cicilianos Δημ. October 31, 2007 Δημ. October 31, 2007 Ante na to ferei h Bonta....na to dw kai giauto tha perimenw ligaki.Paideia mhpws to exei stis suskeues tou mellontos? Παράθεση ΘΑΣΟΣ το σμαραγδενιο νησι! http://www.myphone.gr/gallery/data/500/12161p_goldenbeach1.JPG
volcom Δημ. November 1, 2007 Δημ. November 1, 2007 guys...an pa8ei vlavi to x800 pou to kanoun episkeui??sto plaisio??..ta promi8eute kanenas apo edw stn ellada germanos-wind-plaisio?? Παράθεση
djdog Δημ. November 1, 2007 Δημ. November 1, 2007 To X800 και γενικα ΟΛΑ τα ΕΤΕΝ τα φερνει κατα αποκλειστικοτητα το Πλαισιο. Δεν πουλιουνται σε κανενα αλλο καταστημα..Ουτε Vodaphone ουτε Wind ουτε Γερμανο.. Αν αγοραστει απο Ελλαδα,το σερβις ειναι στη Γερμανια..Το πας στο Πλαισιο και αυτοι το στελνουν εξω...(20-25 μερες κανει συνηθως);) Παράθεση "Earth has its boundaries, but human stupidity is limitless” Gustave Flaubert
UnReaL Δημ. November 3, 2007 Δημ. November 3, 2007 Introducing the new improved Mobile Shell Starting with the X800, E-TEN has begun bundling an exclusive Today screen plug-in based on the multi-award winning Spb Mobile Shell. Mobile Shell puts your most used applications, system tools, and contacts right at your finger-tips while also providing world time and local weather forecasts for added convenience. Taking a close look at Mobile shell: ◆Home tab Tap the battery icon (which serves a double purpose allowing you to check your Glofiish's remaining battery power at a glance) to reveal a list of your most frequently used applications. Smart algorithms dynamically adjust the displayed applications based on your usage, but you also have the option to 'pin' applications on to the list so they are always available. ◆Time tab Tapping the clock icon reveals the date and time in up to three customizable cities from around the world, ideal for frequent travelers. Additionally, information of the next alarm is displayed, and if you want to set a new alarm simply tapping once more takes you directly to the control panel, helping you to save time! ◆Weather tab The weather icon dynamically changes to reflect the current weather and single tap expands the tab to reveal a four-day forecast including weather conditions and temperatures. Forecasts are available for most major cities around the world and are updated automatically (or on demand) whenever your Glofiish is connected to the internet. ◆Photo speed dial tab Add your five most frequently dialed contacts to the photo speed dial list so you have a quick and easy way to call them in the future. ◆QuickBar In addition to the new Mobile Shell which gives you instant access to your most used applications and information from the Today screen, E-TEN is also pleased to introduce QuickBar, a handy utility which provides shortcuts to commonly used system utilities, from inside any application. Simply pressing the QuickBar hot key brings up the QuickBar overly which lets you switch screen orientation, check wireless settings and more, instantly. Παράθεση
UnReaL Δημ. November 3, 2007 Δημ. November 3, 2007 Ακόμα δύο εικόνες. Είναι παράθεση από το newsletter της ΕΤΕΝ. Παράθεση
johner Δημ. November 3, 2007 Δημ. November 3, 2007 To κλασικό spb shell, δεν έχει κάτι νέο. Πάντως αρκετά καλό που το ενσωμάτωσαν. Παράθεση
NLS Δημ. November 3, 2007 Δημ. November 3, 2007 όχι αρκετά καλό, σούπερ κίνηση και μετά αρχίζεις και κολλάς την αρρώστια να βάλεις ότι έχει φτιάξει η SPB (που δένουν μεταξύ τους) Παράθεση --- NLS ilogic.gr
stevezos2_1 Δημ. November 3, 2007 Δημ. November 3, 2007 einai fovero to til.to eixa parei gia ena diastima kai pragmatika petaei.. Παράθεση
NLS Δημ. November 3, 2007 Δημ. November 3, 2007 τι εννοείς το είχες πάρει για ένα διάστημα; Παράθεση --- NLS ilogic.gr
spoilt Δημ. November 5, 2007 Δημ. November 5, 2007 re paidia kana neo apo to teras....... Παράθεση [sIGPIC][/sIGPIC] MY HPI RS4 3.........
NLS Δημ. November 5, 2007 Δημ. November 5, 2007 έξω μόλις κυκλοφόρησε έμαθα αλλά δεν είναι πια τόσο τέρας (εφόσον είπαν για το M800 και εφόσον έρχεται και το 9502) Παράθεση --- NLS ilogic.gr
keltonas Δημ. November 5, 2007 Δημ. November 5, 2007 ΑΠΟ ΠΛΑΙΣΙΟ ΜΕΤΑ ΑΠΟ ΤΗΛΕΦΩΝΙΚΗ ΕΠΙΚΟΙΝΩΝΙΑ ΜΟΥ ΕΙΠΑΝ ΟΤΙ ΘΑ ΤΟ ΕΧΟΥΝ ΔΙΑΘΕΣΙΜΟ ΜΕΣΑ ΝΟΕΜΒΡΙΟΥ ΚΑΙ ΤΙΜΗ ΓΥΡΩ ΣΤΑ 699Ε Παράθεση
karagiozis10 Δημ. November 6, 2007 Δημ. November 6, 2007 Ρε σεις, σε μηχάνημα που ψάχνει τη χαμένη του μνήμη, είναι σοβαρό να ενσωματώσεις το spb shell ? :lol: Παράθεση Πουθενά δεν αξιοποιείται τόσο πολύ το χρήμα, όσο μέσα στα σώβρακα των ανθρώπων :lol:
NLS Δημ. November 6, 2007 Δημ. November 6, 2007 είμαι σίγουρος ότι το έχουν υπόψη οι ίδιοι το τι μπορούν και τι δεν μπορούν να βάλουν Παράθεση --- NLS ilogic.gr
UnReaL Δημ. November 6, 2007 Δημ. November 6, 2007 Ακόμη ένα review http://www.etenblog.com/2007/11/02/first-review-of-eten-glofiish-x800-by-our-reader/ είναι στα αρχικά στάδια ακόμα, αλλά το ανανεώνει συνεχώς. Παράθεση
gre Δημ. November 6, 2007 Δημ. November 6, 2007 Γράφει βίντεο η κάμερα του; και αν ναι σε τι ανάλυση; Παράθεση
NLS Δημ. November 6, 2007 Δημ. November 6, 2007 βέβαια γράφει - νομίζω VGA αλλά αυτά είναι λεπτομέρειες ρε παιδιά - θα μας τρελάνετε (τα κακά του να μπήκε το PocketPC στο χώρο της κινητής) Παράθεση --- NLS ilogic.gr
johner Δημ. November 7, 2007 Δημ. November 7, 2007 Kατοπιν παραγγελίας στο play247. €575,96 Διαθέσιμο σε 2 μέρες από expansys.€549.95 Παράθεση
Administrators athanaso77 Δημ. November 7, 2007 Administrators Δημ. November 7, 2007 βέβαια γράφει - νομίζω VGA QVGA (320 x 240) Παράθεση
gre Δημ. November 7, 2007 Δημ. November 7, 2007 αλλά αυτά είναι λεπτομέρειες ρε παιδιά - θα μας τρελάνετε (τα κακά του να μπήκε το PocketPC στο χώρο της κινητής) Δεν είναι κακό, ούτε απλές λεπτομέρειες. Eίναι πιθανός αντικαταστάτης του κινητού μου(w800) οπότε κοιτάζω και τις λεπτομέρειες αφού το βλέπω και σαν κινητό. Αν κάνω αυτή την αλλαγή(από το W800 που είναι κινητό, στο ΕΤΕΝ Χ800) υπάρχει κατι που δεν θα μου αρέσει; Για πείτε μου όσοι έχετε κάνει αυτή την αλλαγή. Έχει κάποιο μειονέκτημα ή κάτι που δεν κάνει σε σχέση με τα κινητά; Παράθεση
NLS Δημ. November 7, 2007 Δημ. November 7, 2007 αν δεν έχεις ξανα-ασχοληθεί με WM πλατφόρμα, θα σε ξενίσει όσο και αν έχει προσπαθήσει η MS, το WM παραμένει πρώτα OS για PDA και μετά OS για κινητό (και κατά τους παλιούς PocketPCάδες ΚΑΛΟ ΑΥΤΟ, κατά όλους τους άλλους, ίσως κακό) είσαι σίγουρος; Παράθεση --- NLS ilogic.gr
sTavr0z Δημ. November 10, 2007 Δημ. November 10, 2007 παιδια σημερα πηγα σε wind . 600 ευρω το x800.Πολυ καλη τιμη τελικα και με επιδοτηση παει κατω στα 450 σε εμενα!!Καλα που δεν πηγα να παρω το χ-500 απο πλαισιο. Το κινητο αναμενεται σε λιγες μερες. :D Παράθεση TrelosPlanitis.blogspot.com - ολα τα τρελά εδώ .. -
sTavr0z Δημ. November 10, 2007 Δημ. November 10, 2007 ps: παρακαλω γρηγορα καποιος να τρεξει για επιβεβαιωση..αν και το ειδα με τα ματια μου.. Παράθεση TrelosPlanitis.blogspot.com - ολα τα τρελά εδώ .. -
skoros7 Δημ. November 10, 2007 Δημ. November 10, 2007 αν δεν έχεις ξανα-ασχοληθεί με WM πλατφόρμα, θα σε ξενίσει όσο και αν έχει προσπαθήσει η MS, το WM παραμένει πρώτα OS για PDA και μετά OS για κινητό (και κατά τους παλιούς PocketPCάδες ΚΑΛΟ ΑΥΤΟ, κατά όλους τους άλλους, ίσως κακό) είσαι σίγουρος; Και τι πειράζει τους παλιούς να δουλεύει ΚΑΙ το τηλέφωνο τέλεια; Παράθεση
