jpower73 Δημ. November 11, 2015 Δημ. November 11, 2015 (edited) Και μέχρι να βγει η λολλι,.... Αλλη μία επώνυμη ρομ... Coolpad F1 mobile HTC 8297 = transplantation • Beta2,DPI switch, the camera switches support stored switching =root card package By wazls 11.11: Thank care provided at the end of the package Again with this streamlined some procedures like bypass Adjust script Storage switch? UM Mang Yin Shi Mang mixed entropy coat?/font> Add speed display of the status bar, no network is not displayed RF optimization Adjustment of the minimum brightness Normal timer Alarm clock rings Added automatic color changing module Add key Assistant icon smaller is better Add g-sensor Kit . Batteries can easily beautify MTK engineering mode in the gravity Toolbox access Increases voice tutorial: First of all, turn on the music, listen to ringtones Select input method Enter the MTK engineering mode Third column LoudSpeaker Mode Audio click on the third row of the right Ring Level drive to 6, Max Vol 160 click set and then the bomb box click OK to restart Voice is such a Added advanced settings "no theft": Protect your eyes Advanced restart Flash call Press the light switch Camera switch cool camera with original camera switch DPI switch WiFi password view Other If turn WIFI not linked for the first time, restart, I can test connection Start slow, please be patient Power setting has been completed, please restart it will work better Several software built-in, mind not to use Open ART a little Cottonwood, try not to use! Rational feedback BUG, I will do my best to fix ___________________________________________________________________________ |·· Other optimizations: |·· Manual tuning is better |·· Developer animation on/off & open Gpu rendering & background process limit of no more than 4 |·· I fix the bug, individually-driven investigation, spend a lot of time and energy, please apply the weight Reference screenshot http://i1378.photobucket.com/albums/ah119/Amarantos_Amarantos/Screenshot_2015-11-11-19-41-31_zpszgdjmlef.jpeg Link: http://pan.baidu.com/share/link?shareid=977730701&uk=1144278703 Αν ζητήσει κωδικο: ajke Και..... https://mega.nz/#!pBZWFTba!_4hnopzHBOukHM11Ol2_JTvfCmJ_zUEsuwfBfrj_S88 Edited November 12, 2015 by jpower73 Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
georgeIII Δημ. November 11, 2015 Δημ. November 11, 2015 προσπαθω με αυτον τον οδηγο http://forum.xda-developers.com/android/software-hacking/how-to-conver-lollipop-dat-files-to-t2978952 να κανω port την ρομ του fire. Ή εγω ειμαι πολυ χαζος ή κατι αλλο συμβαινει... μαλλον το πρωτο χαχαχαχα, μπορει να βοηθησει καποιος; Παράθεση
azuli Δημ. November 11, 2015 Δημ. November 11, 2015 Και μέχρι να βγει η λολλι,.... Αλλη μία επώνυμη ρομ... Coolpad F1 mobile HTC 8297 = transplantation • Beta2,DPI switch, the camera switches support stored switching =root card package By wazls 11.11: Thank care provided at the end of the package Again with this streamlined some procedures like bypass Adjust script Storage switch? UM Mang Yin Shi Mang mixed entropy coat?/font> Add speed display of the status bar, no network is not displayed RF optimization Adjustment of the minimum brightness Normal timer Alarm clock rings Added automatic color changing module Add key Assistant icon smaller is better Add g-sensor Kit . Batteries can easily beautify MTK engineering mode in the gravity Toolbox access Increases voice tutorial: First of all, turn on the music, listen to ringtones Select input method Enter the MTK engineering mode Third column LoudSpeaker Mode Audio click on the third row of the right Ring Level drive to 6, Max Vol 160 click set and then the bomb box click OK to restart Voice is such a Added advanced settings "no theft": Protect your eyes Advanced restart Flash call Press the light switch Camera switch cool camera with original camera switch DPI switch WiFi password view Other If turn WIFI not linked for the first time, restart, I can test connection Start slow, please be patient Power setting has been completed, please restart it will work better Several software built-in, mind not to use Open ART a little Cottonwood, try not to use! Rational feedback BUG, I will do my best to fix ___________________________________________________________________________ |·· Other optimizations: |·· Manual tuning is better |·· Developer animation on/off & open Gpu rendering & background process limit of no more than 4 |·· I fix the bug, individually-driven investigation, spend a lot of time and energy, please apply the weight Reference screenshot http://i1378.photobucket.com/albums/ah119/Amarantos_Amarantos/Screenshot_2015-11-11-19-41-31_zpszgdjmlef.jpeg Link: http://pan.baidu.com/share/link?shareid=977730701&uk=1144278703 Αν ζητήσει κωδικο: ajke προσπαθω αλλα με ff δεν κανει τιποτα το κουμπι download και με τον ie μου ζηταει τηλεφωνο..και ψηνομουν για μια νεα ρομ σημερα γιατι εκεινη η σαπια η iNew μεσα σε ενα μηνα σερνεται.. Παράθεση
jpower73 Δημ. November 11, 2015 Δημ. November 11, 2015 Αχαχαχαχα, την έχεις "ταπεινωσει" αυτην την inew..... Την κατεβάζω απο baidu.. Τα ζωα μου αργά... Θα την ανεβάσω σε μεγκα...... Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
azuli Δημ. November 11, 2015 Δημ. November 11, 2015 Αχαχαχαχα, την έχεις "ταπεινωσει" αυτην την inew..... Την κατεβάζω απο baidu.. Τα ζωα μου αργά... Θα την ανεβάσω σε μεγκα...... ωραιος ελπιζω να την προλαβω σημερα Παράθεση
jpower73 Δημ. November 11, 2015 Δημ. November 11, 2015 Είμαι γυρω στο 45%.. Τώρα ομως έχει γκαζωσει λίγο... (350κβ/") Φαίνεται πως πεσαν για υπνο οι Κινέζοι... Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
azuli Δημ. November 11, 2015 Δημ. November 11, 2015 Είμαι γυρω στο 45%.. Τώρα ομως έχει γκαζωσει λίγο... (350κβ/") Φαίνεται πως πεσαν για υπνο οι Κινέζοι... κανω τα μπακαπ μου και περιμενω..! Παράθεση
jpower73 Δημ. November 11, 2015 Δημ. November 11, 2015 (edited) Η υπομονή είναι μία από τις 7 αρετές.. http://s22.postimg.org/urwronvb1/Screenshot_2015_11_12_00_10_42.jpg http://s28.postimg.org/dfabra3ex/Screenshot_2015_11_12_00_21_05.jpg Ξεκινάει το Uploading σε μεγκα.... Ετοιμο.. https://mega.nz/#!pBZWFTba!_4hnopzHBOukHM11Ol2_JTvfCmJ_zUEsuwfBfrj_S88 Edited November 12, 2015 by jpower73 Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
azuli Δημ. November 12, 2015 Δημ. November 12, 2015 παιδια η 8297W-仿AndroidL-11.01 μου βγαζουν τα windows οτι εχει μεσα ιο (ramnit.gen!Α) .Δεν ξερω αν ειναι false positive αλλα δεν εχω ξαναδει κατι αναλογο Η υπομονή είναι μία από τις 7 αρετές.. http://s22.postimg.org/urwronvb1/Screenshot_2015_11_12_00_10_42.jpg http://s28.postimg.org/dfabra3ex/Screenshot_2015_11_12_00_21_05.jpg Ξεκινάει το Uploading σε μεγκα.... Ετοιμο.. https://mega.nz/#!pBZWFTba!_4hnopzHBOukHM11Ol2_JTvfCmJ_zUEsuwfBfrj_S88 κατεβαζω,thanks..!μαλλον το πρωι θα περαστει Παράθεση
jpower73 Δημ. November 12, 2015 Δημ. November 12, 2015 μολις σε βολέψει, κανε και ενα ριβιου... αν αξίζει να δοκιμαστεί αντί της εμυι.. Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
suzukis Δημ. November 12, 2015 Δημ. November 12, 2015 Καλημέρα. Καμία καλή εφαρμογή για ανάκτηση διαγραφεντων αρχείων από την SD? Παράθεση Το χασαμε το κορμι πατριωτη!!!! [sIGPIC][/sIGPIC]
Moihack Δημ. November 12, 2015 Δημ. November 12, 2015 Καλημέρα. Καμία καλή εφαρμογή για ανάκτηση διαγραφεντων αρχείων από την SD? Δες αυτο: http://www.cgsecurity.org/wiki/PhotoRec Είναι free & open source και μου χει σωσει διαφορα αρχεια απο 2 διαφορετικες sd. Οσο δεν εχεις γραψει 1000 πραγματα απο πανω εχεις πολλες πιθανοτητες να βρεις αυτο που θες. Παράθεση
suzukis Δημ. November 12, 2015 Δημ. November 12, 2015 Δες αυτο: http://www.cgsecurity.org/wiki/PhotoRec Είναι free & open source και μου χει σωσει διαφορα αρχεια απο 2 διαφορετικες sd. Οσο δεν εχεις γραψει 1000 πραγματα απο πανω εχεις πολλες πιθανοτητες να βρεις αυτο που θες. Δεν είναι apk ? Παράθεση Το χασαμε το κορμι πατριωτη!!!! [sIGPIC][/sIGPIC]
Moihack Δημ. November 12, 2015 Δημ. November 12, 2015 Δεν είναι apk ? Οχι στο pc το τρεχεις, αν και δεν νομιζω οτι υπαρχει κατι σιγουρο και αξιοπιστο σε apk εκδοση. Παράθεση
suzukis Δημ. November 12, 2015 Δημ. November 12, 2015 Οχι στο pc το τρεχεις, αν και δεν νομιζω οτι υπαρχει κατι σιγουρο και αξιοπιστο σε apk εκδοση. Σε ευχαριστώ. Θα προτιμούσα κάτι σε apk να κάνω την διαδικασία κατ ευθείαν από το τηλέφωνο Παράθεση Το χασαμε το κορμι πατριωτη!!!! [sIGPIC][/sIGPIC]
jpower73 Δημ. November 12, 2015 Δημ. November 12, 2015 αν το τηλέφωνο σου βγαζει sd card corrupted... και τα ρεστα, βγάλτην απο το τηλέφωνο και βαλτην στο πισι.. Μπορεί να εκπλαγείς..!! :p Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
suzukis Δημ. November 12, 2015 Δημ. November 12, 2015 αν το τηλέφωνο σου βγαζει sd card corrupted... και τα ρεστα, βγάλτην απο το τηλέφωνο και βαλτην στο πισι.. Μπορεί να εκπλαγείς..!! :p Δεν μου βγάζει κάποιο πρόβλημα η κάρτα. Απλά διέγραψα κατά λάθος έναν φάκελο με φωτο και θέλω να τις επαναφερω Παράθεση Το χασαμε το κορμι πατριωτη!!!! [sIGPIC][/sIGPIC]
savvas_p25 Δημ. November 12, 2015 Δημ. November 12, 2015 Δεν μου βγάζει κάποιο πρόβλημα η κάρτα. Απλά διέγραψα κατά λάθος έναν φάκελο με φωτο και θέλω να τις επαναφερω Σαν τις εφαρμογές του υπολογιστή δεν έχει αλλά αν θέλεις δοκίμασε απο το playstore (dumpster image & video restore,restore image ) Παράθεση
marras Δημ. November 12, 2015 Δημ. November 12, 2015 Δεν μου βγάζει κάποιο πρόβλημα η κάρτα. Απλά διέγραψα κατά λάθος έναν φάκελο με φωτο και θέλω να τις επαναφερω Όπως είπε και ο Σάββας, δοκίμασε το Dumpster και αν δεν γίνει κάτι, δες το diskdigger. Παράθεση http://www.ibizaclub.gr/lottaria.gr/marras//titans/caliber002.jpg Ευτυχώς που ξέχασα να μεγαλώσω...
klaipelas Δημ. November 12, 2015 Δημ. November 12, 2015 Ενας φιλος μου που εχει jonzalvo v.2 εχει ενα προβλημα στη σελιδα stoiximan.gr εμφανιζει τη σελιδα ετσι http://postimg.org/image/5j4lejyn7/ξερει κανεις πως διορθωνεται; Mηπως με διαγραφη ιστορικου γιατι κατι τετοια εχω δει στο mozilla. Παράθεση Coolpad f1 (Great F1) - AEX MODDED LITE by jpower Leeco Le Max 2 X820 6gb - 64gb (RROS-Q-8.7.3-20210920-x2-20210920) 19/March/2020 by C.B.G.)
jpower73 Δημ. November 12, 2015 Δημ. November 12, 2015 (edited) Να επιλέξει user agent : desktop Αν δεν βοηθήσει, να αλλάξει Browser Ας βάλει Boat browser Εδω σε desktop version http://s16.postimg.org/mqlclp69x/Screenshot_2015_11_12_15_55_08.jpg photo storage Και η ίδια σελίδα σε mobile version (οπως η δική του) http://s12.postimg.org/u1q6nykwd/Screenshot_2015_11_12_15_58_51.jpg Edited November 12, 2015 by jpower73 Παράθεση CoolPad F1 :D Redmi Note 9 Pro 6-128
mixanikosgr Δημ. November 12, 2015 Δημ. November 12, 2015 (edited) boat browser ψηφίζω και γω Για προγράματα undelete σε pc έχω χρησιμοποιήσει και βάλει σε άλλους το recuva, σε τηλέφωνο νομίζω είχα χρησιμοποιήσειτο diskdigger γιατί μια φίλη είχε σβήσει τις φώτο από την εσωτερική και θυμάμαι είχε βρει και όλα τα partitions Edited November 12, 2015 by mixanikosgr Παράθεση
iPap Δημ. November 12, 2015 Δημ. November 12, 2015 Παιδιά ο συγκάτοικός μου ζαχαρώνει το κουλπαντ με 90 λίρες. Τι λέτε;; 140 ευρώ το είχα πάρει Ιούλιο του 14. Παράθεση ZTE Blade, ZTE Nubia Z5s mini, Coolpad F1, Samsung Galaxy S6, OnePlus 5T, Samsung Galaxy S20 5G (SD865), Google Pixel 4a.
Sotirisglns Δημ. November 12, 2015 Δημ. November 12, 2015 Παιδιά ο συγκάτοικός μου ζαχαρώνει το κουλπαντ με 90 λίρες. Τι λέτε;; 140 ευρώ το είχα πάρει Ιούλιο του 14. Χαλαρά. (Όλα έχουν ένα "κοντέρ" )και το δικό σου γράφει ένα χρόνο και κάτι μήνες... Παράθεση
mixanikosgr Δημ. November 12, 2015 Δημ. November 12, 2015 Αν γυρίσουμε σε official 4.4 και ART, δεν θα είμαστε καλυτερα; (εννοείται μετά το καθάρισμα κινέζικων κλπ) Παράθεση
