[Επίσημο] Nokia N76
nervous
καλημερα! το sar της συσκευης ειναι: 1.04w/kg!!!!
Nokia N76 (Type RM-135)
CERTIFICATION INFORMATION (SAR)
THIS MOBILE DEVICE MEETS GUIDELINES FOR EXPOSURE TO RADIO WAVES.
Your mobile device is a radio transmitter and receiver. It is designed not to exceed the limits for exposure to radio waves recommended by international guidelines. These guidelines were developed by the independent scientific organization ICNIRP and include safety margins designed to assure the protection of all persons, regardless of age and health.
The exposure guidelines for mobile devices employ a unit of measurement known as the Specific Absorption Rate or SAR. The SAR limit stated in the ICNIRP guidelines is 2.0 watts/kilogram (W/kg) averaged over ten grams of tissue. Tests for SAR are conducted using standard operating positions with the device transmitting at its highest certified power level in all tested frequency bands. The actual SAR level of an operating device can be below the maximum value because the device is designed to use only the power required to reach the network. That amount changes depending on a number of factors such as how close you are to a network base station. The highest SAR value under the ICNIRP guidelines for use of the device at the ear is 1.04 W/kg.
Use of device accessories and enhancements may result in different SAR values. SAR values may vary depending on national reporting and testing requirements and the network band. Additional SAR information may be provided under product information at http://www.nokia.com.
  • Απαντήσεις 817
:eek: Έλεος, έχω την εντύπωση ότι έχει βάλει στόχο η Nokia να πιάσει το όριο 2W/kg!! :lol: :lol:
ΚΑΛΟ :p :lol: :p η εκδικηση της ΝΟΚΙΑ .Εφιαλτης στο κινητο σας:p περα απο την πλακα ομως ειναι ενα πολυ σοβαρο θεμα και δυστυχως δεν τιμαει την νοκια κριμα
Η Δημοκρατία μας αυτοκαταστρέφεται διότι κατεχράσθη το δικαίωμα της ελευθερίας και της ισότητας, διότι έμαθε τους πολίτες να θεωρούν την αυθάδεια ως δικαίωμα, την παρανομία ως ελευθερία, την αναίδεια του λόγου ως ισότητα και την αναρχία ως ευδαιμονία
Ακριβώς...κρίμα...Ήδη έχασε έναν σίγουρο αγοραστή για τη συγκεκριμένη, πολλά υποσχόμενη, συσκευή...
καλησπερα αν εχετε προσεξει αλα απο την σειρα ν7...(ν70,ν73....) εχουν απκετα μεγαλο sar!!! μηπως το κανει για να εχουν η πελατες το σιγκεκρινων κινητων πολυ καλο σημα.....
Το τόσο πολύ καλό σήμα δεν αρκεί για να με κάνει να δεκτώ την υψηλή αυτή εκπεμπόμενη ακτινοβολία.
Βέβαια με ένα ακουστικό bluetooth το πρόβλημα αντιμετωπίζεται,ωστόσο δε χρησιμοποιώ ποτέ.
τα πιο ασφαλη ειναι τα ενσύρματα hands free, ποιος μου λεει οτι και η συχνοτητα του bluetooth δεν ειναι επικίνδυνη για τον άνθρωπο;
The "unwired" revolution began...
_http://www.myphone.gr/forum/image.php?type=sigpic&userid=6201&dateline=1272991407
Να φανταστω οτι σπιτι σου δεν εχει κοντα στο κρεβατι σου ηλεκτρικη πριζα,
οτι δεν περνας ποτε κοντα απο κολονες της ΔΕΗ,
οτι οταν κλειδωνεις το αμαξι σου πατας το κουμπι με ξυλινη λαβιδα,
και οταν βγαινεις βολτα αποφευγεις με μαεστρια ολη αυτη τη θαλασσα συχνοτητων που ειναι γεματη πλεον η ατμοσφαιρα
και σε πειραξε το Bluetooth ακουστικο?
Παρε ενα Bluetooth με κλιπσακι και καλωδιο.
Συγνωμη για το υφος μου.
Εγω παλι γιατι νομιζω οτι τα επιπεδά του ειναι αρκετα καλα σε γενικα πλαισια?
1.04 σημαινει οτι σε αρκετα xtreme συνθηκες και με ενεργοποιημενο το 3G ισως και να πιασει τετοια επιπεδα.
αρα χωρις 3G μου ακουγεται πολυ καλα! εξαλου δεν καθομαι ολη μερα σε κανενα απομονομενο υπογειο να μιλαω.
εξαλου ενα ωραιο bluetooth δινει τη καλυτερη λυση. σου λυνει και τα χέρια στην οδηγηση και ειναι και μουρατο. (καπου διαβασα οτι σκεφτονται να αλλαξουν και τον νομο και τα bluetooth πιθανοτατα να ειναι πλεον και νομιμα κατα την οδηγηση)
Και ελεος, το μπλε δοντι δεν εχει καμμια μα καμμια σχεση με τις συχνοτητες της κινητης και δεν ειναι βλαβερο.
παντως το κινητακι ειναι φοβερο και το περιμενω να το τσιμπισω.:cool:
Σωστός .
Είναι χαζό να απορρίπτουμε μια συσκευή με την δικαιολογία της ακτινοβολίας .
Όταν βομβαρδιζόμαστε καθημερινά από παντού με τα προαναφερόμενα και άλλα τόσα
προσωπικα ουτε κι εγω το απορριπτω,σιγουρα παντως θα αποτρεψει πολλους αλλους που θα δωσουν σημασια στο sar παρα σε οτι αλλο μας ενοχλει γυρω μας.
Το ανώτατο επιτρεπτό όριο εκπομπής ακτινοβολίας για τα κινητά τηλέφωνα στην Ε.Ε. είναι στα 2.0w/kg, στην Αμερική και στις περισσότερες χώρες της Ασίας στα 1.6w/kg, στην χώρα μας κυμαίνεται στα 1.6w/kg ως ένα επιπλέον όριο ασφάλειας από την ευρωπαϊκή νόρμα.
Το N76 λοιπόν κινείται μεν εντός των διεθνών πλαισίων εκπομπής ακτινοβολίας αλλά σε σχέση με άλλες συσκευές (πχ. την δικία μου N71 = 0.41w/kg) οι εκπομπές του για την σύγχρονη πραγματικότητα κρίνονται υψηλές.
ΤΕΣΠΑ, ο καθένας αποφασίζει και αγοράζει ανάλογα.
Old programmers never die. They just terminate and stay resident.
Παιδια εχω τρελαθει με το κινητακι! Τα σπαει στην κυριολεξια..... Εχει ....σχεδιασμο παρα πολυ καλα χαρακτηριστικα και δεν ειναι δυνατον να το αφησω... Εχει μεγαλο Sar αλλα δεν με νοιαζει και τρελα.. Τοσα υπαρχουν γυρω μου αυτο θα με νοιαξει τοσο? Κι οσο για το οτι ειναι 2 μεγκα δεν με αγχωνει γιατι εχει και 16 εκατομυρια χρωματα... Αυτο βοηθαει παρα πολυ..
:D
Άρης
Follow me
mi perdeveis tin camera me tin othoni tou kinitou! To pio pithano pou mporei na simbei einai na blepei iperoxes tis foto sto kinito alla otan tis metafereis sto pc na einai entelos diaforetikes:(
elpizw mono na argisei na vgei... molis pira to 7390 vgalane kinito tis seiras n tou goustou moy... adiko...
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
den mporoume na allazoume kinito kathe mina...
:O
:O
Toulaxiston to diko sou exei to mikrotero SAR apo ola.
Kai mia fili mou ithele na to parei alla tora tha perimenei gia to N76
Aπο οτι ειδα το βγαλαν και στο site της νοκια το ελληνικο με διαθεση 1ο τριμηνο του ετους.. Πιστευω τελη φεβρουαριου αρχες Μαρτιου να το εχουμε...Πιστευω θα λασναριστει ταυτοχρονα με το Ν95..
Τι λετε?
Τι λετε?
Με διαφορα καμποσες μερουλες θα τα δουμε και τα 2 στην αγορα!!!;) :)
Η αγάπη αποτελείται απο μια μοναδική ψυχή που κατοικεί σε δύο σώματα! (Αριστοτέλης)
Proud Owner of a Xbox360 fully updated!!! (http://www.enternity.gr)
Next Generation Consoles WAR:http:// http://www.vgchartz.com/
