Samsung 360 H1 & M1
mirrorofsorrow
καλημερα...
Αντιμετωπίζω ένα προβλημα και θα ηθελα την εμπειρια σας....
Προσπαθώ να βάλω στο Μ1 μια κάρτα sim 3G vodafone, και η συμπερηφορα του κινητου είναι η διαδικασία να ξεκινάει νορμαλ, να μου ζητάει το Ριn, και μετά την ειαγωγή του Ριn, να κάνει reset-reboot!!!!!!!! Με κάρτα sim vodafone παλιά δλδ όχι 3G, το κινητό λειτουργεί κανονικα......
Έχετε καμια ιδέα? εχει αντιμετωπίσει κανεις αλλος το ίδιο προβλημα?
  • Απαντήσεις 2,3χιλ.
ΜΟΛΙΣ έκανα update!! :w00t: :w00t:
(κανονικά μέσω pc studio)
BUJA2
BUJC1
Οι αλλαγές:
Please find below the updates included within the new firmware release (C1) for the Vodafone 360 Samsung H1/M1:
Improved email experience
You can now more easily select which email account you want read. The layout of emails has been improved and you can now download the first part of an email. You can also display the full sender email address in the expanded view so it’s easy to see who it’s from.
In addition, many bugs have been fixed in the push mail capability which, together with changes being made on the server side of the service, this should improve the overall reliability of the service.
Improvements to 360 People
Multiple phone numbers and email addresses for your contacts will now be shown within the Contact view making it easier for you to choose how to communicate with your contacts.
There is now a bigger end call button with an easier to use experience. The end call button is red so that you can identify this button easier. A long press on the right Apps hardkey will also end the call.
There is a new manual sync button in the command bar within ‘Settings/ Vodafone 360 settings’. Tap the sync button and your phone and your 360 web account will communicate with each other making sure all of your information is up to date.
Improved photos experience
You can now easily edit the name of a picture when in camera or gallery mode. You're also provided with the option to edit a picture name and comments when uploading to social networking sites.
Improved maps experience
Shared points of interest on the map are turned off as the default but you have the option to turn them back on if required. Placemarks will also be shown but only from friends connected to you on Vodafone 360.
On the map there are now fixed +/- zoom buttons making it easier for you to enlarge/reduce the size of the map when you need to.
Customised Alert Tones
You will be able to customise your Message, Email, Chat & Event alert tones for each profile and you can select a custom MP3 file for any of these in addition to the ones provided.
Other improvements
The responsiveness of the touch screen has been improved making it a much better experience and quicker!
There is a simplified incoming call lock screen. The direction in which the slider is moved to reject a call has changed so that you don’t accidentally reject a call.
You can now set customise your background on the locked screen with wallpapers. You can choose one of the default wallpapers or select one of your own from your photos or even download something else.
The keyboard has a simpler layout to make it easier to use - a long press on the space bar brings up the punctuation characters. Also lower case characters are now shown on the keyboard when you choose this option.
Edited by Arxegonos
Συγνώμη που θα σας απογοητεύω, αλλά αυτό το firmware είχε βγει το Μάρτιο, και το έχω από τότε που αγόρασα το κινητό.
χαχαχαχ
Για εμενα είναι νεο ομως!!!!!! και ευχαριστες αυτες οι αλλαγες!
εχει τιποτε αλλο νεο, που δεν προλλαβα να εντοπισω? για βοηθα εσυ που το δουλευεις τοσο καιρο, tnslack....
Edited by mirrorofsorrow
Συνένωση μηνυμάτων. Χρησιμοποίησε το πλήκτρο Τροποποίηση.
Βγήκε αλλά το απέσυραν λόγω bugs
δηλαδη εγω τωρα θα εχω bugs και εσεις οχι?
Νέο είναι ότι, όταν είσαι συνδεδεμένος στο wifi ότι εφαρμογή και να ανοίξεις συνδέετε μέσο wifi και δεν ενεργοποιείτε το GPRS Δεν ξέρω αν ήταν έτσι και από την αρχή Και τα υπόλοιπα έτσι όπως γράφει πιο πάνο ο φίλος
xaxaxax kane tin nea anaba8misi kai esu!!!!!
Η αλήθεια είναι ότι δεν μπορώ να κάνω εγώ αναβάθμιση, πρέπει να γυρίσω πίσω στι παλιά firmware και μετά να κάνω.. :D
Με τα sms ??? υπαρχει προβλημα ακομα ????
Προσωπικά ποτέ δεν είχα πρόβλημα με τα μηνύματα αλλα απότι διάβασα ήταν ένας λόγος που απέσυραν το update αυτό.
Πια η διαφορά άραγε με το δικό σας και με το δικό μου firmware?
όποια και να είναι η διαφορά εσύ δε μπορείς να κάνεις update και να βάλεις το καινούργιο;
Αν πάρω το κινητό τώρα θα έχει το νέο λογισμικό ή θα πρέπει να κάνω update;
Απο καμία μέχρι κάτι λίγα υποθέτω. Μικρο-κολλήματα πχ που ίσως διαπιστώσεις στην πορεία κ δεν τα έχουμε εμείς.
Θα κάνεις αναβάθμιση
Καλησπερα παιδια , να ρωτησω εγω εχω κανει φλασαρισμα και εχω την
phone i8320BUJA2 , pda i8320BUJB3 kai csc i8320VGRIJ4 και θελω να παω στην i8320BUJC1 ξερετε αν θα εχω καποιο προβλημα με την συσκευη????
Αν ειναι να μην προχωρησω στην αλλη εκδοση.
Unbox Your Phone
γεια σας και παλι φιλοι μ. εγω εχω το Μ1 μηπως γνωριζει καποιοσ αν υπαρχει καμια διαθεσιμη αναβαθμιση και αν ναι πωσ θα την βαλω. σας ευχαριστω πολυ
Η αναβάθμιση ανέβηκε σήμερα και την κάνεις μέσω του pc studio.
σε ευχαριστω πολυ φιλε μ αλλα μολισ μπηκα και δεν εχει τιποτα
Ούτε εμένα μου δείχνει κάτι για Μ1. Άσε που συνδέεται όποτε θέλει. Κάποιες φορές μου βγάζει και σφάλμα και με ρωτάει αν θέλω να σταλούν οι πληροφορίες στη samsung. Αυτό συμβαίνει τόσο σε XP όσο και σε Vista. Edited by np60s
OK η αναβάθμιση τα σπάει!
Πολύ καλή δουλειά! :yahoo:
Αφορά H1 όμως, επομένως το M1 δε θα δει κάτι στο PCStudio.
Τι να πώ ρε παιδιά , ότι έγραψα σε αυτό μου το πόστ το πήρα απο το forum του 360 και αναφέρει την έκδοση που κατεβάσαμε και λεει Η1/Μ1..
Απο εκεί και πέρα...:what:
Για νέο λογισμικό ακούω. Δοκίμασε κανείς τι γίνεται με την αναφορά μυνημάτων με τη νέα έκδοση;
Μια ερώτηση, γιατί δεν το διευκρινίζει κατά την αναβάθμιση. Πριν και μετά την αναβάθμιση πρέπει να απενεργοποιήσεις την συσκευή και να βγάλεις και βάλεις την μπαταρία, όπως γίνεται με τα SONY ERICSSON; Στο PC SUITE που έδινε η SONY ERICSSON το έγραφε σαφώς. Στο PC STUDIO δεν αναφέρει κάτι για αυτό.
παιδια με ποιο pc suite μπορω να κανω αναβαθμιση? (H1 εχω!)
Device : Samsung Galaxy 3 (GT I5801)
Rom : Kyrillos' ROM v10 GWK74 beta
Kernel : CM7-kernel 1.3 H.V.
Min Freq: 83Mhz, Max Freq:1200Mhz
Init.d Scripts: Supercharger Storage Method Used: Hybrid Data2SD
Παιδιά παρουσιάζεται συνεχώς το εξής. Πάω στο PC STUDIO αναγνωρίζει κανονικά τη συσκευή μου, πατάω στο εικονιδιο για ενημέρωση, πάω στην ενημέρωση συσκευής και επιλέγω το κινητό μου. Τότε αρχίζει να κάνει αναζήτηση και μετά απο 2-3 δευτερόλεπτα μου βγάζει: Αποτυχία σύνδεσης με το διακομιστή. Δε μπορεί να συνεχιστεί η ενημέρωση.
Δοκίμασα να το κάνω απο δυο υπολογιστές που έχω έναν με WIN XP και ο άλλος με VISTA. Και στους δύο τα ίδια. Μα τι συμβαίνει;
Θυμάμαι και στην προηγούμενη αναβάθμιση που έκανα μερικές βδομάδες πρίν όταν πήρα τη συσκευή μου έκανε πάλι τέτοια κόλπα, και εντελώς ξαφνικά μια στιγμή συνδέθηκε και μου έκανε την αναβάθμιση τότε. Τι μπορώ να κάνω ξέρει κανείς;
Όχι δεν χρειάζεται να κάνεις τπτ
Samsung New pc studio. Όταν συνδέεις το κινητό με τον υπολογιστή έχεις επιλογή να το κάνεις εγκατάσταση Η το κατεβάζεις από εδώ
Θα συνεχίσεις μέχρι να ξεκολλήσει, εγώ το παθαίνω συνέχεια στα win7
καλημερα...
