Τροποποιήσεις / Βελτιώσεις για το Nexus S
sakiss
Σε ποια rom αναφέρεσαι; Στου brainmaster ή στου formel;
ANDROID DEVICES: OnePlus 7 Pro / ONEPLUS 6T / ONEPLUS 5T / ONEPLUS 3T / MOTOROLA NEXUS 6 / LG G2 / LG OPTIMUS G / LG E960 NEXUS 4 / GOOGLE NEXUS 7 / GOOGLE GALAXY NEXUS / NEXUS S (BY SAMSUNG) / NOKIA 5800 / SAMSUNG WAVE / SAZEM MY V-65
  • Απαντήσεις 4,1χιλ.
Επισυναπτόμενες εικόνες
Bγήκε η 1.9.16 του brainmaster http://goo.gl/iM398
Version 1.9.16:
MIUI Changelog:
Recommended updates this week:
1. Download Manager support for SD card status free download of Themes, Music, Apps and other documents.
System:
New account registration system (Added Nickname / handle support)
Optimisation of system updates and music when no SD card is present, more unified style
Optimisation of clearing user data / clear all data (Factory defaults)
Fix issue with Gmail settings, selecting some items leads to FC
Fix rating stars display problem for Market
Phone:
Adding call fails logging to call log
Optimisation of database
Fix lockscreen phone notification interface does not display missed call information
Fix USSD / MMI interface leads to unable to call issues
Fix pick up quieten ringer and flip to silence triggering incorrectly
Fix problem with Bluetooth device unable to answer first call when paired problem
Fix pop-up to answer incoming call problems when selecting headset devices
Messaging:
Fix can’t send text messages to contact number with +86 (Overseas service)
Contacts:
Optimisation of import contacts to MIUI guide
Fix problem where contacts showed incorrect MiTalk account details for contacts
Fix abnormal issue with read-only contacts leading to FC
Themes:
Fix download theme without SD card, insert SD card cannot mount for migration of data problem
Fix replacement system notification sounds, the sound using the system to alert the application is not updated with new notification sound
Fix in some cases the “Current” ringtone label recurring problem
Camera:
Optimisation of camera shake detection time (Less than 5 seconds)
Open camera settings menu optimisation, if the shutter button takes pictures using hardware key the panel will disappear
Use of volume keys to optimise camera sounds has no effect
Fix Auto Focus issue and anti-shake causes camera to not respond leading to system restart
Fix issue switching to front facing camera duplicating “effect” when switching
Backup:
New interface for Cloud backup results and details
Fix removal of local copy of application during off-screen lead-free response questions
Fix inconsistency in Cloud backup progress indicator
Superuser:
Pop up optimisation tips / reminders for Root privileges
File Explorer:
Optimised remote FTP management, fixes for notifications as well.
Compass:
Beginner guide tips added
E-mail:
E-mail interface optimisation, new compose, and search message body interface
Settings:
Optimisation for Headset, Bluetooth headset default volume settings
Download manager:
Fix download large number of files / batch operations (pause / open) causes application to not respond
My Changelog:
- Removed LG Widgets
- Added BuglessPete's kernel
- Fixed Google Talk issues
- Fixed Google Music issues
- Fixed 3D Graphics performance (Thanks morfic for finding this fix!)
- Fixed Ring delay issues
- TCP and NET security tweak
- SDCard read ahead 2048 KB tweak
- Some small fixes and other things that I've forgot
στη miui :p
Και οι δύο αυτές που σου ανέφερα τροποποιημένες miui είναι. Εκτός και αν εννοείς τη stock miui.
του Brainmaster :p
σημερα δοκιμασα και το gps λιγακι, αντιθετα με την nscollab με τη αυτη κλειδωνει απειρως πιο γρηγορα.
εχω ενα θεμα ομως, οταν εχω συνδεδεμο το bluetooth και με καλουν δεν μεταφερεται αυτοματα η κληση σε αυτο αλλα πρεπει να το επιλεξω απο την οθονη της κλησης...
edit το οποιο θεμα το εχουν και αλλοι απο οτι βλεπω
Edited by panoc
Motorola Moto G
Nexus S, SlimJB 2.0, Beladus 7.1
@ sakis
Επειδή είδα που ρώτησες στο xda για wipe, να σου πω τη δίκη μου εμπειρία. Ήμουν με brainmaster 1.9.9.1 και εχτές πέρασα του former (που βασίζεται στην 1. 9. 9) και σήμερα πάνω σε αυτή του former έβαλα την 1. 9. 16 του brainmaster. Και στις δύο περιπτώσεις έκανα wipe cache και dalvik και fixing permissions. Κανένα πρόβλημα ούτε στη μια ούτε στην άλλη περίπτωση δεν είχα.
Τώρα ένα προβλήμα που εχω έχει σχέση με τις επαφές. Κάνω συγχρονισμό το gmail και μου λέει να σβηστούν 224 επαφές, όλες δηλαδή. Φυσικά δεν το προχωράω αλλά υπάρχει κάποιος τρόπος να εχω κάπου τις επαφές μου σαν αρχείο, ώστε να μην εχω πρόβλημα σε περίπτωση που σβηστούν όλες;
Sent from my Google Nexus S using Tapatalk
παιδια δοκιμαστε το Graphics Performance BOOOST απο το xda! το δοκιμασα σε καποια παιχνιδια δινει περισσοτερα frames και φωτια στο quadrant link http://forum.xda-developers.com/showthread.php?t=1264519
Nokia 3210->t68i->Nokia 3410->Nokia 6510->Nokia 8850->Sharp GX20->Sharp GX30i->Sharp V703->Nokia N80->Nokia 6110 Navigator->Nokia 6210 Navigator->Nokia N85->Nokia N97->Nokia 6710 Navigator->Nokia N86->iphone 3G 16GB->iphone 3GS 16GB->HTC Desire->HTC Desire HD->Iphone 4 32GB->HTC Trophy 7->Galaxy S->Nexus S->Iphone 4s 16GB->Galaxy S2->Nexus 5 32GB-> Galaxy s6 edge Gold
@ sakis
καντες ολες εξαγωγη στη μνημη.και αφου τις σβησεις ολες παιρνεις το αρχειο που τελειωνει σε .vcf αν θυμαμαι καλα απο το τηλεφωνο και το κανεις import στο gmail.
μολις εχει ιντερνετ το τηλεφωνο θα σου τις περασει μονο του εφοσον ειναι ενεργοποιημενος ο συγχρονισμος.
Sent from my GT-P1000
Ξύπνησε σ' έναν εφιάλτη αλλά δεν θυμάται να κοιμήθηκε
φιλε δεν μαφηνει να μετακινησω το αρχειακι.λεει οτι ειναι μονο για διαβασμα το αρχειο αυτο.πως το εκανες εσυ?
με root explorer και mount as r/w
Motorola Moto G
Απλώς να προσθέσω και αυτό:
http://www.myphone.gr/forum/showthread.php?p=3540901#post3540901
Θα το δοκιμάσω για να δημιουργήσω αρχείο vcf και να δούμε τι θα γίνει, όταν παω σπίτι γιατί τώρα είμαι έξω.
Σάκη, έχεις την τελευταία του brainmaster; Προσπάθησα αυτό για το graphic boost να αφαίρεση το αρχείο, αλλά δεν υπάρχει μέσα. Το έχει κάνει ο brainmaster αυτό το tweak;
πατας πανω δεξια το κουμπι να γινει mount r/o μετα μπορεις η να μετακινησεις το αρχειο η να πας στο αρχειο απο πανω eg.cfg και να σβησεις τη πρωτη γραμμη και ναφησεις την απο κατω που λεει 0 1 POWERVR_SGX540_120 χωρις να μετακινησεις/σβησεις το αρχειο, θα εχεις το ιδιο αποτελεσμα
Οχι δεν το εχει αυτο το tweak το βάζετε μόνοι σας.Πάντως η τελευταία rom του brainmaster ειναι αισθητά πιο γρήγορη και ομαλή.
Αναβάθμιση της Custom Recovery στην v5.0.2.0 (μην ξεχάσετε να κάνετε shut down το τηλ...στο δικο μου τουλάχιστον ετσι την εκανα apply μετά το φλασάρισμα το reboot δεν αρκούσε)
http://forum.xda-developers.com/showthread.php?t=1248760
Edited by sakiss
Δηλαδή εσύ το αρχείο /system/lib/egl/libGLES_android.so το έχεις στο κινητό σου;
Δε μου λετε μπορω να βαλω matrix kernel σε MIUI ROM ?
Εγώ έχω βάλει και τον 6.0 και τον 6.5 χωρίς το παραμικρό πρόβλημα. Τον 7.0 θέλεις να βάλεις;
Γράψε λάθος το έχει συμπεριλάβει το tweak ;)
Το ξέρω. Είδα την ερώτησή σου και τι σου απάντησαν στο xda. :p
Για αυτό και το ρώτησα, γιατί δεν υπήρχε το αρχείο. Εχτές έβαλα του brainmaster και σήμερα πέρασα του formel ο οποίος δεν το έχει αφαιρέσει το αρχείο. Το μετακίνησα κάπου αλλού και μόλις έκανα επανεκκίνηση. Για να δούμε...
Πάντως και του formel είναι πολύ καλή rom.
Δε μου λετε που μπορω να βρω τον kernel matrix 6.5 και 7.0?
στο xda εχει οποιον kernel γουσταρεις.εγω τους δοκιμασα ολους και κατεληξα σε trinity 144.με τους αλλους ετρωγε κολημα το κινητο οταν το ειχα 1.44 χρονισμενο και δεν μπορουσε να ολοκληρωσει benchmark εκτος απο το quadrant.με trinity ολα τερμα και δεν καταλαβανει τιποτα
Καλησπέρα.
Τώρα πριν λίγο προσπάθησα να βάλω την MIUI ROM στο κιν. Πρώτη μου απόπειρα να περάσω άλλη ROM.
Ακολουθώ τα βήματα του πρώτου post.
Δηλαδή κατεβάζω το αρχείο 1.9.16.MULTI_MIUI_BRAINMASTER_NEXUS_S.zip και TUV10-MIUI-Any-NS+4G-30082011.zip, και τα πετάω χύμα μέσα στον αποθηκευτικό χώρο του κιν.
Μπαίνω σε fast boot menu και διαλέγω recovery μου βγάζει ένα τρίγωνο με θαυμαστικό, και δεν κάνει τπτ άλλο, εκτός αν πατήσω volume up+power , βγαίνει λίστα
-reboot system now
-apply update from /sdcard
-wipe data
-wipe cache
Δοκιμάζω apply update from /sdcard (γιατί δεν βρίσκω το install zip from sd card) , και μου εμφανίζει το μήνυμα signature verification failed..installation aborted
Τι να κάνω??
Έχεις περασμένη custom recovery;
Opps!!! Πρέπει πρώτα να περάσω custom recovery??
Σόρρυ νόμιζα ότι ή περνάς custom recovery ή ΜIUI!!!
Λάθος!
Το κιν το πήρα unlock (με την κλειδαριά κάτω από το Google καθώς ανοίγει) από το service.
Μού έκαναν αντ/ση πλακέτας. Και από 'τη κατάλαβα το ξεκλείδωσαν κιόλας.
Edited by eXXa
Nαι ακολούθησε πρώτα τον οδηγό για custom recovery.
