stefanosx Δημ. September 21, 2005 Δημ. September 21, 2005 ti kerdizw me thn anavathmisei tou logismikou?sto 7610 Παράθεση ΝΟΚΙΑ :respect:
houla Δημ. September 22, 2005 Δημ. September 22, 2005 Να ρωτησω κατι ασχετο.. Πως μπορω να ανοιξω το κινητο χωρις sim, για να το χρησιμοποιησω μεσα στο αεροπλανο;;; :O Παράθεση :ninja:
antonis_wrx Δημ. September 22, 2005 Δημ. September 22, 2005 ti kerdizw me thn anavathmisei tou logismikou?sto 7610 NΕΑ Αναβαθμιση για 7610-6670 SW version 6.0522.0 Changes made from MCU SW version 5.0509.0 and version 6.0522.0 7610/6670 Nokia Mobile Phones Service Bulletin No. SB-034/07.09.05 Call and network management * Call establishment/disconnection improvements * Soft reject with SMS added as a new feature * Correction for ascending .rng ringing tones SMS * Correction for configuration message handling * 7-bit/Unicode character counter support for SMS * T9 memory size increased * Reply to SMS with MMS added as a new feature Email * Email attachment handling improvements Browser * Browser stability improvements * Correction for input field entry confirmation * Correction for login process to sites which requires username and password Streaming * Improvements to streaming connection establishment from browser * UI corrections to streaming session interruption Bluetooth * Bluetooth device discovery improvements * Bluetooth connection time to CK-7W improved Calendar * Calendar stability improved Application installer * Improvements to embedded SIS-file handling SIM-ATK * Launch browser command corrected in SIM-ATK Diverses * Correction for crash when opening mp4-file from File Manager * Boot up stability improvements * File manager stability improvements * Localisations corrections * Operator name list updated * Correct response to AT+CNMI AT command * Battery life time improvements * Improvements to large image handling in gallery * Thumbnail image visibility improved in phonebook Παράθεση http://antonis-wrx.blogspot.com
karx Δημ. September 23, 2005 Δημ. September 23, 2005 μηπως ξερει κανεις πως μπορω να γραφω σουηδικα στα sms και γενικα να βαλω κι αλλες γλωσσες?τωρα εχει μονο ελληνικα αγγλικα και γερμανικα. πρεπει να το παω στη νοκια ή μπορω να το κανω απο το σπιτι, και αν ναι πως? ευχαριστω!! Παράθεση
nikowen Δημ. September 28, 2005 Δημ. September 28, 2005 kalispera paidia.thelw na rwtisw kati gia to 7610 mou.to exw parewi edw kai 3 meres.exw vgalei kapoies fwtografies alla ta xrwmata tous einai kapws san ksethwriasmena otan tis pernaw sto pc.to exw megisti analisi sti rithmisi sto kin.entaksei den perimenw na exei poiotita fwtografikis alla exw dei fwtos apo to idio kin edw mesa me poly kalitera xrwmata kai poly pio zwntanes.exete na mou proteinete kapoia lisi?:)tnx ek twn protervn.... Παράθεση
WinMik Δημ. September 28, 2005 Δημ. September 28, 2005 antonis_wrx μεγειά το κινητό ! :D :wink: Παράθεση
cypherth Δημ. September 28, 2005 Δημ. September 28, 2005 πως μπορω να κανω το 7610 να δουλεψει ως καμερα για τον msn? γινεται με καποιο τροπο και αν ναι με ποιον εκτοσ του remote s60, το οποιο δοκιμασα και δεν δουλευει? μηπως υπαρχει καποιοσ τροποσ μεσω usb?? Παράθεση cypherth
gps_sat Δημ. September 30, 2005 Δημ. September 30, 2005 Εχω στα χερια μου ενα 7610 το οποιο εχει πεσει και νεκρωσαι η οθονη.προσπαθω να ανακτησω τον τηλεφωνικο καταλογο μεσω usb συνδεσης της Mobile Action και του αντιστοιχου software αλλα εκει που παει να κανει download απο τη μνημη του κινιτου δεν καταβαζει τιποτα,σταματαει! Επειδη δεν ειχα ξανα τετοιο κινιτο ή παρομοιο Nokia ,υπαρχει πιθανοτητα να μου βγαζει καποιο μηνυμα στην οθονη του κινιτου και να χρειαζεται να πατησω κατι; Ευχαριστω Παράθεση
tgi Δημ. October 1, 2005 Δημ. October 1, 2005 Καλημέρα σας, Από τότε που βγήκε η εκδοση PC Suite 6.6 (06/07/2005) έχει πρόβλημα με τον συγχρονισμό... :shock: :shock: :shock: Οταν έκανες συγχρονισμό με το outlook στο πρώτο συγχρονισμό έκανε copy τα δεδομένα από το τηλέφωνο στο outlook και στο δευτερο συγχρονισμό έσβηνε τα δεδομένα από το τηλέφωνο :angry: Αυτό μετά από κλήση μου στην nokia, :mad: :yahoo: φτιάχτηκε. Αρκει να κατεβάσετε την νέα έκδοση που βγήκε 30/9/2005 PC Suite 6.6 rel 18. :up: :up: Αυτά προς ενημέρωση!!!!! Παράθεση
yianniscy84 Δημ. October 18, 2005 Δημ. October 18, 2005 Gia sas, exw ena problima me to 7610 mou. Otan to enwsw me to kalwdio sto PC gia to PC Suite molis anoi3w to Phone Browser, fainetai to eikonidio tou kinhtou mou alla den mporw na kanw copy tpt panw tou h install applications. Mou bgazei to mhnyma "The operation could not be completed" :what: . Diabasa apo alla forums oti otan kaneis rename thn MMC douleuei, alla emena den douleuei. Dokimasa akoma kai hard format alla pali tpt. Dokimasa akoma na kanw reinstall ta drivers tou Data Cable kai tou PC Suite alla pali tpt :w00t: . Ti na kanw? Pls help. Παράθεση
billys_541 Δημ. October 18, 2005 Δημ. October 18, 2005 Gia sas, exw ena problima me to 7610 mou. Otan to enwsw me to kalwdio sto PC gia to PC Suite molis anoi3w to Phone Browser, fainetai to eikonidio tou kinhtou mou alla den mporw na kanw copy tpt panw tou h install applications. Mou bgazei to mhnyma "The operation could not be completed" :what: . Diabasa apo alla forums oti otan kaneis rename thn MMC douleuei, alla emena den douleuei. Dokimasa akoma kai hard format alla pali tpt. Dokimasa akoma na kanw reinstall ta drivers tou Data Cable kai tou PC Suite alla pali tpt :w00t: . Ti na kanw? Pls help. Και σε μένα αυτό κάνει.Βγές στην αναμονή των windows και ξαναμπές.Θέλει 2-3 φορές.Μετά δουλεύει κανονικά. Παράθεση
yianniscy84 Δημ. October 19, 2005 Δημ. October 19, 2005 Και σε μένα αυτό κάνει.Βγές στην αναμονή των windows και ξαναμπές.Θέλει 2-3 φορές.Μετά δουλεύει κανονικά. Ti ennoeis anamoni? Log off? :p Παράθεση
cypherth Δημ. October 22, 2005 Δημ. October 22, 2005 ξέρει κάποιος ποια έκδοση του black list ή του black baller ή κάποιου άλλου ίδιου σε λειτουργία προγράμματος κάνει για το 7610? το black list αντί να πετάει τις κλήσεις δείχνει κατειλλημένο και μόνο μετά από 1 ή 2 χτυπήματα ενώ εγώ θέλω απευθείας υπάρχει πρόγραμμα που απευθείας από το πρώτο χτύπημα να δείχνει κλειστό. επίσης ποια έκδοση του smart answer λειτουργεί πάλι στο 7610 και να σου δίνει τη δυνατότητα να βάλεισ amr ή άλλο αρχείο από την κάρτα χωρίς να χρειάζεται να ηχογραφήσεις κάτι? υπάρχει κάποιος αντίστοιχος τηλεφωνητής που να το κάνει αυτό, και φυσικά να ενεργοποιείται από τα 0 calls? Παράθεση cypherth
focusinos Δημ. October 22, 2005 Δημ. October 22, 2005 Έχω τη version 5.0509.0, 28-02-05, RH51. Υπάρχει κανένα update καινούργιο? Παράθεση
haris_led Δημ. October 22, 2005 Δημ. October 22, 2005 Έχω τη version 5.0509.0, 28-02-05, RH51. Υπάρχει κανένα update καινούργιο? Ναι, η 6.0522.0, 02-06-05, RH51:) EDIT: Λέει: SMS * 7-bit/Unicode character counter support for SMS Ξέρει κανείς πως μπορούμε να γράψουμε με unicode? Δεν το βρίσκω στο μενού που γράφεις νέο sms! Παράθεση
yianniscy84 Δημ. October 22, 2005 Δημ. October 22, 2005 Και σε μένα αυτό κάνει.Βγές στην αναμονή των windows και ξαναμπές.Θέλει 2-3 φορές.Μετά δουλεύει κανονικά. Τίποτα δεν γίνεται καμιά άλλη λύση? Παράθεση
yianniscy84 Δημ. October 22, 2005 Δημ. October 22, 2005 Μπορει να διορθωθει το προβλημα αν αλλάξω firmware? Υπαρχει καπου να το κατεβασω? Παράθεση
focusinos Δημ. October 22, 2005 Δημ. October 22, 2005 Ναι, η 6.0522.0, 02-06-05, RH51:) και που το βρίσκουμε το update αυτό;; Παράθεση
billys_541 Δημ. October 22, 2005 Δημ. October 22, 2005 Και να το βρείς τι θα το κάνεις?Δεν γίνεται να το περάσεις στο κινητό.Εκτός και αν έχεις ειδικό εξοπλισμό. Παράθεση
haris_led Δημ. October 22, 2005 Δημ. October 22, 2005 και που το βρίσκουμε το update αυτό;; Για να αναβαθμίσεις το κινητό σου μπορείς να πας σε ένα Nokia shop και να κρατάς και την εγγύηση του κινητού σου, και θα σου την κάνουν τσάμπα! Μία μέρα μπορεί να σου το κρατήσουν Παράθεση
tgi Δημ. October 22, 2005 Δημ. October 22, 2005 Μόνο μία ώρα θα κάνεις μόνο, στο Nokia Club της Βερανζέρου στην πλ Κάνιγκος!!! :) Αν έχεις εγγύηση είναι δωρεάν :D ... αν όχι...........15€ :mad: Αν σου ζητήσει τι πρόβλημα έχει πές του το κλασικό : Μου κολάει και μου κάνει restart στα καλά καθούμενα!!! :confused: :confused: Μην ψαρώσεις αν σου πεί ότι έχει ιό!!! Το λέει για να σου πάρει χρήματα!!!! :cry: Εκεί είναι μία γυναίκα που θα σου κάνει την δύσκολη αλλά τις αναβαθμήσεις τις κάνει ένας πιτσιρικάς!!!! Αν έχεις Vodafone nokia 7610, και θέλεις να βάλεις το update της nokia to original.... ζήτα το στον πιτσιρικά!!! Θα στο κάνει!!! :w00t: Μην πάς στο nokia club της Ν.Ιωνίας.... είναι ένας τύπος όπου δεν σε εξυπηρετεί καθόλου!!! Εμένα στην προηγούμενη αναβάθμηση, ενώ του είπα ότι θέλω το original της Nokia, με το έτσι θέλω έβαλε της Vodafone!!!!! :mad: :mad: Good Luck Παράθεση
kostakiss Δημ. October 22, 2005 Δημ. October 22, 2005 σε λίγες μέρες πιθανότατα θα αγοράσω το n70..επειδή δεν θέλω να χάσω τις επαφές..μπορείτε να μου πείτε τι να κάνω για να τις σώσω έτσι ώστε μετά να τις βάλω μετα στο n70? :confused: με αντιγραφή επαφών του 7610 μέσω nokia pc suite στο pc μπορεί να γίνει επαναφορά(επαφών 7610) σε n70? Παράθεση
nervous Δημ. October 23, 2005 Δημ. October 23, 2005 σε λίγες μέρες πιθανότατα θα αγοράσω το n70..επειδή δεν θέλω να χάσω τις επαφές..μπορείτε να μου πείτε τι να κάνω για να τις σώσω έτσι ώστε μετά να τις βάλω μετα στο n70? :confused: με αντιγραφή επαφών του 7610 μέσω nokia pc suite στο pc μπορεί να γίνει επαναφορά(επαφών 7610) σε n70? Περασε την εφαρμογη contacts manager στο 7610.Κανε στην συνεχεια export ολες τις επαφες σου μεσα απο τις επιλογες. Θα δημιουργηθει ενα αρχειακι με ολες τις επαφες σου (Export.csv) .Φυλαξε το στο pc σου μεχρι να παρεις το Ν70. Οταν παρεις το Ν70 ,περασε παλι την contacts manager. Κανε στην συνεχεια import απο τις επιλογες του μενου της εφαρμογης αφου πρωτα εχεις στειλει το παραπανω αρχειο (Export.csv) στο Ν70. Εισαι ετοιμος ! :) Παράθεση [imgalign]http://i37.tinypic.com/23k3s09.jpg[/imgalign] Μην ψάξεις ποτέ να βρεις κάτι τέλειο για να το αγαπήσεις. Αγάπησε κάτι ατελές και τελειοποίησε το με την αγάπη σου! iPhone 5S Space Grey Προσοχή! Κατάργηση γραφής Greeklish
MrZ Δημ. October 23, 2005 Δημ. October 23, 2005 Και με συγχρονισμό με το outlook δεν μπορει να το κάνει?Αναρωτιόμουν...Σχεδόν όλα τα κινητά που κυκλοφορούν (τα τελευταία χρόνια τουλάχιστον) υποστηρίζουν συγχρονισμό με outlook (επαφές,ημερολόγιο,σημειώσεις,υποχρεώσεις). Αν κάνεις μια φορά συχρονισμό με το outlook δεν θα μπορείς μετά να περάσεις τα δεδομένα σε όποια συσκευή θέλεις απλώς με ένα συγχρονισμό με τη συσκευή? :O Παράθεση Ride fast Ride hard Ride home. ZX6R
kostakiss Δημ. October 23, 2005 Δημ. October 23, 2005 το έκανα synchronize με outlook,έκανα και backup με το pc suite..αλλα τώρα πάει το "κινητακι"..το έδωσα.. πάμε γι αλλα..nokia n70!! :w00t: :shifty: Παράθεση
