Samsung Galaxy S10 Lite
ccypruss000
Versions: SM-G770F/DS (Global); SM-G770F/DSM (Russia, India)
Network Technology
GSM / HSPA / LTE
Launch Announced 2020, January
Status Available. Released 2020, February 3
Body Dimensions 162.5 x 75.6 x 8.1 mm (6.40 x 2.98 x 0.32 in)
Weight 186 g (6.56 oz)
SIM Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)
Display Type Super AMOLED Plus capacitive touchscreen, 16M colors
Size 6.7 inches, 107.8 cm2 (~87.8% screen-to-body ratio)
Resolution 1080 x 2400 pixels, 20:9 ratio (~394 ppi density)
Always-on display
HDR10+
Platform OS Android 10.0; One UI 2
Chipset Qualcomm SM8150 Snapdragon 855 (7 nm)
CPU Octa-core (1x2.84 GHz Kryo 485 & 3x2.42 GHz Kryo 485 & 4x1.78 GHz Kryo 485)
GPU Adreno 640
Memory Card slot microSDXC (uses shared SIM slot)
Internal 128GB 6GB RAM, 128GB 8GB RAM
UFS 2.1
Main Camera Triple 48 MP, f/2.0, 26mm (wide), 1/2.0", 0.8µm, PDAF, Super Steady OIS
12 MP, f/2.2, 12mm (ultrawide)
5 MP, f/2.4, 1/5.0", 1.12µm, dedicated macro camera
Features LED flash, panorama, HDR
Video 2160p@30/60fps, 1080p@30/60/240fps; gyro-EIS
Selfie camera Single 32 MP, f/2.2, 25mm (wide), 1/2.8", 0.8µm
Features HDR
Video 1080p@30fps
Sound Loudspeaker Yes
3.5mm jack No
Comms WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
Bluetooth 5.0, A2DP, LE
GPS Yes, with A-GPS, GLONASS, GALILEO, BDS
NFC Yes
USB 2.0, Type-C 1.0 reversible connector
Features Sensors Fingerprint (under display, optical), accelerometer, gyro, proximity, compass
ANT+
Battery Non-removable Li-Po 4500 mAh battery
Charging Fast battery charging 45W
Misc Colors Prism White, Prism Black, Prism Blue
Models SM-G770F, SM-G770F/DS, SM-G770F/DSM
SAR 0.69 W/kg (head) 0.93 W/kg (body)
SAR EU 0.49 W/kg (head) 1.52 W/kg (body)
Price € 649.00 / £ 604.83 / ₹ 39,999
Samsung Galaxy S24 ULTRA 512GB Yellow - iPhone 15 Pro 256GB Titanim Blue
Quote
Κάτοχος από την πρώτη ημέρα του S10 lite. Μεταπήδηση από Note 9 λόγω ραδιοφώνου. Πάρα πολύ καλή κάμερα με φοβερό ευρυγώνιο.
Οθονάρα (πιο κάτω από το note9 αλλά πολύ καλή) και απίστευτη μπαταρία 48 (ναι 48) ωρών με την ίδια χρήση που έκανα στο Note 9 των 24ωρών.
Περιμένω θήκη και τζάμι από εξωτερικό. Γενικά ευχαριστημένος
Έχει κανονικά fm radio? Στα specs που διαβάζω στα sites δεν το αναφέρουν
Δεν το αναφέρει αλλά έχει κανονικά. Εγώ πήγα πρώτα να το επιβεβαιώσω.
Σήμερα παρέλαβα θήκη και τζάμι Olixar από mobilefun.co.uk
Πολυ καλη συσκευη και το S 10 lite και το Nοte 10 lite.
Υποψιν η samsung αντιμετωπιζει και τις δυο συσκευες ως ναυαρχιδες που σημαινει οτι στο μελλον θα αναβαθμιστουν και σε android 11 και 12.
Edited by s_wind
Βλέπω ότι το note 10 lite είναι φθηνότερο απο το s10 lite και μου κάνει εντύπωση. Η σειρά note πάντοτε είναι ακριβότερη της s.
Ξέρει κανείς πού οφείλεται; στον επεξεργαστή που φοράει το s10 lite (snapdragon) ή και κάπου αλλού;
Λέτε να αξίζει η μετάβαση από το note 9 στο note 10 lite;;;
Edited by xetasa
πριν:nokia n82+5800+x6+n8 SlimModed by Lagoskon+lumia 800+920+820+830+925+1020+930, huawei p8 lite+p9 lite+mate 10 pro, iphone 5c+5+5s+6, Xiaomi Redmi note 2+ redmi 3s gold+ redmi note 3 pro+Redmi Note 4+Redmi Note 5+Mi A1+Mi8 6/64+Mi9 6/128+Poco F3, samsung galaxy s3+s3 mini+s4+s6+s7+s7 edge+s8 plus+s9plus+s10 plus 8/128+note 9+Note 10 plus+s20 fe 5G+s21fe+s21ultra+s21plus+s22 plus+s23ultra
τώρα: s23 plus 8/512 & s21 fe 6/128
Το Note 10 lite εχει τον επεξεργαστη του Note 9 - S9 .Θα εχει σιγουρα μετα απο ενα καλο στησιμο καλυτερη μπαταρια απο το 9.
Κατα ταλλα και οι 2 συσκευες ειναι σπλας προυφ δηλαδη ανθεκτικες στην βροχη αλλα οχι σε βυθιση σε νερο σε πισινα κτλ.
Αλλες διαφορες μικρολεπτομερειες .Και οι 2 συσκευες ειναι οκ.
Edited by s_wind
Γεια σε όλους! Είμαι μεταξύ S10 Lite και S10E. Λέτε να αξίζει το Lite, ή να προτιμήσω το E ως πιο ποιοτικό και πιο "ναυαρχίδα" (αδιαβροχοποίηση, στερεοφωνικά ηχεία)? Ευχαριστώ εκ των προτέρων!
Κοίτα μιλάς για 2 κινητά που σε μέγεθος είναι πραγματικά πολύ διαφορετικα. Το ένα είναι αρκετά μικρό ενώ το άλλο αρκετά μεγάλο. Πρώτα κοίτα τι θες σε μέγεθος και μετα τα άλλα.
Κάτοχος από χθες του S10 Lite. Αρχικά, ήμουν αρκετά επιφυλακτικός, κυρίως λόγω της πλαστικής πλάτης της συσκευής, για την οποία έγιναν αρνητικά σχόλια σε κάποια reviews, της απουσίας πιστοποίησης IP68 και της έλλειψης δεύτερου (stereo) ηχείου. Να σημειώσω ότι και ο ίδιος ο πωλητής στο κατάστημα, προσπαθούσε απεγνωσμένα να με αποτρέψει από την αγορά του συγκεκριμένου κινητού, τονίζοντάς μου με κεφαλαία γράμματα το πλαστικό πίσω μέρος, ως αποτρεπτικό παράγοντα για να δώσω 700€. Αντί αυτού, μου πρότεινε το S10 στα 789€. Επέμεινα στο Lite, λόγω του Snapdragon 855, της ύπαρξης FM radio (που δε συνηθίζεται σε καμία εταιρεία για συσκευές της ανώτερης κατηγορίας) και του ότι πρόκειται για ολοκαίνουργιο μοντέλο. Το αγόρασα και δεν το μετάνιωσα καθόλου. Το κινητό είναι πάρα πολύ γρήγορο και ισχυρό σε όλα του, ο ήχος εξαιρετικός, η αίσθηση στο χέρι, η οθόνη και η μπαταρία επίσης. Κυριολεκτικά πετάει!
Απορώ που η συγκεκριμένη συσκευή δεν εχει μεγαλύτερη απηχηση στη χώρα μας.
Η μονη συσκευη της Samsung στην Ελλαδα/Ευρωπη με:
SD855
8GB RAM
MicroSD
FM
6,7" Super Amoled Plus HDR+
4500mah
Μηνιαια updates και εως Android 12
Προφανή αρνητικα η μη premium κατασκευη, η ελλειψη IP rating και η απλα αρκετα καλή κάμερα (σαν upper midrange).
Σε οποια παρουσιαση του και αν πετυχαίνω εχει επικες επιδοσεις και αυτονομία.
Οταν θα πεσει και η τιμή του κατω απο τα 500€ θα ειναι ακομα μεγαλύτερο deal.
SD855
8GB RAM
MicroSD
FM
4500mah
Και εγω πιστεύω οτι ειναι η ποιο value for money πρόταση της σαμσουνγκ.
Προφανώς όμως στα 600€ δεν τραβαει το ενδιαφέρον. Στα 450-500 θα πουλησει μια χαρά πιστεύω. Οταν πάει εκει μπορεί να το αγοράσω.
SD855
8GB RAM
MicroSD
FM
4500mah
Kι ομως το Galaxy s10 Lite εχει καλυτερη καμερα κυριως η βασικη , απο το P30 της Huawei.
Edited by s_wind
Ενδιαφέρον!
Έχουμε εικόνα για την διάρκεια της μπαταρίας;
Σαυτο νομιζω οτι δεν χρειαζεται να ψαχτει καποιος γιατι εχει 500Mah απο τα S10 plus-2019 .Σιγουρα 101% θα κρατα παραπανω.
Και Update σε κάμερα. Φοβερή κάμερα και μπαταρία ημερών ...για πλάκα !!!
https://www.gsmarena.com/samsung_galaxy_s10_lites_first_firmware_update_adds_super_steady_at_4k_other_camera_upgrades-news-41784.php
Μας τα χαλάει στο night mode.
Τον επομενο μηνα θα το παρω γιατι μου αρεσει και σαν συσκευη εχει καλο επεξεργαστη μπαταρια πολυ καλη και καμερα επισης.
SD855
8GB RAM
MicroSD
FM
4500mah
Διαφωνώ για την "μη premium κατασκευή". Μία χαρά premium είναι η αίσθηση της συσκευής στο χέρι, αφού το πλαίσιο περιμετρικά είναι από αλουμίνιο. Αντικειμενικότερο θα ήταν το "όχι πάρα πολύ premium κατασκευή", αποκλειστικά λόγω της πλαστικής πλάτης, η οποία παρ'όλα αυτά δεν αφήνει καθόλου άσχημη αίσθηση.
Τα πάντα σχετικά είναι. Το γυαλί στην πλάτη σίγουρα είναι ποιο Premium απ το πλαστικό.
Απο την αλλη δεν αξιζει 300€ παραπανω που θα ειχε αν ηταν γυάλινη η πλατη και προμοταρονταν ως galaxy s20 lite που θα ηταν πολυ ποιο λογικο.
Επισης 855 και 865 ουσιαστικά είναι το ίδιο τσιπ. Η ιδια ακριβώς αρχιτεκτονική απλα με ελαφρως υψηλότερο χρονισμο και την αναμενόμενη υψηλότερη θερμοκρασία και κατανάλωση στον 865. Προσωπικά προτιμω τον 855 απο τον 865 γι αυτούς τους λογους. Και ειδικά αν παμε σε 855 ή τον αντίστοιχο exynos του 865 που είναι ακομα χειρότερος στα παντα σε σχεση με τον 865, τοτε ο 855 (που εχει και ραδιόφωνο να μη ξεχνιόμαστε) φαντάζει καλύτερη λυση, αλλα το μάρκετινγκ θα ισχυρίζεται τα αντίθετα.
Το μεγαλύτερο μείον σε αυτη τη συσκευή βρίσκω που δεν εχει στέρεο ηχο και θα χρειαστεί ροοτ για οποιον θέλει να το κάνει. (Με ροοτ φυσικά ο 855 μεταμορφώνεται τσαμπα σε 865 αφου οπως είπα πρόκειται για το ιδιο τσιπ. Κανείς δε σου απαγορεύει να τον πας οπου και ο 865 και παραπάνω αν θες.
Επισης παιρνει Google camera για μεγαλύτερη βελτίωση στις φωτο, που τα galaxy s20 δεν παίρνουν λογω exynos.
Αυτη η συσκευή είναι η μονη που αξιζει κανείς να παρει απ τη σαμσουνγκ σε σχεση κόστους / απόδοσης και απο οτι βλέπω ελάχιστοι ασχολούνται..
Δεν πειράζει σε μερικούς μήνες κατω των 500€ στο σκρουτζ θα γίνει η ποιο τιμια πρόταση να αγοράσεις.
+1000! Συμφωνώ απόλυτα! Είναι εξαιρετική συσκευή. Θα είναι κρίμα να μην πάει καλά σε πωλήσεις, διότι σε αυτή την περίπτωση, η Samsung δεν θα μας δώσει του χρόνου τέτοιο καιρό το διάδοχό της, το S20 Lite. Παρόλο που την έχω για δεύτερη, μου αρέσει πάρα πολύ και τη χρησιμοποιώ εξίσου με τη βασική μου συσκευή.
Να σου πω την αλήθεια, οσο λιγότεροι την αγοραζουν τοσο συντομότερα ίσως πεσει. Την παρακολουθώ και στο xda και δυστυχώς δεν εχει ουτε ροοτ για την ωρα για οποιον ενδιαφέρεται, μιας και επειδη δε θεωρείται ναυαρχίδα λίγοι εχουν ασχοληθει.
Ας βαλω και το λινκ εδω οποιον τον ενδιαφέρει .
Θα βρείτε χρήσιμα πραγματάκια εκει ειδικα εν καιρο.
https://forum.xda-developers.com/galaxy-s10-lite
Ερώτηση προς οποιον το αγορασε: Ειχε μετατροπέα usb type c προς βύσμα ακουστικών για να βάζουμε απλα ακουστικα?
Ειχε ακουστικά μεσα?
Αν οχι ξέρει κανεις που βρίσκουμε τετοιο μετατροπεα να δουλευει σιγουρα στη συσκευή ?
Edited by sosimple2
Ακουστικά έχει, για μετατροπέα δεν θυμάμαι (δεν έχω πρόχειρο το κουτί). Ε, όχι και δεν είναι ναυαρχίδα το S10 Lite. Μέλος της οικογένειας S10 είναι, είναι δυνατόν να είναι mid-range? Και με Snapdragon 855, έχουμε δει πολλά smartphones της μεσαίας κατηγορίας? Mid-range είναι το A80 που πήγε άπατο και άκλαυτο, όχι δα και το S10 Lite.
  • The title was changed to Samsung Galaxy S10 Lite
