[Επίσημο] Nokia 7610
Itchrist86
εας ελπισουμε οτι δεν 8α εχει το ιδιο προβλημα με τα πιξελ,οπως το 6600..γιατι τοτε...
http://www.myphone.gr/gallery/uploads/5309/2.jpg Βελιγραδι VOLIM TE UVEK! 13/2/97
  • Απαντήσεις 4,8χιλ.
Αρχικό Μήνυμα από το μέλος xultimatex ( 6 Ιούν. 2004 , 10:29)
S'ena filadio tou Germanou eida oti to kin exei mpei sti lista! To exei san "Sintoma konta sas" kai den exei timi! Ston katalago pou sigrinei dinatotites pollon kiniton leei oti exei irDA! Ti allo tha akousoume! :wacko:
Episis sto eksofillo leei oti to filadio isxii mexri 18/6 opote kai erxontai ta kinita kai den einai "Sintoma konta sas" Mallon tote prepei na perimenoume to 7610! Iparxei omos kai i pithanotita stis 18/6 na erxetai to teleutaio kinito kai to 7610 na erthei pio noris! :blink:
καλα στον γερμανο δεν ξερουν την τυφλα τους
και αλλο review του 7610...
Got my 7610 and here is my review
i had been waiting for the 7610 for a very long time
but i should say the first time i say the phone on nokia.com, i hated the phone for some unknown reason. i was like an anti-7610
but as time passed by i fell in love with phone
believe me, the 7610 is worth the wait
when i got my 7610 i felt like i was on top of the world. i got the black and brown 7610 and is quite good looking. i put in the sim card and there was the beautiful view of the 7610
1.the 7610 feels quite solid. the keypad does not shake as in the 6230 and there are no gaps between the keys
2.the keypad is a bit hard and sometimes you may have a problem pressing the left directional button as you may instead press the ok button as they are quite close. otherwise no keypad problem
3.the system is faster than my 6600. adding, deleting files does not take long.
4.camera : the camera is just too good. high quality pics take a little time to save (by little time i mean some 1 sec extra) . but after clicking if you move the camera, the pics dont move. the quality of the pics is just awesome. even when you zoom the pics, the pics are not pixelated.
5.the video camera captures videos at a viewable quality. the videos are not bad as in 6600 and 3660
6.when i transferred some pics from my 6230 and 6600 to my 7610, the pics looked much much better on screen.
7.the camera also works well in dim light
8.the mp3 player is ofcourse mono. but when mp3s are player through the loudspeaker of the phone, they are quite loud and can be easily heard
CONCLUSION :
PROS : 1.great camera
2.good video recording
3.great screen
4.fast OS system
CONS : 1.rs-mmc cards (as they are not yet available in the market)
2.mono mp3 player
OVERALL I WOULD GIVE THIS PHONE 4 OUT OF 5
Αρχικό Μήνυμα από το μέλος giannis42 ( 5 Ιούν. 2004 , 18:40)
indeed, heap size is 8MB
shared memory is 40MB
vre paidia ti simeni afto, to ida se ena forum gia 7610.
heap memory ine san tin ram sto pc su. fwrtwni ta prgys pu trexei ke oti allo theli -xreiazetai kathe stigmi to OS.
i alli ine mnimi san skliros diskos pu exun ola ta kinita. apothikevis arxia, epafes, programmata klp klp
Alex = the best!
PIN: 20DDA1B0 (Storm)
Στην θεωρία είναι όντως έτσι αλλά εδώ ξέρουμε 100% οτι η shared memory που λέει ο τύπος, δηλαδή ο αποθηκευτικός ελεύθερος χώρος του τηλεφώνου, είναι 8ΜΒ. Τα άλλα 32ΜΒ τι είναι;
Μήπως όμως ο τύπος που το λέει αυτό τά'χει μπερδέψει και ισχύει το αντίθετο; RAM 8MB και STORAGE 8MB;
Τόσοι το κάναν κριτική, δεν μπορούσε ένας να βάλει το application manager να μας πει στα σίγουρα; Τόσο δύσκολο είναι; Βασικά όλες οι κριτικές που έχουμε δεί μας λένε τα ίδια πράγματα, τίποτα νέο.
Na epivevaiwsw kai egw oti den exei stereo hxo.
Kai to xeirotero einai oti den pairnei katholou to stereo headset (bgazei enhancement not supported).
Mp3 paizei (eite apo to megafwno eite apo to monofwniko headset), alla ekane mikra kollhmata sthn anaparwgh. To arxeio pou dokimasa htan bebaia 192Kbps, opote isws auto na eftege. Isws sta 128/92 kbps na paizei kalutera.
Kata ta alla, polu wraio apo kathe apopsh....
Υπέροχο το τηλεφωνάκι παιδιά!! Φίλε άγνωστε22 είσαι σίγουρος ότι δεν παίρνει ακουστικά στερεοφωνικά; Δηλαδή, εμένα δεν με νοιάζει να είναι στερεοφωνικά, αυτό που με νοιάζει είναι να παίρνει έστω κια μονοφωνικό 2πλό handsfree . Υπάρχει κάτι τέτοιο; Η θα μπορούμε μόνο να ακούμε με το μονό ακουστικό που έχει μέσα στο κουτί του; :wacko: :blink: :confused: :worry:
Παρακαλώ ας το επιβεβαιώσει κάποιος!!! :!: :!:
Ευχαριστώ!
Στο παρακάτω λίνκ είναι ένα Γαλλικό e-shop το οποίο όμως στέλνει Ελλάδα(!) έχει την RS-MMC 109.90? .
Ιδού το λίνκ! Εδώ ακριβώς!!
:) ;) :happy:Γαλλικό e-shop
Γράφτηκα στο Mobile BPit και έστειλα μήνυμα σε έναν κάτοχο του 7610
σχετικά με την υποστήριξη στέρεο και διπλού handsfree.
Ορίστε η απάντηση που έλαβα:
Ερώτηση:
CITATION
Je suis un gar?on de Gr?ce et je voudrais vous demander quelque chose sur votre Nokia 7610.
Votre Nokia 7610 peut-il accepter double mains libres except? du mains libres mono qu'il a dans la bo?te ?
Je veux dire, le nokia 7610 de bidon peux accepter le mains libres st?r?o que les autres s?ries 40 de nokia vous acceptent savent.
Merci beaucoup ! !
J'attends avec int?r?t d'avoir de vos nouvelles !
Merci encore !
Απάντηση:
Carlinaxe: non malheureusement le 7610 n'acc?pte pas le st?r?o
Μετάφραση:
Ερώτηση:
QUOTATION I am a boy of Greece and I would like to ask you something on your Nokia 7610. Your can Nokia 7610 accept free couplers except free hands mono qu'il has in the box? I want to say, the nokia 7610 of can can accept the stereo free hands that other series 40 of nokia accept you know. Thank you very much! ! J'attends with interest to d'avoir of your news! Thank you still!
Απάντηση:
Carlinaxe: not unfortunately 7610 stereo n'acc?pte not it
:cry:
Το έκανα και edit για να μην λέει ο αγαπητός μας moderator ότι κάνω άχρηστα και άσχετα πόστ.
Ευχαριστώ!
Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι...
Wind Όσα παίρνει ο άνεμος
εχετε φαγωθεί με το στερεο! μα και στο 6600 δεν φταίει που είναι μονοφωνικό...φταίει που είναι για τα μπάζα(ακριβώς δεν ξέρω τι φταίει, πάντως σίγουρα όχι η μονοφωνία)
δηλαδή αν στο ηχοσυστημα του σπιτιού σας απομονώσετε το ενα κανάλι ακούγεται χάλια?
ήηηηηηηημαρτον....
ασχετο, απο ιντερνετ μπορούμε να πάρουμε το 6620 και να ξενοιάζουμε? αν ναι, πως που κτλ...
να είστε καλα :-)
To 6620 δεν εχει βγει φιλε μου και κατι ακουγετε οτι παει για ακυρωση...
τουλάχιστον σε ενα Forum αυτο διαβασα. Προφανως το 7610 θα ειναι ο αντικαταστατης του!;)
Παρεπιπτόντως καλωσηρθα και παλι στο FORUM...
Αχχ αυτη η cosmote τι μας κανει...
The "unwired" revolution began...
_http://www.myphone.gr/forum/image.php?type=sigpic&userid=6201&dateline=1272991407
Γεμισαμε απο φωτος τραβηγμενες απο 7610. :)
Παπαγαλοι :p φωτογραφημενοι απο 7610
http://www.unknown-insanity.com/uploads/homey_1.jpg
http://www.unknown-insanity.com/uploads/Bernie.jpg
http://www.unknown-insanity.com/uploads/Homey_2.jpg
iPhone 5S Space Grey
Παιδια δεν ειδα σε κανενα review για το LifeBlog.Δεν εχουμε κανενα νεο??
Νά'ταν μόνο το LifeBlog. Δεν έχω δεί ακόμα ολοκληρωμένο review (τουλάχιστον σε μια γλώσσα που να μπορώ να διαβάσω). Όλοι κάνουν αρίθμιση στα πλεονεκτήματα και μειονεκτήματα λες και φτιάχνουν λίστα με ψώνια! :) Ακόμα περιμένουμε να μάθουμε τα τεχνικά του χαρακτηριστικά που μας ενδιαφέρουν. Μας έχουν πήξει στις φωτογραφίες. Φτάνει άλλες φωτογραφίες, το κινητό θέλουμε τώρα. :D
Wirelessly posted (:) Μάνος_the_Wireless_Master:): SonyEricssonP900/R101 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Συγκεντρωμένες οι τιμές του Νόκια 7610 σε διάφορα Ελληνικά καταστήματα Γερμανός 7610 = 541 ευρώ, Πλαίσιο τελική 7610 =506 ευρώ, 9volto 7610= 530 ευρώ και Alpha Copy 512 ευρώ. Οι τιμές είναι τελικές με Φ.Π.Α. και προέκειψαν από τηλεφωνική επικοινωνία που είχα σήμερα με τα εν λόγο μαγαζιά. Το παράξενο είναι ότι τα μαγαζιά αυτά καθώς και η αντιπροσωπία της Νόκια δεν ξέρει πότε θα είναι διαθέσιμο το κινητό. :worry: :confused: Ελπίζω να μην είναι άσχετο και αυτό άσχετο petran. :o
pantws egw eimai se dilima tin agorasw to nec tis cosmote me 1.3mp i to 7610?mallon to nec afou apo smartphone eimai kalimenos apo to p900
Try not to become a man of success, but rather try to become a man of value.
Albert Einstein
Γεια χαρα σε ολους!Σημερα ειχα την τιμη να πιασω στα χερια μου το 7610!Δυστηχως ομως δεν ειδα το μενου του.
Το κινητο ειναι αρκετα πιο λεπτο και στενο απο το 6600 αλλα εχουν το ιδιο υψος.Η οθονη καλυπτει σχεδον το 60% του κινητου.Η ποιοτητα κατασκεης του ειναι πολυ καλη χωρις τριξιματα.Τα πληκτρα και το κεντικο πολυπληκρο πατιουντε με ευκολια, αν και το κουμπι 3 ειναι πολυ μικροτερο σε σχεση με τα αλλα.Τελος η τιμη του ηταν 410 λιρες Αγγλιας δηλαδη καπου στα 600+ ευρω. :cool:
http://www.threegmobile.net/international/index.html
Σε αυτό το λίνκ υπάρχει ένα review του 7610 από το ThreeGMobile.net .
Enjoy!!! :happy:
Ελπίζω να μην είναι άσχετο και αυτό Petran.
