PPC hardware
Alexkass
kalhspera paidia...
tha kanw mia koufh erwthsh alla ti na kanw pou eimai asxetos...
kapou prepei na ginw rezili kai na rwthsw... :p
einai ena ppc pou exei ena sd slot (ipaq 1710) kai apoti katalava se auto to slot pernei kai mmc...
estw oti thelw na syndesw panw mia sdio syskeyh... px sdio bluetooth...
prepei na vgalw thn karta mnhmhs e? h oxi?
den yparxei tropos na einai kai h karta mnhmhs panw kai mia syskeyh SDIO?
(tha thn pw thn blakeia alla me ta mayra mesanyxt apou exw mono gia gelia eimai) dhladh kati san polymprizo? :wacko:
nai gelate e? e den iksera pw sna to pw :O
+bobb -=azor=-
  • Απαντήσεις 594
kalhspera paidia...
δυστυχως στην θυρα μπορεις να βαλεις μονο μια καρτα θα εχεις ειτε bluetooth ειτε μνημη ...
παντως υπαρχουν καρτες wifi με μνημη και λυνεται αυτο το προβλημα ομως δεν εχω δει κατι τετοιο για καρτες bt
Bluetake i-Phono BT420EX Bluetooth Stereo Headset
"Long have we been waiting for a pair of Bluetooth wireless stereo headsets that will let us listen to music on our mobile devices. You can hear the music with just about any Bluetooth wireless headset, but not in stereo with CD quality music. Salvation is here and it's called the Bluetake i-Phono. Billed as an entertainment and communication combo headset, the i-Phono BT420EX Bluetooth stereo headset works as a dual mono headset when you are talking on the phone and stereo headphones when you're listening to music or watching movies. The headset has a built-in Bluetooth radio that will work with any Bluetooth enable cell phone, PDA and laptop. If your device doesn't have Bluetooth capability (like many MP3 players) or doesn't support the audio gateway profile, the i-Phono comes with a Bluetooth adapter that can turn your audio device into a Bluetooth enabled device instantly and send the stereo signal to the headset. Very convenient!"
http://www.pocketpcthoughts.com/images/web/2003/iPhono.jpg
λινκ: http://www.mobiletechreview.com/tips/Bluetake_i_Phono.htm
Alex = the best!
PIN: 20DDA1B0 (Storm)
kalhspera paidia...
exw dei mhxanhmataki pou mpenei se ipaq kai ginete kinhto...
einai omws gia na mpei se thyra compact flash....
se thyra gia sd yparxei?
an pali yparxei einai gia ola ta ppc h kapoia sygekrimena?
rwtaw pio poly gia rz1710 alla pali an den einai ok gia auto to kinhto gia pia kanei? gia kanena 1940? h kati allo?
pantws thelw na mpenei se fthno ppc
+bobb -=azor=-
Eπειδή με έχουν ρωτήσει αρκετοί φίλοι μέσω ΡΜ κι έπεσα πάνω σ'αυτό,
ορίστε το link:
SDio 56k modem απο τη Socket.
http://www.socketcom.com/product/MO7200-558.asp
Mία εναλλακτική λύση είναι η αγορά ενός irda 56 modem. Θα πρέπει να μεταφέρετε μία επιπλέον συσκευή με υποχρεωτική οπτική επαφή modem+ppc, αλλά κερδίζετε σε αυτονομία.
τα καλύτερα είναι... δίπλα σας
πρώην συντονιστής συζητήσεων στα fora Windows Phone και Digital Gadgets[sIGPIC][/sIGPIC]
kalimera se oli ti parea. Iparxei tropos na metatrepoume cf kartes se sd oste na mporoume na tis xrisimopoioume stin sd ypodoxi tou ppc mas? etsi tha mporousame cf eksartimata na ta xrisimopoiousame kai emeis. :)
Την έχει δοκιμάσει κανείς? έχει καλή λήψη? ενδιαφέρομαι για χρήση κυρίως στο αυτοκίνητο.
Μην περιμένεις να πιάσει τέλεια γιατί κάθε φορά που θα στρίβεις με το αμάξι θα πρέπει να γυρνάς και την κεραία :D . Υπάρχει βέβαια και ειδικό κιτ για το αυτοκίνητο που περιλαμβάνει 4 κεραίες έναν μικτή και την πλεξούδα για την τροφοδοσία όλων αυτών. Στερεώνεις τις κεραίες σε κάθε τζάμι του αυτοκινήτου και τότε θα πιάνει μια χαρά η τηλεορασούλα!!
Γιώργος
Γεια σας παιδία.
Είμαι καινούργιος στο forum.
Βρήκα το παρακάτω site σχετικά με τις sdio cards και ήθελα να ρωτήσω αν ξέρετε που μπορώ να αγοράσω κάποια από αυτά και κυρίως από Ελλάδα
Ας είναι και άλλης εταιρίας. Κυρίως ενδιαφέρομαι για sdio tv tuner και sdio radio
http://www.sdcard.com/europe/TextPage.asp?Page=5
ean parousiastike 3ana sorry agnoiste auto to minima :P
http://www.myphone.gr/forum/showthread.php?t=50144 :D
hmm erotima <<KAFE KANI ?>>
Κάπου είχα δεί μια συσκευή που συνδεόταν στον υπολογιστή με USB, η οποία είχε θερμαινόμενη πλάκα, όπως η ηλεκτρική κουζίνα!! Βέβαια δεν ήταν για να φτιάχνει καφέ αλλά για να τον κρατάει ζεστό...!!!
Όσο πάμε και πλησιάζουμε στο ερώτημά σου! Σε 10 ίσως χρόνια, θα κάνουμε 2-3 κλίκ και θα επιλέγουμε τύπο/ζάχαρη/βαρυ/ελαφρύ μέσα απο ένα απλό interface...:p
http://arcadia.ceid.upatras.gr/arkadia/thumbs/places/agiorgit/agiorg5p.jpg
παιδια γνωριζετε ποιες μνημες ειναι καλυτερες για το mio 168;(αν εχουν καποια διαφορα στην αποδοση στη πλοηγηση)
Aγορασα μεταχειρισμενο το IPAQ 1915 και δυστυχως μου ηρθε χωρις πενακι. Που μπορω να βρω? καταστημα στην ελλαδα ψαχνω και οχι ιστοσελιδα
ΕΙΤΕ ΧΙΟΝΙΖΕΙ ΕΙΤΕ ΒΡΕΧΕΙ ΜΕΝΕΙ ΛΕΥΚΟ ΤΟ ΓΙΑΣΕΜΙ...
Μπορεις να παραγγειλεις απο play247.gr (πιστευω οτι εχει). Δεν χρειαζεται να χρησιμοποιησεις πιστωτικη (αντικαταβολη) και την επομενη μερα θα ειναι σπιτι σου . Εγω οσες φορες εχω παραγγειλει κατι ακομα και 6 το απογευμα την επομενη το πρωι ειναι σπιτι μου.
Καμιά ιδέα γιατί δεν εντοπίζει bluetooth hands free το QTEK 9090;
Έχω δοκιμάσει με διάφορα ακουστικά. Το bluetooth δουλεύει γιατί βρίσκει άλλες συσκευές.
Άλλος με προβλήματα bluetooth ???
  • 1 month later...
hmm R.T.F.M. :lol:
ama diabasis to mianial apo to hand tha dis pos ola exoun 1 mikro kolpo gia ton sinxronismo sinithos einai power + 1 key pou exoun epanotous etsi mporoun na entopistoun apo tin siskebisou kai fisika den ftei to 9090 :p
Εχει κανενας καμια καλη θηκη η οποια χωραει το iPAQ 4150 με την χοντρη μπαταρια?
Η στανταρ θηκη ειναι λιγακι στενη εδω που τα λεμε και φοβαμαι οτι θα ξεχειλωσει αμα την χρησιμοποιω συνεχεια......
σκεφτομαι να παρω ειτε την nylon της HP, ειτε καμια σε στυλ βιβλιαρακι......
Μπορείτε να μου δώσετε λινκ από κάποιο μαγαζί που να μπορώ να παραγγείλω μια σταθερή βάση για το αυτοκίνητο? Θέλω να το χρησιμοποιήσω σαν navigator
Ευχαριστώ πολύ
Υπογραφή εκτός Ο.Π.Χ.
Σας παρακαλώ εαν ξέρει κάποιος οτιδήποτε για το μπορώ να αγοράσω camera για το h6340 ας βοηθήσει. :wacko: :wacko: :wacko: :wacko: :wacko:
ΕΥΧΑΡΙΣΤΩ ΠΡΟΚΑΤΑΒΟΛΙΚΑ
Eixa agorasei mia tis HP 120 euro peripou prin 1 xrono! Den ksero poso exoun tora pantos htan 1,3MPixel. Kapou tin exo ksexasmeni se kapoio syrtari sxedon axrisimopoihth! :p
