mythos_bt Δημ. February 17, 2004 Δημ. February 17, 2004 MyVGA 1.0.2 (freeware) The Toshiba e800/e805 is the first Pocket PC that supports video-modes other than standard 240x320 portrait: 480x640 portrait and landscape. Unfortunately Toshiba allows running only three preinstalled programs in these resolutions. MyVGA fixes this problem and can switch the Toshiba between QVGA and VGA modes, portrait or landscape, and unlock the system allowing the execution of other programs. MyVGA also addresses the following well-known problem with hi-resolution. While standard fonts are too small for hi-res it is preferred to adjust them (system-wide with special tools or direct in each program, which has such options). But after switch in standard low-res mode all fonts will appear too big. MyVGA helps to fix the problem by storing settings of other programs for each video-mode independently and restoring appropriate settings while switching resolution. MyVGA can be used solely with Toshiba e800/e805 Pocket PCs. It is not compatible with any other devices. _http://myvga.ppccool.com/
Alexkass Δημ. February 17, 2004 Δημ. February 17, 2004 αρκετά καλό, όπως και του drizz (resfix 2.0). ;) το έβαλα και εδώ (το πρωί): http://www.myphone.gr/forum/showthread.php?threadid=4220 Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. February 17, 2004 Δημ. February 17, 2004 Calendar Plus Professional (New Major Release) by SBSH http://www.handango.com/include/pictures/347733/main.gif Calendar Plus Professional 3.0 is the most powerful enhancement for the Pocket PC Today screen. CP Professional wraps together three tools: Calendar Plus Today - The leading Today plug-in in the market, enabling you to view on the Today screen your upcoming agenda - up to 30 days!, your tasks, and your contacts' birthdays/anniversaries. Featuring appointments and tasks in a combined and intuitive display, full customization capabilities, language support for English/French - easily switch between the two languages, categories filter, 24 hour colored time-lines and many other features. Calendar Plus Search Solution - A powerful Pocket Outlook searching tool. Search your contacts, appointments and tasks databases in a great intuitive design. Enjoy sophisticated search capabilities by phone number, mobile phone, email address and much more. Categories Manager - "Attach" icons and colors to each of Pocket Outlook's categories to achieve better results with CP Today. λινκ: http://www.handango.com/brainstore/PlatformProductDetail.jsp?siteId=311&jid=9978B1F4EX3672132883666EBA639XC1&platformId=2&productType=2&catalog=0§ionId=0&productId=95186 μόλις το αγόρασα ;) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
mythos_bt Δημ. February 17, 2004 Δημ. February 17, 2004 Εχεις απολυτο δικιο αλλα δεν παρακολουθω το thread για το toshiba και ετσι δεν το ειδα. :(
Alexkass Δημ. February 17, 2004 Δημ. February 17, 2004 Αρχικό Μήνυμα από το μέλος mythos_bt (17 Φεβ. 2004 , 23:52) Εχεις απολυτο δικιο αλλα δεν παρακολουθω το thread για το toshiba και ετσι δεν το ειδα. :( μα σωστά έκαμες και το έβαλες εδώ. εφαμογή είναι :) απλά το έβαλα και στο ε800 γιατί είναι και σχετικό με το μηχάνιμα :) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
DrMaslow Δημ. February 17, 2004 Δημ. February 17, 2004 μόλις το αγόρασα κι εγώ!!! τέλειο!!!!!!!!!!!!!!!και πολύ γρήγορο! Exposed_Bone 8,5€ έχει!!!!!!!!! [sIGPIC][/sIGPIC]...μα πως να μην ξεχάσεις την αυλή σου και την παλιά τη γνώμη καθενός όσους κρυφά περπάτησαν μαζί σου να σημαδεύουν πάλι τη ζωή σου και να 'σαι το πουλί κι ο κυνηγός στις μαύρες λαγκαδιές του παραδείσου... Μάνος Ελευθερίου Ακούστε το
xristos69 Δημ. February 17, 2004 Δημ. February 17, 2004 ξέρετε αν υπάρχει για PPC κάποιο πρόγραμμα μουσικής πέρα απο players?ας πούμε επεξεργασία παρτιτούρας (score editing), ή οτιδήποτε άλλο?
Exposed_Bone Δημ. February 18, 2004 Δημ. February 18, 2004 kanena software gia na kano format tin sd?
Exposed_Bone Δημ. February 18, 2004 Δημ. February 18, 2004 @xristos69 koita sto handango ... exei auto pou zitas
psybill Δημ. February 18, 2004 Δημ. February 18, 2004 Αρχικό Μήνυμα από το μέλος Exposed_Bone (18 Φεβ. 2004 , 10:25) kanena software gia na kano format tin sd? σου εστειλα ενα demo να κανεις τη δουλεια σου!! ;) check your mail..
mythos_bt Δημ. February 18, 2004 Δημ. February 18, 2004 Αρχικό Μήνυμα από το μέλος Exposed_Bone (18 Φεβ. 2004 , 10:25) kanena software gia na kano format tin sd? Νομιζω οτι μπορεις να κανεις με το resco explorer.
Alexkass Δημ. February 18, 2004 Δημ. February 18, 2004 Αρχικό Μήνυμα από το μέλος mythos_bt (18 Φεβ. 2004 , 11:02) Νομιζω οτι μπορεις να κανεις με το resco explorer. όντως, ο resco explorer 2003 5.0 έχει format. Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Muck Smith Δημ. February 18, 2004 Δημ. February 18, 2004 Αρχικό Μήνυμα από το μέλος mythos_bt (18 Φεβ. 2004 , 11:02) Νομιζω οτι μπορεις να κανεις με το resco explorer. Προτιμείστε το format μέσω card reader από το PC. τα καλύτερα είναι... δίπλα σας πρώην συντονιστής συζητήσεων στα fora Windows Phone και Digital Gadgets[sIGPIC][/sIGPIC]
Exposed_Bone Δημ. February 18, 2004 Δημ. February 18, 2004 den exo card reader pou ine i epilogi sto resco gia format?
Alexkass Δημ. February 18, 2004 Δημ. February 18, 2004 παρατεταμένο κλικ πάνω στο storage card και πάτα φορματ. αρκεί να έχεις τον 5.0 http://www.langkawi.dk/p82.gif Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. February 18, 2004 Δημ. February 18, 2004 Αρχικό Μήνυμα από το μέλος xristos69 (18 Φεβ. 2004 , 01:20) ξέρετε αν υπάρχει για PPC κάποιο πρόγραμμα μουσικής πέρα απο players?ας πούμε επεξεργασία παρτιτούρας (score editing), ή οτιδήποτε άλλο? ακριβώς δες εδώ: http://www.handango.com http://www.pocketgear.com http://www.langkawi.dk/got-ya.gif Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Alexkass Δημ. February 18, 2004 Δημ. February 18, 2004 ThunderHawk per QTEK 2020 υποστηρίζει: και Pocket PC Phone Edition QTEK 2020 και Eten P-300 λινκ: http://www.bitstream.com/wireless/prerelease.html Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
Exposed_Bone Δημ. February 18, 2004 Δημ. February 18, 2004 http://www.handango.com/PlatformProductDetail.jsp?productType=2&optionId=1_2_2&jid=93FE1845X89DX4213ACF6ADFE92577AF&platformId=2&siteId=1&productId=85981&advSearch=true§ionId=0&keyWords=eXPerience&catalog=30&txtSearch=eXPerience eXPerience by Digital Expedition http://www.handango.com/pictures/404722/frontpage.jpg
Exposed_Bone Δημ. February 18, 2004 Δημ. February 18, 2004 Είχα δοκιμάσει την παλιά έκδοση δεν με ικανοποίησε .... και την έβγαλα μετά από 7 μέρες χρίσεις
Alexkass Δημ. February 18, 2004 Δημ. February 18, 2004 η 2.04 ακούγεται πιο γρήγορη και σταθερή. Must program απότι διαβάζω για τους χρήστες ε800 ;) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
xristos69 Δημ. February 18, 2004 Δημ. February 18, 2004 Γεια χαρα σε όλους,Επειδή σύντομα (ελπίζω) θα θα είμαι κάτοχος ενός Qtec 2020 και επειδη φροντίζω πρίν πεινάσω( για προγράμματα) :lol: μπορώ να προμηθευτώ ενα cd με διάφορα προγραμματα για ppc.Μιας που εγω είμαι άσχετος με τον χώρο των PPC και με το τι κυκλοφορεί θέλω την γνώμη σας αν αξίζει τον κόπο η απόκτησή του.Και εννοείται βέβαια οτι θα μοιραστώ οτιδήποτε απο αυτα με οποιονδήποτε :cool: . εχω την λίστα εδώ http://briefcase.pathfinder.gr/file/fotos_fotos/15420/218711
tranquillity Δημ. February 19, 2004 Δημ. February 19, 2004 mxmx ontos gia pite kanenas ama i ekodsi auti tu expirience aksizei? i am back at last ..... Μπορείτε να προσθέσετε μια εικόνα μέγιστων διαστάσεων 420 x 150 pixels και μέγιστου μεγέθους 16,3Kb
Alexkass Δημ. February 19, 2004 Δημ. February 19, 2004 Αρχικό Μήνυμα από το μέλος tranquillity (19 Φεβ. 2004 , 11:30) mxmx ontos gia pite kanenas ama i ekodsi auti tu expirience aksizei? αν και υποστηρίζει today add-ons θα έλεγα ότι προτείνεται μόνο για vga αναλύσεις, δλδ ε800 προς το παρόν. δοκίμασέ την δεν έχεις να χάσεις τίποτα :) Alex = the best! http://www.myphone.gr/gallery/data/500/9260sakalogo1.gifτο blog μου PIN: 20DDA1B0 (Storm)
andrikosBO Δημ. February 19, 2004 Δημ. February 19, 2004 καλημέρα.. ψάχνω για κάποια εφαρμογή που να μετακινεί την taskbar από το πάνω μέρος της οθόνης στο κάτω (ppc2002). Έχει να προτείνει καποιος κάτι ; Ευχαριστω
