Sony Ericsson K700i
gbil
R2AE033
- Released on EMMA II (6/12/04)
- Faster overal speed
- Search function disabled in Asian firmware (Far east only?).
- Search function in phonebook upgraded for non-Asian firmware (C doesn't delete Contact, but letters you've entered, cursor cancels search)
- 900 ms+ delay on answering a call before the microphone was switched on has been fixed.
- Display Smileys in MMS/Browser
- Support of Apple ITunes format .m4a (=.mp4) including speech encoding format AAC
- Stopwatch no longer goes into backlight off mode or sleep mode
- Noise in HCA-20 car handsfree is gone
- The signal strength indicator has changed. Now signal is lowered by 1 bar at a time. Signal is raised to 5 bars if a strong signal is detected.
- Various crashes fixed (e.g. when music is playing an an alarm goes off)
- Various Java / Java 3D fixes
- Various browser / WAP / CSS fixes
- Various fixes to the Calendar application
- Various layout / font size fixes
- Updated Camera driver to change the default flicker compensation mode from 50 Hz to automatic.
- JBenchmark1: 2129
- JBenchmark2: 125
- Software versions:
LCD 200406041
Camera 3.10
ITP CXC 125 813 R1S
R2AT003
- Released by DaVinci on 13/5/05
- Less noise in photos taken with low lighting conditions
- Significant increase in Bluetooth speed when copying data to the phone (from around 23.1Kbps in previous firmware revisions to 49.8Kbps)
- JBenchmark1: 2392
- JBenchmark2: 127
LCD: 200406041
Camera: 3.10
ITP: CXC 125 813 R2C
R2AY004
- Released by DaVinci on 24/5/05
- Currently no reported changes from R2AT
- JBenchmark 1: 2419
- JBenchmark 2: 127
LCD: 200406041
Camera: 3.10
ITP: CXC 125 813 R1T
H kamera veltiwnetai poly sto skotadi!Ksexaste ton enoxlhtiko thorivo (xrwmatista skoupidakia) otan einai nyxta h exei aneparkes fws.Pleon vgazeis olokathares fwtografies me to fako se APOLYTO SKOTADI.As vgaloun k aftoi pou protimousan to S65 ypo tetoies sinthikes pou perifanevondan (stoys diaksifismous) thn ksekatharh anwterothta toy telefteou se skoteines sinthikes sto thema camera. :)
  • Απαντήσεις 7,6χιλ.
Είναι πιο απλό, στις ρυθμίσεις στα μηνύματα απενεργοποίησε τους εθνικούς χαρακτήρες, θα γράφεις μόνο με κεφαλαία αλλά θα αυξηθούν οι χαρακτήρες που χωράνε σε ενα sms :)
Και στην φωτογραφική και στο βίντεο με το βελάκι προς τα πάνω αλλά στις χαμηλότερες αναλύσεις μπορείς να επιλέξεις Χ4 ΖΟΟΜ και στην προηγούμενη Χ2 στις άλλες δεν έχει καθόλου ΖΟΟΜ.
Ευχαριστώ πολύ!!!!!!
Άλλη μία απορία: ο ήχος της κάμερας απενεργοποιήτε;;; Και στο αθόρυβο τον κάνει...
Q σου λεβέντη μου!!!
Εμένα στο αθόρυβο δεν τον κάνει! Ζήλεια! :lol:
Μάλλον έχεις firmware Vodafone Live οπότε δεν κλείνει ο ήχος με τίποτα.
http://www.zacharia.gr/lefteris/files/sigmyphone.gif
R2AE033
- JBenchmark1: 2129
- JBenchmark2: 125
LCD 200406041
Camera 3.10
ITP CXC 125 813 R1S
R2AT003
- JBenchmark1: 2392
- JBenchmark2: 127
LCD: 200406041
Camera: 3.10
R2AY004
- JBenchmark 2: 127
LCD: 200406041
Camera: 3.10
Σε ποιο σαιτ υπάρχουν αυτές οι εκδόσεις λογισμικού????
Don vito ευχαριστω για την απαντηση αν και τα ειχα ηδη βρει σε καποιο αλλο σαιτ.
Πολυ ενδιαφερον ειναι η βελτιωση της καμερας και της ταχυτητας του bluetooth!
Αραγε τα σαινια εδω στην Ελλαδα θα εχουν τη καινουρια εκδοση?
Εδω και λιγο καιρο καθε φορα που παω να φορτισω το K700 (το φορτιζω κλειστο) ανοιγει και κλεινει επειδη δεν κανει καλη επαφη το φυς του φορτιστη με το μπριζακι φορτισης του κινητου. Το καπακι προστασιας σπρωχνει το φυς προς τα κατω με αποτελεσμα να μη κανει επαφη και ετσι αναγκαζομαι να βαλω κατω απο το φυς ενα τσιγαρο ή ενα στυλο για να κανει επαφη. Φοβαμαι να μη καψω το κινητο απο το ανοιξε κλεισε λογω της μη καλης επιαφης. Τι μπορω να κανω για λυσω αυτο το προβλημα; Να παρω καινουργιο φορτιστη;
Ευχαριστω
το έχω ακόμη και εγώ το ίδιο πρόβλημα αλλά επειδή το τράβαγα απότομα το φυς να βγει και χάλασα την υποδοχή και έχω κάνει προβλημα....(καλός μ@λ@κ@ς είμαι και εγώ... :X )ό μ ω ς δεν καίγεται το κινητό αν βάζεις βγάζεις το κινητό στο φορτιστή..αλλά μ η το κάνεις και συνέχεια για να δεις τα όριά του! ;) ...εγώ έκοψα το πλαστικό...και δεν έχει εξόγκωμα και βάζω και βγάζω εύκολα το φορτιστή...εγώ μια ιδέα έδωσα...τα συμπεράσματα και το τι θα κάνεις είναι δικό σου θέμα...!
AlbumArt_%7B31303397-6.
Ποτέ μην κάνεις το ίδιο λάθος,
θυμήσου ότι υπάρχουν τόσα άλλα!
Παιδιά Καλησπέρα. Αγόρασα σήμερα ένα K700i και έχω την εξής απορία. Δεν υπάρχει πουθενά κανένα lend που να αναβοσβήνει ώστε να βλέπεις την κατάσταση του τηλεφώνου δηλ. αν είναι ανοικτό; Μήπως το τηλέφωνο έχει κάποιο πρόβλημα; Αν θα αναβοέσβηνε κάτω από ποιες συνθήκες θα μπορούσα να το δω;
Στο κουμπι που ανοιγεις την συσκευη, εχει led που αναβει ομως οταν πεσει η μπαταρια (κοκκινο). Δεν ειναι σαν τα παλια που αναβοσβηνε συνεχεια.
Ευχαριστώ φίλε μου. Βλέπεις το είχα συνηθίσει στα προηγούμενα τηλέφωνα που είχα (τ610 - τ630 - p900) και δύσκολα θα το ξεσυνηθίσω σ'αυτό. Ελπίζω στο καινούργιο k750i να το έχουν διορθώσει.
Γι' αυτό και στα τελευταία μοντέλα (Κ750 και νεότερα) έχουν αλλάξει το βύσμα φόρτισης.
"Η χειρότερη άρνηση, η μεγαλύτερη απελπισία, είναι να φουντάρεις στον τόπο σου και να ζεις με τις αναμνήσεις..."
Νίκος Καββαδίας
παιδια και εγω το ιδιο προβλημα ειχα.το πηγα στην ΣΕ σαλονικη καθαρισαν το βισματακι και τωρα δουλευει κανονικα.
http://www.myspace.com/alexis747
http://www.alexis747.hi5.com
Η μεγαλυτερη αποδειξη της αγαπης, ειναι να αφηνουμε αυτους που αγαπαμε ν να ζησουν ελευθεροι ....
Υπαρχει και εδω, εγω εκανα αναβαθμιση τη δευτερα σε SE service και μου περασαν την R2AY
Don_VitoCorleone
έχεις περάσει στο κινητό σου την R2AT003 βερσιον;
Οχι,εχω περασει ομως την R2AY004 :D
HELLRAISER την εβαλα προχθες στο service center της Πατρας......δωρεαν φυσικα
ΠΗΓΑΙΝΕ ΡΥΘΜΙΣΕΙΣ>ΟΠΤΙΚΕΣ>ΦΩΤΙΣΜΟΣ>ΑΥΤΟΜΑΤΟ ΓΙΑ ΝΑ ΣΟΥ ΕΜΦΑΝΙΖΕΙ ΤΗΝ ΩΡΑ ΚΑΙ ΝΑ ΚΑΤΑΛΑΒΑΙΝΕΙΣ ΟΤΙ ΕΙΝΑΙ ΑΝΟΙΚΤΟ! ΤΗΝ ΙΔΙΑ ΑΠΟΡΙΑ ΕΙΧΑ ΚΑΙ ΓΩ ΚΑΠΟΤΕ
HTC Touch Diamond-Legend-Sensation XE-One X-M7-M8-10 SAMSUNG Galaxy S9+ S21 Ultra
Microsoft Surface pro 8
Καλησπέρα... θέλω να κάνω αναβάθμιση στο k700 μου αλλά να μην το αφήσω σε κάποιο service. Όποιος έχει βάση συγχρονισμού και την τελευταία αναβάθμιση και ενδιαφέρεται να με εξυπηρετήσει [ίσως και με κάποιο συμβολικό ποσό ως αμοιβή] ας μου στείλει ένα μήνυμα...
Μένω Αθήνα.
we gave birth and killed
what we thought would live
in this world
of fake freedom.
kalispera se olous agorasa prin apo liges meres to k700i kai simera pira bleutooth usb adapter level1.arxika otan ekana egatastsei stous drivers mou evgaze oti einia tis toshiba!!!!!kai kolouse sto 56% piga sto site ths level katavasa tous drivers kai h egkatastash egine kanonika otan omos pao na to anoixo bgazei:
Bluetooth device not found.
Please verify your Bluetooth device in properly connected and turned on
ftaei to usb h to kinhto?
poia einia h kaliteri bluetooth adaptor?
please help!!!!
εγώ νόμιζα ότι είχε προβλημα το κινητό στην υποδοχη του...anyway...οι ειδικοι μίλησαν...
Καλησπέρα... θέλω να κάνω αναβάθμιση στο k700 μου αλλά να μην το αφήσω σε κάποιο service. .
10 λεπτα δουλεια ειναι η αναβαθμιση σε service, δεν σου το κρατανε μερες.
