Τροποποιήσεις / Βελτιώσεις για το Galaxy Nexus (I9250)
sakiss
Ειδα οτι ο συγκεκριμενος kernel exei 3 version Ext, Bigmem, standard. Γνωριζεις τι διαφορα εχουν? Τι προτεινεισ για χρηση?
Standard ('std') version features
Based upon:
latest AOSP kernel source (android-omap-tuna-3.0-jb-mr2)
selected Cyanogenmod patches
continuously updated Linux version (3.0.96)
selected patches from the device's chipset vendor Texas Instruments
selected patches from Google
CPU:
CPU frequencies: 192, 384, 537, 729, 1036, 1228, 1344, 1420, 1536* MHz (default on boot: 192 - 1228; *1536 MHz only in extended version)
control to set a minimum CPU frequency for screen-on (default: 384 MHz)
Will help with smoothness and responsiveness when you use the phone. When screen is off, however, 192 MHz frequency is used as well.
CPU governors: ondemandplus (default; more info), interactive, ondemand, powersave, performance
ondemandplus is an ondemand- and interactive-based governor that has additional power-saving capabilities while maintaining very snappy performance.
ARM CPU topology: multi-core scheduling (enabled by default; saves battery by scheduling load among the CPU cores; more info)
GPU & Display:
GPU frequency control: 307, 384 (default), 512 MHz
color, contrast and gamma contols
sane and natural looking color settings
I/O & memory:
I/O schedulers: SIOplus (default), deadline, noop, row, bfqv5, cfq
updated HSMMC driver (high speed multimedia card; the phone's 'hard drive bus controller' if you will)
tuned LPDDR RAM timings (+10% throughput; more info)
optimized ext4 mountings
Android 3.4 low memory killer
improved memory handling routines (memset, memzero, ...)
Network:
TCP congestion control algorithms: westwood (default), cubic, reno
DTIM skip override (what it is and how it works)
Misc:
timer slack feature (what does it do?)
vibration strength control
battery life extender (BLX)
fast charge
various performance and battery life tweaks
launcher whitelist to make launcher unkillable (what it does and how it works)
init.d support (no matter if the ROM supports it or not)
elevated systemui priority
Fancy Updater App (optional; downloadable from this thread; written by Parthipan Ramesh)
more things... go check the source if you're interested.
compiled with Google GCC 4.7 toolchain (from Android NDK r9)
Extended ('ext') version additional features
sound control (high performance sound, volume boost)
custom voltage control
fsync toggle
temperature control
1536 MHz CPU overclock step
zRAM from 3.7 kernel (with fast LZ4 compression)
module support (for PGM, e.g.)
all features of the std version
BIGMEM ('big') version additional features
BIGMEM (gives you an additional ~65 MB of available RAM; disables 1080p video recording modes, however)
all features of both std and ext version
Προτίνω τον τελευταίο για τα 65 mb επιπλέον ραμ με μόνο συμβιβασμό το ότι χάνεις τα Full HD video capture...σιγά τα αυγά δηλαδή...απλά πριν τον περάσεις γύρνα την κάμερά σου σε 720p.
Edited by Vlasismiriagos
Εγώ δεν μπορω να δω πολυ πανω απο 12500+ με ίδιο setup (stock 4.3 με fancy r43)...κάτι άλλο παιζει...;
Samsung Galaxy S8
LG G4
Asus Transformer T100
Δεν ξερω τι εχει κανει ο boy petersen σε αυτο τον kernel (Fancy Kernel) κ το exei pushareι τοσο, αλλα σε AnTuTu benchmarking με τον Leankernel (default sth SlimBean ROM) εβγαζε μεγιστο γυρω στο 9700 με maxCPU 1300 - interactivex. Εκανα εγκατασταση τον Fancy Kernel r43(ext. version) με maxCPU1344 - ondemandplus κ μου εδωσε 11700. Σημαντικη διαφορα!! :happy:
Αληθεια, εχει default κατωφλι 192ΜΗz (lower CPU), ειναι αρκετα ασφαλες τοσο χαμηλα? Το εχετε δοκιμασει?
LG G6
Μέτρησες με το ίδιο Antutu (έχει βγει η beta 4.0 πλέον, αυτή που ποστάραμε πιο πριν) ? Αν όχι, τότε από εκεί και μόνο προκύπτει τεράστια διαφορά (στο 3 έβγαζα 8500 περίπου, τώρα είμαι με το 4 στο 12500 όπως είδατε πιο πριν). Πέραν κάποιων μικροβελτιώσεων δεν υπάρχουν τρομερές διαφορές μεταξύ καλών kernels (όχι beta ή τίποτα "περίεργες" προσπάθειες).
Και προσωπικά ποτέ δεν το αφήνω στα 192, πάντα βάζω όλα τα min στα 384 για να ξυπνάει και πιο εύκολα/γρήγορα...
Samsung Galaxy S8
LG G4
Και ομως εχω κανει τις μετρησεις το τελευταιο 24ωρο με το ιδιο version AnTuTu
LG G6
Αν μπορείς να δεις και να συγκρίνεις αποτελέσματα, να δούμε ποια υποσυστήματα κάνουν αυτή τη διαφορά, θα ξέρουμε και ποιος kernel "σπρώχνει" ποιο σύστημα καλύτερα (π.χ. υπάρχουν kernels που έχουν το fsync απενεργοποιημένο by default, και άρα βγάζουν ελαφρώς καλύτερα νούμερα στο file i/o). Όπως επίσης ότι kernel με kernel μπορεί να έχουν και διαφορά δεκάδων δευτερολέπτων στο boot. Και σίγουρα μεγάλη διαφορά στα αποτελέσματα έχει και η ROM που έχεις (αυτό που λέμε, ποια ROM κουμπώνει καλύτερα με ποιον kernel)....
Samsung Galaxy S8
LG G4
Το δοκίμασες τελικά;;; τι λέει;;;
Εχει περισσότερες επιλογές από το gravity box. Το δοκίμασα για λίγο το xboost, αλλά δεν με βόλεψε γιατί ήθελε σε κάποιες ρυθμίσεις (όπως αλλαγή χρωμάτων στην status bar) να κάνεις reboot για να εφαρμοστούν. Για μένα είναι πιο λειτουργικό και απλό το gravity box και αυτό θα χρησιμοποιώ.
Καλημερα παιδες. Ειχα βαλει σωστα το στοκ του 4.3 και ολα πηγαιναν κομπλε,μεχρι που ξαφνικα κλεινει το κινητο μονο του.. Δηλαδη εκει που μπορει να ειναι σε αναμονη,σε idle δλδ,παταω να ανοιξει και παρατηρω οτι για καποιο ανεξηγητο λογο το κινητι εχει σβησει τελειως.. Μου το εκανε πανω απο 5 φορες σημερα.. Δοκιμασα με 3 διαφορετικους kernles,και το κανει κανονικα σε ολους :/ Ξερετε τι μπορει να φταιει?
Μήπως έχεις βάλει τώρα τον fancy kernel; αν ναι, ανέβασε την χαμηλότερη συχνότητα γιατί την βάζο στα 192MHz με αποτέλεσμα να μπορεί να μην ανοίγει το τηλέφωνο σε μερικούς...
Ρε παιδια σε stock rom πως βγαζω την μπαρα google που εχει στην αρχικη οθονη;;;
Θα κατεβάσεις κάποιον άλλον launcher απο το play store όπως για παράδειγμα τον Nova Launcher που σου δίνει την δυνατότητα να την αφαιρέσεις.
ΠΡΙΝ. SE XPERIA X1 SILVER
ΥΣΤΕΡΑ. SAMSUNG GALAXY NEXUS
ΤΩΡΑ XIAOMI REDMI NOTE 9 PRO
Οκ...ευχαριστω για την απαντηση,θα το δοκιμασω
Τι σας έχω; Stock kernel 4.3 με ενεργοποιημένο το module για να λειτουργεί το PGM... http://forum.xda-developers.com/devdb/project/dl/?id=885
PGM?
What is PGM?
Ο τροπος να ξυπνας την οθονη χωρις τη χρηση των hardware buttons?
LG G6
PGM?
What is PGM?
Ακριβώς, και όχι μόνο αυτό... Μπορείς με διάφορα gestures να κάνεις κάποιες ενέργειες χωρίς την παραμικρή χρήση hardware buttons... Το μόνο αρνητικό είναι ότι δεν είναι καθόλου battery friendly...
Για να παιζει κατι τετοιο θα πρεπει το κινητο να μην κλεινει εντελως, ποτε. Ναι μεν, το λειτουργικο συστημα εχει κανει shutdown, αλλα πρεπει στο display να υπαρχει διαρκως ταση. Δηλαδη battery drain.
LG G6
Το ξέρω τι γίνεται... Απλά το λέω στα παιδιά γιατί πολύ απλά το τηλέφωνο πολύ δύσκολα θα αγγίζει τις 12-15 ώρες και αυτό γιατί χρησιμοποιούσα το PGM για μια εβδομάδα περίπου...
Φίλε μου το χρησιμοποιώ 1 χρόνο τώρα.η διαφορά στην μπαταρία είναι της τάξης του 0.1-0.2 % (ανά ώρα) παραπάνω.Τίποτα δηλαδή...Ούτε η οθόνη μένει ανοιχτή, ούτε το κινητό δεν κοιμάται ποτέ, όπως είπε κάποιος παραπάνω.το μόνο που κάνει είναι να κρατά τον αισθητήρα αφής σε εγρήγορση, κάτι που πραγματικά ζήτημα είναι αν καταναλώνει 1% με 2% την ημέρα... αν συνηθίσεις με το pgm δεν υπάρχει επιστροφή πάντως να το ξέρετε.Δεν υπάρχει πιο βολικό πράγμα.Δεν είναι τυχαίο που το υιοθέτησε στο G2 η LG και από ότι διαβάζω όχι τόσο επιτυχημένα όσο το pgm.
