ΕΤΕΝ M600
Gia ton player dokimaste oles tis epiloges sta video settings kai me to benchmark deite pia einai kalyteri! Tha steilo kai e-mail gia optimization se samsung na do ti tha mou poun! Oso gia to STD prepei na psaksoume sta forum tou Dell Axim 51v gia na doume an ekei brikan tin lysi mipos kanei kai gia emas!
Yianni, meta to rom upgrade tou dell, oloi lene oti einai ok me to STD. to kako einai oti emeis me tin 0161 synexizoume na exoume to provlima. Eftixws emena den mou etyxe sta 20 lepta opws ston Kwsta, alla an mou symvei mesa sti mera, ton 'ipia':mad:
  • Απαντήσεις 1,4χιλ.
Aytos o piccard ti einai? Player?
Sigoura tha to diorthwsoun kai mexri tote tha eimaste karteri. Toulaxiston den kanei hard reset. A, exei kai ena poly kalo pleon pou pisteyw tha einai se ola ta WM5 etsi. Otan pas na kaneis hard reset, se rwtaei prwta an theleis. An den pathseis ok kanei aplws ena soft reset!
Kai mia erwthsh. Blepw sto ppc, xwris na to syndesw sto pc, oti kathe treis kai logo anoigei to active sync. Prospathei na kanei synexeia sygxronismo. Les kai exei timer kai to anoigei kathe logo. Akomh kai otan einai me to kalwdio syndemeno sto pc kanei idio kai se spaei ta neyra. Mporw na to apenergopoihsw ayto? Na kanw manual opote thelw?
Κωστας - Κατερινη
o piccard einai o kyrios programmer tou TCPMP.
afto pou les me to activesync lene oti kai sto x51v prokalei to sudden death. I lisi pou dinoun einai edw:
>>Where's the info to change activesync to manual
HERE IT IS
* Open Activesync on your WM5 device
* Click Menu
* Click Add Server Source
* Enter any server address (eg Chillywinter.com) and click Next
* Enter any Username (eg Chillywinter)
* Enter any password (eg Chillywinter)
* Enter any Domain (eg Chillywinter)
* Click Next
* Click Finish
Now Menu / Schedule won't be ghosted out, so select it:
* Click Menu
* Click Schedule
* Change Peak times = Manual
* Change Off-peak times = Manual
* Click OK
You have now successfully changed your activesync option to manual. This seems to have the effect of ensuring the PDA doesn't try to sync when in standby mode.
Now delete the fake server you created:
* Click Menu
* Click Options
* Highlight "Exchange Server"
* Click Delete
Activesync will no longer try to sync when in battery / standby mode.
Ante na doume ti allo tha kanoume gia na mi pathainei egefalika:D
:w00t: kalo!!!!!! Kai poly eksypno! Gia na doume ti tha kanei twra.
Kanenan allo kalo player exete na proteinete? Na yparxei bebaia gia "agora"
Κωστας - Κατερινη
Μέλι στάζει από το στόμα του msmobiles για το Μ600...
"HTC? Who needs HTC if there are such stunning phones like above mentioned Gigabyte g-smart and like ETEN M600!? While HTC still dominates market of Windows Mobile phones, insistence of HTC on usage of sloppy processors in latest mini Pocket PC phones (like HTC Prophet and HTC Wizard) is putting people off"
...και φαρμάκι για HTC
Και καλά κάνει από την στιγμή που είναι καλύτερα τα
προιόντα των άλλων εταιριών!
Βασικά το θέμα με την HTC προέκυψε μια εποχή που το
msmobiles.com έβαζε τα νέα τηλέφωνα που θα βγάλει και η
HTC έστειλε του δικηγόρους της. Και μετά από αυτό όλο
την θάβει...
Καλά κάνει!!!
Με την Wind κάνεις πράγματι οικονομία...αφού δεν έχεις ποτέ σήμα, δεν μιλάς, δεν στέλνεις μηνύματα, δεν χρεώνεσαι...
Wind Όσα παίρνει ο άνεμος
Σαββάτο το Παράγγειλα το βράδυ
Τετάρτη 21/12 ήρθε :w00t:
ΗηΡρΘθΕε!!
EmT6e0n0
::LiNK RaMoNe
Hey, Ho!
Let's Go!
:Xhttp://www.eff.org/br/brstrip.gif:X
telika arxizw na pistevw pws to 9100 mexri twra symperiferetai kalitera se ola (video me tcpmp, skype paizei teleia, den exei sudden death problem, kai alla) ektos tis taxititas pou an peirakseis registry sto 9100 einai ok alla tespa.
Den kserw alla exw arxisei na vidwnomai perierga:wacko:
Panare egkataleipeis apo tin ekkinisi? Xoris kan ta 3 prota firmware updates? :D Se kammia periptosi o OMAPas tou 9100 den mporei na paizei kalytera video! Sto eggyomai auto basi tis arxitektonikis tou! Ela synerthe akoma den to pira sta xeria mou na synergastoume! Akous ekei 9100????? :D
ti na pw re Yianni, eilikrina me to 9100 den eixa kanena provlim (opws toxw peiraksei vevaia gia na paei kala). Den to syzitw oti mou aresei kalitera to m600, alla exei arxisei na mou spaei ta nevra se pragmata pou den to perimena. Anyway, tha prospathisoume na to strwsoume to atimo, pou tha paei:D
Oti tha to strosooume einai sigouro! Alla to 9100 pou estisa 2 xtes pali molis baleis kanena dyo programmata sto today screen kyriolektika pethainei! Bebaia to M600 akoma den to exo na to skiso ligo na do ti kanei alla ta bugs einai sigouro oti tha diorthothoun. Enas allos simantikos logos pou pira to M600 einai oti milontas me atomo apo tin mama e-ten me diabebaiose oti otan bgei i ekdosi WM5.0 second edition tha tin exoume kai sto M600. Einai pagia politiki tous leei kai enas tropos na antagonistoun tin HTC pou den edine anabathmiseis eos tora! ;)
AAAAA kai ksexasa to STD einai ontos problima apo tin mama MS opos mou eipe kai perimenoun kai autoi tin lysi apo tin microsoft an kai sto firmware 161 exoun beltiosei ta pragmata opos mou eipe arkei na einai ksetsekarismenes oi gnostes 2 epiloges kai na afinoume to BT on! Oi kapoies asimbatotites pou exei to 9100 me sigkekrimena programmata ofeilontai sto oti h HTC elyse to STD me tropo xoris tin egkrisi tis MS. Alla auta tha ta doume stin praksi sintoma.
gia poies ksetsekarismenes gnostes 2 epiloges milas?
Με συγχωρείτε αγαπητοί συνφορουμίτες αλλά αν ποτέ αντικαταστήσω το s100 με ppc που να έχει έστω και ένα από τα προβλήματα των 9100 ή m600, σας επιτρέπω να με κρεμάσετε ανάποδα στο σύνταγμα και να με λιθοβολήσετε με ...jasjar. Ε, ήμαρτον πια. Διαβάζω τα σχετικά θέματα καθημερινά και πάνω που λέω "αυτό θα πάρω", κάτι αρνητικό βγαίνει στη φόρα και ξεροκαταπίνω. Θα κρατήσω το s100 μέχρι νεοτέρας.
Σόρρυ κιόλας, γιατί το S100 όταν πρωτοβγήκε ήταν άψογο; Να μην αρχίσουμε να λέμε τα αίσχη που έβγαλε και συνεχίζει να βγάζει μέχρι και την τελευταία αναβάθμιση. Πρόκειται για συσκευές με τρομερό λειτουργικό σύστημα και τις κορυφαίες λειτουργίες στην αγορά. Αν το S100 πριν ένα χρόνο είχε και έχει ακόμα χοντρά προβλήματα, γιατί να μην έχουν αυτές;
Όσο για τα όσα διαβάζετε, τουλάχιστον σε εμένα αποτελούν τις εξαιρέσεις, ατόμων που τα ψάχνουν και τα λιώνουν τα smartphones τους. Και καλά κάνουν...
[imgalign]http://icons.iconarchive.com/icons/iconshock/social-media/96/twitter-icon.png[/imgalign]"Some hearts are different than others. Like crystal in a world of glass... Even the way they shatter is beautiful..."
Wannabe Editor? Reviewer? Columnist?
Join the Unwired Revolution, now!
Panzws divx,avi videos den paizei katholou kala me ton beta player kai me ton PocketMVP pou h ekdosh tou einai mexri WM2003 den paizoun katholou.
To PocketTV paizei bebaia MPEG, alla ti na to kanw afou ta paizei kai o media player. Allo programma den kserw na dokimasw
Κωστας - Κατερινη
loipon paides, exontas kai to 9100 kai to m600, thelw na pw oti ta goustarw kai ta dyo, to kathena vevaia gia diaforetikous logous. Den pistevw oti kamia siskevi einai teleia, apla ta opoia xaraktiristika tis einai 'teleia' gia kathe xristi ksexwrista analoga me tis anages tou.;
Etsi loipon, parathetw mia geniki souma apo kala kai kaka twn 2 aftwn siskevwn
Epeksergastis: M600 wins-klaseis pio grigoros, pragmatika oti pio grigoro kikloforei se wm5 siskevi.Apla teleios
Fwteinotita othonis:M600 wins- me 10 skales diavathmisis enanti 4 tou 9100, kai logw ltps tft screen i fwteinotita tis einai pali oti pio fwteino exete dei se ppc
Antithesi-Zwntania xrwmatwn: 9100 wins-Poli pio zwntana xrwmata sto 9100, to M600 antitheta einai ligo ksethwriasmeno se sxesi me to 9100, akoma kai se xamilo fwtismo
Ixeio:9100 wins, me 2 stereo speakers, einai poli pio sinatos kai katharos o ixos, en antithesi me to m600 pou to exei stin pisw meria kai an kai pio sigano, an to afisei se trapezi, kaliptete teleiws kai akougetai akoma pio siga
Akoustiki stin omilia:9100 wins. An kai to m500 eixe poli kalitero akoustiko apo to s100, edw isxyei to antitheto.
Sima:9100 wins. Se 3 diaforetika simeia (spiti,douleia,s=asanser) me tim karta kai ta dyo, me to 9100 milas, to m600 kanei spasimata(me ti rom 0161)
Meso apothikefsis:M600 wins. SD simainei polla, mini sd simainei liga...
Bluetooth:Sta idia epipeda kai ta dyo, den ksexwrizei kapoio
WIFI: 9100 wins- exei both wifi b kai wifi g. Ektos aftou, einai poli pio stathero. Sto M600 exei kapoia provlimata stin energopoiisi tou merikes fores kai meta apo ligo gonatizei kyriolektika to systima (sugardad knows better...)
IR:9100 wins - To M600 an kai exei epilogi receive incoming beams, an kai sto file explorer tou exei epilogi beam file, tha elege kaneis oti ksexasane na valoune to hardware sti siskevi!!!
Soft Keys:9100 wins. Gia ena leitourgiko pou exei stirixtei se afta, i apousia tous sto m600 einai simantiki
Pliktrologio: 9100 wins. Apla giati exei kai hardware pliktrologio
Camera: M600 wins. Ligo kaliteri fwtografia apo to 9100, polles perissoteres epilogew rythmisewn. Sto flash einai ka ta dyo gia ta mpaza...
Mpataria:9100 wins. Opoios ton exei mikro(ton epeksergasti), krataei perissotero...
Enswmatomena programmata: M600 wins- Plithwra poli kalwn programmatwn pou pragmatika leipoun apo to 9100, opws zoom sms, call filter, scenarios(profile manager) kai alla.
TCPMP:9100 WINS!!! logw vevaia mi swstis ypostiriksis tou samsung epeksergasti apo tous programmers. Idio video (ZIKOS tainia-168mb) sto 9100 paizei apsoga, sto m600 paei me trella spasimata
Destinator Pn: M600 wins. Pragmatika taxytato, toulaxiston 3-4 fores pio grigoro apo to 9100 se ploigisi,allagi diadromis klp
Skype: Polloi tha legan m600 wins? Valte to skype sto m600, kai tha deite. 4 stis 10 mou crashare, kai akouga ton allo me fovera spasimata.To ifdio anaferoun kai sto thread bugs sto eten-users! Antitheta to 9100 me to teleftaio skype paizei apsoga, milas kai akous pentakathara. Ara, so far 9100 wins!!!
Today plugins: M600 wins- dexetai oti tou valeis xwris na komplarei katholou, en antithesei me to 9100 pou gia na paei grigora kai se landscape mode anexei mono pocketbreeze, i mono weatherpanel kai wisbar advance. An tou valeis to WAD, ton ipies...
Hardware keys:9100 wins - me 7 enanti 4 tou m600
D-pad:9100 wins- To dpad sto m600 einai poli mikro, kai an kai kaneis douleia se pocketbreeze (zorizese omes), gia games apla ksexaste to
Bugs:M600 looses.To std pou einai poli simatiko yparxei distixws sto m600, kai kapoia provlimatakia me to wifi episis (to lene kai sto eten-users, to pathe kai o sugardad)
Anyway, afta einai kapoia liga simeia pou ithela na episimanw ti diaforetiki symperifora twn 2 aftwn siskevwn. Prosoxi den kanw vs, tis goustarw kai tis 2 gia afta pou kanei kalitera i kathemia tous, kai an me rwtgate poia tha kratouse, tha elega to 9100M600!!!
Episis, prospathisa oso mporousa na apofigw ypokeimenika themata (opws emfanisi, design, poitita kataskevis, mini usb i proprietary usb) gia na min mpoume sti diadikasia na sxoliazoume meta oti afti einai gnwmi sou, kai i dikia mou gnwmi einai afti k.o.k.
Exw kai fwtos apo tis 2 siskeves, an prolavw mexri to sk, tha tis anevasw.
Afta filtatoi, den kserw an tha prepei na postarw to idio kai sto wizard thread, pantws pistevw na apofasisei o kathenas simfwna me afto pou ton volevei perissotero:D
βαλτε αυτο το Post σε δικο του θεμα και καντε μια δημοσκοπηση!!!
μπραβο Panare, πολυ καλη δουλεια:up:
εγω βεβαια αποφασισα λιγες ωρες πριν απο αυτο, αλλα νομιζω οτι εκανα καλα. το wizard μου κανει περισσοτερο.
l
Thanks ;) για το review ,μην ανησυχεις , οσοι ενδιαφερονται ,θα το διαβασουν :)
iPhone 5S Space Grey
Auto to STD einai polu sovaro bug :( :cry: Kapou diavasa se kseno forum oti me to bt sunexeia energopoihmeno diorthwnetai, to dokimase kaneis?
Ericsson GF768 -> Nokia 8210 -> Nokia 6210 -> Nokia 8310 -> Nokia 6510 -> Nokia 7210 -> Sharp GX30 -> Sony Ericsson P900 -> ETEN M600 -> HTC Cruise -> Nokia 8850 -> iPhone 4 -> iPhone 4S -> Samsung GT-I9505 -> LG G2 -> iPhone 6S -> S10+
It ain't over till It's over yet!
Well Done Πάνο καλό συγκριτικό.
Πάνο δοκίμασες την ΝΕΑ έκδοση του Skype η οποία κυκλοφόρησε 15 Δεκ 2005;
ή έτρεξες την συμπεριλαμβανόμενη του πακέτου *outdated*?
Ρεστ οφ γιου, μήν βγάζετε βιαστικά συμπεράσματα, μήν παρασύρρεστε να είστε αντικειμενικοί.
Είναι ΠΟΛΥ νωρίς για τελικά/τετελεσμένα συμπεράσματα, πάρα πολύ νωρίς...
Ακόμη δέν είμαστε σε θέση να έχουμε μια stable ROM (κακώς βέβαια) αλλά παρόλα ταύτα τουλαχιστον κρατάμε το μικρό ΤΕΡΑΣ M600 στα χεράκια μας από το να το περιμένουμε άλλες 15 ημέρες....
Το M600 μαστίζεται (είναι γεγονός) από παιδικές αρρώστιες που όμως τόσο κατα γενική όσο και επίσημη ομολογία αντιμετωπίζονται και δεν είναι σε καμία περίπτωση πρόβλημα της συσκευής αλλά software....
Ντου νότ μπλέϊμ M600, Μπλέϊμ Μάϊκροσοφτ εντ πουτ δε κοτ ντάουν σλόουλι! :lol:
Επίσης η μέν ορθογόνια θέση για IR και το μενού beam με προβληματίζει και εμένα
καθώς μου αφήνει ίχνη από υπονοούμενα οτι μέν έχει IR αλλά θα ενεργοποιηθεί μετά την διόρθωση του STD
::LiNK RaMoNe
Hey, Ho!
Let's Go!
Kai ego opos leei kai o Mythozz oute thelo na skeftomai tis paidikes astheneies (gia na min po karkino) tou S100! Ksexasame to BT pou eksafanizotan kai akoma kai me tin teleutaia to pathaine esto kai spania? Mipos ta hardware problimata me to esoteriko hxeiaki na kaigetai kai na parakalame ta Nokia club na mas to allaksoun? H mipos to sima tou itan to kalytero arxika pou esy allazes nomo kai auto akoma na allaksei keraia! Ki omos ekeino to S100 itan to pio latremeno mixanimataki pou eixa pote kai den pavei na to latreuei akoma kai simera kanenas apo tous idioktites tou eite proin eite nyn! ;) To M600 einai kainourgio kai oi gnwstoi psyxanomaloi tou Myphone eimaste edw na bgaloume tin psixi mas ospou na strosei kai an ginei auto pou einai alla den to exei deiksei akoma! (Telika mallon aurio tha to exo sta xeria na to skisoooooooooooo to atimo!) :D
soo panaros ki alli M600 users .. proton meges sas ollon kai xronia pola !!! deuteron pios mpori na mou dosi ta cab apoto ext rom tou M600 ta xriasome gia HaccK ;-)
ki gia aftous pou den to exoun ena reviudaki
Η Samsung έχει Πελάτες, Η Apple έχει οπαδούς !!!
