Έφαρμογές: Ότι νεότερο κυκλοφορεί... {Όλα τα είδη Software}
Tomby
Αρχικό Μήνυμα από το μέλος Frontier (12 Ιαν. 2004 , 15:56)
τι Χημικός είμαι... :lol:
ΠΑΝΑΓΙΑ ΜΟΥ!!!! ΧΗΜΙΚΟΣ!!! μακριά!!! :p η Φυσική είναι το πάν :) (αυτά έλεγε ένας καθηγητής μου-φυσικός- στο σχολείο μου) και μάλωνε όλη την ώρα με τον χημικό μου :happy: :lol:
Alex = the best!
PIN: 20DDA1B0 (Storm)
  • Απαντήσεις 1,6χιλ.
McAfee System Protection
McAfee VirusScan PDA Enterprise 2.0
http://www.networkassociates.com/us/images/products/mcafee/mcafee_box.jpg
PDA Platforms
Windows Pocket PC 2002
Windows Mobile 2003
λινκ: http://www.networkassociates.com/us/products/mcafee/antivirus/remote_user/vs_pda.htm
Alex = the best!
http://www.handango.com/pictures/221980/shot1.gif PhoenixStudio is a combined software synth, sequencer and drum machine for the PocketPC, with effects like delay, distortion, and reverb
Believe us, once you try this out you'll be hooked! PhoenixStudio is a software synthesizer and sequencer, using the full potential of the PocketPC. The interface is fast, snappy, and dare I say pretty good-looking, and the sound... well, download the trial version and hear for yourself!
PhoenixStudio features three dual oscillator monosynths, and one drum machine with custom drum sample support. The integrated mixer also includes some effect units: distorsion, delay with feedback and reverb. The program outputs 44kHz 16-bit stereo sound, commonly known as "CD Quality". Headphones or external speakers are strongly recommended!
Please download the trial first to make sure your PocketPC is powerful enough. If the trial works properly, the full version should run just fine!
Check out our webpage, with more information about PhoenixStudio, at http://www.meloditronic.com!
Requirements
PocketPC (3.0, 2002, 2003), 1 MB available RAM, 12 or 16-bit color
Compatible Devices/Operating System
Casio E-125, Dell Axim X5
:wacko: :wacko: :eek: :confused: :worry:
SMS is better on your PDA
http://www.webtogo.de/Images/sms_3.jpg
Are you tired of composing SMS on a keypad and fed up with storage restrictions and tiny screens?
Are you longing to Copy & Paste from other applications and to dial or send from your PDA Contacts?
Or are you looking to finally put you bluetooth headset to good use?
If so, WebToGo SMS/Phone is your answer. It will let you:
Dial or send directly from your PDA Contacts/Address Book
Turn your handheld into a fully functional mobile phone (Pocket PC only).
Send Messages of unlimited length to multiple recipients
Copy & Paste from e-mails, memos and all other applications
Take advantage of your handheld's bigger screen and superior data input.
Store all the messages you'll ever want to keep
λινκ: http://www.webtogo.de/uk/page.asp?p=361
Alex = the best!
Αρχικό Μήνυμα από το μέλος oxin_rain (18 Ιαν. 2004 , 22:38)
SMS is better on your PDA ::::::
apo ellinika ti leei? tha ta deixnei kala i oxi?
...δεν έχει βγεί το crack ακόμα.. (νομίζω).. και η trial έκδοση σε αφήνει να στλείλεις / λάβεις μόνο 2 κλήσεις και SMS..
..ελληνικά στο SMS δεν διάβασε... (δεν ξέρω αν πέρνει επιπλέον ρυθμίσεις για να μπορεί.. )
γιατί παιδεύεστε?
το easySMS δε σας κάνει?
γράφει ελληνικά κανινικότατα, υποστηρίζει μεγάλα μηνύματα, διαβάζει από τη μνήμη του τηλεφώνου, ζητάει αναφορά παράδοσης, και είναι πολύ εύχρηστο και FREE!.
Τρέχει σε όλα ppc+hpc+palm, ψιλοϋποστηρίζει και bluetooth.
Το είχει φτιάξει αρχικά ο Frank Siedler και συνέλαβε καθοριστικά ο δικός μας Frontier για την ελληνική υποστήριξη. (και κάποιοι ακόμα για ατελείωτα beta testing :D )
http://www.siedler-net.de/WinCE/easySMS/
τα καλύτερα είναι... δίπλα σας
πρώην συντονιστής συζητήσεων στα fora Windows Phone και Digital Gadgets[sIGPIC][/sIGPIC]
den ine simbato me to 6600 epidi ta ine xilioklidomeno!!alal elpizoume gia to mellon ke stina rxi dne borouse sto 3650 alla meta egine!
i am back at last .....
Μπορείτε να προσθέσετε μια εικόνα μέγιστων διαστάσεων 420 x 150 pixels και μέγιστου μεγέθους 16,3Kb
Το πρόγραμμα είχε φτιαχτεί να δουλεύει μέσω υπέρυθρων.
Το bluetooth προέκυψε αρκετά αργότερα :)
(κι απ'ότι ξέρω ο Frank εδώ κι αρκετό καιρό δεν έχει τον απαιτούμενο χρόνο για να το εξελίξει περισσότερο)
ego me to t610 mou douleuei kanonika to eastSMS me bluetooth.
exo vali stin thira tin BT1.
Δοκίμασα το Easy SMS με το Χ70 και... δεν... ούτε με υπέρυθρες ούτε με Bluetooth... :(
[imgalign]http://icons.iconarchive.com/icons/iconshock/social-media/96/twitter-icon.png[/imgalign]"Some hearts are different than others. Like crystal in a world of glass... Even the way they shatter is beautiful..."
Wannabe Editor? Reviewer? Columnist?
Join the Unwired Revolution, now!
Αρχικό Μήνυμα από το μέλος Mythozz (20 Ιαν. 2004 , 21:18)
Ψέμματα... η τελευταία έκδοση δούλεψε τελικά με υπέρυθρες... :) :D
Easy SMS στο H5555 > BT > S55 δουλεύει άψογα ..(και με ελληνικά βέβαια...) (η com-port που ζητάει στα settings.. στο ΒΤ1..)
Αρχικό Μήνυμα από το μέλος Mythozz (20 Ιαν. 2004 , 21:26)
Emm ξέρω επαναλαμβάνομαι, αλλά μόλις τώρα δούλεψε και με Bluetooth... :D
Αψογα! ;)
Newest PocketMVP Build Supports Full Screen Video
"PocketMVP has reach a milestone among all PocketPC's. With this new v0.8.011804 release PocketMVP now supports normally encoded FULL SCREEN VIDEOS!! We have tested 800kbit DivX / 24fps at 640X252 with 64bit audio and NO drops! Is there a catch... lol... there always is. Currently this is only supported with the new ATI 3200 interface on the G1000 or the E80x. But think about it.... no more re-encoding is needed! There are tons of other fixes that you can read in the changelog."
λινκ: http://www.corecodec.com/modules.php?op=modload&name=News&file=article&sid=71&mode=thread&order=0&thold=0
Alex = the best!
