyed. The sextant and marine chronometer were missing, and the only lifeboat appeared to have been intentionally launched rather than torn away, suggesting the ship had been deliberately abandoned. Popular stories of untouched breakfasts with cups of tea on the cabin table, washing hung out to dry, a cat found asleep on top of the gallery locker and a bowl of a half-eaten apple pie are wholly without substance.
Προφανώς η ιστορία του Mary Celeste είναι πολύ πιο "καθημερινή" και μάλλον δεν κουβαλάει κανένα υπερφυσικό στοιχείο πάνω της...
Η πιο αληθοφανής εξήγης της εγκατάληψης του Mary Celeste είναι η εξής: Το πλοίο είχε φορτωθεί στη Νέα Υόρκη με πολλά βαρέλια οινοπνεύματος (αυτό ήταν το φορτίο του), και με προορισμό την Τζένοα της Ιταλίας. Ο καπετάνιος του πλοίου δεν είχε ξαναμεταφέρει τέτοιο φορτίο, το οποίο και ενδεχομένος να θεωρούσε επικίνδυνο. Λόγω του ότι οταν το πλοίο βρέθηκε και οδηγήθηκε στη στεριά είχε 9 βαρέλια οινοπνεύματος άδεια, πιθανολογείται ότι κατά το ταξίδι υπήρξε μια μικρή διαροή οινοπνεύματος, το οποίο ενδεχομένος να δημιούργησε μερικές αναθυμιάσεις και εξάτμιση. Ο καπετάνιος ίσως θεώρησε ότι αυτό θα οδηγούσε σε έκρηξη, με αποτέλεσμα να έδωσε πανικόβλητος εντολή στα μέλη του πληρώματος να επιβιβαστούν στη σωστική λέμβο έως ότου περιοριστεί η διαροή και το πλοίο είναι και πάλι ασφαλές. Οι άνεμοι τότε πιθανώς να απομάκρυναν το πλοίο από τη λέμβο, με αποτέλεσμα το πλήρωμα είτε να πνίγηκε, είτε να βγήκε σε κάποια στεριά (τελευταία σημείωση του ημερολογίου του πλοίου έλεγε πως ήταν κοντά στις Πορτογαλικές νήσους Αζόρες) και να πέθαναν από πείνα ή δίψα.
http://www.imdb.com/title/tt0288477/
Από Wikipedia:
Η wikipedia δεν ειναι καθολου αξιόπιστη πηγη...:)
