katsj Δημ. January 18, 2006 Δημ. January 18, 2006 Gia tin ora exo brei auto http://www.buzzdev.net/index.php?option=com_content&task=view&id=61&Itemid=45 to opoio ousiastika apotelei trick gia na metafereis tin kathe glossa apo ton emulator sto PPC sou. Pantos apo to palikari pou ematha gia ta language packs epeimenei kai einai filaraki apo Ameriki ergazomeno stin M$ pou mazi me allous ellhnes ekei mesa paleuoun na ypostirixthoume os xora edo kai arketo kairo. Astouch diastaurose to kai esy an mporeis pantos! Παράθεση
katsj Δημ. January 18, 2006 Δημ. January 18, 2006 Kai mias kai to ksekinisame to thema poios mporei na kanei tin parakato diadikasia an exei ta tools pou xreiazontai mpas kai kanoume kati apo monoi mas? Diabaste loipon: Hi, sorry for my bad English (I'm German) there is no need to translate anything its all done by microsoft Emulator Language Code Reference: CHS - Chinese : Simplified (PRC) CHT - Chinese : Traditional (Taiwan) CSY - Czech: Czech Republic DAN - Danish: Denmark ELL - Greek: Greece ESN - Spanish: Spain (International Sort) FIN - Finnish: Finland FRA - French: France GER - German: Germany ITA - Italian: Italy JPN - Japanese: Japan KOR - Korean (Extended Wansung): Korea NLD - Dutch: Netherlands NOR - Norwegian: Norway (Bokmål) PLK - Polish: Poland PTB - Portuguese: Brazil PTG - Portuguese: Portugal RUS - Russian: Russia SVE - Swedish: Sweden HowTo: You need (instaled): - Visual Studio 2005 (or any other way to run MS Dervice Emulator) - Windows Mobile 5.0 SDK for Pocket PC - Localized Windows Mobile 5.0 Pocket PC Emulator Images (in your Language) - WM5_Files_Dumper.exe 1. Run the Dervice Emulator (VS2005: "Tools -> Connect to Dervice") and select one of the new Emulator Images 2. "File -> Configure..." and set a Shared folder (Works like a SD-Card) 3. Copy WM5_Files_Dumper.exe to this folder and run it from the virtual PPC. 4. Get all files from your "Shared folder" with ".mui" at the end. ( Like "shellres.dll.0407.mui" for german ) In the same way it is posible to copy... - all *.htm files (Localized helpfiles) - autocorrect.txt, mssp2_*.lex, dictprob.dat, statdict.dat (spellchecker/word completion) to XDA:/Windows do not use any *.dll or *.exe of those images they won't work. I NEED HELP TOO! I need some .dll files from a original german-ROM (WM2005). If somebody helps me, i coud extract him *.mui, .htm, ... files in any language thanks Παράθεση
RaZoR333 Δημ. January 18, 2006 Δημ. January 18, 2006 Kai mias kai to ksekinisame to thema poios mporei na kanei tin parakato diadikasia an exei ta tools pou xreiazontai mpas kai kanoume kati apo monoi mas? Diabaste loipon: Hi, sorry for my bad English (I'm German) there is no need to translate anything its all done by microsoft Emulator Language Code Reference: CHS - Chinese : Simplified (PRC) CHT - Chinese : Traditional (Taiwan) CSY - Czech: Czech Republic DAN - Danish: Denmark ELL - Greek: Greece ESN - Spanish: Spain (International Sort) FIN - Finnish: Finland FRA - French: France GER - German: Germany ITA - Italian: Italy JPN - Japanese: Japan KOR - Korean (Extended Wansung): Korea NLD - Dutch: Netherlands NOR - Norwegian: Norway (Bokmal) PLK - Polish: Poland PTB - Portuguese: Brazil PTG - Portuguese: Portugal RUS - Russian: Russia SVE - Swedish: Sweden HowTo: You need (instaled): - Visual Studio 2005 (or any other way to run MS Dervice Emulator) - Windows Mobile 5.0 SDK for Pocket PC - Localized Windows Mobile 5.0 Pocket PC Emulator Images (in your Language) - WM5_Files_Dumper.exe 1. Run the Dervice Emulator (VS2005: "Tools -> Connect to Dervice") and select one of the new Emulator Images 2. "File -> Configure..." and set a Shared folder (Works like a SD-Card) 3. Copy WM5_Files_Dumper.exe to this folder and run it from the virtual PPC. 4. Get all files from your "Shared folder" with ".mui" at the end. ( Like "shellres.dll.0407.mui" for german ) In the same way it is posible to copy... - all *.htm files (Localized helpfiles) - autocorrect.txt, mssp2_*.lex, dictprob.dat, statdict.dat (spellchecker/word completion) to XDA:/Windows do not use any *.dll or *.exe of those images they won't work. I NEED HELP TOO! I need some .dll files from a original german-ROM (WM2005). If somebody helps me, i coud extract him *.mui, .htm, ... files in any language thanks Κατι τετοιο σκεφτομουν να κανω και με το mpx200 οταν εβαλα τα wm5, ομως δεν βρηκα τα αρχεια. Υπαρχει ενα προβλημα που δεν αναφερει ο φιλος σου: τουλαχιστον στα wm5 που ειχα στο mpx υπηρχε επιλογη γλωσσα, στο ipaq δεν υπαρχει επιλογη γλωσσα αλλα μονο region, αντε και βρηκες τα αρχεια, την γλωσσα πως την αλλαζεις? Υ.Γ τουλαχιστον βρηκα ελληνικο πληκτρολογιο, με το οποιο εγραψα αυτο το ποστ! Edit:Εψαξα να βρω ποιες γλωσσες (.mui αρχεια) εχει εγκαταστημενες το hp rx1950 στον φακελο windows και τελικα βρηκα μονο την 0409 που ειναι αγγλικα (us). Τελικα ο atsouch ειχε δικιο ειναι καθαρα θεμα του κατασκευαστη ποια γλωσσα θα υποστηριξει. Προς το παρον η HP υποστηριζει μονο Αγγλικα (us) http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/23197.html Παράθεση
katsj Δημ. January 18, 2006 Δημ. January 18, 2006 Brika ta arxeia tha dokimaso apopse na ta peraso sto M600 pantos me kapoies allages sto registry einai polloi pou kataferan na baloun tin glossa tous! Tha sas exo nea argotera! Παράθεση
geovass Δημ. January 19, 2006 Δημ. January 19, 2006 Μια χαρα τα ακουω/βλεπω ! Αντε να το δουμε και αυτο !!! Bravo στα παιδια που ασχολουνται !! Παράθεση
stratus Δημ. January 19, 2006 Δημ. January 19, 2006 Brika ta arxeia tha dokimaso apopse na ta peraso sto M600 pantos me kapoies allages sto registry einai polloi pou kataferan na baloun tin glossa tous! Tha sas exo nea argotera! Τα αρχεια απο τον emulator τα εχω.Να τα αντιγραψω δεν γινεται απευθειας στο ppc δεν γινεται γιατι εινα readonly.Πως θα τα περασω μεσα;Εχεις βρει τιποτα; Παράθεση Η συζήτηση έχει υπερεκτιμηθεί ως μέσο επίλυσης διαφορών
ssarl Δημ. January 19, 2006 Δημ. January 19, 2006 Κάντε τα ρε παιδιά post σε κανένα rapidshare να δοκιμάσουμε όλοι από κάτι. Ποιος ξέρει, κάποιος μας μπορεί να πετύχει κάτι... Παράθεση
katsj Δημ. January 19, 2006 Δημ. January 19, 2006 Ta arxeia ennoeis tou menou enarksis sosta? Auta balta me enan card reader stin SD kai meta copy me ton resco explorer apo tin SD sto Windows directory! Ta alla ta .mui mporeis kai kateuthian meso activesync! Ta dll den xrieazontai kai den mpainoun alloste! Παράθεση
stratus Δημ. January 19, 2006 Δημ. January 19, 2006 Ta arxeia ennoeis tou menou enarksis sosta? Auta balta me enan card reader stin SD kai meta copy me ton resco explorer apo tin SD sto Windows directory! Ta alla ta .mui mporeis kai kateuthian meso activesync! Ta dll den xrieazontai kai den mpainoun alloste! Kαι ετσι να το κανεις δηλ να περασεις τα mui το προγραμμα ανοιγει στα αγγλικα.Νομιζω οτι πρεπει να πειραξεις και τα resources μετα να βλεπουν το σωστο mui Παράθεση Η συζήτηση έχει υπερεκτιμηθεί ως μέσο επίλυσης διαφορών
kostas_mob Δημ. January 19, 2006 Δημ. January 19, 2006 τελικά ελληνικά sms με 160 χαρακτήρες πως μπορούμε να γράψουμε αν δεν έχουμε hardware keyboard (σε κάνα qtek s100 για παράδειγμα). Μόνο με resco keyboard? Παράθεση
andrew_sh Δημ. January 19, 2006 Δημ. January 19, 2006 Ρε παιδιά συγνώμη αλλά δεν καταλαβαίνω. Με το ελληνικό intellidialer,και ελληνικο πληκτρολόγιο (ΑΕΚΜΑΡ, Resco) τα ελληνικά τι τα θέλετε? Για να έχετε το interface στα ελληνικά? Αυτό δεν το θέλετε, πιστέψτε με. Είχα το S100 από Ace hellas. Δεν μπορώ να πω, έχει γίνει καλή δουλειά (εγω δεν πρόσεξα ορθογραφικα λάθη κτλ.). Ελληνικά όμως με τεχνολογία ΔΕΝ κολλάνε (καλώς ή κακώς). Αν κολούσαν, το dvd θα το λέγαμε Ψηφιακό πολυμορφικό δίσκο ή Ψ.Π.Δ. !!! (Και άλλα πολλά παραδείγματα) Εγώ πάντος βρήκα τρόπο για να έχω ελληνικό intellidialer (που είναι το μόνο που θέλω στα ελληνικά λόγω ελληνικών επαφών). Αν ενδιαφέρεται κάποιος ας μου πει. Παράθεση
Demon Δημ. January 19, 2006 Δημ. January 19, 2006 Ρε παιδιά συγνώμη αλλά δεν καταλαβαίνω. Με το ελληνικό intellidialer,και ελληνικο πληκτρολόγιο (ΑΕΚΜΑΡ, Resco) τα ελληνικά τι τα θέλετε? Για να έχετε το interface στα ελληνικά? Αυτό δεν το θέλετε, πιστέψτε με. Είχα το S100 από Ace hellas. Δεν μπορώ να πω, έχει γίνει καλή δουλειά (εγω δεν πρόσεξα ορθογραφικα λάθη κτλ.). Ελληνικά όμως με τεχνολογία ΔΕΝ κολλάνε (καλώς ή κακώς). Αν κολούσαν, το dvd θα το λέγαμε Ψηφιακό πολυμορφικό δίσκο ή Ψ.Π.Δ. !!! (Και άλλα πολλά παραδείγματα) Εγώ πάντος βρήκα τρόπο για να έχω ελληνικό intellidialer (που είναι το μόνο που θέλω στα ελληνικά λόγω ελληνικών επαφών). Αν ενδιαφέρεται κάποιος ας μου πει. Θα συμφωνήσω μαζί σου και θα δώσω ακόμα ένα παράδειγμα. Σκέψου πως φαίνεται η μίξη μεταξύ Ελληνικών και Αγγλικών όταν πχ περνάς ένα today plug in, το Pocket Plus για παράδειγμα. Όσον αφορά για τον τρόπο να έχεις τον intellidialer στα Ελληνικά με ενδιαφέρει να μου πεις αλλά γιατί δεν το λες να το ξέρουν όλοι εδώ; :) Παράθεση
RaZoR333 Δημ. January 19, 2006 Δημ. January 19, 2006 Ρε παιδιά συγνώμη αλλά δεν καταλαβαίνω. Με το ελληνικό intellidialer,και ελληνικο πληκτρολόγιο (ΑΕΚΜΑΡ, Resco) τα ελληνικά τι τα θέλετε? Για να έχετε το interface στα ελληνικά? Αυτό δεν το θέλετε, πιστέψτε με. Είχα το S100 από Ace hellas. Δεν μπορώ να πω, έχει γίνει καλή δουλειά (εγω δεν πρόσεξα ορθογραφικα λάθη κτλ.). Ελληνικά όμως με τεχνολογία ΔΕΝ κολλάνε (καλώς ή κακώς). Αν κολούσαν, το dvd θα το λέγαμε Ψηφιακό πολυμορφικό δίσκο ή Ψ.Π.Δ. !!! (Και άλλα πολλά παραδείγματα) Εγώ πάντος βρήκα τρόπο για να έχω ελληνικό intellidialer (που είναι το μόνο που θέλω στα ελληνικά λόγω ελληνικών επαφών). Αν ενδιαφέρεται κάποιος ας μου πει. Ουτε και εγω θα διαφωνησω μαζι σου, απο την στιγμη που μπορω να γραψω Ελληνικα ειμαι ΟΚ. Παράθεση
andrew_sh Δημ. January 19, 2006 Δημ. January 19, 2006 Όσον αφορά για τον τρόπο να έχεις τον intellidialer στα Ελληνικά με ενδιαφέρει να μου πεις αλλά γιατί δεν το λες να το ξέρουν όλοι εδώ; :) Έχω φτιάξει ένα cab αρχειάκι που κάνει όλη τη δουλειά. Αλλά λόγω των κανόνων του forum δεν μπορώ να το επισυνάψω (περιέχει ένα dll της Ace Hellas). Αλλά μπορώ να σας πω τη διαδικασία να το κάνετε μόνοι σας. 1) Βρίσκετε μια ρομ της Ace. 2) Κάνετε extract το nk.nbf 3) Με το typhoonnbfdecode.pl (υπάρχει στο http://www.xda-developers.com) κάνετε decrypt το nk.nbf 4) Mε τα WM5 editing tools (υπάρχει στο http://www.xda-developers.com) κάνετε dump τη ROM 5) Sinexizw me greeklish giati varethika na patao alt-shift. 6) Apo ta arxeia tis ROM pernete to smartdialing.dll 7) Antigrafete afto to arxeio sto \windows tis siskevis sas kai kanete overwrite to proigoumeno 8) An xrisimopoieitai to arxeio, kante to rename, meta copy to kainourgio, soft reset kai delete to palio 9) Eistai etoimoi. An 8elete mporw na sas steilw me email to smartdialing.dll gia na apofygete ta vimata 1 - 6 Egw to exw kanei .cab kai to exw valei stin extended rom. Opote me kathe hard-reset exw aftomata greek intellidialer!! Prosoxi! : To exw dokimasei mono sto 9100 mou. Den kserw an 8a paiksei gia alles siskeves. Episis, i efthini gia oti kanete, einai mono diki sas. Minima pros tous Moderators: H paron diadikasia den paravainei kanena kanonismo. An exeis apoktisi to arxeio smartdialing me nomimo tropo den yparxei provlima. (Egw to apektisa apo kinito diko mou, agorasmeno apo Ace Hellas). Kai mi ksexname pws gia kathe software pou exeis agorasmeno, dikaiouse na exeis mia kopia! Παράθεση
katsj Δημ. January 19, 2006 Δημ. January 19, 2006 Kapoia pragmata ginontai gia tin fanela! Prosopika tin brisko na deikso poso aplo einai auto pou I ace hellas xreonei xrysafi kati pou den simbainei me atistoixes prospathies etaireion se alles xores pou dinoun rom se topiki glossa ksekleidotes! Apla den goustaro tous gnostous gkaragkiozides ;) Παράθεση
Muck Smith Δημ. January 19, 2006 Δημ. January 19, 2006 Θα παρακαλέσω οι συζητήσεις που αφορούν στο S100/ppc phone να γίνουν στο αντίστοιχο thread. Aς κρατήσουμε αυτό για ό,τι ακριβώς λέει ο τίτλος του. Παράθεση τα καλύτερα είναι... δίπλα σας πρώην συντονιστής συζητήσεων στα fora Windows Phone και Digital Gadgets[sIGPIC][/sIGPIC]
andrew_sh Δημ. January 19, 2006 Δημ. January 19, 2006 Ksexasa ena vima. vima 6,5) Kante disable to smartdialing ("Smart Dialing Options") vima 8,5) Kante enable Παράθεση
stratus Δημ. January 20, 2006 Δημ. January 20, 2006 Kapoia pragmata ginontai gia tin fanela! Prosopika tin brisko na deikso poso aplo einai auto pou I ace hellas xreonei xrysafi kati pou den simbainei me atistoixes prospathies etaireion se alles xores pou dinoun rom se topiki glossa ksekleidotes! Apla den goustaro tous gnostous gkaragkiozides ;) Συμφωνω μαζι σου. Παράθεση Η συζήτηση έχει υπερεκτιμηθεί ως μέσο επίλυσης διαφορών
ilias_l Δημ. February 24, 2006 Δημ. February 24, 2006 pedia otan egw grafw sms me to resco i me to aemap oi alloi ta pernoun ws erwtimatika ??????? kamia lisi ? Παράθεση
manos the greek Δημ. February 24, 2006 Δημ. February 24, 2006 Έχεις ενεργοποιήσεις το unicode? :) Παράθεση Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι... Wind Όσα παίρνει ο άνεμος
ilias_l Δημ. February 24, 2006 Δημ. February 24, 2006 oxi. giati otan to energopoiw oi xaraktiers gia sms peftoun stous 70... Παράθεση
maousos18 Δημ. February 24, 2006 Δημ. February 24, 2006 να ρωτήσω κατι ως ασχετος. Το wm 5 δεν εχει unicode?Δηλαδη μέσω του ποκετ γιορντ δεν μπορω να γραφω ελληνικά? Επισης στον internet explorer den emfanizontai ta ellinika ή ακόμα και στον acrobat reader? Παράθεση
ilias_l Δημ. February 24, 2006 Δημ. February 24, 2006 mia xara vlepeis ellhnika... an exeis tin aggliki ekdosi opws egw gia na grapseiseis 8eleis extra utility... omws an stileis sms (non-unicode) tote oi alloi ta pernoun ws wrwtimatika ???? kamia lisi ? Παράθεση
ilias_l Δημ. February 25, 2006 Δημ. February 25, 2006 update: έλυσα το πρόβλημα με το hardware keyboard: χρησιμοποίησα ένα mapping ειδικό για SMS απο εδώ: http://ae.inc.ru/aekmapviewlayout.php?ID=8 Μου μένει να κάνω το ίδιο με το Resco keyboard... Επίσης πως μπορώ να έχω ελληνικό dialer? (αντί για abc, def, ...--> αβγ, ..) Παράθεση
Enema Δημ. February 25, 2006 Δημ. February 25, 2006 Που το άκουσες αυτό John? Δεν παίζει κάτι τέτοιο. Η M$ ήδη δίνει ελληνικά στα PPC, είχα το 9100 με ελληνικά από την M$ ΠΡΙΝ βάλει το χέρι της η ACE Hellas. Η μετάφρασή τους από την MS είναι απαράδεκτη, μισή και ανορθόγραφη. Από την ACE Hellas είναι καλύτερη φυσικά αν και δε νομίζω οτι αξίζει αυτή την αύξηση στα χρήματα. Ξέχασέ το για full ελληνικά από MS πάντως, δεν μας έχουν σε μεγάλη υπόληψη. Εσυ μονος σου τα περασες τα ελληνικα απο την ms? Αν ναι, απο που μπορεις να μου πεις?:worry: Παράθεση [sIGPIC][/sIGPIC]
