All about BMW
omikrone3
Thete kai epixeirhmata:
Ta piswkinhta exoun mikroterh prosfysh se odwstrwma kakhs poiothtas logw mikroterou askoumenou barous stous kinhthrious troxous.
Rear-Wheel Drive Benefits:
-Predictable steering and handling
-Interfaces well with specialty driving controls
-Capable of high speeds
-Retains maximum forward stability
Rear-Wheel Drive Disadvantages:
-Climbing obstacles may be difficult
-Small front casters may sink into soft surfaces
-May exhibit rearward pitching if not properly configured
More difficult to master - While the handling characteristics of rear-wheel drive may be useful or fun in the hands of someone who knows how to use them, in the hands of most drivers, having the rear wheels move about is unintuitive and dangerous. Rear wheel drive rewards skill, and punishes the lack of it. Other layouts are much more forgiving, but don't offer the same rewards in handling.
Decreased interior space - This isn't an issue in a vehicle with a ladder frame like a pickup truck, where the space used by the drive line is unusable for passengers or cargo. But in a passenger car, rear wheel drive means: Less front leg room (the transmission tunnel takes up a lot of space between the driver and front passenger, less leg room for center passengers (there is also a smaller tunnel for the drive shaft), and sometimes less trunk space (since there is also more hardware that must be placed underneath the trunk).
Increased weight - The components of your typical rear wheel drive vehicle's power train may be less complex, but there are more of them. The driveshaft adds weight. The transmission is probably heavier. There is extra sheet metal to form the transmission tunnel. There is a rear axle or rear half-shafts. A rear wheel drive car WILL weigh slightly more than a comparable front wheel drive car (but less than four wheel drive).
Front-wheel Drive Benefits:
-Retains maximum rearward stability
-Offers obstacle-climbing capabilities
-Performs well on soft surfaces
Front-Wheel Drive Disadvantages:
-Low maximum speeds
-May be difficult to steer on outdoor terrain
-May exhibit catastrophic forward pitching during aggressive descends
Kai an thelete ki alla.bebaia opoios xerei 2-3 pramata gnwrizei pws kammia lysh den einai idanikh.
The controversy has gone on for decades: which is better - front wheel drive or rear wheel drive? We used to have predominately rear wheel drive (RWD) automobiles on the road, but by the late 1970's, front wheel drive (FWD) vehicles were beginning to dominate. While the majority of current passenger cars are still front wheel drive, rear wheel drive vehicles are becoming more common. For example, Infiniti has gone back to RWD on their G35 model, and Cadillac has RWD on their new CTS model. So what are the advantages and disadvantages of each drive system?
Let's look at front wheel drive first, as it is most common. Reduced cost: that is often the reason manufacturers design and build the way they do. FWD systems are cheaper to manufacture and install than RWD systems. There is no driveshaft or rear axle housing to build. The transmission and differential are located in one housing and less parts are needed. It also makes it easier for the designers to locate other parts beneath the vehicle, such as brake lines, fuel lines, and exhaust system.
Reduced weight is another advantage. Lowering a vehicle's weight improves acceleration, braking, and fuel economy. Traction is improved by having the weight of the engine and transaxle over the drive wheels. This is a big advantage on slippery roads.
A big advantage of FWD is interior space. No large bumps in the floorpan are required to accommodate mechanical parts. Look at current Honda Civics, and you will find great rear seat room in a small vehicle because of a flat floor pan. With no rear differential, trunk space can also be increased.
The disadvantages of FWD are mainly the decrease in vehicle handling ability. With more weight over the front of the automobile, the back end tends to become very light. Rear tire traction is decreased and the car may swap ends on icy roads easier. This has been overcome by designers somewhat by placing as much weight as possible further back in the vehicle. Ideal weight distribution is often described as 50/50 front to rear, but FWD cars seldom get near this.
Another disadvantage is the load placed on the front tires. They must transfer all acceleration, steering, cornering, and braking forces to the road. The tires have only a finite amount of grip, so using some of it for acceleration must decrease it in other areas. The rear tires have very little load on them and are basically only along for the ride. This is why accomplished FWD racers say "put the gas to the floor and steer - the rear will follow".
All the disadvantages of FWD systems are advantages of RWD vehicles. With some of the mechanical parts removed from the front and installed at the rear, vehicle balance and handling are much improved. Using the rear tires for acceleration traction takes the load off the front, so drivers accelerating out of a corner have much more lateral grip. RWD is used on all the world's fastest road course race cars and many performance production vehicles for this reason.
Repair costs are another advantage of RWD systems. Although costs vary greatly by make and model, if you have transmission problems with a RWD vehicle, the cost of differential repair is not required, as it might be on a FWD system. The reliability of FWD cars has increased so much over the decades, that this might not be a big concern.
Disadvantages of RWD are higher assembly and production costs, more parts to have problems with, and less interior room in the vehicle. Independent rear suspension, used on many current RWD cars allows the engineers to position the body closer to the differential and driveshaft, so interior room has improved.
Traction has always been a problem with RWD vehicles, because of the lower rear vehicle weight over the drive wheels, but modern electronics has changed that. Traction control and vehicle stability systems enable RWD cars to rival FWD vehicles on slippery surfaces. Improved tire designs have also helped.
Even with the decrease in passenger compartment room and increased mechanical complexity, I am still a rear wheel drive fan. I guess I just like the feel of the handling when pushed into corners. Other very good drivers I know would disagree with me.
So what is the answer? How about all wheel drive! Porsche uses AWD on a Carrera model to enhance performance and traction. Subaru has won several world rally championships with all wheel drive. The debate on what drive system is best still continues, and probably will for as long as we drive.
kai
How many driven wheels does a vehicle really need? The proliferation of SUVs on America's highways and byways over the last ten years would suggest that two simply isn't enough. But what exactly are the advantages of four-wheel drive (or all-wheel drive) versus front-wheel drive and rear-wheel drive?
First of all, before we're "driven" to confusion by all of this terminology, let's lay a few ground rules. In most automotive circles (and for the purposes of this discussion) the following acronyms will hold true:
AWD = all-wheel drive
4WD = four-wheel drive
RWD = rear-wheel drive
FWD = front-wheel drive
Each of these drive systems has its own advantages and disadvantages which I'll cover in greater detail.
Since the majority of vehicles sold today are front-wheel drive, we'll start here. As the name suggests, FWD vehicles use only the front wheels to deliver power from the engine to the pavement. While relatively rare on the streets of America during the first half of the 20th century, FWD cars now account for approximately 70 percent of new car offerings. Why the recent switch from RWD to FWD in new cars? Well, since most vehicles carry their engines up front, it is a simpler task to get that engine power to the driven wheels when they are both on the same end of the car. Essentially, you turn the engine sideways and connect a short driveshaft between either side of the engine and the two front wheels. Less distance and fewer parts between the engine and the driven wheels means less horsepower loss through mechanical inefficiency. Additionally, fewer parts means reduced production costs and, ultimately, a lower sticker price. One final advantage of FWD is that it puts the engine weight directly over the driven wheels which can improve traction on slippery or snow-packed roads.
Despite its practical advantages, FWD has several disadvantages when related to vehicle performance. First of all, since vehicle weight shifts to the rear of a car during hard acceleration, FWD cars will always be fighting a losing battle when it comes to straight-line acceleration. Handling performance also suffers on FWD platforms since the option of using "throttle-induced oversteer" or sliding the rear end doesn't exist (unless you get really creative with the emergency brake).
In the end FWD is a very practical way to power a vehicle but its inherent design is contradictory to performance. Look at it this way: Your car came with four wheels, why put the stress of steering, braking, and acceleration on only two of them?
Take everything I just said about FWD cars and reverse it for RWD cars. Performance goes up because now the two rear wheels handle the duties of acceleration, leaving the front wheels to focus solely on directing the vehicle (plus the majority of braking). This means that when you punch it, vehicle weight transfers to the rear end, just where you want it during acceleration. You can also "steer" a RWD car with the gas pedal by applying power and sliding the rear end while in a corner. If you don't think this is an advantage, try driving a Mazda Miata and a Chevy Cavalier convertible through the same set of backroad twisties. Even though they're both top-down, four-cylinder compact cars, the experience will be very different with a clear victory in "fun factor" going to the Miata.
This doesn't necessarily make rear-wheel drive the "better" configuration since it has disadvantages too. As mentioned earlier, RWD cars require a driveshaft (and dreaded interior "hump") and a differential to get power from the engine to the rear wheels. These components add extra cost and weight to a vehicle while robbing horsepower and making RWD cars generally less efficient than FWD vehicles. This layout is also more challenging to drive in inclement weather where, without the aid of traction control, a RWD car can more easily end up on somebody's front lawn or stuck in a ditch.
I personally have an affinity for RWD because its biggest disadvantage is also its biggest advantage; it's less practical and, consequently, more fun.
Both of the previous drivetrain layouts are based on using only half of a vehicle's wheels to deliver power to the ground. But those other wheels are just sitting there, why not use them too? Actually, the concept of using all-wheel drive is not new. A Dutch manufacturer named Spyker had one of the first full-time 4WD vehicles on display at the Paris Motor Show in 1903.
While we're here let's go over what the supposed differences are between four-wheel drive and all-wheel drive. 4WD was basically the original term used to describe all four wheels being driven on early Jeeps and trucks. These systems were not very advanced in that they simply put power to all four wheels, usually after an interior shift lever was moved and/or the vehicle's hubs were manually "locked" by the operator. During this period 4WD was thought of as a purely off-road utility. Today 4WD still refers to vehicles that can opt for two- or four-wheel drive. These vehicles often have a 4WD "low" and "high" setting that can be switched using an interior lever. The "low" setting provides even greater torque for pulling or climbing in an off-road environment. The "high" is useful for slippery on-road situations like packed snow or ice. 4WD also uses a locking center differential to avoid unnecessary slippage between the right and left wheels while off-road.
AWD generally operates all the time with no "low" or "high" gearing options. While 4WD is basically an SUV term, associated with off-road use, AWD is a car/wagon/minivan term that means traction improvement for performance or bad weather reasons. Some vehicles, like the Mercury Mountaineer or the Lexus RX 300, are tougher to classify because they are SUVs in appearance but use AWD instead of 4WD. Many of these types of vehicles are being called "crossovers."
The "all" part of all-wheel drive is a bit misleading since the majority of AWD vehicles use the front wheels primarily and only direct power to the rear wheels when a sensor detects front-wheel slip. Other cars, like the Porsche 911 Turbo, use AWD for performance purposes like getting from zero-to-sixty in 3.7 seconds. Even with sufficient horsepower, a Porsche with only two-wheel drive would be traction-limited to high 4- or low 5-second zero-to-sixty times. AWD also helps keep Subaru wagons and Chrysler minivans from sliding on wet or snowy roads by redirecting power from "the wheels that slip to the wheels that grip."
So, it seems like 4WD/AWD is the best way to go, right? Well, not exactly. Both of these systems add substantial weight, complexity and cost to a vehicle. They also reduce gas mileage because of increased drag on the drivetrain. When you consider that traction control is becoming more and more common on front- and rear-wheel drive cars, the supposed advantages of 4WD/AWD start to wane.
By now it should be obvious that there is no "best" drivetrain layout; just different designs with different characteristics. Hopefully, after reading this column, you'll have a better idea which one is right for your circumstances and not get suckered into buying an all-wheel drive Subaru for your daily commuter in Phoenix or a BMW M3 for exploring the Yukon.
Akomh
http://www.autoforumz.com/Ford-Mecury-Winter-safe-driving-FWD-RWD-Police-car-ftopict72385.html
http://www.totallychrysler.com/chrysler/chrysler-archive/chrysler/chrysler-p-730.html
http://www.automotiveforums.com/t165104.html
http://autozine.kyul.net/technical_school/handling/tech_handling_5.htm
Mporei h pisw kinhsh na einai pio diasdkedastikh alla thelei kai xerades.Fysika h exelixh ths pisw kinhshs eunoei th pisw kinhsh(ta hlektronika pou elega)Kai gia thn istoria opados ths Williams eimai.Alla den mporw na mhn paradextw pws h Alfa den exei mia dynamikh auth thn periodo.Autes oi syzhthseis exoun ginei kai exantlhthei.Sthn ellada aplws exoume syndesei BMW me mourh kai pisw kinhsh.
  • Απαντήσεις 1,2χιλ.
Καλά αυτό που λες στο πρώτο post:
αν και καθαρα απο αποψη φυσικης δεν υπαρχει τεραστια διαφορα.(προσφυση κρατηματα κτλ)
πως στο καλό κολάει με αυτο ου λές στο τελευταίο?
Αφου ρε φίλε δεν υπάρχει διαφορά πο άποψη φυσικής (με απενεργοποιημένα τα ηλεκτρονικά ενοείτε) τότε γιατή θέλει χεράδες η πισωκούνα? Καταλαβες τη ενοώ? Δεν κολάει το ένα με το άλλο!
Ωραίο το αθράκη που έστειλες πάντως, και αξιόλογη προσπάθεια δικαιολόγησης των λεγόμενων σου, δεν ξ΄ρω για τους άλλους λλά εγω δεν είμαι καλυμένος με βάση το πρώτο σου post, sorry!
Εγω παλι δεν καταλαβα...Απ τη μια λεει πως δεν εχουν και τρελες διαφορες,απ την αλλη κανει copy paste ολοκληρο κατεβατο για να μας δειξει τις διαφορες τους!!!
Επειδη υτωςη αλλως ειμαστε εκτος θεματος το αφηνω ως εχει γιατι μαλλον δεν καταλαβαινομαστε!!
Δλδ τι θα κανες?Μηπως ειασι mod? :p
Ελα παντα πλακα κανουμε.Αυτο που εννοουσα στο πρωτο ποστ ηταν πως σαν μηχανολογικες λυσεις καμμια δεν υπερεχει ξεκαθαρα εναντι της αλλης.Αυτο γινεται προφανες(για το μεσο νου) και απο τα κειμενα και τα λινκ που παραθετω.Δεν εχω διαθεση για flame war(ουτως η αλλως εδω μεσα δε σας παιρνει-εσεις το ειπατε)Προσωπικα το θεμα το χα ψαξει απο μικρη ηλικια και εχω βγαλει τα συμπερασματα μου.Απο κει και περα καταλαβαινω και αυτον που τα "εσκασε" για την πισω κινηση τοσο οσο και αυτον που δεν θελει η δεν εχει να σκασει για κατι που μπορει να του προσφερει στον ιδιο βαθμο και το FWD.
Nαι η διατυπωση ηταν λαθος.Εννουσα στο συνολο.Απο αποψη φυσικης η RWD παρουσιαζει μεγαλυτερη υπερστροφη(διωχνει κωλο κτλ)
Και παλι εννουσα στο συνολο(συμεπριφορα,κοστος,ασφαλεια)
Αυτα και δε θα επανελθω ξανα στο θεμα.Αν θελει και κανας mod να τα ξαποστειλει σε off topic καλο θα κανει.
Κατ'αρχήν δεν είναι off-topic και δεν είχα την πρόθεση να την "πω" ή να προσβάλω κανένα. Απλά θα ηθελα να ξέρω γιατή απο άποψη φυσικής, οπως είπες, δεν υπάρχει διαφορά. Απ'την στιγμή όμως που εξηγήθηκες, τα πράγματα ξεκαθάρισαν, και δεν μου μένει παρά να σου ξαναδώσω τα συγχαρητήρια μου για το αθράκη που πόσταρες, γιατή το βρίκα πολλύ επιμωρφοτικό!
Να σαι καλα φιλε.Παρεπιπτοντως βρηκα απο γνωστο εργασια του Πολυτεχνειου ΑΠΘ(Μηχανολογων) σχετικο με το τοπικ(επιπεδα προσφυσης στους 4 τυπους κινησεις σε διαφορα οδοστρωματακτλ)Ειναι του 94 αλλα απο οτι ειδα λεει ενδιαφεροντα πραματα κι αν εχω χρονο θα την σκαναρω και θα την ποσταρω
Βασικά το θέμ αναλύεται και στο thrend autonea.
Οι καινούργιες φήμες λένε λοιπόν ότι η Μ1 θα συνεχήση να είναι το στάνταρ Supercar τις BMW και δεν θα βασίζεται στην σειρά 1! Τώρα μη ρωτάτε που το διάβασα γιατή δεν θυμάμαι, νομίζω σε Site του Autobild!
eida kai ston dromo tin proti BMW 120d...
mprosta... koukla... plagia koukla...
otan tin afisa na me prosperasei... to piso meros... xm... thimizei ligo fiat/daewoo...
anyway... poli entiposiaki otan tin vlepeis apo kathrepti pantos...
Εδω μεσα μπορω να λεω οτι θελω εναντιον της Αλφα???
Χεχε, πήρες χαμπάρι τι μας έκαναν στο 'αλλο thrend με τις Alfa ε? Μπα δεν νομίζω, αν πεις κάτι για Alfa θα το σβήσουν ή θα κλειδώσουν το Thrend γιαυτο καλύτερα ξέχνα το! :confused:
1.ΟΥΚ ποστάρης εναντίον τις Alfa
2. ΟΥΚ ποστάρης σε Thrend τις Alfa με μπεμβεδίσια υπογραφή!
3. Κάτι μου λέει ότι και αυτο το ποστ μας θα σβηστεί σύντομα :lol:
ΕΔΩ έχουμαι ένα καλό αφιέρωμα στην παλιά Μ1
http://www.bmwworld.com/models/vintage/m1.htm
Και ΕΔΩ είναι το Club των "άτυχων" ιδιοκτητών Μ1
http://www.bmw-m1-club.de/english/welcome.html
:blink: :wacko: :cry:
ΓΙΑΤΗ ΜΟΥ ΧΑΛΑΣ ΤΗ ΜΕΡΑ ΜΟΥ???
ΕΔΩ έχουμαι ένα πολλύ πολλύ, μα πάρα πολλύ καλό αφιέρωμα στην πρωτάρα, και γενικά ωραίο Site για τους Βαυαρόφιλους :whistle:
Μιλάμε ΚΟΡΥΦΑΙΟ site, με μπεμβεδο-φόρουμς γεμάτα πορομένους μπεμβεδάκιδες, μιλάμε >ΠΟΡΟΜΕΝΟΥΣ!!! Έχει πάνω απο 100 φωτογραφίες τις πρωτάρας και διάφορες Spy-shots τις νέας 3άρας, ΤΣΕΚΑΡΕΤΕ ΟΠΟΣΔΗΠΟΤΕ!
Επίσης AC Schnitzer ACS1:http://www.germancarfans.com/tuners.cfm/tunerid/7040928.001/bmw/1.html
  • 2 years later...
Ρε παιδιά γιατί πέθανε το thread? :blink: Κανένας κάτοχος και κανείς που να εδιαφέρθηκε ξανά;
Επανέρχομαι 2 χρονάκια μετά :D
Επειδή πρώτη φορά γράφω σε thread σχετικό με την αυτοκίνηση ας παραθέσω κάποια στοιχεία.
Είμαι πρόσφατα κάτοχος μιας 116i... Από τα χέρια μου έχουν περάσει μια Clk 320 coupe, μια cabrio, ενα VW Passat 2λιτρο,ενα Audi A2 και ένα Daihatsu Terios...
Και όμως από όλα οδηγικά απολαμβάνω περισσότερο την μικρή. Μην βαράτε...
Όντως δεν έχει τα τρελλά γκάζια όμως "το κωλαράκι" φεύγει φέτες και η γενικότερη αίσθηση οδήγησης είναι πολύ καλή. Το DSC δένει υπερβολικά το αυτοκίνητο σε σημείο που για να σε πετάξει ο 1600άρης τουλάχιστον θα πρέπει ....χεμ...τι να πω :p . Η δυνατότητα απενεργοποίησής του πάντως είναι πολύ θετική. Κρατάς το κουμπάκι 3 sec και είσαι ελεύθερος να...... χεμ.. οκ με προσοχή πάντα ντε ;)
Αυτές τις μέρες δημιούργησα το εξής forum http://bmwseries1.forumup.gr/, όποιος κατέχει το συγκεκριμένο αυτοκίνητο αλλά και όχι μόνο και θέλει να συνεισφέρει να δημιουργήσουμε κάτι καλό και κυρίως πρακτικό σαν αυτό
http://bmws1vc.altervista.org/forum/index.php?act=idx
ας μπει στο club να το προχωρήσουμε...
καλησπερα φιλε με την υγεια η νεα σου Μπεμπα να εχεις καλους δρομους...
να σε ρωτησω τι διαστασεις εχουν τα ελαστικα σου?χτυπανε?σε ενοχλουν?
για τα ραν Φλατ εννοω...
καλη η προσπαθεια σου φιλε μου στο νεο φορουμ αλλα η ελληνικη αγορα δεν ειναι τοσο μεγαλη...και δεν νομιζω να εχει τοση ανταποκριση...
Δημήτρης
XS Max 512gb.
Γειά σου pik, σε ευχαριστώ καταρχήν για τα καλά σου λόγια :D ... σε αυτό που λές για το φόρουμ έχεις απόλυτο δίκιο, αλλά δεν βαριέσαι,ας κάνουμε μια δοκιμή για αρχή και βλέπουμε... αν και εγώ επίσης δεν βλέπω να γίνεται τίποτα :rolleyes:
Όσο για την ερώτησή σου δυστυχώς της έχω φορεμένα αυτά που έχει από τη "μαμά", οι διαστάσεις είναι 87Η 195/55R 16 και οι ζάντες είναι πλαστικά καπάκια :O .Σύντομα σκέφτομαι να περάσω σε κάτι άλλο, σκέφτομαι 18" ζάντα και για ελαστικά 225 ίσως και παραπάνω αν μπορώ ... Βέβαια είμαι προβληματισμένος στο αν θα περάσω πρώτα Xenon ή ζάντες, αλλα με βάση τη λογική αυτές υπερισχύουν. Σκεφτόμουνα σαν πρώτη ιδέα τις Goodyear EAGLE NCT 5 EMT 225/40 R18 88W , όμως πρόσφατα ενημερώθηκα ότι είναι πλέον εκτός παραγωγής και δεν διατίθενται. Δεν είναι από ιδιαίτερα έγγυρη πηγή οπότε ίσως λέω και ανοησίες :O . Αν όμως ισχύει θα μου πεις μπορώ να περάσω σε Bridgestone που είναι και καλύτερα ελαστικά ίσως, όμως οι 205 r18 runflat βγαίνουνε μόνο από την Goodyear, για τις 225 no problem ...
Αν θέλεις ρίξε μια ματιά σε αυτό το site για ζάντες της BMW : http://crass.on.ru/bmw/wheels/index.htm ;)
Γιατι θα βαλεις 18αρες;
Δεν ειναι αρκετα χαμηλες οι επιδοσεις της;
Θες να την επιβαρυνεις κι αλλο;
Proud owner of: Master System III , SNES , Mega Drive , Saturn , PSone , N64 , Dreamcast , PS2 , GameCube , XBox , XBox 360 , Wii , PS3 , PSP , DS .....
PC: CPU Phenom II 955 - MB MSI 790FX-GD70 - Corsair Vengeance 1x4GB - Sapphire 5850 Xtreme - WD800ADFD - COOLERMASTER RS-1000 SILENT PRO M 1000W
NickTG δεν έχεις άδικο. Εξάλλου ας μην ξεχνάμε και την κατανάλωση. Ωστόσο έχω φάει κόλλημα τελευταία με αυτή την robusta εικόνα που δίνουνε οι 18άρες σε συνδιασμό με μεγάλα ελαστικά. Με απενεργοποιημένο το DTC πάντως σε κάτι καλές curve που έχω ανακαλύψει θέλω να δοκιμάσω λίγο καλύτερη πρόσφυση χωρίς να χάσω όμως αυτήν την ολισθηρότητα. Δεν ξέρω αν με λαμβάνετε δεν μπορώ αν το εκφράσω απόλυτα. Γενικά θέλω να πειραματιστώ ... ;)
φιλε να πειραματιστεις οσο θελεις αλλα να μην επιβαρυνεις το οχημα σου...ειναι κριμα...
θα σου προτεινα μια 17 με το πολυ 225/45/17....κατι σε BBS για παραδειγμα...
διαφορετικα μαμα εχει η εταιρια καλες...
οσον αφορα τα ελαστικα δες Μισλεν και Μπριτζεστοουν Ποτενζα 050...ειναι καλα..
στην υπογραφη σου ειναι η δικη σου Μπεμπα?εχει ξενον αυτη και εχει και το μ πακ...καλο κομματι...
μην βαλεις ξενον καλυτερα πρωτα το ζαντολαστιχο...αλλα οχι υπερβολες...αποψη μου...
Δημήτρης
XS Max 512gb.
Έχεις δίκιο Pik. Βασικά όπως ανέφερα αυτό που με ενδιαφέρει είναι να φένεται μεγάλο το λάστιχο κατά κάποιον τρόπο να προεξέχει και η ζάντα από αυτό δεν ξέρω αν γίνομαι κατανοητός τι εννοώ :p Πιστεύεις με μια 17άρα και ένα καλό συνδιασμού ελαστικού θα το πετύχω;
Όσο για την ερώτησή σου όχι δεν είναι το δικό μου μόνο στο χρώμα μοιάζουνε (προς το παρόν :p ).Είναι ενός ιταλού έχει αυτά που αναφέρεις και είναι 120 diesel.
Btw τώρα είδα το Bologna, σε κανένα Motorshow έχεις πάει καθόλου; Σκέφτομαι τον επόμενο Δεκέμβρη να ανέβω μια βόλτα. Αυτά είναι από εκεί, τραβηγμένα με κινητό:
Και τέλος δεν σε ρώτησα τι αυτοκίνητο έχεις; :p
  • 11 months later...
Το 116i τι λεει γνωριζει κανεις?
Και αποπροβληματα πως τα παει?
Σκεφτωμαι για αγορα
TOMMIS RODOS ;)
Σκεφτωμαι για αγορα
πολυ καλο αυτοκινητο.τα παντα εχουν αισθηση,τιμονι φρενα κρατημα,κιβωτιο ταχυτητων.ειμαι πολυ ευχαριστημενος
το μονο αρνητικο τα run flat ελαστικα που κοπανανε,αλλα οταν τα αλλαξεις μπορεις να βαλεις συμβατικα με αγορα ενος κιτ επισκευης γτ δεν εχει χωρο για ρεζερβα
  • 1 month later...
