[Επίσημο] Nokia E66
nervous
ρε παιδια παω να συνδεσω το ε66 και ενω εχω βαλει το pc suite κατα την διαρκεια που μου ζηταει να συνδεσω το τηλεφωνο εχω αυτο το σφαλμα
nokia e66 usb phone parent
  • Απαντήσεις 2,1χιλ.
Nokia E66 FW 300.21.012 changelog
PURPOSE
  • This release is a major feature release and also was intended to correct main complaints from Customers and Operators
NEW FUNTIONALITIES:
  • Mail for Exchange 2.9
  • Numonyx USB Flashing support
  • Gimlet 5.2 (v 9.5.2.66)
  • Turkish SMS Support
  • Support for Rapido Yawe 1.15
  • Myspace, Youtube and Facebook support (NA for HK and Taiwan variants)
  • User experience improvements
  • Increased robustness of the Home Key functionality. This helps avoid the problem of Home key not opening the menu
CHANGES AND IMPROVEMENTS:
  • Improved Switch application functionality
  • Internet Radio 1.15 Increased Functionality and Stability
  • VoIP upgrade Improved functionality and stability
  • Download Client 3.2 Greater stability and improved functionality
  • Email Setup Wizard Update Supports Gimlet 5.2
  • Simplified MMS Notification handling support
  • Support for conference numbers longer than 24 digits
  • Improvements in Browser for seamless YouTube support
  • Language menu can be accessed when Chinese Language is used
  • Bug fixes for the NokiaPC Internet AccessApplication
  • Improved BT headset connectivity
  • Many functionality and Stability improvements in MfE
GENERAL
  • Stability and functionality improvements
  • Increased robustness in handling SMS
  • Updated Time zones
  • Updated Operator names database
  • Localisation improvements
  • Updated Startup settings
  • Security Updates and vulnerability fixes
  • Phone not suspending packet data connection when receiving call Fixed
  • Many bug fixes for MyNokia feature
  • Minor audio related bugs fixed
  • Updated helps
BROWSER
  • Minor stability improvements
CALL HANDLING
  • Minor improvements in Call handling and quality
CALENDAR
  • Stability and Minor Functionality improvements
CONNECTIVITY
  • WLAN functionality Improvements
  • Fix to prevent Wifi Certification issues when Wifi alliance moves to Win 2008 as the test server
  • Fix for the one way audio problem seen in Cisco VoIP client
  • Memory leak fixes
CONTACTS/PHONEBOOK
  • Minor UI Improvements
  • Stability and functionality improvements for search functionality
EMAIL
  • Mail for Exchange upgraded from 2.7.22 to 2.9.158
  • Gimlet updated to v5
  • Email setup wizard updated
  • Support for Exchange Server 2007 in MfE
  • Many functionality and stability improvements in MfE
  • Robust Synchronisation of Calendar and email items
INTERNET RADIO
  • Improved functionality
  • Increased application stability
LOCATION/GPS
  • Increased A-GPS stability
  • Better stability in location services.
MESSAGING
  • Usability improvements
SMS
  • Support for receiving more SMSs. Allows more than 4000 messages in inbox
SWITCH APPLICATION
  • Application updates and many stability and functionality improvements
VOIP / SIP
  • Many Usability, stability and functionality improvements
3210-3310-8210-8310-6510-7250-3100-6230-6060-6280-E65-N82+2630-C7-SIII Mini-Moto G 2014-Redmi Note2 prime-Redmi Note3 Pro-Redmi Pro Χ25-Redmi 5 Plus-Mi A2
Καλημέρα σας.
Η μπαταρία του Ε66 που πρόσφατα αποκτησα (μεταχειρισμένο), κρατά 1,5 μέρα με νορμάλ χρήση. Εχω αγοράσει νέα μπαταρία γνήσια , έκανα και update στο λογισμικό του , αλλα το πρόβλημα παραμένει το ίδιο αν σκεφτεί κανείς ότι στο τηλέφωνο δίνουν 260 ώρες αναμονή ή 450 λεπτά χρόνο ομιλίας . Επίσης έχω διαβάσει όλο το ποστ και τις οδηγίες σας και βεβαίως έχω κλειστα Wi-fi, BT και τυχον εφαρμογές που τρέχουν στο παρασκήνιο. Παρακαλώ για τη βοήθεια σας.
Τόσο κρατάει κ σε μένα. Μέρα παρά μέρα το φορτίζω και αν χρησιμοποιήσω wifi κλπ, και κάθε μέρα. Υπάρχει ένα θέμα αν έχεις κάποια προβληματική έκδοση του garmin που ρουφάει τη μπαταρία.
Δυστυχως εδω και 20 μερες ειμαι χωρις κινητο .Το παρεδωσα στην voda για ελεγχο και πιθανη αντικατασταση ,αλλα απο τοτε ψαχνομαι.Το κινητο ηθελε συνεχεια επανεκκινηση και το συρταρψτο τμημα ειχε σε 15 μερες αρκετο τζογο.Η voda το εστειλα στην Alpha copy και η συνεχεια μαλλον γνωστη.Παρ ολο που εστειλα 2 email στην voda ουδεις απαντησε,τελικα τους πηρα τηλ και μου ειπαν οτι ακομη το εξεταζουν στην Alpha,και δεν μπορουν να μου πουν τιποτε για ημερομηνια παραδοσης.Θα κανω υπομονη λιγες μερες ακομη και επειτα μαλλον στην προστασια καταναλωτη,δυστυχως ειμαστε σε καθεστως αποικιοκρατιας
Εγώ το είχα πάει για service για διάφορα προβλήματα, μου το επέστρεψαν μετά από 25 μέρες (από εξωτερικό που είχε πάει για επισκευή υποτίθεται) στην ίδια ακριβώς κατάσταση. Αφού έκανα σκηνή στα κεντρικά πλέον και όχι στο υποκατάστημα, το πήγαν επιτόπου για service και σε 15' μου είχαν αλλάξει οθόνη + slide δωρεάν φυσικά...
το κινητο μας παίζει Mp4?μετεφερα απο ν95 ενα βίντεο και παιζει μόνο τον ήχο.Ίσως με κάποιο πρόγραμμα? :)
pocophone X3 NFC // huawei watch gt :!:
Για κάποιο λόγο τα βίντεο που τραβάνε τα Nseries Ν95, Ν82 κλπ... δεν παίζουν πλήρως στα Eseries.
Το ίδιο συμβαίνει και με το E51.
Ekana Update sto 300.21.012, ola kala :)
--- Από Ομάδα Διαχείρισης ---
Θα σε παρακαλούσα να αποφεύγεις τα greeklish και να γράφεις με ελληνικούς χαρακτήρες. Δες εδώ την ανακοίνωση κατάργησης των.
Καμια διαφορα?
Οι διαφορές υπάρχουν αναλυτικότατα λίγα μόνο ποστ πιο πάνω;)
σε θεωρητικο επιπεδο, γιατι στην πραξη ο χρηστης δεν καταλαβαινει καποια ουσιωδη διαφορα
παιδια μια ασχετη ερωτηση, μπορει κανεις να μου πει αν το Ε66 εχει πλαινα λαμπακια για αναπαντητες και sms σαν αυτα που εχει το 6300? γιατι ειναι πολυ βολικα.
εχει καποια αντιστοιχη λειτουργια?
Έχει να ρυθμίζεις αν θα αναβοσβήνει ο φωτισμός του κεντρικού πολυπλήκτρου όταν έχεις αναπαντητη, sms, mms και email.
ευχαριστω για την απαντηση,
ειναι εμφανης αυτος ο φωτισμος? φαινεται δηλαδη στο σκοταδι ευκολα η πρεπει να εχεις το νου σου στο κινητο?
Όταν το έχεις στο οπτικό σου πεδίο κάνει μπαμ ότι αναβοσβήνει. Και από μακρυά φαίνεται όταν αναβοσβήνει έντονα. Δεν είπαμε να είναι θαμμένο ή χωμένο και να φαίνεται που αναβοσβήνει.
Γεια σας και από μένα,
με το συγκεκριμένο κινητό επάθα την πλάκα μου μόλις το είδα, αλλά μετά από ανάγνωση 102 σελίδων δεν ξέρω αν αξίζει να το πάρω ή όχι. Ειδικά με τα κολήματα που τρώει.
Τι λέτε και εσείς ρε παιδιά ? Δεν θέλω να χάσω και την επιδότηση :)
Διάβασε το εν λόγω θέμα και βγάλε τα συμπεράσματα σου.
Αν το έχεις ήδη κάνει, πιστεύω πως έχεις ήδη αποκτήσει μια γνώμη.
Όσο και αν σου φαίνεται περίεργο δεν μπόρεσα να βγάλω συμπέρασμα γιατί οι γνώμες είναι μοιρασμένες. Εσένα πια είναι η γνώμη σου?
Προσωπικα δεν ειμαι καθολου ευχαριστημενοςαφου εμεινε 1 μηνα για επισκευη,ενω το εχω 3 μηνες.Αγορασα ενα μεταχειρισμενο Ν95 και βρηκα την λυση,το 66 το εχω ρεζερβα
να το παρεις χωρις δευτερη σκεψη. δεν θα μετανιωσεις την αγορα σου. τα περοσσοτερα απο τα προβληματα που διαβασες λυνονται με τις αναβαθμισεις.
Kαι αναβαθμιση εγινε και ελεγχος κλπ,το τηλεφωνο παλι κολλαει,η δε μπαταρια ειναι για αναμονη μονο,κανω λογικοτατη χρηση και καθε μερα θελει φορτισμα.Επειδη στην δουλεια εχουμε ακομη ενα,τα ιδια κανει και εκεινο,καμμια σχεση με το Ε65
Καλησπέρα παιδιά.
Το κινητό μου έχει firmware την έκδοση 200. Κάνω update, αλλά το πρόγραμμα λέει οτι έχω την πιο τελευταία έκδοση. Τελικά είναι η 200 η τελευταία; Εσείς πώς περάσατε την 300;
MB Ε65 ΒΤ AMG
Καλησπέρα παιδιά.
Μήπως είναι κάποια branded συσκευή τύπου vodafone live??
Αν ναί τότε για να μπορείς να ακολουθείς τις φυσιολογικές αναβαθμήσει θα πρέπει να αλλάξεις το product code και να ξαναπροσπαθήσεις να το ξανα αναβαθμίσεις!
Η τελευταία έκδοση πάντως είναι η: 300.21.012
Απο το Γερμανό την αγόρασα τη συσκευή. Μπορεί να είναι και branded απο Cosmote; Πώς μπορώ να το ελέγξω αυτό;
Άν είναι, τί κάνω σε αυτή την περίπτωση;
MB Ε65 ΒΤ AMG
Πήγαινε στο Product Codes και δες αν το δικό σου product code ταιριάζει μς το Ελληνικό. Αν δεν ταιριάζει τότε θα ακολουθήσεις την διαδικασία που αναγράφεται στο Εισαγωγή της Ελληνικής γλώσσας & debrand συσκευής
(αλλαγή product code).
Καλησπέρα, ένα πρόβλημα προέκυψε σήμερα ξαφνικά. Ενώ έστελνε κανονικά μηνύματα μέχρι τώρα, από το απόγευμα δεν στέλνει! Τα αποθηκεύει στο Outbox και όχι στο Sent για να φαίνεται ότι στάληκαν. Το μήνυμα δεν πάει. Έβγαλα την κάρτα και τη δοκίμασα σε άλλο κινητό και στέλνει κανονικά. Όλα τα υπόλοιπα δουλεύουν εκτός τα μηνύματα. Τι ρυθμίσεις να κοιτάξω; :confused:
