[S60 1st, 2nd Edition] Παιχνίδια
trod
  • Απαντήσεις 5,1χιλ.
νεο παιχνιδι:
Whether Mr.Q is painting as a worker or as an artist, he has a pretty tough job to do.
He has to paint all the cubes of this pyramid with the same color. This would not be so tough, was there not for the army of pests, bothering our hero and making his painting job as hard as possible.
First comes the pink (and not so smart) Snake.
Snake hatches from a pink egg , which falls onto the Pyramid every round of the game. The pink egg bounces down the Pyramid and when reaches the bottom, the snake embarks on its deadly pursuit of our hero.
You have to control Mr. Q's path along the pyramid so that he avoids the unpleasant (to say the least) rendezvous with Snake.
Snake is not exactly a rocket scientist, so you will be able to make him jump off the Pyramid to its doom pretty easily - just step onboard one of the "flying saucers" conveniently located on both sides of the pyramid and waiting to save your … (you guessed it!).
You get a bonus of 500 points every time you do that too.
Another pretty annoying character is the Critic - a greenish fellow, who paints the cubes back to their original color in an obvious disapproval of Mr. Q's painting talent.
Let's move on to the deadly rubies. They are red, they are fast, and they are deadly. The deadly rubies drop onto the top of the Pyramid and randomly bounce down the cubes. They cannot follow Mr. Q like Snake can, but they come in large numbers, so you'd better pay attention.
The bottom of the Pyramid is a dangerous place. The Nasty Jumping Buddies enter Mr. Q's peaceful creative life from the uncharted territory below the Pyramid. As the name suggests, they are nasty and they can jump in all directions. So they jump up the pyramid and to avoid them you have to put some real effort into navigating Mr.Q across the Pyramid. So many enemies and not a single friend? Mr. Q is a painter and not a politician, right?
Right. While Mr Q. may be alone in his heroic adventures, he can actually control Time. How does he do it? By catching the Hourglass, which occasionally drops down from heaven. The Hourglass does a darned good job as a Guardian Angel, freezing all the other ill-minding characters on the Pyramid, so that Mr. Q can finish his painting job and move to the next level in his artistic achievements.
http://trials.smartphone.net/Product_images/3/364/CEZoom4.gif ;) κυκλοφορεί!!!
only crossfit...
Αρχικό Μήνυμα από το μέλος ALR ( 7 Οκτ. 2004 , 00:58)
Paidia krima...to rallaki einai TROMERO!!Ti na pw emeina afwnos..perimena kati kalitero apo to proigoumeno rallaki tou n-gage (Sega rally) alla auto kseperase kathe prosdokia pou eixa :up:
paizei se 7610???an nai pou mborw na to brw?? :!:
teorizo prospathw na katebasw apo to site sou to casino games for s60 alla den xerw giati katebainei se agnwsti morfi kai den to blepei to pc suite..kamia protasi??
http://briefcase.pathfinder.gr/download/laios23/38168/578002
Το γούστο μου είναι πολύ απλό. Είμαι πάντα ικανοποιημένος, έχοντας το καλύτερο...''Oscar Wilde
παιδια οποιοσ δεν βαριετε να μου απαντηση πωσ κανω εγκατασταση και πωσ θα δουλεψουν τα αρχεια blz του ngage σε nοκια 7610
ευχαριστω
Αρχικό Μήνυμα από το μέλος thanos21 ( 7 Οκτ. 2004 , 18:15)
ευχαριστω
Prota prepei na vreis ton Blizzard installer,na ton egatastiseis kai ystera vazeis to arxio .blz pou theleis stin mmc,to vriskeis anoigontas ton blz installer kai patas apla install :)
Vevea gia na ta kaneis ola auta tha xreasteis kai kapoion file manager(px:seleq)
@laios23: Sxetika me to site tou teorizo apla kane mia metatroph to arxio pou katevainei se zip kai ustera ksezipare to.an den ginei tipota metetrepse to se .rar kai ksezipare to!(i .rar tha einai i .zip)
Apla o pathfinder metatrepei kathe arxio pou anevainei sto club san .dat opote analoga me ti morfi to anevase o user prepei kai su na to metatrepseis ksana me mia aplh metonomasia ;)
Αρχικό Μήνυμα από το μέλος ALR ( 7 Οκτ. 2004 , 16:20)
akribos! :)
only crossfit...
thanos21 η διαδικασια ειναι οπως στην περιεγραψε ο ALR αλλα για file manager μην βαλεις το Seleqγιατι στο 7610 δεν λειτουργει το αριστερο πληκτρο και δεν μπορεις να κανεις δουλεια.
Αρχικό Μήνυμα από το μέλος xt550 ( 8 Οκτ. 2004 , 16:17)
gia sas pedia. mporeite na kanete mia anakefaleosi me diafora links gia paixnidia poy paizoun sto 7610? euxaristo poly
Συνεχης πηγη με τα παντα στο irc, καναλι #aivanet :)
iPhone 5S Space Grey
FreeMines
Remake of classical Minesweeper game. Try to mark all the mines with flags. But don't step on any...
http://www.sacredware.com/Images/Screenshots/Minesweeper/4_sm.jpg
http://www.sacredware.com/Default.aspx?Section=ProjectDetails&Language=En&ProjectID=4
tax_opari91 θα πρεπει να περασεις αυτον τον φακελο με ενα card reader στο E:\.
Αν εχει και φακελο libs νομιζω οτι τον βαζεις στο E:\System\Libs και μετα παιζεις το παιχνιδι.
