Έφαρμογές: Ότι νεότερο κυκλοφορεί... {Όλα τα είδη Software}
Tomby
στο irc δεν το έχεις?
αν δεν το έχει τότε αγόρασε το :)
Υ.Γ. τα προγράμματα που τα θέλουμε σαν τρελοί καλό είναι να τα αγοράζουμε για να έχουμε και κάποια 'legal' ηθική :) :lol:
Alex = the best!
PIN: 20DDA1B0 (Storm)
  • Απαντήσεις 1,6χιλ.
http://www.jgui.net/phoneprofiles/today_default.jpg
This program organizes your common phone and pocket computer functions and features in so called: Profiles. Each Profile defines and saves a whole range of your settings.
When you change the Profile, this program changes all settings in one time.
This program gives you four Phone Profiles:
Default Profile: to use basically, with standard settings
Loudest Profile: to use in the situations you need more attention because the more noise around you, like shopping, driving
Quietest Profile: to use in the situations you want be more privately, like sitting in the cinema, company meeting, nice dating
τώρα δουλεύει και με τα 2003 :)
link: http://www.jgui.net/phoneprofiles/index.html
Alex = the best!
BtRegTweak 1.1 (freeware)
With this freeware tool, you can eliminate the so-called "WM2003 BT annoyance", that means that the BT manager wont pop up anymore. This can be very annoying, when you use only one BT device (for example, a GPS receiver). The feature can be switched on or off. (You have to restart your PDA to apply the settings!)
It is reported to work on: iPAQ 2210, iPAQ 5550
UPDATE: 1.1 now supports the iPAQ 1940, please test it!
_http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=XE41EB8B7778A5BAABBBC26X294E54X1&platformId=2&productType=2&catalog=0&sectionId=0&productId=96903
Resco Explorer 2003 Version 5 Released
http://www.pocketpcthoughts.com/images/hansberry/2004/20040210-rescoexplorer5.gif
New features include:
. FTP add-in
. Send files via Bluetooth (iPAQs only)
. Send more files via IrDA (OBEX)
. Format storage card(s)
. System info in properties
. Drag'n'Drop feature
. HP Mobile Printing support
λινκ: http://www.resco-net.com/explorer.asp
Alex = the best!
Αρχικό Μήνυμα από το μέλος Alexkass (10 Φεβ. 2004 , 16:50)
auto pou perimena
to Drag'n'Drop feature ti ine?
και ο 4.30 έστελνε :)
το drag'n drop είναι: μεταφέρεις με 'σύρσημο' ένα αρχείο από έναν φάκλο σε άλλον ;)
Alex = the best!
Αρχικό Μήνυμα από το μέλος Alexkass (11 Φεβ. 2004 , 10:49)
Afto to eixe kai h prohgoumenh ekdosh (htan option se ena apo ta menu tou), mhpws ennwei kati allo?
Αρχικό Μήνυμα από το μέλος Alexkass (11 Φεβ. 2004 , 11:00)
το έχει κατεβάσει κανείς?
Μολις εκανα την εγκατασταση.
O 4.30 δεν έστελνε με ΒΤ... Αν το μπερδεύεις με το Qtek που μπορεί και στέλνει απο μόνο του είναι άλλο θέμα. ;)
Τα iPAQ όμως με 4.30 δεν έστελναν. Τώρα με τον 5 που έβαλα είναι μια χαρά...
[imgalign]http://icons.iconarchive.com/icons/iconshock/social-media/96/twitter-icon.png[/imgalign]"Some hearts are different than others. Like crystal in a world of glass... Even the way they shatter is beautiful..."
Wannabe Editor? Reviewer? Columnist?
Join the Unwired Revolution, now!
βασικα η resco υποστήριζε ότι ο 4.30 στέλνει μόνο από ipaq.
δεν το είχα δοκιμάσει στο 4150 επειδή δεν το γνώριζα τότε. :(
ίσως δεν δούλευε με το 1940 :worry:
Alex = the best!
Αρχικό Μήνυμα από το μέλος Exposed_Bone ( 9 Φεβ. 2004 , 08:45)
alla sixronos voithame kai tin eteria kai etsi iparxoun perisoteres pi8anotites na bgoun nees ekdosis apo ta programmata pou ta 8eloume san treloi
Τώρα καταλαβαίνω γιατί υποστηρίζετε σαν τρελοί την M$...
άρα κι εγώ διαφήμιση το Symbian από δω και πέρα! :p
Πέρα απ'την πλάκα, το σωστό είναι να τ'αγοράζουμε ΠΑΝΤΑ το progies. 'Η κόπιες κάνουν πολύ ζημιά στις ανερχόμενες εταιρίες και δεν πρόκειται να ρίξουν ποτέ τις τιμές (μεγάλες και μικρές)...
Αρχικό Μήνυμα από το μέλος mythos_bt (11 Φεβ. 2004 , 16:47)
Εγω με το 1940 και την 4.30 εστελνα κανονικα μεσω bluetooth χωρις το παραμικρο προβλημα.
Katse re synonomate giati me eskases... :D
Eixes to Resco 4.30 kai otan ekanes Send to sou evgaze kai BLUETOOTH Recipient ?? Egw pote den to eida...
Tote giati to vgazoun san neo feature re paidia? Mipws kaneis lathos? Me tin egkatastasi tou 5.0 emfanistike kai to antistoixo menou sto Send to... kai leitourgei...
Lol an den to dw den to pisteyw...
Αρχικό Μήνυμα από το μέλος Mythozz (11 Φεβ. 2004 , 18:59)
Και εγω στη θεση σου το ιδιο θα μου ελεγα :lol: ομως σε διαβεβαιω οτι εστελνε κανονικοτατα.Εξαλλου αν δεις στην παρακατω διευθυνση το "send files via Bluetooth (iPAQs only)" δεν αναφερεται ως νεα λειτουργια.
_http://www.resco-net.com/explorer.asp
EDIT:
Πιο "χειροπιαστη" αποδειξη
http://216.239.59.104/search?q=cache:FeLR1XZlOJkJ:www.resco-net.com/explorer.asp+resco+explorer&hl=el&ie=UTF-8
DVDx (freeware)
DVDx is a FREE DVD database program designed for the PocketPC with optional Microsoft Access synchronization
With DVDx, you can:
Review your DVD library or your DVD wish list on your PocketPC or Desktop
Add/modify/delete DVDs on your PocketPC or Desktop
Synchronize your DVD list on your PocketPC with your Desktop
Track who has your DVDs or how much, where and when you bought them
Supports multiple languages as supplied by DVDx users
Supports entering DVDs, VCDs, Laser Discs, and VHS tapes DVDs
_http://www.mavininteractive.com/ProjectManagement.do?command=ProjectCenter&pid=6
Αρχικό Μήνυμα από το μέλος mythos_bt (11 Φεβ. 2004 , 19:47)
EDIT:
Egw exw thn prohgoumenh ekdosh tou resco kai stelnw kanonika meso bluetooth :p
Goux goux:
Key Features
FTP add-in NEW
send more files via IrDA (OBEX) NEW
format storage card(s) NEW
system info in properties NEW
Drag'n'Drop feature NEW
HP Mobile Printing support NEW
search file/text in file
quick "send to folder"
file and folder copy, move, delete,...
favorites - quick folder access
ZIP compression
built-in viewer (text, jpg, png, bmp, gif...)
register editor (import/export/search)
network browser (PPC 2002,2003 only)
file association
strong file encryption
encryption add-in for desktop PC
"Send To" add-in for desktop PC
Key Features leei, oxi New Features......... ;)
@Oxin_Rain: Not Yet..
-άρα παίζει και σε 2000 (περιορισμένες λειτουργίες), 002 και 2003.
- PHM PowerToys Version 0.15 Released
. TaskMan: enables you to switch to, close, and kill applications.
. TrayLaunch: allows you to add icons to the Today screen notification area.
λινκ: http://www.phm.lu/Products/PocketPC/PowerToys/
Alex = the best!
