[Επίσημο] Εφαρμογές
eLeKtriK EyE
mhpws yparxei tote kapoia allh egarmogh pou na kanei thn idia douleia me to facewarp kai na trexei sto 6670?to facewarp einai apo tis agaphmenes mou efarmoges kai tha hthela opwsdhpote mia paromoia efarmogh gia 6670!kai kati allo,yparxei kamia efarmogh pou na asfalizei ta sms etsi wste na mhn mporoun na ta vlepoun oi alloi???kati san to photosafe as poume...euxaristw prokatavolika! :D
Δεν έχω δοκιμάσει σε 6670, αλλά δοκίμασε το phototwister.Δουλέυει στο 7610 το οποίο έχει 1mp camera :O
Ride fast
Ride hard
Ride home.
ZX6R
  • Απαντήσεις 8,7χιλ.
[New] SimWatcher for Series 60 :lock:
SimWatcher by Denda Mobile Content is a new tool that helps you to get hold of the new mobile number that is used on your phone in case of loss or theft. Just install it on your phone, enter your e-mail address and/or home address. In case of loss or theft the new user of your phone will change the SIM card and that's where SIM Watcher does its job. When the mobile phone is turned on, SIM Watcher automatically checks if the right SIM card is inside the mobile phone. If it is another SIM card, SIM Watcher will send you an e-mail with the mobile phone number of the new user and the IMEI number of your phone. In addition to this, a pop-up window is shown to the new user of the mobile phone every ten minutes, which indicates that the phone belongs to someone else. SIM Watcher will show your name and address, which gives honest people the opportunity to return your phone.
http://my-symbian.com/7650/applications/applications.php?fldAuto=1210&faq=5
[New] BabyMonitor for S60 :baby:
BabyMonitor by OpenBit helps you monitor your baby from a distance. If the baby cries or if any loud sound is produced, the phone will automaticly call you enabling you to hear what is happening. You can call and make sure everything is ok at any time. The phone will respond, activate automatically, without anyone picking up the receiver.
http://my-symbian.com/7650/applications/applications.php?fldAuto=1209&faq=2
[New] Notepad for Series 60 :rtfm:
Notepad by Unteh allows editing text documents on your Series 60 phone. This application has functionality like an ordinary text editor "Notepad" in Windows. It even has a well known Windows XP GUI design. With Notepad you can edit text documents that were created on a stationary PC and copied to mobile phone. Text documents created by Notepad can be transferred to PC.
http://my-symbian.com/7650/applications/applications.php?fldAuto=1211&faq=18
iPhone 5S Space Grey
paidia kalhmera!epsaksa sto irc gia to mumsms++ 4.09 kai to vrhka mono se arabikh glwssa.yparxei se agglika h mhpws psaxnw adika?? an einai na to katevasw sta arabika mpas kai kataferw na kanw tipota...euxaristw! :D
Υπάρχει κανένα πρόγραμμα που να κάνει shutdown το κινητό?
Για shutdown δεν εχω δει κατι παντως restart κανει το appman και το sysman σιγουρα.
Τα ξέρω αυτά τα προγράμματα και όπως λες κάνουν reset, εγώ βασικά ήθελα ένα πρόγραμμα που κλείνει το κινητό γιατί το αφήνω ανοιχτο το βράδυ στο ραδιο και μετά με πέρνει ο ύπνος και το πρωί δεν έχω μπαταρία ήθελα ένα πρόγραμμ που να του λες οτι στις 2 θα κάνεις shutdown το κινητό :O
Δεν νομιζω να υπαρχει κατι τετοιο :( Δεν το εχει παρει πουθενα το ματι μου! :) Παρ'ολα αυτα βεβαια μια τετοια εφαρμογη θα ηταν αρκετα χρησιμη μπορω να πω ;)
B L U E in G R E E N :cool:
Σύντομα θα έχω έτοιμη την ΕΛΛΗΝΙΚΗ έκδοση του MumSMS.....
tha perimenw to post sou...pros to paron xrhsimopoiw thn arabikh :(
to mono pou katafera na kanw einai na epilegw ta sms pou thelw na kleidwnw...kwdikous kai alles rythmiseis den exw kanei giati den katalavainw tpt... :wacko:
Είναι και μία εφαρμογή που λέγεται RESTART.
...μία μέρα, ο Κινέζος Αυτοκράτορας διέταξε τον πρώτο ζωγράφο της αυλής να σβήσει τον καταρράκτη από μία τοιχογραφία του παλατιού, γιατί ο θόρυβος του νερού τον εμπόδιζε να κοιμηθεί...
Regis Debray: Vie et Mort de l' Image
Ε βρε kary κατέβασε κάποια πιο παλιά π.χ την 4.02
hello...kserei kaneis kana programma(player) gia series 60 to opoio na paizei .mpeg videakia?
.mpeg οχι ,αλλα .αvi ναι με το smartmovie.
Περισσοτερα στο αναλογο θεμα
[ΕΠΙΣΗΜΟ] Video Converters & Players: Ποιον από όλους;
Παιδια ποια ειναι αυτον τον καιρο η καλυτερη εφαρμογη για απεριοριστο βιντεο; Πεστε μου και μια εναλλακτικη για παν ενδεχομενο.
Ευχαριστω :)
Ανταλλακτήριο προγνωστικών στοιχήματος ποδοσφαίρου. Από τον παίκτη, για τον παίκτη!
http://www.progno.gr ;)
geia se olous...akousa kai pali gia ena programa pou mporis na douleueis to sinagermo tou autokinitous sou meso tou 6600 kai na eidopiise kiolas oti exi energopiithei...isxii kati tetio???yparxi tetia efarmogi ???
Υπάρχει καμία εφαρμογή που να καθαρίζει τα 'σκουπίδια" από τον c;
"Όποιος ελεύθερα συλλογάται,συλλογάται καλά."Ρήγας Φεραίος"
http://www.myphone.gr/gallery/data/500/9674.jpg
Δεν εχω ακουσει κατι τετοιο! :) Μου φαινετε λιγο δυσκολο, θα πρεπει και στο αυτοκινητο να εχεις καποιο software, hardware που να συνδεετε με το κινητο και να του δινει τις πληροφοριες που πρεπει ;) Ισως με κανενα gps? :)
...'ελα φίλε, για κοίτα το επόμενο (...Cleaning Up -- clearing temp folders and unused system temporal files (with full safety...)
Psiloc Extended FileManager
http://www.symbos.com/live/product_information.php?ApplicationID=412
Και μερικά άλλα ενδιαφέρον!!!
Αν σας λέει η δικια σας οτι δέν σας απατάει και σεις δεν την πιστεύετε, τότε -lie spy- ανιχνευτής ψέμματος... :D
Lie Spy
http://www.symbos.com/live/product_information.php?ApplicationID=304
Λεξικό της Magenta
Greek-English & English-Greek dictionary (Magenta)
http://www.symbos.com/live/product_information.php?ApplicationID=898
*δεν ξέρω αν ειναι συμβατά με το 3230 όμως, πιστεύω πως ναι... :O
παιδια υπαρχει προγραμμα στο 6600 να παιζει τα αρχεια video mpeg?? οσο και αν εψαξα δεν βρηκα κατι. αν το εχει καποιος ας δωσει ενα λινκ η ας μπορει να το στειλει στο louis_gas@hotmail.com
Hello paidia.Loipon apeidi ta exw mperdepsei sas rwtw:Exw kanei tis sxetikes anazitiseis sto forum kai exw pmerdeftei.Thelw mia app pou na mou apeikonizei xarti ths thessalonikis ki as mhn einai gps,diladi thelw na psaksw mia odo kai na mou deixnei pou einai ston xarti.Route,powernavig.,ktl...exw mperdeftei.To ena thelei gps bluetooth receiver,to allo den exei xarti thessalonikis.To mapeditor to exw alla den mporw na ftiaksw diko mou xarti.Exete na mou proteinete tipota pou na me voithisei?Sorry an eimai off topic kai efxaristw ek twn prwterwn gia tixon apantiseis! :D
Αγαπάτε Αλλήλους
Φιλε μου δυστυχως δεν μπορεις να κανεις τιποτα. Για το Route66 δεν υπαρχει χαρτης της Θεσσαλονικης και τα αλλα προγραμματα χρειαζονται και GPS Receiver... :)
http://i39.tinypic.com/ojjlzk.gif
