[Επίσημο] Nokia N85
mirrorofsorrow
Nokia N85, Nokia N79 - old heroes, new wrapping
Review στα αγγλικα .
But don't think that the Nokia N85 is an exact copy of the Nokia N95
that has had its casing refurbished in an effort to prolong its platform's life cycle this way.
In fact it's one of the first phones to enjoy the revamped NSeries development strategy.
The build quality is one of the more popular questions about the Nokia N85 -
actually it's always frustrating when you find out that your 500-Euro phone is all flimsy.
Fortunately, Nokia has addressed this old issue of the N95 in their brand new N85
- its dual slider mechanism feels very sturdy and the phone itself is very palm-friendly too.
What's more, its glossy plastic surface isn't that much of a fingerprint magnet as you'd expect it to be.
The rear plate comes in a variety of colors, which is also a tribute to Nokia's current strategy.
So, as far as looks, build quality and materials go, we have no niggles with the N85 at all.
  • Απαντήσεις 2χιλ.
Και όσον αφορά την οθόνη του Ν85:
One of the N85's highlights is its 2.6 inch OLED-display capable of 16 million colors. While these bare numbers might not tell you much, the picture quality will for sure - the N85 is an enormous improvement over the Nokia N95 with its brighter and juicier colors along with very readable fonts. All in all, it's one of the best units we have seen yet. To tease you a little, let me say this - I managed to have a sneak peek at the next generation of screens some time ago (boasting the VGA resolution) and found that they were quite in line with the screen utilized in the Nokia N85.
Αν και εχουν ακουστει σχολια οτι η οθονη του N95 8GB δεν ειναι απο τις καλυτερες που υπαρχουν σε κινητα .
Οπως και να εχει αποτελει ενα πολυ θετικο βημα .
Ανυπομονώ να δω την οθόνη του. Άντε να δούμε τι θα λέει. Πάντως δεν αλλάζω το N95-2 με τίποτα ... Το Ν85 δε με συγκινεί ιδιαίτερα.
Αν δεν παρουσιάζει κάποιο σοβαρό πρόβλημα μ' αρέσει πάρα πολύ. Το μόνο που θα με χάλαγε είναι η το καφέ χρώμα στην πίσω όψη, αλλά απ' όσο κατάλαβα βγαίνει σε διάφορα χρώματα, οπότε ok.
Επίσης, καθότι δεν έχω ασχοληθεί με τα πιο πρόσφατα Symbian κινητά της NOKIA, να υποθέσω ότι η ενοχλητική καθυστέρηση του λειτουργικού έχει εξαλειφθεί; Μέχρι στιγμής έχω παίξει με N71 και N73 (είπαμε, με τα παλιά!) και αυτή η ταχύτητα του λειτουργικού (μάλλον η έλλειψή της) είναι το λιγότερο εκνευριστική. Αυτός και μόνο είναι λόγος ν' απορρίψω (ή να προτιμήσω) ένα Symbian κινητό...
Έχει βελτιωθεί πολύ η ταχύτητα στα νέα τηλέφωνα Symbian. Ιδίως τα πιο καινούργια με Feature Pack 2, όπως το Ν85, είναι πολύ εξελιγμένα σε αυτό τον τομέα.
Guest vasilistop
αναφερουν οτι τα dual led ειναι πιο αποτελεσματικα στα 3 μετρα αλλα δεν πιστευω οτι φτανουν στο επιπεδο ενοs xenon flash(με τιποτα),θα ηθελα παντος να δω μερικες photo σε συνθηκες χαμηλου φωτισμου οπως προσωπα σε αποστασεις απο 2
εως 3 μετρα
Πάντως, όσοι το έχουν χρησιμοποιήσει, έστω και σαν πρωτότυπο, λένε οτι το διπλό led είναι πολύ πιο αποτελεσματικό απο το απλό led. Αυτό σίγουρα μπορεί να θεωρηθεί πρόοδος. Επίσης, το διπλό led μπορεί να αξιοποιηθεί και κατά την λήψη βίντεο, την στιγμή που το ξένον είναι πρακτικά άχρηστο.
Δέστε και τι αναφέρεται σχετικά για το συγκεκριμένο θέμα:
I don't think it's much of a letdown, since this type of flash usually beats Xenon units at close-up shots. The image quality along with the camera interface haven't changed a bit; all things considered, it's one of the market's finest 5 Mpix shooters, just like other Nokia-branded phones are.
Τα διπλό slide έχει τριπλή χρήση. Πλήκτρα ελέγχου μουσικής και βίντεο, zoom in και out στην έκθεση και πλήκτρα ελέγχου στα παιχνίδια n-Gage.
Τα εφέ λειτουργούν ταχύτερα απο οτι στο Ν78. Ειδικά το εφέ scrolling της οθόνης. Σίγουρα συμβάλει ο επεξεργαστής που φοράει αλλά και η άφθονη RAM. Χρησιμοποιεί το ίδιο θέμα με το default του Ν78.
Επίσης o αισθητήρας κίνησης φαίνεται να λειτουργεί άψογα.
Αν πω οτι δεν ψηνομαι θα ειναι ψεματα.Αρκει βεβαια να <<λεει>> απο ποιοτητα.Προστατευτικο πανω απο την οθονη εχει η ειναι οπως το n95;Και μια και δεν ειδα να αναφερεται πουθενα,η κεραια του gps ξερουμε που ειναι,γιατι αν ειναι στην ιδια θεση με το n95 τοτε σκουρα τα πραγματα.
Όχι, ευτυχώς του άλλαξαν θέση. Πλέον είναι στο πάνω μέρος δίπλα στον φακό της κύριας κάμερας και δεν χρειάζεται να έχουμε ανοιχτό το slide για να πιάσει σήμα.
Guest vasilistop
λεει "beats Xenon units at close-up shots" δηλαδη σε τι αποστασεις?
Η αγάπη αποτελείται απο μια μοναδική ψυχή που κατοικεί σε δύο σώματα! (Αριστοτέλης)
Proud Owner of a Xbox360 fully updated!!! (http://www.enternity.gr)
Next Generation Consoles WAR:http:// http://www.vgchartz.com/
κατα την νυχτερινη ληψη φωτογραφιας αναβουν και τα 2 led η μονο το ενα;
Στη φωτο δε γνωριζω αλλα στο βιντεο (αν ακολουθει τα βηματα του Ν96 , που μαλλον το κανει) θα ειναι ενεργα και τα δυο led .
Οταν αγορασα το Ν95 μου πριν 16 μηνες αναρωτιωμουνα αν θα το αλλαζα μετα απο 1 χρονο οπως εκανα παντα γιατι εβγαιναν ολο και πιο προηγμενα τηλεφωνα!
Βλεπωντας το Ν85 μου δινει την αισθηση του ξαναζεσταμενου φαγητου!
Σορρυ nokia μαλλον θα μεινω με το 95αρι μου μεχρι να αποφασισετε να βγαλετε κανενα 100σταρι με 8mpx καμερα με 5 οπτικο ζουμ και HD 1080p βιντεο, 800 διπυρινο επεξεργαστη,3σιμησαρα touch οθονη,TV,και τελως παντων κατι πολυ περισοτερο απ'οτι προσφερε το Ν95 που βγηκε πριν εναμιση χρονο!!!!
Τα χρειάζεσαι όλα αυτά; Ή μήπως το Ν95 έτσι όπως είναι τώρα, με λίγο καλύτερη ποιότητα κατασκευής, είναι κάτι παραπάνω απο ικανοποιητικό;
Δεν το συζητάμε, αν είναι σαν τα διπλά LED του Ν96, στη βιντεοσκόπηση θα γίνεται η νύχτα μέρα.
Για τη φωτογραφία δεν ξέρω τι θα γίνει.
Οτι τα χρειαζομαι ναι, ποιος δεν θα ηθελε να εχει το ολα σ'ενα σε μια συσκευη τεχνολογικα πολυ προηγμενη που θα αντικαταστουσε πραγματικα και φωτογραφικη και βιντεοκαμερα και PSP και pc!
Και ναι το Ν95 είναι κάτι παραπάνω απο ικανοποιητικό!
Αλλα το Ν85 και το Ν96 δεν ειναι τιποτα αλλο απο ξαναζεσταμενο φαγητο γι'αυτο ειπα οτι θα μεινω με το 95ρι μεχρι να βγει το 100ρι!
