Alexkass Δημ. February 19, 2004 Δημ. February 19, 2004 δεν νομίζω να υπάρχει. γιατί να το κάνεις αυτό? μιας και το κλείσημο παραθύρων και όλες οι ενδείξεις βρίσκονται πάνω? http://www.langkawi.dk/u156.gif κατέβασε το handyswitcher και βάλε το σε ένα κουμπί (αφού το κάμεις εγκατάσταση). είναι Must. ;) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. February 19, 2004 Δημ. February 19, 2004 CabBackup PocketPC CAB re-Generator 1.0 http://www.pdatopsoft.com/images/screenshots/img107587808783293400.jpg Any other traditional backup program copy, as-is, the content information with its location from your device into a different place. CabBackup is the first software to re-create a CAB file of any PocketPC program (a CAB file is an installation folder containing all files needed to run a program). Basically, it recomposes the installation folder of any program, allowing you to backup easily and quickly all your PocketPC programs on an external memory card. Therefore, all unused programs can be stored and safely uninstalled. Thus, it dramatically saves memory space on your device. CabBackup does not need any synchronization with a PC and gives the freedom to backup your PocketPC programs anywhere, anytime. CabBackup features include: - Backup in 2 easy steps any PocketPC program into a new directory or external memory card - See the properties of installed programs Advantages: Whenever you are away from your computer, CabBackup is a great backup tool for PocketPC programs to save memory space on your device. Before you do a hard reset on your handheld device, make sure to backup all your programs with CabBackup. Finally, before installing new releases, CabBackup allows you to store previous version as a precaution on an external memory card. This first release includes free upgrade to Windows Mobile 2003 coming soon and any other upgrades until the 2.0 (not included). λινκ: http://www.pdatopsoft.com/software/item.php?pid=3141& Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
andrikosBO Δημ. February 19, 2004 Δημ. February 19, 2004 thnx ! για closing έχω βάλει το omegaone bat pack το οποίο περιλαμβάνει ανάλογο εργαλείο.. Και κάτι άλλο.. Θήκη αλουμινίου που μπορώ να βρώ; Προτιμώ κάποιο κατάστημα Ελλάδα :)
Alexkass Δημ. February 19, 2004 Δημ. February 19, 2004 θα σου έλεγα στο Buy & sell του φόρουμ. αλλά δεν βλέπω τώρα να πουλάει κανείς. γιατί όχι από το expansys.com ? Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
andrikosBO Δημ. February 19, 2004 Δημ. February 19, 2004 έψαξα στο expansys αλλά τζίφος... δεν μου βγάζει αποτελέσματα για 1915 hard case ... μόνο τις δερμάτινες
Alexkass Δημ. February 19, 2004 Δημ. February 19, 2004 βρε συ, ψάξε για 1930, 1940, 1935, 1945 :) ίδια είναι σε μέγεθος και σχήμα :) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. February 19, 2004 Δημ. February 19, 2004 οκ. ψάξε στο http://www.dabs.com http://www.cyberport.de και λογικά και τα άλλα παιδιά θα σου προτείνουν και άλλα σάιτς ;) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
DrMaslow Δημ. February 19, 2004 Δημ. February 19, 2004 @andrikosBO: λοιπον πήγαινε εδω http://shop.brando.com.hk/ipaq1910metalcase.php είναι το καλύτερο και πιο φθηνό site που έχω βρει ποτέ! Ψωνίζω εδώ και 2 χρόνια απο εδώ!!! την έχει με 25€ μαζί με τα έξοδα αποστολής και σε 5 μέρες θα είναι σπίτι σου! (κι ας λεει οτι θα κανει 15 μερες)!!!!! [sIGPIC][/sIGPIC]...μα πως να μην ξεχάσεις την αυλή σου και την παλιά τη γνώμη καθενός όσους κρυφά περπάτησαν μαζί σου να σημαδεύουν πάλι τη ζωή σου και να 'σαι το πουλί κι ο κυνηγός στις μαύρες λαγκαδιές του παραδείσου... Μάνος Ελευθερίου Ακούστε το
mythos_bt Δημ. February 19, 2004 Δημ. February 19, 2004 GasUpLogger 0.13 (freeware) _http://www.kent7.com/holly/gasuplogger/
andrikosBO Δημ. February 19, 2004 Δημ. February 19, 2004 Αρχικό Μήνυμα από το μέλος DrMaslow (19 Φεβ. 2004 , 13:04) @andrikosBO: λοιπον πήγαινε εδω http://shop.brando.com.hk/ipaq1910metalcase.php είναι το καλύτερο και πιο φθηνό site που έχω βρει ποτέ! Ψωνίζω εδώ και 2 χρόνια απο εδώ!!! την έχει με 25€ μαζί με τα έξοδα αποστολής και σε 5 μέρες θα είναι σπίτι σου! (κι ας λεει οτι θα κανει 15 μερες)!!!!! ωραίος ! Σε ευχαριστώ πολύ :D
Alexkass Δημ. February 19, 2004 Δημ. February 19, 2004 Updated VNC Viewer For The Pocket PC http://www.pocketpcthoughts.com/images/hansberry/2004/20040219-vncviewer.gif They have added the ability to send a right-click (tap and hold) to the server and specify a port number. I had trouble with the right-click functionality though, but I need to see how old my VNC server software is. It worked fine on the Windows 2000 desktop but in Excel, the menu would disappear as soon as I lifted the stylus. I also didn't see a menu option to refresh the display, something I find myself using quite a bit on the desktop client. In the few minutes I played with it though I didn't need to refresh on a relatively speedy 10mb connection. The price is free. Through this weekend only, you can get two for the price of one. There is no installer. It is just a simple .exe you can copy to your device. To uninstall, just delete the .exe and manually remove the section of the registry that remembers the server names you have put in. There are versions for all Pocket PC types and even the SHx/MIPS processors for some of the 2000 devices. link: http://www.cs.utah.edu/~midgley/wince/vnc.html Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. February 21, 2004 Δημ. February 21, 2004 Free Bluetooth Dialer for Pocket PC available http://msmobiles.com/archives/2004.2.20_191059/blue.jpg Bluetooth Dialer is a small program for Pocket PC to dial a phone number directly from the contact list. You no longer need to store phone numbers in your phone. Select the contact person name on your PDA and send it to the phone to dial. This application is very handy if you have a Bluetooth headset. In that case you don΄t need to take your phone from the pocket. link: http://www.handango.com/PlatformProductDetail.jsp?siteId=1&catalog=0§ionId=0&productType=2&platformId=2&productId=110906 Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Prof.Wizard Δημ. February 21, 2004 Δημ. February 21, 2004 Δεν ξέρω αν οι δικηγόροι της παρέας ενδιαφέρονται (καθότι στ'αγγλικά) αλλά: Lawyer Log http://www.handango.com/pictures/284273/lawyer.gif Για $6 ίσως αξίζει... μπορεί να δώσει και ιδέες για κάποιον να κάνει κάτι αντίστοιχο στα ελληνικά! :p
Alexkass Δημ. February 21, 2004 Δημ. February 21, 2004 Spb Finance 1.5 Released "Spb Software House is pleased to announce the release of Spb Finance 1.5. The new version introduces several new features, enhances many current functions, and contains important fixes for stability and speed. Spb Finance is a powerful stand-alone financial management application and with the new enhancements in version 1.5, it will become even more useful to current owners. Spb Finance 1.5 is a free upgrade for current Spb Finance users." Scheduled transactions with recurrence patterns Reminder notifications for scheduled transactions World currency list Export to QIF wizard λινκ: http://www.spbsoftwarehouse.com/products/finance Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Prof.Wizard Δημ. February 21, 2004 Δημ. February 21, 2004 TripLog http://www.handango.com/pictures/307223/triplog_detail.gif Για όποιον ταξιδεύει επαγγελματικά και χρειάζεται να δηλώνει καύσιμα στην εταιρία του... ;)
Alexkass Δημ. February 21, 2004 Δημ. February 21, 2004 SMARTFilter για Pocket PC Phone Edition http://www.pocketpcitalia.com/cms3/viewthumb.asp?id=976 λινκ: http://www.novomobile.com/smartfilter.php Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Exposed_Bone Δημ. February 21, 2004 Δημ. February 21, 2004 http://www.handango.com/pictures/671611/vmbtsmsscr1.jpg http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=57AE7357X3487F6C1EBDD18CC3XX841E&platformId=2&productType=2&catalog=0§ionId=0&productId=98711 InstantSMS Sender (PPC 2003) Compatibility Phone Model Send SMS Receive SMS Delivery Report Nokia 6310i S S S Nokia 8910i S S S Nokia 7650 O N N Nokia 6600 S N N Nokia N-Gage S N N Sony Ericsson T616 S S N Sony Ericsson T68i S S N S - Supported and tested. N - Not Supported by phone. O - Supported and not tested.
Alexkass Δημ. February 21, 2004 Δημ. February 21, 2004 είναι λογικά από την ίδια εταιρία με το Bluetooth Dialer :) μπράβο Πάνο!!! :) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Exposed_Bone Δημ. February 21, 2004 Δημ. February 21, 2004 αν υποστηρίζετε απο το 7600 θα το αγοράσω αλλά το θέμα ειναι πως θα μάθω αν υποστηρίζετε απο το 7600
Alexkass Δημ. February 21, 2004 Δημ. February 21, 2004 λογικά το υποστηρίζει. υποστηρίζει το 8910ί που στο ΒΤ είναι περίπου ίδια (άλλο αν του 7600 έχει περισσότερες επιλογές). κατέβασε το trail και δες ;) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
aristos87 Δημ. February 21, 2004 Δημ. February 21, 2004 Έχω ενα 6310i αλλα δεν κατέφερα να το δει αυτο το πρόγραμμα ούτε ο Bluetooth Dialer :( ΗΕLP!!! Χρήστης: Nokia 5140i,PSP 1004k EU Παλαιότερα: nokia 3510, Ipaq 1915, nokia 3200,Ipaq 1940, nokia 6600, Κ700i,6230i,K750i,W900i,Mitac Mio 168,K800i,N73 Music Edition,N95 8GB, HP 614c,Κ810i,JC777s,Nokia 5800,Nokia n97 mini
Alexkass Δημ. February 21, 2004 Δημ. February 21, 2004 αφού το 1940 το έχει ενσωματωμένο :) λογικά πρέπει να δουλεύει. το 7650, 6600 δούλευαν οκ και με το 4150 και λογικά με το 2020 που είναι το ίδιο πρόγραμμα ;) edit: στο 2020 ακόμα προσπαθώ... :wacko: Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
aristos87 Δημ. February 21, 2004 Δημ. February 21, 2004 Tin epelexa alla tipota den tin vlepei :( Χρήστης: Nokia 5140i,PSP 1004k EU Παλαιότερα: nokia 3510, Ipaq 1915, nokia 3200,Ipaq 1940, nokia 6600, Κ700i,6230i,K750i,W900i,Mitac Mio 168,K800i,N73 Music Edition,N95 8GB, HP 614c,Κ810i,JC777s,Nokia 5800,Nokia n97 mini
