Sony PlayStation 3
mcde
  • Απαντήσεις 4,5χιλ.
yeap! lets talk about lotto now.. :rolleyes:
PS3 (v2.50) update
Now on to the PS3 v2.50 update. The latest features/enhancements include:
* Support for the PS3 Official Bluetooth Headset - we’ve told you about the upcoming Bluetooth Headset and SOCOM: U.S. Navy SEALs Confrontation Bundle on the Blog. This latest firmware installment enables High-Quality (HQ) mode, which delivers clear and wide-band online voice chat. On top of that, an added on-screen indicator shows battery status, volume level and use of HQ mode.
* PlayStation Trophies interface enhancements - I know that many of you are busy collecting trophies and raising your PlayStation Trophy level. This update makes sharing and comparing your trophies with your friends even easier. On 1st part of the profile page you’ll see a symbol under level that represents level and the actual percentage towards the next level along with the existing level meter. The level symbol carries over to the trophy comparison screen where you will now be able to see your level, your friend’s level and the percentage towards the next level for both users along with all of the game by game comparison information you see today.
* Friend status – Offline friends on your Friends list will have information below their avatars that will indicate how long it has been since they were last online.
* Video – This update adds the Scene Search feature similar to the feature on the PSP. Activating this feature while viewing a video on the PS3 will break the video up into scenes that you can quickly access by pressing the X button. You can break the videos into one, two or five minute intervals. In addition, you can now choose to have all of the videos under the video section of the XMB play in sequence. Go to Settings then Video Settings to turn this option on.
* PlayStation Store – We’ve added a redeem codes option right on the store to make it easier to redeem your PlayStation Network Cards and promotion codes. In addition, PlayStation Network Sign Up and Account Management have been redesigned.
* Power Save Settings – You can now set your PS3 and wireless controllers to turn off automatically after set periods of inactivity. Go to Settings then Power Save Settings to turn on these features.
* Background Downloading - You now have the option to set the PS3 to turn off automatically after a background download or installation of content has completed. This option is available when you turn off the system from the button under [users] while content is being downloaded or installed.
* In-game Screenshots - this tool will allow everyone to capture, share and in other words, immortalize their favorite gameplay moments. This will be supported on a game by game basis. Please check back to find out which games will support this feature.
* In addition to all of the features above there are some additional features and enhancements included in 2.50. Once the update launches, you can read all of the details here.
The support for the Bluetooth Headset will be of particular interest to all of you SOCOM fans. With the “Proximity Chat” feature, SOCOM: Confrontation gameplay is intensified as it allows you to experience high-quality voice playback in full surround sound. Whether the action is near or far, Proximity Chat clearly matches distance to sound effects and voiceovers within the game, putting you in the heart of the action.
Να σου πω 43 νούμερα;
http://exothema.files.wordpress.com/2008/06/mhtsotakhs.jpg
* Power Save Settings – You can now set your PS3 and wireless controllers to turn off automatically after set periods of inactivity. Go to Settings then Power Save Settings to turn on these features. (Καιρός ήταν...)
* Background Downloading - You now have the option to set the PS3 to turn off automatically after a background download or installation of content has completed. This option is available when you turn off the system from the button under [users] while content is being downloaded or installed. (Ομοίως)
Όλα αυτά είναι πολύ ωραία features.
-Candygram.
-Candygram, my foot. You get out of here before I call the police. You're the shark, and you know it.
-Wait. I-I'm only a dolphin, ma'am.
paidia kalispera, na rwtisw kati .
exw paraggeilei to PS3 apo ameriki. 8elw na mou pei kaneis an kserei an 8a exw problima me ta NTSC kai PAL ka8os k me to kalodio tou revmatos! pls paidia an kserei kaneis na me enimerwsei, stin periptwsi pou to amerikaniko den paizei stin ellada gia na akirwsw tin paragelia! euxaristw polly
τα παιχνιδια ειναι region free οποτε δεν εχεις προβλημα αλλα οι ταινιες δεν θα παιζουν ειναι region 1 ενω εμεις εχουμε region 2 εσυ αποφασιζεις αν σε ενδιαφερουν τα παιχνιδια η οι ταινιες η και τα δυο
Επισης τα παιχνιδια του ps1 δεν θα παιζουν (του 2 δεν παιζουν ετσι κι αλλιως)
Με το ρευμα θα εχεις προβλημα. Θα πρεπει να αγορασεις μετασχηματιστη. Και ακριβο κιολας γιατι τα watt του ps3 ειναι πολλα.
Αν το κανεις μονο για να σου βγει πιο φτηνα δεν αξιζει, θα βρεις τον μπελα σου.
Έχω την εντύπωση ότι δεν υπάρχει θέμα μετασχηματιστή, απλά ευρωπαϊκού τύπου καλωδίου.
Αλλά συμφωνώ ότι δεν αξίζει.
Επίσης αυτό έχει ρωτηθεί και απαντηθεί δεκάδες φορές στο thread, υπάρχει και η αναζήτηση...
-Candygram.
Λεει πουθενα το ps3 οτι δεχεται και ρευμα 120 volt? Μονο οσες συσκευες εχουν εξωτερικο μετασχηματιστη δεν εχουν προβλημα (κινητα, λαπτοπ, slim ps2 κλπ), και παλι οχι ολες.
Έχει universal PSU, 100-240V.
The entire power supply is built into the PlayStation 3. The Xbox 360 requires an external "brick" that can be swapped out depending on the local regulations for electronic devices. The US and Japan uses 110-120V, 60Hz adaptors. We have confirmation from SCEA now that the power supply inside the Playstation 3 is, in fact, universal. The power supply supports 100 to 240 volts at 50 to 60 Hertz, which is useable in all modern power grids -- including Europe. Although European markers require a different physical plug for their infrastructure, there is no need to replace the power supply.
http://www.dailytech.com/article.aspx?newsid=4908&ref=y
Και κάτι άλλο: το firmware 2.50 προσθέτει υποστήριξη Flash 9 στον browser.
-Candygram.
Λοιπόν μετά από καιρό έχω αποφασίσει να αγοράσω το ps3.Δεν γνωρίζω κάτι από τεχνικά θέματα και θέλω να ρωτήσω:Τσιπάρεται το ps3?Υπάρχει τρόπος να φορτώνω backup παιχνίδια στη κονσόλα?
Όχι και όχι.
Firmware Update 2.5 For PS3, 5.0 For PSP Now Up For Download
-Candygram.
το Saints Row 2 είναι καλό? μου το δώσανε (full promo game) για να το "τεστάρω"..
Ε, εσύ δεν πρέπει να μας πεις τότε; :p
Είναι τύπου GTA (open world, βίαιο κλπ).
-Candygram.
Καλησπερα,θελω να βαλω στο PS3 ενα δισκο 250giga,απο οτι καταλαβα δεν αξιζει να παρω στις 7200 αλλα στις 5400.
Ξερει κανεις πως θα κανω copy - paste ολα τα αρχεια και τις εγκαταστασεις απο τον εναν σκληρο στον αλλο?
Θα πρεπει να τους βαλω πχ στο PC και να κανω copy paste τα παντα και τα hidden files?
Ξερω οτι θα μου πειτε ''ΔΙΑΒΑΣΕ ΤΟ ΜΑΝΟΥΑΛ",απλα ρωταω αν υπαρχει κατι που πρεπει να προσεξω και επισης αν προτεινετε καποια συγκεκριμενη μαρκα σκληρου.
Αν είχες διαβάσει το manual :rolleyes: θα ήξερες ότι θα χρειαστείς έναν εξωτερικό σκληρό δίσκο (ή USB stick αν επαρκεί ο χώρος) και ότι θα πρέπει να χρησιμοποιήσεις την backup utility από τα settings του PS3.
Αφού αλλάξεις το σκληρό θα ξανασυνδέσεις τον εξωτερικό και θα κάνεις restore και πάλι από την backup utility.
Το copy paste δε νομίζω ότι θα δουλέψει σωστά.
Tutorial.
-Candygram.
Μόλις αγόρασα το ps3 στο πακέτο με τα παιχνίδια Motorstorm και Resistance Fall Of Man.Αφού τα ξεσκίσω αυτά θέλω να πάρω τα Need for speed,GTA 4,Metal Gear Solid 4:)
Εχω το 60gb ps3 και οταν πηγαινω στην μνημη μου λεει οτι χρησιμοποιούνται απο τα 55 τα 39 ειναι λογικο?εχω φορτώσει μονο 4 παιχνιδια..
...Δικαιωμά μου να γυρνώ στο σπίτι Τα χαράματα...
Όχι, δεν είναι. Μήπως σου μένουν 39?
-Candygram.
