Linux: the power of a penguin
VaradeRo
Αρχικό Μήνυμα από το μέλος Epilas (28 Ιούλ. 2004 , 23:08)
Paidia gia na ipostirikso to file Belerefonti tha sas pw thn empeiria mou em mandrake,San kirios loipon katevasa ta cd ths kai ekana thn egatastash.Prwta sto home pc mou kai meta sto laptop mou (anathema me ithela kai 2h prospatheia).To home pc arxise ta provlimata thn 4h mera to laptop (viastiko) th 2h.Prwth fora sth zwh mou eida linux na kollaei.Freeze,kollhse,stuck san ta Windows XP pou eginan toso "teleia" pou kataferan na kollane xwris mple othones!!!Ti na pw.San na mhn eftane omws afto mesa se dio meres sto amoiro to laptop mou skaei to xfree86.Paei to GUI mou.O KDE nekros.To gnome to idio.Ola.Khdeia to forhto!!!Paw kai egw o kakomoiris me ligi voithia apo ton Belrefonti na dwsw kana dio entoles bas kai strwsei.MPAAAAAAAAAAA!!!!bash:command not found!!!!Kai den milame gia thiria entoles.Apla pramata.Telos pantwn ayto pou thelw na katalikse einai MAKRIA apo th mandrake.Prospathisan na thn kanoun toso filiki pou thn kanane xali.Adinami kai entelws mh praktiki.Einai san na exw mia lamborghini sto garage mou kai na ths exw foresei to 1,2 moteraki tou fiesta mou.E den paei re file.Den paei.Nai kai egw thelw to linux se pio pollous xrhstes oxi omws xanontas th mageia tou.Mh trelathoume i kira fwfw pou mpainei sto internetgia sintages den tha valei pote linux.Oute h ksanthia gramateas pou ftiaxnei keimenakia sto word kai kamia prothesi den exw na prosvalw kanenan.APla to Linux einai ena leitourgiko sistima gia experienced kai power users.Afta eixa na pw.Kratithite makria apo th mandrake.Katastrefei to agno pnevma tou Linux( ti wraia pou ta lew e?)Rwthste to filo Belerefonti ti na valete.Aftos ta exei dokimasei ola kai tha sa spei.Ega pantws toin akousa evala SLackware kai vrhka thn ygeia mou.A kai den eimai experienced use sto linux.Nai.Na mathoumeto Linux.Oxi kati pou moiazei me Linux.
Δεν μπορω να καταλάβω για ποιον λόγο γενικέυεις την συζήτηση, και δίνεις μάλιστα και συμβουλές "προς αποφυγείν", ορμώμενος απο ένα δικό σου πρόβλημα!!! "ayto pou thelw na katalikse einai MAKRIA apo th mandrake.Prospathisan na thn kanoun toso filiki pou thn kanane xali.Adinami kai entelws mh praktiki.Einai san na exw mia lamborghini sto garage mou kai na ths exw foresei to 1,2 moteraki tou fiesta mou.E den paei re file.Den paei." Εγώ χρησιμοποιώ Mandrake 2 μήνες τώρα (γιατι είμαι νέος χρήστης του linux) και δεν μου έχουν κρασάρει ούτε μια φορά!!! Ούτε μου παρουσίασαν ποτέ πρόβλημα ασυμβατότητας σε κάτι. Τώρα για πιο λόγο σε εσένα κολλάνε κ στο desktop και στο laptop... αυτό μόνο εσύ μπορεις να το ξέρεις, και το "άστρο" σου. Αλλα θεωρώ ανεπίτρεπτο (γενικότερα μιλάω όχι μόνο για την δική σου παρατήρηση) μέσα απο ένα προσωπικό πρόβλημα του καθενός (που δεν ξέρεις αν το αντιμετωπίζει ο άλλος ή ο παράλλος) να καθοδηγείς τον χρήστη που διαβάζει το forum σε λανθασμένες εντυπώσεις!!! Είναι σαν να τρώς ένα μήλο, κ επειδή βρήκες ένα σκουλικάκι να βγαίνεις στους δρόμους κ να διαδηλώνεις ενάντια στα μήλα!!!
Αρχικό Μήνυμα από το μέλος Belerefontis (28 Ιούλ. 2004 , 22:50)
Μα τί έχουμε πάθει όλοι με το Μανδράκη ρε παιδειά ?Προσωπικά πιστεύω οτι είναι μία απο τις διανομές που σκοτώνει το Λίνουξ πιό πολύ απο οποιαδήποτε άλλη καθότι έχει πλέον θυσιάσει την παραμετροποίηση και τις δυνατότητες του Λίνουξ για χάρη της εμφάνισης και της εύκολης λύσης.Όχι οτι λεχω βέβαια κάτι με τα παιδιά που την υποστηρίζουν αλλα πιστεύω πώς θα έπρεπε να αναθεωρήσει λίγο την άποψή της επι του Λίνουξ η εν λόγω εταιρεία. :(
Οι δυο εκδοσεις που μένουν πιό πιστές στο θέμα του Λίνουξ κατ'εμέ είναι οι Debian και Slackware.
Αυτό είναι φίλε Βελερεφόντη το μεγάλο μειωνέκτιμα αλλα και το αδύνατο σημείο του Linux, ενάντια στην παντοκρατορία της Microsoft. Οτι ΔΕΝ υπάρχει μια βασική διοίκηση, που θα οδηγήσει και θα αναπτύξει του Linux. Η 100% παραμετροποίηση του λειτουργικού, που είναι ένα απο τα μεγαλύτερα πλεονεκτίματά του, είναι παράλληλα κ μεγάλο μειωνέκτιμα, διοτι έδωσε τροφή για έρευνα σε ομάδες προγραμματιστών, δίνοντας (η κάθε ομάδα) την δική της απόχρωση στο εν λόγω λειτουργικό. Γι'αυτό άλλωστε έχουμε τόσες πολλές διανομές, και ο καθένας μας, έμπειρος ή άπειρος, νέος ή παλιός, να επιλέξει εκείνει που πραγματικά θα τον "βοηθήσει"!!! Δεν θα ήταν πολύ όμορφο όμως να υπήρχε μια κεντρική διοίκηση, που θα ήταν πιο πάνω απο την Mandrake, την Suse, την Redhat, την Debian, την Slak και όλες τις υπόλοιπες διανομές, οπου σαν σκοπό θα είχε να αντλήσει τις τεχνολογικές καινοτομίες του λογισμικού, και να δημιουργήσει 1 και μοναδική έκδοση? Μπορει ναι!!! Μπορει κ όχι!!!
  • Απαντήσεις 3χιλ.
Αρχικό Μήνυμα από το μέλος ng78 ( 2 Αύγ. 2004 , 03:41)
Αφού αποσυνδεθείς από το Internet, πάτησε Alt+F2 και κάνε paste την εντολή:
kdesu kwrite /etc/ppp/options
ή ειδικά αν έχεις το Knoppel:
sudo kwrite /etc/ppp/options
(έτσι ανοίγει το configuration file του ppp)
Bρες τις γραμμές:
lcp-echo-interval 30
lcp-echo-failure 4
και σβήσε τις τελείως. Αυτό διορθώνει πάρα πολλά προβλήματα με το pppd σε διάφορες διανομές.
kai ego exo provlima me to mou sta fedira core 2...enonete to modem omos den annigi kamia selida vasika poupote den enonete...afto pou egrapses 8a lisi to provlima sigoura?
btw exo akoma 1 provlima sxetika me tin entoli nmap..xrisimopio ta fedora core 1 (2.4.22-1.2115.nptl) kai opote enonoume me root kai xrisimopio tin entoli nmap anti na mou leei pia ports exi annixta ekino to ip pou tou vazo na kani scan leei mou
Note: Host seems down. If it is really up, but blocking our ping probes, try -P0
Nmap run completed -- 1 IP address (0 hosts up) scanned in 1.954 seconds
3erete y? na kamo update to kernel? i na valo fedora core 2 an sigoura linete to provlima me to modem?
Αρχικό Μήνυμα από το μέλος eXecrable (10 Αύγ. 2004 , 14:39)
Euxaristw poly file! Mono na rwtisw kai kati allo... Pws an kanw etsi egatastasi tha mporw na epilegw poio leitourgiko na bootarw (knoppix i WinXp)?
Ginetai?
(+carma PropheT) ;)
Αν και λογικά θα το έχεις βρει και μόνος σου πλέον, ο knoppix-installer βάζει αυτόματα το LILO (Linux Loader - βασικά σε ρωτάει άμα θες να τον βάλεις :p), ο οποιος αναλαμβάνει να σε ρωτάει κάθε φορά που ξεκινάει το PC σου ποιο λειτουργικό θέλεις να ξεκινήσεις.
Sorry που άργησα τόσες μέρες να σου απαντήσω, για κάποιο άγνωστο λόγο μου διέφυγε το post σου... (χαζομάρα μου δηλαδή αλλά τέλοςπάντων).
edit: όπως επίσης δεν είδα ότι σου απάντησε ο φίλος ng78. :p
Αρχικό Μήνυμα από το μέλος SyS_V|rUS (23 Αύγ. 2004 , 13:10)
Παράθεση
Όπως σου λέει και το ίδιο το πρόγραμμα, το μηχάνημα που προσπαθείς να σκανάρεις δεν απαντάει στο ping. Εφόσον ξέρεις ότι το μηχάνημα είναι όντως εκεί, βάλε την παράμετρο -P0 . Επίσης δοκίμασε να παίξεις και με τις υπόλοιπες επιλογές του nmap και κυρίως με την μέθοδο που χρησιμοποιείς για να κάνεις scan.
Βέβαια δεν είναι απαραίτητο να βρεις ανοιχτές πόρτες σε ένα PC... :whistle: :!: :cool:
nai to 3ero....dokimasa kai me to -P0 alla den ginete tpt..a kai kati allo..otan den ime sto root doulevi mia xara..omos den doulevoun oles oi epiloges otan den ise se root
Αρχικό Μήνυμα από το μέλος SyS_V|rUS (23 Αύγ. 2004 , 16:56)
pedia epidi ime arxarios sta linux 8a itan kala na goraso kanena vivlio? kai pio vivlio mou protinete na goraso? i na mou pite kanena link kamiou kalou ebook gia na to katevaso....
Δοκίμασε εδώ : http://users.hol.gr/~nemesis/Linux_Newbie_Administrator_Guide.doc
Απο εδώ διαβάζω κ εγώ...!!!
Αρχικό Μήνυμα από το μέλος SyS_V|rUS (23 Αύγ. 2004 , 13:35)
Μμμ.. Τότε κάτι παίζει με το Stealth TCP Scan που κάνει από default το nmap όταν είσαι root ( -sS ). Δοκίμασε να βάλεις κάποια άλλη μέθοδο ανίχνευσης.
thx jimpanourgias...8a diavazo kai ego apo eki..
PropheT molis pato enter mou vgazi oti ine down...eno otan den ime root otan patiso enter perna sxedon 1 lepto kai mou efanizi pia port ine annixta...ivra tutorials gia to nmap...8a ta diavaso...elpizo na leei tpt gia to provlima pou exo..
Αρχικό Μήνυμα από το μέλος SyS_V|rUS (23 Αύγ. 2004 , 18:03)
Δοκίμασε αυτή την εντολή σαν root:
nmap -sT -P0 -O -p 1-1024 -T Normal xxx.yyy.zzz.vvv
Όπου xxx.yyy.zzz.vvv το IP που θες να scanάρεις :whistle:
Αν βαριέσαι να περιμένεις (γιατί 1024 ports με normal speed θα κάνουν πολλή ώρα) μπορείς να μειώσεις το range (πχ -p 1-256) ή να αυξήσεις την ταχύτητα σε Aggressive ή Insane (πχ -T Aggressive), αλλά γενικά θέλει προσοχή που θα κάνεις scan.
Αρχικό Μήνυμα από το μέλος SyS_V|rUS (23 Αύγ. 2004 , 18:35)
PropheT thx doulevi telia...:D y omos 8eli prosoxi otan kamno scan???
exo kai mia alli erotisi...pos mporo na kliso kapia ports pou exo annixta?
Θέλει προσοχή γιατί άμα κάνεις scan μηχανήματα εταιριών μπορεί να σε πάρουν πρέφα. Γενικά δεν σε κυνηγάνε, αλλά πρόσεχε εσύ καλού-κακού.
Ports στο linux μπορείς να κλείσεις με τον "δύσκολο" τρόπο χρησιμοποιώντας το iptables (iptables tutorial - Θέλει διάβασμα)
ή με τον "εύκολο" τρόπο χρησιμοποιώντας ένα "firewall" (ή αλλιώς ένα front-end για το iptables):
Firestarter Firewall
Shorewall Firewall
:happy:
Αρχικό Μήνυμα από το μέλος SyS_V|rUS (23 Αύγ. 2004 , 19:13)
ok euxaristo kai pali...8a dokimaso ton diskolo tropo...y me ta diskola ma8ennis pio polla kai pio xrisima pramata..
Ωραίος... :happy:
Παρακαλώ :o
Αρχικό Μήνυμα από το μέλος jimpanourgias (23 Αύγ. 2004 , 02:01)
Κι εγώ χρησιμοποιώ το Mandrake 3 χρόνια τώρα και μάλιστα εδώ και 2 μήνες αφαίρεσα εντελώς τα Windows από τα PC μου και δουλεύω μόνο Mandrake Linux.
Προβλήματα δημιουργούνται στο Linux αν έχεις τα Windows στον ίδιο σκληρό δίσκο και τρέξεις κάποιον defragmenter μέσα από τα Windows. Γενικά κατά τη συνύπαρξη Windows-Linux στο ίδιο PC, τα Windows έχουν μια τάση -αργά ή γρήγορα- να καταστρέφουν το Linux (LILO κ.ά.).
Επειδή λοιπόν τα δύο λειτουργικά στην πραγματικότητα δεν μπορούν να συνυπάρξουν στον ίδιο δίσκο χωρίς προβλήματα, είχα να επιλέξω μεταξύ Windows και Linux και φυσικά επέλεξα Linux.
this signature is under heavy construction
αν και συχνα πυκνα κανω φορματ κι επανεγκαταστασεις, δεν αντιμετωπισα ποτε προβλημα με τη συνυπαρξη win και λινουξ (αναγκαστικη συνυπαρξη γιατι χρειαζομαι τα win για τη δουλεια). Τα τελευταια τεσσερα χρονια (μπορει και παραπανω) δουλευω και με τα δυο λειτουργικα (κυριως το λινουξ και σπανια τα win) χωρις προβλημα.
http://briefcase.pathfinder.gr/download/princessofthedawn/11956/308444/0/101_0139.jpg
Lord, let me be the person my dog thinks I am
anni3e to terminal kai grapse su - gia na ginis root
meta grapse gedit kai 8a anni3ei ena text editor sto text editor grapse
boot=/dev/hda
map=/boot/map
install=/boot/boot.b
prompt
timeout=30
lba32
default=linux
#ta xxx na ta antikatastisis me to version tou kernel pou exis
#mporis na grapsis uname -r sto terminal gia na dis to version
image=/boot/vmlinuz-xxx
label=linux
initrd=/boot/initrd-xxx.img
read-only
append="root=LABEL=/"
meta na to kamis save to file sto /etc/ me onoma lilo.conf
otan klisis to gedit na grapsis sto terminal /sbin/lilo kai 8a sou grapsi "Added linux *" kai tora 8a annigi sta linux...kai mporis na kamis format ta windows...
an ennoeis na kamis format ta win kai na ta 3anavalis tote sto file pou sou ipa na kanis anti na valis boot=/dev/hda na antikatastisis to hda me to partition pou einai to /boot px hda2 otan kamis save to lilo.conf na grapsis sto terminal /sbin/lilo kai meta na grapsis
dd if=/dev/xxx of=/lnxsct.bin bs=512 count=1
sto xxx na valis to partition pou ine to /boot kai meta na paris mia disketta kai na grapsis sto terminal
mount /dev/fd0
cp /lnxsct.bin /mnt/floppy
umount /dev/fd0
a kai kane kai mia boot disk gia ta linux..an sivmi kati na mporis na mpis sta linux
otan kanis format ta win kai ta 3anavalis tote na kanis copy to file lnxsct.bin apo tin disketta ston c:\ kai meta pigenne start --> run kai na grapsis
notepad c:\boot.ini
kai na simplirosis sto telos tou file C:\lnxsct.bin="Linux"
px des to diko mou boot.ini
[boot loader]
timeout=30
default=C:\lnxsct.bin
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
sto default mporis na valis pio na kani boot apo mono tou...an perasou ta secs exi sto timeout na mpi aftomata sta linux i sta win....
otan to kamis save..tote 8a ine mia xara...kai kamnis boot apo to ntldr...
an exis kamia aporia pemou....
καλημερα παιδια,
θα ηθελα αν ξερετε να μου προτεινετε κανενα καλο βιβλιο για linux(για αρχαριους που σκοπευουν να ασχολθουν με το θεμα ομως..)επισης θελω να βαλλω linux αλλα δεν ξερω τι παιζει με το μοντεμ (alcatel speedtouch 510 ethernet......Ευχαριστω
ALWAYS FEAR OF A GOOD SNIPER, UNLESS YOU ENCOUNTER HIM FROM BEHIND
(CS RULES)
Αρχικό Μήνυμα από το μέλος SyS_V|rUS (24 Αύγ. 2004 , 11:14)
pedia den ivra akoma tropo na mporo na grafo kai sta ellinika...parolo pou protimo ta greeklish...mporite na mou pite pos?
Ο πιο απλός τρόπος για να γράφεις ελληνικά στο γραφικό περιβάλλον είναι να προσθέσεις 2 γραμμές στο /usr/X11/XF86Config (μερικές φορές υπάρχει και ως XF86Config-4, αν το έχεις αυτό να αλλάξεις).
Βρες το σημείο που ξεκινάει κάπως έτσι:
Section "InputDevice"
       Identifier      "Generic Keyboard"
       Driver          "keyboard"
       Option          "CoreKeyboard"
       Option          "XkbRules"      "xfree86"
       Option          "XkbModel"      "pc104"
       Option          "XkbLayout"     "us"
EndSection
και άλλαξε/πρόσθεσε τις παρακάτω 2 γραμμές πριν το EndSection:
       Option          "XkbLayout"     "us,el(extended)"
       Option          "XkbOptions"    "grp:alt_shift_toggle,grp_led:scroll"
Κάνε restart τον X-Server και θα μπορείς να αλλάζεις από αγγλικά σε ελληνικά και το αντίστροφο με alt-shift. :)
efxaristo para poli PropheT
parakalo eXecrable...makari na imoun korifi...akoma exo polla na ma8o..ime arxarios sta linux...exi peripou 1-2 evdomades pou ta evala...omos evala stoxo na gino korifi sta linux...makari na ta katafero...
pedia exo 1 provlima sxetika me to printer....den mou tiponi ellinika...egrapsa diaforous aglikous xaraktires kai diaforous ellinikous sto gedit..kai patisa print kai mou ekane print mono tous aglikous xaraktires...opou ixe ellinika afine keno...pls help..
a kai mia aporia...pos mporo ena partition (/dev/hdb1) na ton kamo na ginete automount apote annigoun ta linux? epidi vargieme ka8e fora pou annigoun ta linux na ton kamno mount...
