Συζητήσεις / Προβλήματα / Απορίες για κινέζικα κινητά
Γεια σας παιδια, καλως σας βρηκα, ειμαι στραβογιαννο στο forum, 1st δημοσιευση αν ... χε :) χε κανω & κανα λαθακι ... με το μαλακο ...
Λοιπον πηρε το ματι μου - στα χερια ενος αγνωστου διπλανου σε καφετερια αυτον τον ... κλωνο του S4 (κατα τον ιδιοκτητη του) & σε ... αστεια τιμη 164$=122€ ...
http://www.buysku.com/wholesale/feiyang-7100-android-4-2-mtk6589-quad-core-5-5-inch-qhd-screen-1gb-4gb-gps-dual-camera-3g-smartphone-white.html
http://www.etbuying.com/goods-654-53inch-White-Feiyang-7100-Quad-Core-Phone.html#.UhiSZ43RqAV
Αν δεν κανω λαθος, δεν ειδα πουθενα αλλο αντιστοιχο νημα για Feiyang , ειναι τοοοσοοο ανυποληπτη κινεζια ... ? ? ?
Name: Feiyang 7100+ Android 4.2 MTK6589 Quad-core 5.5-inch QHD Screen 1GB/4GB GPS
Dual-camera 3G Smartphone (White)
Serial number: 1391932
Respective classification: Dual Sim Card Cell Phones,WiFi Cell Phones,3G Cell Phones ,Touch Screen Cell Phones,Android Cell Phones,GPS Cell Phones
Unit Type: 1 Set (1 items per Set)
Color: White
Net weight: 200g ( 0.44lb. )
Gross weight: 460g ( 1.01lb. )
Product size: 14.60cm x 7.60cm x 1.00cm (5.75in x 2.99in x 0.39in)
Packing size: 16.00cm x 9.00cm x 5.00cm (6.30in x 3.55in x 1.97in)
Description
The Feiyang 7100+ is a wonderful quad-core 3G smartphone with high performance, stylish design and attractive price. It adopts the advanced Android 4.2 OS, and is powered by MTK6589 Cortex-A7 quad-core 1.2GHz CPU, PowerVR SGX544 MP2 GPU and 1GB RAM to ensure its running more stably. It supports dual SIM card dual standby, and is fully compatible with worldwide quad-band GSM and WCDMA 3G networks for making phone calls. 5.5-inch 960*540 QHD capacitive 5-point touch screen will make your operation more conveniently.
It supports WiFi and WCDMA 3G networks for surfing internet, and also supports wireless Bluetooth for data transmission and hands-free calling. With a built-in GPS chip for effortless navigation, you will not get lost when going out. Besides, it has a 0.3MP front camera for self capturing and enjoying online video chat, and a 5.0MP back camera for shooting interesting things and moments.
Basic Parameters
Product Category 3G smart phone
Brand Feiyang
Model 7100+
Color White
Shell Material Plastic
Mobile Phone Style Bar style
Operating System Android 4.2
CPU MTK6589 Cortex-A7 quad-core 1.2GHz
GPU PowerVR SGX544 MP2
RAM 1GB
ROM 4GB
Expansion Memory Support micro SD/TF card up to 32GB
Keyboard Type Virtual keyboard
Input Mode Handwritten and keyboard input
SIM Card Dual SIM card dual standby
Screen
Screen Size 5.5-inch
Screen Type TFT, capacitive 5-point touch screen
Resolution 960*540 (QHD) pixels
Screen Color 16000K colors
G-sensor Support
Light Sensor Support
Proximity Sensor Support
Network
Network System WCDMA/GSM
Frequency Band 2G GSM: 850/900/1800/1900MHz
3G WCDMA: 850/2100MHz
Network Connection 3G, WiFi, GPRS, WAP
Data Transfer
GPS Navigation Support built-in GPS navigation, and also support A-GPS
Wi-Fi Support, IEEE802.11b/g/n
Bluetooth Support Bluetooth 2.0
USB Support USB 2.0 high speed data transmission
Main Applications
Camera Dual camera, 0.3 million pixels front camera, and 5.0 million pixels back camera with LED flashlight and auto focus
Audio Format Support MP3/WAV/AMR/AWB
Video Format Support 3GP/MPEG4
Image Format Support JPEG/BMP/GIF/PNG
E-Book Format Support TXT/CHM/DOC/HTML
Ringtones Type Support Polyphonic/MP3
Sound Recorder Support, built-in microphone for long time audio recording
Java No
FM Radio Support, a 3.5mm earphones is needed
TV No
Game Support
SNS Service Support, such as Facebook, Twitter, etc
Other Applications Android market, Browser, Clock, Calendar, Calculator, Gallery, Latitude, File Manager, Flash Player, Maps, Email, Gmail, Google Talk, etc
Others
Phonebook 500
Message Support SMS/MMS
Speaker Support, built-in speaker
Microphone Support, built-in microphone
Battery Type 3.7V 2100mAh rechargeable Li-ion battery
Talk Time Up to 4 hours
Standby Time Up to 200 hours
OSD Language English, German, French, Italian, Spanish, Portuguese, Czech, Dutch, Polish, Roman, Greek, Hebrew, Indonesian, Malay, Vietnamese, Turkish, Russian, Arabic, Thai, Korean, Simplified Chinese, Traditional Chinese, etc
:worry: Το ξερετε ? Ηρθε η ωρα να το ξεσκονισουμε ? :!:
ThL W7S, ThL W100S, Elephone P10C, Jiayu S3 advance
  • Απαντήσεις 8,4χιλ.
ο Qualcomm Snapdragon 8225Q υποστηρίζει κανονικά 720p εγγραφή και αναπαραγωγή.
http://www.qualcomm.com/sites/default/files/pods/tout/200-diagram_1.jpg
Εχεις περασει καποια απο αυτες τις εφαρμογες και ειχες οντως HDvideo? H καμερα του ειναι οντως 8αρα,και σε σχεση με αλλες 8αρες πχ sansung, xperia κλπ πως ειναι?
Έχω βάλει την snap camera και έχει όντως 720p όμως χρησιμοποιώ τη χαμηλότερη ανάλυση. Και στις φωτογραφίες το ίδιο. Πάνω απο 3.2MP δεν έχει διαφορά για εκτυπώσεις 10Χ15. Πάντως τα 8ΜΡ φαίνονται πραγματικά. Στις 12άρες κάνουν απάτες οι κινέζοι.
Απο ποιότητα, μέτρια. Το επόμενο κινητό θα έχει BSI
Edited by Gousgounis
Λέγεται interpolation νομίζω και ανεβάζει την ανάλυση με αλγόριθμο γίνεται συνήθως στους Mediatek επεξεργαστές. Από ποιότητα εγγραφής βίντεο 720p πώς τα πάει; Από ότι είδα στα specs έχει GPU adreno 203 δεν είναι κάπως παλιά, πως τα πάει σε απαιτητικά games?
Ευχαριστω για τις απαντησεις , καποιες ερωτησεις ακομη, αφου εχει οντως HD γιατι χρησιμοποιεις την χαμηλοτερη?ποιο ειναι το μειονεκτημα αν τραβας σε hd η 8mp?και ποιο κινητο θα εχει bsi φακο το επομενο που θα βγαλει η faea η το επομενο που θα παρεις? νομιζω οτι το f2 εχει F2.0 BSI πισω φακο.
Το επόμενο που θα πάρω, όχι όμως τώρα κοντά... Έχει μεγάλη διαφορά ο BSI σε συνθήκες χαμηλού φωτισμού.
Τραβάω σε χαμηλότερη ανάλυση γιατί δεν έχει νόημα να θυσιάζω τζάμπα χώρο. Ούτε DVD θα κάνω τα βιντεάκια μου, ούτε τις φωτογραφίες θα εκτυπώσω σε γιγαντοαφίσα.
Δεν lagάρει (πάνω απο 15fps), όμως δε το τέσταρα ιδιαίτερα.
Η GPU που φοράει είναι overclocked στα 350mhz όμως πάλι δεν είναι για πολλά πολλά. Σηκώνει απαιτητικά παιχνίδια όπως το real racing 3 όμως όχι άνετα και επίσης ζεσταίνεται αρκετά.
Απο rom τι παιζει; Βγαζουν πιο καινουργιες official?
Βγαίνουν κατα καιρούς από την εταιρία, αλλα έχει και 2~3 custom (μέχρι και MIUI). Η τελευταία επίσημη βγήκε σχετικά πρόσφατα στις 6/8. Δεν την έχω περάσει ακόμη.
Το λεπτότερο κινητό στον κοσμο! 5.75mm
Η πρωτιά του Huawei Ascend P6 ως το λεπτότερο smartphone στον κόσμο κράτησε λίγο, καθώς η BBK ανακοίνωσε επίσημα το Vivo X3, το οποίο παίρνει (για την ώρα) τον τίτλο με πάχος 5.75mm αντί 6.18mm του smartphone της Huawei.
vivo_x3
Πέραν της λεπτής κατασκευής, το Vivo X3 προσφέρει αρκετά αξιόλογα τεχνικά χαρακτηριστικά και ενδιαφέρουσες λειτουργίες, όπως σύστημα αναγνώρισης χειρονομιών για διαχείριση ορισμένων εφαρμογών και ξεκλείδωμα της οθόνης, αλλά και το DAC chip ES9018 (μετατροπή digital to analog) για άριστη ποιότητα ήχου μαζί με ενσωματωμένο λογισμικό Xtudio για τη δημιουργία μουσικής.
Vivo X3
Οθόνη 5” IPS HD (1280 x 720)
Επεξεργαστής quad-core MediaTek MT6589T 1.5GHz
Μνήμη RAM 1GB
Αποθηκευτικός χώρος 16GB
Κάμερα 8MP F2.2 με flash
Εμπρόσθια κάμερα 5MP
WiFi, Bluetooth, dualSIM
Λειτουργικό σύστημα Android 4.2.2 Jelly Bean
Μπαταρία 2000mAh
Διαστάσεις 143.27 x 71.03 x 5.75mm
Βάρος 150gr
Στόχος της BBK είναι να λανσάρει άμεσα παγκοσμίως τη συσκευή, αλλά για την ώρα έχει δώσει ημερομηνία κυκλοφορίας και τιμή μόνο για την Κίνα (1η Σεπτεμβρίου, περίπου €300)
http://img.talkandroid.com/uploads/2013/07/The-worlds-new-thinnest-phone-BBK-Vivo-X3side.jpg
http://www.android-news-blog.de/wp-content/uploads/2013/08/vivo-x3-6.jpg
http://www.3dnews.ru/assets/external/illustrations/2013/08/15/661018/Worlds-new-thinnest-phone-Vivo-X3-poses-for-a-weird-photoshoot-acts-like-a-knife(14).jpg
http://www.android-news-blog.de/wp-content/uploads/2013/08/vivo-x3-5.jpg
http://www.ixbt.com/short/images/2013/Aug/3437635_sxt_thumb.jpg
http://img1.gtimg.com/digi/pics/hv1/234/101/1399/90995964.jpg
http://www.9duw.com/article/UploadPic/2013-8/20138239455423913.jpg
http://bbk.com/vivo/x3/function.php
Edited by lewnidask
Galaxy S10
δηλαδη αν εχεις νευρα και πιασεις αυτη τη συσκευη θα σου μεινει στο χερι , σωστα?:lol:
Νίκος
Κάτοχος Samsung Galaxy S10+ (Android 10 Official).
- 001 με την όπισθεν
Πολυ καλο για να..ανοιγεις πορτες, αντι να χρησιμοποιεις ταυτοτητα..:lol:
Δεν ξερω ομως αν κατσεις και το εχεις στην κωλοτσεπη, τι θα γινει..
ΓΙΩΡΓΟΣ:clap:
προσωπικά θα πήγαινα σε κάτι πιο "επώνυμο" πχ. THL W8 beyond ή κάποιο παρόμοιο που κυμαίνεται στα ίδια λεφτά.
Με άλλη μάρκα θα έχεις και περισσότερες επιλογές σε modding αφού περισσότεροι οι κάτοχοι.
δεν θα διαφωνήσω καθόλου. Προσωπικά το μόνο που θα με κρατούσε είναι αυτό που είπα και πριν... δεν υπάρχουν αρκετοί κάτοχοι για διασταύρωση εμπειριών και troubleshooting σε περίπτωση που κάτι στραβώσει.
Ειδικότερα για το κινητό... φαίνεται πολύ δυνατό για τα λεφτά του.
το κινητο το κατασκευαζει η εταιρεια που κατασκευασε και το σταρ s5 butterfly,αν κρινω απο την ποιοτητα του τοτε και αυτο θα ειναι πολυ αξιολογο τηλεφωνο.
Αν αυτό είναι το Star S5 τότε μιλάμε για 100% ίδιο κινητό υποθέτω;
http://www.aliexpress.com/store/product/Star-S5-Butterfly-MTK6589T-Quad-Core-1-5GB-RAM-8GB-ROM-Android-4-2-Smart-Phone/907801_1073463963.html
Βγαίνει και φθηνότερο από το Pulid (με China Post βέβαια...)
ναι το ιδιο ειναι με αλλο ονομα.
Η Acer παρουσιάζει ένα ακόμα μοντέλο στη σειρά Liquid των Android smartphones, το Liquid Z3, το οποίο θα κυκλοφορήσει με πρακτικό μέγεθος οθόνης σε επιλεγμένες αγορές της Ευρώπης με διπύρηνο επεξεργαστή και δύο κάρτες SIM.
Το τηλέφωνο θα υποστηρίζει Quick Mode Profiles και πρόκειται για το πέμπτο κατά σειρά smartphone που λανσάρει η εταιρεία. Τα Quick Mode Profiles (Basic, Senior, Classic και Keypad) ρυθμίζουν αυτόματα τα επιμέρους στοιχεία προκειμένου να μπορούν να το χειριστούν διαφορετικές ηλιακές ομάδες. Παράλληλα, υπάρχει υποστήριξη στο Acer Cloud για εύκολο διαμοιρασμό αρχείων.
Acer Liquid Z3
Λειτουργικό σύστημα: Android 4.2 Jelly Bean
Επεξεργαστής: 1 GHz διπύρηνος
Μνήμη RAM: 512 MB
3G/ HSPA
Οθόνη: 3.5 ίντσες
Κάμερα: 3 Megapixel
Δεύτερη κάμερα: Όχι
Ενσωματωμένη μνήμη: 4GB
Κάρτα μνήμης: micro SD (έως και 32GB)
Dual SIM Wi-Fi n, a-GPS, Bluetooth 3.0, micro USB, FM Radio
Μπαταρία: 1500 mAh
Διαστάσεις: 109x60x10.4 χλστ.
Βάρος: 120 γρ.
Έτοιμο για προ-παραγγελία στα 87,99€ (υπολογίστε +~13€ για τα μεταφορικά)
(μαύρο - λευκό)
Gsmarena
Φαίνεται ένα τίμιο και φτηνό dual sim κινητό , το μόνο μείον που του βρίσκω είναι η μικρή ram
Edited by terry39
Παιδιά πως φαίνεται το κινητό γενικά; Από αυτονομία, games και φοτό πως τα πάει; Ποια η διαφορά από το star s5; Είμαι ανάμεσα σε αυτό και το jiayu g3s για αυτό ρωτώ.
Και το δικαρτο στα 299
http://www.expansys.com.gr/acer-liquid-s1-black-250480/?partner=frnews&utm_medium=email&utm_source=frnews&utm_content=2013-08-26-HEB&utm_campaign=2013-08-26-HEB
Κρίμα να μην μπορούμε να το δούμε από κοντά
οτι ποναει δεν σημαινει πως αξιζει κιολας.....
