d2000217 Δημ. September 26, 2005 Δημ. September 26, 2005 MUSIC FEATURES (HOW TO) Twist to the music with the Nokia 3250 phone. Find out just how easy it is to transfer your music to the phone from your PC. The Essentials: Optimized, easy-to-use music player: Music collection management and playlist editing Dedicated music control hard keys: Play/pause, stop, rewind, forward. High-fidelity 3.5mm stereo headset with voice call and music playback remote control. eAAC+ storage: Memory expandable up to 1GB for up to 750 songs of great quality stereo audio with the new advanced eAAC+ digital audio codec * Battery playtime: Up to 10 hours Built-in memory: 10 MB Memory card: Supports up to 1 GB microSD card Radio pre-sets: 20 * Total storage capacity is limited by number of songs. Storage capacity is approximate and based on 4 minutes per song and 48kbps eAAC+ encoding. Actual storage capacity is dependent on sales package configuration. Nokia Audio Manager Version 5.0 With Nokia Audio Manager 5.0, you can create and organize digital music files on a compatible PC and transfer them to your Nokia 3250 phone. Basic Functions: -Play audio CDs -Save CD music tracks to eAAC+ format -Play eAAC+ and MP3 music tracks -Create, edit, and play M3U playlists -Organize music tracks and playlists in the Nokia Audio Manager Music Studio -Transfer eAAC+ and MP3 tracks from the Music Studio to your Nokia 3250 phone -Transfer playlists from Music Studio to your Nokia 3250 phone With Nokia Audio Manager Music Studio you can organize and copy audio tracks onto your mobile device. Music can be placed into the Music Studio from any Windows folder. The CD player allows you to save CD audio files in AAC digital format, which may then be added to the Music Studio and transferred to a compatible Nokia mobile device. Note: The Nokia 3250 phone is also compatible with Windows Media Player. How to Transfer Music With Nokia Audio Manager you can transfer music tracks to your phone from a CD. You first save music from a CD on the PC and then transfer the tracks from Audio Manager to the phone. Note: With a USB cable (DKU-2 or CA-53) connection, you can transfer large files such as music files between your phone and the PC more quickly than with other connection types. To Transfer Music from a CD to Your Phone : -Insert a music CD in your PC CD drive. -In the Nokia PC Suite main window, click Transfer music to open Nokia Audio Manager. -Click CD player and select the tracks you want to transfer to your phone. -Click Save tracks. The files are saved to your PC in .aac file format. -Click Music Studio and you can see the saved tracks. You can also click Add… to add more tracks saved earlier on your PC hard disk. Select a track and click Edit > Track or Playlist to change the track and artist names. -Connect your phone to the PC. Nokia Audio Manager automatically detects the phone and the Mobile Phone panel shows the music tracks stored earlier on this phone. Παράθεση Η αγάπη αποτελείται απο μια μοναδική ψυχή που κατοικεί σε δύο σώματα! (Αριστοτέλης) [sIGPIC][/sIGPIC] Proud Owner of a Xbox360 fully updated!!! (http://www.enternity.gr) Next Generation Consoles WAR:http:// http://www.vgchartz.com/
songless_bird Δημ. September 26, 2005 Δημ. September 26, 2005 Δε μας χάλασε το ροζάκι... :grin: Βγαινει και σε λαχανι. Αλλα στην ελλαδα μαλλον μονο το μαυρο ,αντε και το γκρι, θα ερθει. Παράθεση [sIGPIC][/sIGPIC] 24F1A078 Το να κανεις λάθη είναι ανθρώπινο. Το να ρίχνεις το φταίξιμο στον άλλον ειναι στρατηγική
gogos7 Δημ. September 26, 2005 Δημ. September 26, 2005 Παίρνει microSD ( http://www.sandisk.com/pressrelease/20050909.htm ) και όχι miniSD όπως τα 6270 - 6280 που δεν έχουν κυκλοφορήσει ακόμη. Δε μπορει κατασταλάξει κάπου, αυτή η Nokia; Παράθεση
johner Δημ. September 26, 2005 Δημ. September 26, 2005 Παίρνει microSD ( http://www.sandisk.com/pressrelease/20050909.htm ) και όχι miniSD όπως τα 6270 - 6280 που δεν έχουν κυκλοφορήσει ακόμη. Δε μπορει κατασταλάξει κάπου, αυτή η Nokia; Αυτές οι κάρτες είναι πολύ μικρές, σχεδόν σαν ένα νύχι, είναι πραγματικά εύκολο να την χάσεις. Πάντως δεν είναι δυνατόν κάθε συσκευή να έχει και τη δική της κάρτα. Mόνο η Nokia το κάνει αυτό στα Series 60. Παράθεση
songless_bird Δημ. September 26, 2005 Δημ. September 26, 2005 Εκανα το βιντεο που εχει η nokia για το 3250, μικροτερο σε μεγεθος για εμας τους PTSNαδες :O N3250 Video 2.7Μb. Edit:Ειναι mp4 . Ανοιγει με quicktime ή nero showtime. Παράθεση [sIGPIC][/sIGPIC] 24F1A078 Το να κανεις λάθη είναι ανθρώπινο. Το να ρίχνεις το φταίξιμο στον άλλον ειναι στρατηγική
nervous Δημ. September 26, 2005 Δημ. September 26, 2005 Μια live photo ,οχι πολυ καλη http://img97.imageshack.us/img97/6538/3250dd3gg7vf.th.jpg δευτερη:Αναφερει usb port. Ειναι mini usb οπως του Ν91 ή μεσω pop port? Tριτη: αναφερει jack για τα ακουστικα. Ειναι κανονικο οπως του Ν91 ή και αυτο μεσω Pop pοrt με τον ανταπτορα που παρουσιαστηκε με το 6630 music edition? edit: μιλαει για jack υποδοχη αλλα τα ακουστικα στο pop port τα εχουνε στις φωτο:confused: Απο οτι καταλαβα για τα ακουστικα μεσω Pop pοrt (Nokia Music Headset HS-20),δηλ μεσω http://www.nokia.com/BaseProject/Sites/Nokia_Europe_18022/CDA/Categories/Phones/Enhancements/Audio/Headsets/NokiaMusicHeadsetHS-20/_Content/_Static_Files/hs-20_pop.jpg Το ιδιο πρεπει να ισχυει και για το usb port ( Nokia Connectivity Cable CA-53) http://www.nokia.com/BaseProject/Sites/NOKIA_MAIN_18022//CDA/Categories/Phones/Enhancements/Data/Cables/NokiaConnectivityCableCA-53Popup/_Content/_Static_Files/ca-53_pop.jpg Παράθεση [imgalign]http://i37.tinypic.com/23k3s09.jpg[/imgalign] Μην ψάξεις ποτέ να βρεις κάτι τέλειο για να το αγαπήσεις. Αγάπησε κάτι ατελές και τελειοποίησε το με την αγάπη σου! iPhone 5S Space Grey Προσοχή! Κατάργηση γραφής Greeklish
songless_bird Δημ. September 26, 2005 Δημ. September 26, 2005 Απο οτι καταλαβα για τα ακουστικα μεσω Pop pοrt (Nokia Music Headset HS-20),δηλ μεσω http://www.nokia.com/BaseProject/Sites/Nokia_Europe_18022/CDA/Categories/Phones/Enhancements/Audio/Headsets/NokiaMusicHeadsetHS-20/_Content/_Static_Files/hs-20_pop.jpg Kαι το Jack που κολλαει στα specs? :confused: Μηπως σου δινει και αυτη τη δυνατοτητα? Αντε να βγει και στο forum Nokia μπας και βρουμε ακρη... Παράθεση [sIGPIC][/sIGPIC] 24F1A078 Το να κανεις λάθη είναι ανθρώπινο. Το να ρίχνεις το φταίξιμο στον άλλον ειναι στρατηγική
nervous Δημ. September 26, 2005 Δημ. September 26, 2005 Kαι το Jack που κολλαει στα specs? :confused: Μηπως σου δινει και αυτη τη δυνατοτητα? Αντε να βγει και στο forum Nokia μπας και βρουμε ακρη... Μαλλον το πλασαρει η νοκια "πονηρα" :devil: :secret: ,σαν συν στα χαρακτηριστικα του ,αφου θα παρεχει στο πακετο τα συγκεκριμενα ακουστικα * Plug your own headphones into the 3.5 mm connector jack in the headset cable Παράθεση [imgalign]http://i37.tinypic.com/23k3s09.jpg[/imgalign] Μην ψάξεις ποτέ να βρεις κάτι τέλειο για να το αγαπήσεις. Αγάπησε κάτι ατελές και τελειοποίησε το με την αγάπη σου! iPhone 5S Space Grey Προσοχή! Κατάργηση γραφής Greeklish
songless_bird Δημ. September 26, 2005 Δημ. September 26, 2005 Μαλλον το πλασαρει η νοκια "πονηρα" :devil: :secret: ,σαν συν στα χαρακτηριστικα του ,αφου θα παρεχει στο πακετο τα συγκεκριμενα ακουστικα * Plug your own headphones into the 3.5 mm connector jack in the headset cable Α... Το βρηκαμε δηλαδη που ειναι το jack...Δεν ειναι κακο να υπαρχει, εστω και ετσι. Αλλα οχι και spec του κινητου.... Παράθεση [sIGPIC][/sIGPIC] 24F1A078 Το να κανεις λάθη είναι ανθρώπινο. Το να ρίχνεις το φταίξιμο στον άλλον ειναι στρατηγική
tax_opari91 Δημ. September 26, 2005 Δημ. September 26, 2005 Αν ειχε και καλη Built-in memory θα τρελαινε κοσμο Παράθεση
or7raul7 Δημ. September 26, 2005 Δημ. September 26, 2005 δεν εχει ραδιο?διαβασα μονο για visual, fm δεν θα εχει? Παράθεση Οι υπογραφές μπορούν να περιέχουν 1 εικόνα, η οποία ωστόσο δεν θα πρέπει να έχει διαστάσεις μεγαλύτερες από 420 x 150 pixels και το μέγεθός της δεν θα πρέπει να ξεπερνά τα 16.384 bytes.
rallistas Δημ. September 26, 2005 Δημ. September 26, 2005 Eμενα μου αρεσει παντως!Πλακα εχει!Μακαρι να ειναι ανθεκτικο το twist!!! ;) Αν περασει με επιτυχεια τα "crash tests" θα το χτυπησω καποια στιγμη! :D Παράθεση ΜΑΧ.
nikoskat Δημ. September 26, 2005 Δημ. September 26, 2005 και δεν εχει ηχογραφηση ραδιοφωνου. να πω τη μαυρη μου αληθεια, εκτος απο το os 9.1 δεν εχει κατι πολυ πρωτοποριακο. ωραιο ειναι παντως και καλη τιμουλα, μια χαρα, δε μας χαλαει:) Παράθεση
songless_bird Δημ. September 26, 2005 Δημ. September 26, 2005 δεν εχει ραδιο?διαβασα μονο για visual, fm δεν θα εχει? To visual προυποθετει την υπαρξη FM radio οπως και στο 3230 ;) Εχει κανονικοτατο. Πραγματι , σωστη η παρατηρηση σου nikoskat για τη ηχογραφιση....Αλλα απο τη στιγμη που μπορει να γινει σε αυτη την εκδοση symbian ισως δουμε καμια τριτη εφαρμογη.Ισως... Παράθεση [sIGPIC][/sIGPIC] 24F1A078 Το να κανεις λάθη είναι ανθρώπινο. Το να ρίχνεις το φταίξιμο στον άλλον ειναι στρατηγική
or7raul7 Δημ. September 27, 2005 Δημ. September 27, 2005 να ρωτησω και κατι αλλο. η καμερα βγισκετε στην πισω πλευρα ή απανω στο στριφογυριστω.αν ειναι εκαι θα ειναι λιγο αβολο να τραβασ βιντεο και φωτο. Παράθεση Οι υπογραφές μπορούν να περιέχουν 1 εικόνα, η οποία ωστόσο δεν θα πρέπει να έχει διαστάσεις μεγαλύτερες από 420 x 150 pixels και το μέγεθός της δεν θα πρέπει να ξεπερνά τα 16.384 bytes.
nervous Δημ. September 27, 2005 Δημ. September 27, 2005 να ρωτησω και κατι αλλο. η καμερα βγισκετε στην πισω πλευρα ή απανω στο στριφογυριστω.αν ειναι εκαι θα ειναι λιγο αβολο να τραβασ βιντεο και φωτο. H καμερα βρισκεται στο twisted part Live Photos from http://mobil.idnes.cz/telefony.asp?r=telefony&c=A050926_175912_telefony_jm http://img354.imageshack.us/img354/816/a050926jmnok3250live01n5zq.th.jpghttp://img354.imageshack.us/img354/9066/a050926jmnok3250live02n3wo.th.jpghttp://img354.imageshack.us/img354/2397/a050926jmnok3250live03n1xm.th.jpg http://img354.imageshack.us/img354/807/a050926jmnok3250live04n3vm.th.jpghttp://img354.imageshack.us/img354/1707/a050926jmnok3250live08n8pc.th.jpghttp://img354.imageshack.us/img354/6767/a050926jmnok3250live09n9jw.th.jpg Παράθεση [imgalign]http://i37.tinypic.com/23k3s09.jpg[/imgalign] Μην ψάξεις ποτέ να βρεις κάτι τέλειο για να το αγαπήσεις. Αγάπησε κάτι ατελές και τελειοποίησε το με την αγάπη σου! iPhone 5S Space Grey Προσοχή! Κατάργηση γραφής Greeklish
nervous Δημ. September 27, 2005 Δημ. September 27, 2005 More : http://img354.imageshack.us/img354/2544/a050926jmnok3250live10n1vf.th.jpghttp://img354.imageshack.us/img354/5034/a050926jmnok3250live12n0fx.th.jpghttp://img386.imageshack.us/img386/1557/a050926jmnok3250live13nn3nj.th.jpghttp://img386.imageshack.us/img386/782/a050926jmnok3250live16n0rk.th.jpghttp://img386.imageshack.us/img386/6422/a050926jmnok3250live19n6av.th.jpghttp://img386.imageshack.us/img386/2593/a050926jmnok3250live21n1kx.th.jpg Source: http://mobil.idnes.cz/telefony.asp?r=telefony&c=A050926_175912_telefony_jm Παράθεση [imgalign]http://i37.tinypic.com/23k3s09.jpg[/imgalign] Μην ψάξεις ποτέ να βρεις κάτι τέλειο για να το αγαπήσεις. Αγάπησε κάτι ατελές και τελειοποίησε το με την αγάπη σου! iPhone 5S Space Grey Προσοχή! Κατάργηση γραφής Greeklish
teorizo Δημ. September 27, 2005 Δημ. September 27, 2005 Nokia introduced its music phone Nokia 3250, update At the Trends Berlin Nokia has introduced its new smartphone Nokia 3250. On the face of it the device seems to be an ordinary candy bar phone, but it consists of two modules. The top part has the screen, and the bottom rotating part is equipped with the digital keyboard on one the side and music buttons and a 2-megapixel camera module at the other side. The smartphone is supposed to support MP3, AAC and WMV, including DRM WMV. The screen functions at landscape or portrait modes with high resolution. Besides there is an expansion slot for memory cards, but the format is not yet clear – miniSD or RS-MMC. The model makes an impression of a budget version of the N90/N91 smartphones without HDD, Wi-Fi and 3G networking. The official release of Nokia 3250 is expected this week, well currently the technical specs are not yet confirmed by the company. Update Right now Nokia has officially announced its Nokia 3250. The smartphone designed for GSM 900/1800/1900 MHz networks will be released in 1Q 2006. The recommended price makes up €350. Nokia 3250 really has a 2-megapixel camera and an FM-tuner. There is the support of MP3, WMA, M4A and AAC music formats. The slot works with microSD cards (up to 1 GB). http://mobile-review.com/news.php?language=en Παράθεση only crossfit...
stred Δημ. September 27, 2005 Δημ. September 27, 2005 Παντως αν κ το 3230 δεν μου αρεσει καθολου εμφανισιακα,το 3250 καπως τρωγεται..αυτα τα 2 πλαισια γυρω απο πληκτρολογιο κ οθονη του πανε.... κ απο χαρακτηριστικα μια χαρα ειναι (μακαρι να ειχε IR ).. Παράθεση dum spiro spero
georgetr Δημ. September 27, 2005 Δημ. September 27, 2005 USB 2.0 full speed with mass storage profile Προσεξατε οτι το usb που εχει στην ουσια θα το βλέπει το PC σαν ενα επιπλεον σκληρο δισκο? Πολυ καλο αυτο! περνας ο,τι θελεις κατευθειαν και απο οποιοδηποτε PC :) Παράθεση
songless_bird Δημ. September 27, 2005 Δημ. September 27, 2005 Ψαχνω απο'δω ,ψαχνω απο'κει...Αλλα που μπαινει η sd ρε παιδια? Δεν εχει hot swap? Κατω απο τη μπαταρια ειναι? Δεν βλεπω πουθενα θυρα... Παράθεση [sIGPIC][/sIGPIC] 24F1A078 Το να κανεις λάθη είναι ανθρώπινο. Το να ρίχνεις το φταίξιμο στον άλλον ειναι στρατηγική
lemanis Δημ. September 27, 2005 Δημ. September 27, 2005 H καμερα βρισκεται στο twisted part Μ@λ@κία τους ρε γμτ :( Αυτός ήταν ένας από τους λόγους που έστειλα το 6260 :confused: Παράθεση http://www.4troxoi.gr/forum/images/avatars/40901403742c3d7ea3caba.jpg
or7raul7 Δημ. September 27, 2005 Δημ. September 27, 2005 σε γενικες γραμμες ειναι ομορφο,με καλα χαρακτηριστηκα εως πολυ καλα. το μονο ελατομα που εχει ,και ισως κανει τους πιο περισσοτερους να το προβλιματιστουν για την αγορα του,ειναι η θεση της καμερας.τουλαχιστον ας ηγταν αυτη για video κλησης και ας υπηρχε η κανονικη απο πισω.αρε νοκια με τις ιδιοτροπιες σου. αν η τιμη ειναι αληθινη τοτε πραγματικα αξιζει. η αναλυση που παιρνει video ειναι η συνιδισμενη ή σαν το ν70? Παράθεση Οι υπογραφές μπορούν να περιέχουν 1 εικόνα, η οποία ωστόσο δεν θα πρέπει να έχει διαστάσεις μεγαλύτερες από 420 x 150 pixels και το μέγεθός της δεν θα πρέπει να ξεπερνά τα 16.384 bytes.
songless_bird Δημ. September 27, 2005 Δημ. September 27, 2005 σε γενικες γραμμες ειναι ομορφο,με καλα χαρακτηριστηκα εως πολυ καλα. το μονο ελατομα που εχει ,και ισως κανει τους πιο περισσοτερους να το προβλιματιστουν για την αγορα του,ειναι η θεση της καμερας.τουλαχιστον ας ηγταν αυτη για video κλησης και ας υπηρχε η κανονικη απο πισω.αρε νοκια με τις ιδιοτροπιες σου. αν η τιμη ειναι αληθινη τοτε πραγματικα αξιζει. η αναλυση που παιρνει video ειναι η συνιδισμενη ή σαν το ν70? Η συνηθισμενη, Αλλα με το ΕΤΙ2 θα τραβαει σε 320x240. Μην πω και παραπανω με πειραγμα του ini. Παράθεση [sIGPIC][/sIGPIC] 24F1A078 Το να κανεις λάθη είναι ανθρώπινο. Το να ρίχνεις το φταίξιμο στον άλλον ειναι στρατηγική
