Online Update K700i, Πως - Προβλήματα - Απορίες...
gbil
τι bugs φτιαχνει η καινουρια εκδοση? με την καμερα τι γινεται?
κανενα λινκ με τα χαρακτισριστικα του νεου Firmware???
  • Απαντήσεις 970
R2AE033
- Released on EMMA II (6/12/04)
- Faster overal speed
- Search function disabled in Asian firmware (Far east only?).
- Search function in phonebook upgraded for non-Asian firmware (C doesn't delete Contact, but letters you've entered, cursor cancels search)
- 900 ms+ delay on answering a call before the microphone was switched on has been fixed.
- Display Smileys in MMS/Browser
- Support of Apple ITunes format .m4a (=.mp4) including speech encoding format AAC
- Stopwatch no longer goes into backlight off mode or sleep mode
- Noise in HCA-20 car handsfree is gone
- The signal strength indicator has changed. Now signal is lowered by 1 bar at a time. Signal is raised to 5 bars if a strong signal is detected.
- Various crashes fixed (e.g. when music is playing an an alarm goes off)
- Various Java / Java 3D fixes
- Various browser / WAP / CSS fixes
- Various fixes to the Calendar application
- Various layout / font size fixes
- Updated Camera driver to change the default flicker compensation mode from 50 Hz to automatic.
- JBenchmark1: 2129
- Jbenchmark2: 125
- Software versions:
LCD 200406041
Camera 3.10
ITP CXC 125 813 R1S
ekana molis tora online update sto kinito mou alla den iparxei i elliniki glossa sto menou.
mono automatic k english mou exei k sto automatic pali agglika einai.
ti kano???
what????pws ginete auto???prin eixes ellinika???sti thesi sou tha xanakana tin anabathmisi....alla den xerw an ginete na xanaperaseis to idio software...
http://briefcase.pathfinder.gr/download/laios23/38168/578002
Το γούστο μου είναι πολύ απλό. Είμαι πάντα ικανοποιημένος, έχοντας το καλύτερο...''Oscar Wilde
Molis paratirisa oti meta tin teleutaia anabathmisi , den mporo na balo ta amr arxeia pou eixa gia ringtone.
Είχε ξαναειπωθεί κάτι τέτοιο στο forum.
Η λύση νομίζω είναι να κάνεις "επαναφορά εργοστασιακών ρυθμίσεων". (φρόντισε να κάνεις backup πρώτα στα αρχεία σου)
"Η χειρότερη άρνηση, η μεγαλύτερη απελπισία, είναι να φουντάρεις στον τόπο σου και να ζεις με τις αναμνήσεις..."
Νίκος Καββαδίας
Παιδια να κανω μια ερωτηση.Η αναβαθμιση στο k700i γινεται μονο με τις βασεις dss-20 και dss-25 ή και με απλο καλωδιο συνδεσης με η/υ;Γιατι ενδιαφερομαι για το Κ500i και η se ενεργοποιησε την online αναβαθμιση και γι'αυτο.(δειτε http://www.sonyericsson.com/spg.jsp?cc=gr&lc=el&ver=4000&template=ps1_1_5_7&zone=ps&lm=ps1_1&pid=10176 )
να δώσω ένα συν στην εξυπηρέτηση του service στη δωδεκανήσου,παρά τους φόβους που έιχα απο τηλεφωνικες επικοινωνίες με το συγκεκριμενο κατάστημα και διηγησεις άλλων,για 2η φορά πηγα το κ700 για αναβάθμιση και τελειωσα μεσα σε 20-30 λεπτά.
Μόνο με τις βάσεις :(
Νίκος Καββαδίας
Παιδια θα χρειαστω την βοηθεια σας.
Παω να κανω την αναβαθμιση και βγαζει μυνημα οτι δεν βρισκει βαση συνχρονισμου.Εχω εγκαταστησει το pc suite και εχω ρυθμισει την com σωστα.
(αναβει ενα πρασινο τικ στο τηλεφωνο που βγαζει κατω δεξια). Τι κανω λαθος? Εχω την βαση DSS-25 απο P910 με τους οδηγους απο το cd.
Με Windows XP SP2 και ΙΕ 6.
Ευχαριστω παρα πολυ για τη νβοηθεια σας.
an exeis to kalwdio trofodosias sindedemeno afereseto
Δεν το εχω βαλει!!!
Τα καταφερα!!! Εβγαλα antivirus και firewall και ολα μια χαρα! Τωρα δεν δουλευουν οι συντομευσεις, μου λεει αδυνατη η μετακινηση αλλα θα το φτιαξω που θα παει.
Δεν το εχω βαλει!!!
ande kales anabathmiseis tote!!!! :D
Λοιπόν, θέλω να αγοράσω βάση για αναβάθμιση. Που θα μπορούσα να βρω στην Αθήνα ή Πειραιά συγκεκριμένα, και ποια είναι η τιμή της. (είτε DSS-20 είτε DSS-25); Ευχαριστώ :)
ston pirgo athinwn stin sinwpis ambelokipous.exei sigoura.parton til.an kai einai m@l@k@s autos pou einai ekei sto service kai mono diafimisi den tha eprepe na tou kanw....
Τιμή ξέρεις;
Τιμή ξέρεις;
kapou 20-25e panw katw.
paidia kalispera.....
exw to eksis provlima...
exw katevasei tous drivers gia to sync ve tin vasi pou mou daneise enas pou exei to p800 omos otan anoigw ton fakleo na tous kanw instal mou vgzei pos dene exw ena arxeio to C:\WINDOWS\SYSTEM\FTDIUNIN.INI kai den exw alli epilogi apo to na patiso finish mporei kapiois na help?
Παιδιά πήγα στο πολυσυζητημένο κατάστημα της Sony Ericsson στην δωδεκανήσου για update και εκτός των άλλων κουφών που μου είπαν άκουσα και το εξής που ίσως με κάνει να μην προχωρήσω στην αναβάθμιση τελικά. Έιναι αλήθεια ότι στην νέα έκδοση (2AE) δεν υπάρχει ελληνικό Τ9 ?
http://www.zacharia.gr/lefteris/files/sigmyphone.gif
Ναι! Το αντικατέστησαν με αραβικό :shoot: ! Εμένα πάντως με βολέβει!!!
Υ.Γ: Φυσικά και έχει ελληνικό τ9!!!
Αν υπάρχει τότε είναι πολύ τρόμπες.
Δε μπορώ να καταλάβω γιατί κάνουν και λένε τα πάντα μέχρι και ψέματα για να μην σου κάνουν αυτήν την !#!#!@$!@$ αναβάθμιση.Τόσο μπελάς είναι γι'αυτούς ? έλεος
να σου πω εγω γιατι...γιατι δεν εχουμε μαζευτει ολοι μαζι μια μερα να παμε εκει να τα κανουμε λαμπογυαλο..να δεις θα ξαναπουνε μ@μ@κιες η οχι???ολα μα ολα τα σερβις που εχω επισκευτει ειναι επιεικως ΑΠΑΡΑΔΕΚΤΑ..οχι μονο ειναι πισω απο τα γεγονοτα(π.χ δεν ξερουν οτι υπαρχει η R2AE Ας πουμε) αλλα σου λενε και ενα σωρο μπαρουφες.οτι θες ακους απο τον καθε ασχετο και στο παιζει και ξερολας...Ρε παιδια εσεις εχετε επισκεφτει κανενα σερβις της προκοπης που να του λες κατι και να σε καταλαβαινει.π.χ θελετε αναβαθμιση κυριε???ΜΑΛΙΣΤΑ σε 20' θα σας εχουμε περΑσει την R2AE... :mad: :angry:
Έτσι είναι όπως τα λες laios23.
Τελικά πήγα και την έκανα την αναβάθμιση. Όπως είπε και ο paokaras45 πριν το κινητό συνεχίζει και έχει Τ9 στην 2ΑΕ ( ξέχασα να τους το δείξω να το μάθουν και οι αυτοί και να μην λένε μλκς στον κόσμο).
Και υπενθυμίζω σε όσους κάνουν αναβάθμιση από 2ΑΑ σε 2ΑΕ να μην ξεχάσουν να κάνουν επαναφορά εργοστασικών ρυθμίσεων (πονάει λίγο αυτό) για να μπορούν να βάζουν ως ήχο κλήσης και ξυπνητηριού αρχεία .amr .
Διαφορές στην κάμερα δεν είδα ούτε στην ταχύτητα του κινητού.Στην αναζήτηση επαφών μπορείς να ψάξεις με πολλά γράμματα αλλά δουλέυει μόνο αν και τα ονόματα είναι γραμμένα με κεφαλαία γράμματα διστυχώς.
Μα καλά ρε παιδιά;Είναι δυνατόν να αφαιρέσουν το Τ9 από το κινητό;
Ε, όχι. Για άλλα τους έχω ικανούς αλλά όχι και γι' αυτό!
Νίκος Καββαδίας
