cypriot Δημ. July 20, 2009 Δημ. July 20, 2009 paidia exw to g1 apo ameriki kai simera exw erthi kipro kai exw svisi tis rithmisis oles katalathos, pws mporw na to energopihsw xwris internet ? Παράθεση
hellogadgetman78 Δημ. July 20, 2009 Δημ. July 20, 2009 kai gia root φυσικα αν ειναι υποχρεωτικο... οκ βρηκα αυτο http://forum.xda-developers.com/showthread.php?t=533731 αλλα ενω γινεται κανονικα η διαδικασια μου κολλαει στο hard spl..otan kano reboot dεν μου εμφανιζει τις εντολες για να πατησω alt+s h alt+l kapoia voithia? IF YOU HAVE ONE SD CARD: • Upload new SPL on your microSD and rename to "update.zip" • Reboot your phone into recovery mode. I ASSUME YOU MEAN HOLDING POWER AND HOME BUTTONS>>>RIGHT? • THIS IS IMPORTANT (perform a nandroid backup, of course) APPLY THE UPDATE USING ALT-S..., and once complete DON'T DO ANYTHING.. read step 4. • WITHOUT PRESSING ANY BUTTONS remove your microSD card from your phone, and plug it into your microSD card adapter/SD card reader • Remove/rename the SPL update (to something other than "update.zip") and upload the update file of the build you are currently using onto your microSD card. Put your microSD card back in your phone AGAIN WITHOUT PUSHING ANY BUTTONS I KNOW THIS IS STUPID, BUT WE RENAME THE BUILD TO UPDATE.ZIP AS WELL • Press Alt + x to go to the console. If your phone does not reboot automatically, press enter, type "reboot recovery", then press enter again. • If you boot up in recovery, you have done everything correctly. Now APPLY THE UPDATE USING ALT-S, reboot, and you're done Παράθεση [sIGPIC][/sIGPIC] αν θέλετε κατεβαστε την εφαρμογη μου Olympiakos Voices ,Panathinaikos Voices and AEK Voices όπως και DrGonzo[/b] (Fear and Loathing to Las Vegas)http://www.cyrket.com/p/android/com.DrGonzo/ και την Veggos http://apps.doubletwist.com/search?q=Veggos απο το Android Market
landscape Δημ. July 21, 2009 Δημ. July 21, 2009 παιδια μονο προσοχη με τα SPL γιατι αυτο ειναι και το αδυναμο σημειο του G1!!!Πολλοι απο απο εμας τα εχουν τουβλιασει (bricked)!! (ναι και εγω τα καταφερα...:() Παράθεση [sIGPIC][/sIGPIC]
doctor-gio Δημ. July 21, 2009 Δημ. July 21, 2009 ρε παληκαρια οσες φορες κ αν προσπαθησα τιποτα...περνω το spl apo edw http://forum.xda-developers.com/showthread.php?t=442480 στην καρτα κανω κ το ρεκοβερυ αλλα δεν πιανει με τιποτα το alt+s ΜΟΥ βγαζει στην οθονη αυτο DREA100 PVT 32B HBOOT-0.95.0000 CPLD-4 RADIO-1.22.12.29 SEP 2 2008 ουτε κ το αλτ+λ μου βγαζει κατι...οσο κ να μισω τα windows mobile με βλεπω να ξαναγυρνω εκει... Παράθεση οτι ποναει δεν σημαινει πως αξιζει κιολας.....
hellogadgetman78 Δημ. July 21, 2009 Δημ. July 21, 2009 ρε παληκαρια οσες φορες κ αν προσπαθησα τιποτα...περνω το spl apo edw http://forum.xda-developers.com/showthread.php?t=442480 στην καρτα κανω κ το ρεκοβερυ αλλα δεν πιανει με τιποτα το alt+s ΜΟΥ βγαζει στην οθονη αυτο DREA100 PVT 32B HBOOT-0.95.0000 CPLD-4 RADIO-1.22.12.29 SEP 2 2008 ουτε κ το αλτ+λ μου βγαζει κατι...οσο κ να μισω τα windows mobile με βλεπω να ξαναγυρνω εκει... Ακολουθα εναν οδηγο για root access και μετα αυτά Παράθεση [sIGPIC][/sIGPIC] αν θέλετε κατεβαστε την εφαρμογη μου Olympiakos Voices ,Panathinaikos Voices and AEK Voices όπως και DrGonzo[/b] (Fear and Loathing to Las Vegas)http://www.cyrket.com/p/android/com.DrGonzo/ και την Veggos http://apps.doubletwist.com/search?q=Veggos απο το Android Market
heylord Δημ. July 26, 2009 Δημ. July 26, 2009 Παιδιά τα έχω καταφέρει τελικά και έχω εγκαταστήσει την έκδοση HTC Hero στο κινητό. Ειλικρινά είναι τέλειο τώρα. Νιώθω ότι πήρα καινούργιο κινητό. Το θέμα είναι ότι δεν έχω κάνει partition την κάρτα μου σε fat32 και ext2 αλλά είναι ολόκληρη σε fat32 με αποτέλεσμα να είναι κάπως αργό να μην πω αρκετά αργό. Πιστεύω όταν δημιουργήσω και ένα partition με file system ext2 για τα προγράμματα, θα γίνει πιο γρήγορο. Παράθεση
hellogadgetman78 Δημ. July 30, 2009 Δημ. July 30, 2009 http://forums.t-mobile.com/tmbl/board/message?board.id=myTouch&message.id=13862#M13862 12 vids How to Install the Battery, SIM card & Memory card on the myTouch 3G How to Set up a Gmail Account on the myTouch 3G How to Text Message on the myTouch 3G How to Copy SIM Card Contacts on the myTouch 3G How to copy Contacts from Outlook to Gmail How to access the Internet on the myTouch 3G How to Customize the Home Screen on the myTouch 3G How to use the Camera on the myTouch 3G How to Search the Android Market on the myTouch 3G How to Take a Video on the myTouch 3G How to Make a Call on the myTouch 3G How to Complete a Master Reset on the myTouch 3G Και μην ξαναδω ερωτηση για απλα πραγματα ολα εδω Παράθεση [sIGPIC][/sIGPIC] αν θέλετε κατεβαστε την εφαρμογη μου Olympiakos Voices ,Panathinaikos Voices and AEK Voices όπως και DrGonzo[/b] (Fear and Loathing to Las Vegas)http://www.cyrket.com/p/android/com.DrGonzo/ και την Veggos http://apps.doubletwist.com/search?q=Veggos απο το Android Market
cmavr8 Δημ. July 30, 2009 Δημ. July 30, 2009 Παιδιά τα έχω καταφέρει τελικά και έχω εγκαταστήσει την έκδοση HTC Hero στο κινητό. Ειλικρινά είναι τέλειο τώρα. Νιώθω ότι πήρα καινούργιο κινητό. Το θέμα είναι ότι δεν έχω κάνει partition την κάρτα μου σε fat32 και ext2 αλλά είναι ολόκληρη σε fat32 με αποτέλεσμα να είναι κάπως αργό να μην πω αρκετά αργό. Πιστεύω όταν δημιουργήσω και ένα partition με file system ext2 για τα προγράμματα, θα γίνει πιο γρήγορο. Εγώ έβαλα χθες την JACHeroski 2.7.3 superlight, και ειναι καλή, αλλά δε δουλεύουν τα leds, bluetooth, και καποια πληκτρα (δεξί alt, shift) από το hardware keyboard. Λέω να γυρίσω σε κάτι που είναι φτιαγμένο για το δικό μας κινητό.. πιθανώς με port κάποιων εφαρμογών της htc. Το dialer ας πουμε έχει μερικά πολύ καλά.. Παράθεση
kostis_fx2 Δημ. July 30, 2009 Δημ. July 30, 2009 @cmavr8 μπορείς να δοκιμάσεις και εσυ αυτό που γράφω εδώ: http://www.myphone.gr/forum/showthread.php?p=2877565#post2877565 ;;; Παράθεση Personal Website: http://www.kospol.gr Android Greek Community: http://www.AndroidGreece.gr BlogThis.gr http://www.blogthis.gr Kostis_fx2 = Ventrix kata kosmon...
cmavr8 Δημ. July 30, 2009 Δημ. July 30, 2009 Ok, το έκανα. γύρω στο 13.5 παίρνει.. Θα βάλω CyanogenMod τώρα, αν και θα μου λείψει το ελληνικό πλητρολόγιο της Hero.. Tried it. CyanogenMod v3.6.8.1, με μόνο ένα πρόγραμμα (netcounter), θέλει πάνω από 23 δευτερόλεπτα! Είναι δυνατόν? Φαντάσου ότι πριν είχα φορτώσει πολλά προγράμματα στη hero rom... και ότι η cyanogen είναι "Tweaked frequency scaling options to be more responsive" Παράθεση
kostis_fx2 Δημ. July 30, 2009 Δημ. July 30, 2009 χε χε, κάτι δεν τους πάει αρκετά καλά απο οτι φαίνεται!!! η άλλη υπόθεση που μπορώ να κάνω είναι οτι προσπαθεί να δώσει περισσότερα timeslots και στις άλλες εφαρμογές και για αυτό καθυστερεί το benchmark... Παράθεση Personal Website: http://www.kospol.gr Android Greek Community: http://www.AndroidGreece.gr BlogThis.gr http://www.blogthis.gr Kostis_fx2 = Ventrix kata kosmon...
johnyhawk Δημ. July 30, 2009 Δημ. July 30, 2009 Πρέπει να το ξεκλειδώσεις πρώτα. Πόσο καιρό έχεις νούμερο στην T-mobile? Bestman εγώ ψάχνω ρυθμίσεις για wind plus non stop. Βασικά τις έχω, αλλά υπάρχουν μερικές επιλογές που δεν υπήρχαν στα άλλα κινητά.. Πιθανώς να υπάρχουν στο iphone. Έβαλα τα παρακάτω αλλά δε δουλεύει. Φαίνεται σε κάποιον κάτι λάθος? Τα κόκκινα είναι τα λιγότερο σίγουρα... APN: gwap.b-online.gr Proxy: 192.168.200.10 Port: 9401 username: wap password: wap server: gwap.b-online.gr mmsc: http://192.168.200.95/servlets/mms mms proxy: 192.168.200.11 mms port: 9401 mcc: 202 mnc: 10 apn type: gprs φιλε μου, το ελυσες τελικα το προβλημα σου με το νον στοπ πλας της γουιντ???Γιατι και εγω εχω το ιδιο προβλημα και δεν μπορω να συνδεθω..... Παράθεση :w00t:
cmavr8 Δημ. July 30, 2009 Δημ. July 30, 2009 χε χε, κάτι δεν τους πάει αρκετά καλά απο οτι φαίνεται!!! η άλλη υπόθεση που μπορώ να κάνω είναι οτι προσπαθεί να δώσει περισσότερα timeslots και στις άλλες εφαρμογές και για αυτό καθυστερεί το benchmark... ναι. Θα το φορτώσω και βλέπουμε στην πράξη @johnyhawk όχι, δεν το βρήκα, άλλαξα σε κανονικό πρόγραμμα. Ούτως ή άλλως το plus έχει πια όριο (40 mb νομίζω) οπότε δεν έχει και πολύ νόημα.. Παράθεση
hellogadgetman78 Δημ. July 30, 2009 Δημ. July 30, 2009 Μαγκες το επομενο βημα ειναι να περασουμε στο cyanogen rom το HTC greek πληκτρολογιο με το predicted text κλπ.Ας επικεντρωθουμε λιγο εκει... Παράθεση [sIGPIC][/sIGPIC] αν θέλετε κατεβαστε την εφαρμογη μου Olympiakos Voices ,Panathinaikos Voices and AEK Voices όπως και DrGonzo[/b] (Fear and Loathing to Las Vegas)http://www.cyrket.com/p/android/com.DrGonzo/ και την Veggos http://apps.doubletwist.com/search?q=Veggos απο το Android Market
Callahan Δημ. August 3, 2009 Δημ. August 3, 2009 Γεια χαρά σε όλους Μπορείτε να μου πείτε αν αξίζει να αλλάξω ένα LG Arena με το G1 (HTC Magic) ? Παράθεση Let me be your fantasy
L10nH34Rt Δημ. August 4, 2009 Δημ. August 4, 2009 Το G1 δεν θα το βρεις Ελλάδα. Μόνο το Magic. Για μένα οι συσκευές ούτε καν συγκρίνονται. Ανάλογα με τη χρήση που κάνεις επιλέγεις.... Παράθεση
GousgounisGR Δημ. August 13, 2009 Δημ. August 13, 2009 Καλησπέρα. Παρήγγειλα ένα HTC Dream πριν λίγες μέρες από ebay.Στην περιγραφή λέει ότι είναι SIM Unlocked.Απότι κατάλαβα αυτό μου επιτρέπει να να βάζω όποια SIM θέλω,σωστά? 'Εχω καρτοκινητή Cosmote Whats-up.Αναρωτιόμουν αν έβαζα την sim απ'την παλιά μπακατέλα στο HTC,θα δουλεύει? Παράθεση
kostis_fx2 Δημ. August 13, 2009 Δημ. August 13, 2009 Καλησπέρα. Παρήγγειλα ένα HTC Dream πριν λίγες μέρες από ebay.Στην περιγραφή λέει ότι είναι SIM Unlocked.Απότι κατάλαβα αυτό μου επιτρέπει να να βάζω όποια SIM θέλω,σωστά? 'Εχω καρτοκινητή Cosmote Whats-up.Αναρωτιόμουν αν έβαζα την sim απ'την παλιά μπακατέλα στο HTC,θα δουλεύει? χωρίς κανένα πρόβλημα... Παράθεση Personal Website: http://www.kospol.gr Android Greek Community: http://www.AndroidGreece.gr BlogThis.gr http://www.blogthis.gr Kostis_fx2 = Ventrix kata kosmon...
GousgounisGR Δημ. August 14, 2009 Δημ. August 14, 2009 χωρίς κανένα πρόβλημα... Ευχαριστώ για την απάντηση kosti.:D Παράθεση
Administrators athanaso77 Δημ. August 15, 2009 Administrators Δημ. August 15, 2009 Γεια χαρά σε όλους Μπορείτε να μου πείτε αν αξίζει να αλλάξω ένα LG Arena με το G1 (HTC Magic) ? Ενημερώσου πρώτα τι σημαίνει λειτουργικό Android πριν το αποφασίσεις. Παράθεση
kostis_fx2 Δημ. August 18, 2009 Δημ. August 18, 2009 χμ... μάλλον κακά νέα: Τέλος τα updates για το G1 http://www.androiddev.gr/forum/viewtopic.php?f=2&t=350 Παράθεση Personal Website: http://www.kospol.gr Android Greek Community: http://www.AndroidGreece.gr BlogThis.gr http://www.blogthis.gr Kostis_fx2 = Ventrix kata kosmon...
andreas_ku990 Δημ. August 19, 2009 Δημ. August 19, 2009 How to root Android with 1 click http://www.youtube.com/watch?v=cfskzfjOMgc&feature=player_embedded Παράθεση ~~They come. They fight. They destroy. They corrupt. It always ends the same.... ~~
doctor-gio Δημ. August 19, 2009 Δημ. August 19, 2009 μετα απο ανεπιτyχη προσπαθεια vα περασω την ρομ απο χερο θελω να ξανα βαλω την cupcake 1.5 exete υποψη καποιον οδηγο η που θα την βρω?koitaksa sto xda αλλα εχει διαφορες ρομ που λεγονται cupcake δεν θελω να κανω hard spl Παράθεση οτι ποναει δεν σημαινει πως αξιζει κιολας.....
komos Δημ. August 27, 2009 Δημ. August 27, 2009 ρε παιδια εγω εχω το g1 και θελω να το rootαρω και μετα να παιξω με ρομ εχω την crc 37 τι πρεπει να προσεξω αν μπορει καποιος να μου δωσει καποιες οδηγιες χοντρα χοντρα εχω κατεβασει καποιους οδηγους αλλα δεν καταλαβαινω αν κανει και για την δικια μου version Παράθεση
eidolongr Δημ. September 1, 2009 Δημ. September 1, 2009 Παίδες,αγόρασα απτο ebay το g1 ξεκλείδωτο.'Οταν ανοίγω το κινητό μου ζητάει gmail account.Βάζω το δικό μου και μετα από λίγο μου λέει try again.Απότι κατάλαβα πρέπει να ρυθμίσω κάποια apn settings? 'Εχω καρτοκινητή cosmote.Plzzzz help guys:cry::cry::cry::cry: Παράθεση
