[Επίσημο] Qtek S100 / imate Jam / MDA compact 2
Alexkass
geia sas.
isws htan la8os pou eftiaksa neo 8ema , mallon eprepe na to pw edw.
telos pantwn 8a ksanagrapsw ta idia kai apo dw kai pera 8a milaw mazi sas edw.
eimai neos xrisths tou s100 (peripou 1 mina) kai exw mono ena parapono
pou isws einai provlima..
polles fores otan paw na energopoihsw to bluetooth mou petaei
ena pop-up kai leei oti den yparxei egkatesthmeno bluetooth yliko sth syskevh!!
den einai sigouro oti epanerxetai an kanw soft reset dioti polles fores exw
kanei kai den egine tipota.
alla oute kai me hard reset einai sigouro oti 8a epanel8ei giati ekana 3 fores kai pali tipota.
epanerxetai mono tou se anypopto xrono.
den kserw an einai geniko provlima h provlima ths syskevis mou.
an exete kapoia gnwsh sto 8ema (giati milisa kai me to tmhma eksipiretishs kai mou eipan pws den ikseran kapoia allh lysh ektos apo hard reset) sas parakalw na thn grapsete giati 8a htan kalutero na kserw kai ti lene oi ypoloipoi.
***epishs exw parathrhsei kai ena provlima sto na mporw na steilw dedomena se kinhto ericsson me bluetooth, an kaneis to exei parathrhsei auto as mou pei.
eyxaristw prokatavolika gia thn boi8ia sas.
Βάλε την καινούρια ROM της AceHellas ή κάποια με Radio version 1.11 που λύνει το πρόβλημα.
  • Απαντήσεις 8,4χιλ.
i rom 1.11 tis qtek (agliki) me ta kainouria com ports sto BT menu me to BT-tools de sinergazontai... menoun ola ok mexri na kaneis klisi... opou to bt-tools anoigei to BT gia 1 lepto... meta tin klisi.. kleidonoun OLA ta pliktra... ektos apo to touchscreen (!!!) xanete to BT os hardware... kai mono me reset diorthonontai ola... pali mexri tin epomeni klisi...
me tin aferesi ton BT-tools ola lithikan...
simvenei se kanenan allo?
re si mallon den exei problem o peksergasthsgiati anoiksa ena parathiro apo (xcpuscallar) gia na blepo poso cpu xrisimopoio kai den anebene pano apo 29%-35%. mallon tha ftaiei h sd :( . tespa...
Y.Γ. Minotavrs sostossssssssssssssssss. pos kai den se eida kapou! piges sto match? :lol:
EDIT: lipon telika de ksero ti sto di@olo ftaiei! evala ena videaki sto idio bitrate (4000 bitrate, 55'' 26.5 mb)sthn mnimi thn kanoniki alla ekane kai perissotera kollimata. looooooooooooooool. tespa... se poso bitrate tha ta paizei kanonika alla xoris tetragonakia?... na vlepete dildadi! ;)
thnx in advance :)
Κοιτα για εμενα και στα 96kbps να το βαλεις μια χαρα ειναι... :)
http://i39.tinypic.com/ojjlzk.gif
:( βοηθεια παιδια γιατι ενω στελνω κανονικα sms δεν μπορω να παρω, τι κανω λαθος? :(
Samsung galaxy s8 duos. Surface Pro 4. DOD LS430W.
to eixa kai ego auto to provlima!!! einai mallon apo kapoio software pou exeis kanei install ( sprite backup mallon exeis old version )
http://feeds.feedburner.com/Techwargr.1.gif
πραγματι και τωρα τι πρεπει να κανω για να διορθωσει?
Μεχρι στιγμης τα προγραμματα που ξερω που το κανουν αυτο ειναι τα: Wisbar (older versions), Sprite Backup (older versions) και Platform4Player. Εχεις κανενα απο αυτα; :O
Δυστυχως δεν το γλυτωνεις το Hard Reset... :(
pedes helpppp den mporo na anikso to ntrw.exe ston ipologisti mou boi8ia !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Η Samsung έχει Πελάτες, Η Apple έχει οπαδούς !!!
Μεχρι στιγμης τα προγραμματα που ξερω που το κανουν αυτο ειναι τα: Winbar (older versions), Sprite Backup (older versions) και Platform4Player. Εχεις κανενα απο αυτα; :O
υπαρχει κανεις που να εχει yahoo messeger και να θελει να με βοηθησει
δεν εχω ξανακανει Hard Reset. :(
Τι ειναι το ntrw.exe και θες να το ανοιξεις; :O
ine ena programma to opio mporo to back up pou ekana na to metafero ston ipologisti gia na apothikepso to rom mou gia ora anagis
τα 96 ειναι λιγα !
οποιος θελει καλη ποιοτητα στα βιντεακια του θα πρεπει να βαλει εως και 500 .
παραπανω δεν χρειαζεται.
4000 kbps ουτε το pc μου θα την παλευε!
häää?? poli apla .. to penaki stin tripoula kato (eki pou kanis soft reset ) kai taftoxronos patas kai to on / off kumbi
τα 96 ειναι λιγα !
Για εμενα λεω. Τα 500 ουτε που θα τα σκεφτομουν ποτε. Αντε αν θελω κατι καλο να βαλω 256kbps. Συνηθως βαζω η 128kbps ή 96kbps (φαινεται πως κοιταω το μεγεθος ε; :p )... :)
αυτο ειναι το ευκολο μερος της υποθεσης μετα τι θελει για να ξαναλειτουργισει?
δεν πρεπει να ξαναπερασω το λειτουργικο κατι σαν τους υπολογιστες ασ πουμε?
εχω κατεβασμενη την τελευταια εκδοση της q tek στον υπολογιστη δεν πρεπει καπως να την περασω.
τι ενοεις να το ανοιξεις πας και δεν γινετε? ειναι προγραμματακι dos...
για παραδειγμα κοιτα μια εντολη και πως το χρησημοποιεις...
c:\> ntrw.exe write NEWROM.nb1 x: ( x = me to drive pou vlepei to pc sou thn sd card sou)
Να σας ρωτήσω κάτι παιδιά? Είμαι μεταξύ Qtek S100 (ή I-Mate Jam) και SE P910i. Βασικά θέλω να βλέπω βιντεάκια divx/xvid στο κινητό. Ποιό από τα 2 μου προτείνετε να αγοράσω. Μέχρι τώρα έχω ένα P800 και είμαι κάπως ευχαριστημένος. Αλλά όμως τώρα ζητάω κάτι καλύτερο..Μία πρόταση?
Μα εννοειται το S100. Δεν υπαρχει καποιο χαρακτηριστικο που να ειναι καλυτερο το P910i εκτος απο την 262k οθονη που στην αναλυση ειναι χειροτερη. Και συγκεκριμενα εσυ που θες και video ενας λογος παραπανω επειδη εχει και μεγαλυτερο επεξεργαστη... ;)
μετα απο απεγκατασταση του αctivesynch και hard reset και επανεγκατασταση του activesynch το pc μου δεν αναγνωριζει το jamaki δεν το βρισκει δεν συνδεεται με τιποτα .......$#@$@#%$*$$ ......καμια βοηθεια κανεις?
22414av-34
ego molis xana evala sto s100 mou 1.06 imate rom me radio 1.10 giati eixa valei thn cooked me ta 27 mb free storage alla kai ayth mou ekane provlimata sto bluetooth... gia kapoio logo DEN mporo na perno arxeia meso bluetooth o upologisths h alla kinhta lene pos h sundesh den einai efikth... Xerh kaneis kati?
oute ena filologo den exoun pia stin ACE?
katsj, όταν έκανα post και ρωτούσα αν γνωρίζει κανείς για ποιό λόγο είναι τόσο ανορθόγραφα τα μενού της ACE ROM, δυστυχώς κανείς δεν κατάλαβε τι εννοούσα...
Εσύ τουλάχιστο περίμενα ότι θα γνωρίζεις την αιτία - μου κάνει εντύπωση που δεν την ξέρεις...
χρησιμοποιείς καλώδιο ή bluetooth?
αν είναι το πρώτο νομίζω θα σου ζητηθεί να δώσεις ένα διαφορετικό όνομα στο ppc σου.
αν είναι το δεύτερο ρύθμισε σωστά πάλι τα ports.
ακόμα και στην 1.1.4,αν πάτε στις ρυθμίσεις ενέργειας λέει μαπαταρια αντί για μπαταρία .
ακόμα και μετά από τόσους μήνες .
είναι αστείο νομίζω ,δεν μπορώ να χαρακτηρίσω αλλιώς.
xrisimopio kalodio usb kai lei meta tin egatastasi tou activesynch sto get connected oti eine unknown usb device den to vlepei katholou sta windos 15 hard reset kai 15 reinstall to activesynch kai tipota
κοίταξε το λογικό είναι αφού κανεις εγκατάσταση το activesync να συνδέεις απλά το κινητό με το καλώδιο και αυτό αυτόματα να κάνει συγχρονισμό.
από κει και ύστερα τι να πω . πρόβλημα με usb σύνδεση δεν είχα ποτε ,αντίθετα στο bt παίζουν πολλά ρολο.
