LeEco Le Max 2 (X820 / X821 / Χ822 Global - X825 / Χ829 U.S.)
Paul64
## CN-DEV-6.0.30s Latest V15e FullRom Modded 15.09.2018 le_x2 LeMax2 X82x by C.B.G. ##
Flash it through TWRP with wipe caches or go with FR from another EUI version. Wait 4+ min until finish.
*Changelog*
- Including latest OTA for updates.
- Several changes inside SystemUI
- More Translations inside Gallery and SuperManager
- Gapps and all Google services updated to latest open Gapps nano 14.09.2018
- Including all latest framework patches amd modes
- Includes all latest changes and updates from V15
- Includes latest LeEco apps updated
- Latest Virtual buttons settings under display settings (GitHub N sources)
- Screen recorder settings
- Dolby latest and V4A under main settings
- Dual apps stock is back after users demand
- Includes latest Leui Launcher with notifications and available themes.(Ariel's mode)
- Include all the advanced apps and settings from V15 to v15e
- Include new FP libs for faster responce thank's to @ThE_MarD
Rom Link
https://drive.google.com/uc?id=1IIUpMiZZdqzJ9_PGJDsml6KSXBVvzjwl&export=download
Recomended TWRP
https://drive.google.com/open?id=1T3NQ_QQafWulIxtD9JT-yH0wYXZtK7Ye
*EXTRAS*
StockThemes flash zip
https://mega.nz/#!UDZDARDK!UAr0Wr40WfxbeK32yfXYdT8K9x4Gn-DZHwzIb07ZEW8
EUI 125 THEMES PACKAGE flash zip
https://mega.nz/#!xLAnhaKb!1bF0R0O-GKShgIJxgVaomGZD4VqgAwfm0JyURYJLNGc
New MIUI 9 camera port for EUI
Από TWRP
https://mega.nz/#!sGQ3GZgY!zxjPDheUTbepSMzngXPAI7HyrKZ9JUBbU8SYMKd284k
Φλασάρουμε από TWRP χωρίς κανένα wipe.
PhoneManager Clean Χωρίς κινεζιές .Φλασάρουμε απο TWRP...
https://drive.google.com/uc?authuser=0&id=1dKVGivVw4tlz5J1CDtj8-6CFdS8NbrWr&export=download
Για τυχόν προβλήματα λήψης SMS/MMS φλασάρουμε αυτό
https://mega.nz/#!AeIlHZyJ!GT-pWZXgMYn3oMaBb6RxcugPjRChqKAckuxYi-gCD1A
Νέα πακέτα θεμάτων και κάμερες για 28s.όλες οι εκδόσεις..21.04.2018
Themes Pack through TWRP:
https://drive.google.com/open?id=14D3L7On5Tk97g60Iie875q9Wy29vTCHI
Camera app:
https://dl.dropboxusercontent.com/s/2kjmzvpq02zk7io/com.pms.cameranextmod.v7.003.apk
Moto Z Camera
https://dl.dropboxusercontent.com/s/x2j75i1tfhflqja/MotoZCameraPro.x2_v2.apk
New AdBlockHosts 30s-v15g
https://mega.nz/#!QbJi3YjZ!bcrTtlB_k8LeTBTwrRLKQ3OC0je-fYcQ4foO4562BhA
EUI-6.030s FullRom Stock (Without any extras) Cleaned and Multilanguage.Rooted With Magisk Latest zip..
https://drive.google.com/file/d/17dVqqd_kRZol6ORhvs_Ubri7xNldRLvw/view
TIP1: If you don't want Root just open zip with 7zip and remove patch file. Close rom zip and flash..
TIP2: After 1st start on system if you want you can go back to TWRP and flash latest Gapps
I made it without Gapps because many users wanted to put their own gapps...
Recommend Gapps Flash without any wipe...
https://drive.google.com/open?id=1Ec0_s2bQzTpKqYiCzGbGGFmxsMAVQjcn
Edited by CrisBal
LeMax2-X820 LegionOS / LeMax2-X822 DerpFest
Xiaomi RN3Pro-MIUI10_9.3.14
Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
TIP2: After 1st start on system if you want you can go back to TWRP and flash latest Gapps nano 6.0 arm64
Λογικά nougat είναι? gapps τα opengapps ή κάτι άλλο?
LeEco le max 2 x820 6/64gb
Xiaomi mi mix 2s 6/64
Xiaomi mi 9t pro 6/128
Poco F4 8/256
Vivo x80 Pro
MM.. Αύριο και η δικιά μου πειραγμενη ....φουλ Ρομ..V15..
Περνώντας το update 17/7 oreo στο άνοιγμα και σε κάθε επανεκκίνηση μου βγάζει αυτό το μήνυμα, βέβαια το τηλέφωνο λειτουργεί σωστά σε όλες της εφαρμογές, γνωρίζει κάποιος τι είναι αυτό το σφάλμα vendor?
Στάλθηκε από το LEX820 μου χρησιμοποιώντας Tapatalk
Edited by nick1967
Μου το εβγαζε κι εμενα οταν ειχα την rr oreo.. Ξεκινησε να το βγαζει απ την εκδοση που υποστηριζε f2fs και μετα και ενω εγω φλασαρα τις εκδοσεις χωρις να εχω κανει μετατροπη σε f2fs..βεβαια ολα λειτουργουσαν οκ..στην msm xtended που εκανα μετατροπη σε f2fs και επειτα φλασαρα δε μου το ξαναεβγαλε.υποθετω λοιπον φταιει αυτο.
Le max2 6/64 (rr oreo rom)
Γυρνώντας στην 10/07 δεν μου βγάζει το μήνυμα πηγαίνω στην 17 έως και 24 μου το βγάζει συνεχώς, και με την διαδικασία fsfs πάλι τα ίδια κάνει, κάποια στιγμή προσπάθησε να κάνει update το Android αλλά σταμάτησε στην μέση περίπου.
Παιδια με την msm extended παρατηρω αρκετα μεγαλη διαφορα sot αν εχει φορτιστει περι τα 2500 mA με το αν εχει φορτιστει στα 1000 mA...στη δευτερη περιπτωση εχω πολυ πιο ομαλη και αργη πτωση μπαταριας
Θα το δοκιμάσω και εγώ στην επόμενη φόρτιση με μικρότερο φορτιστή στην lineage. Νομίζω κάτι τέτοιο είχα παρατηρήσει και εγώ με την AICP του infrag όταν φόρτιζα με μικρότερο φορτιστή.
Edited by GUZGUN
Poco F4 8/256
Vivo x80 Pro
Εχεις φτιάξει partition vendor απο το project Treble?
Le max 820 6/64 gold my device
AOSiP 10-Q by CrisBalGreece 10/1/2020 f2fs files TWRP 3.3.1
HERO VIII_6700k 4.3GHz 1.168v_CORSAIR 16G 3.3GHz_280x gaming
Όχι αυτό δεν το έκανα... Ποιο αναλυτικός μπορείς να γίνεις, γιατί με πιάνεις αδιάβαστο έχω περάσει το τελευταίο TWRP το έκανα fsfs και το ventor και το wipe και έχω κόκκινα
Edit ...έκανα καθαρή εγκατάσταση καί έστρωσε
Edited by nick1967
Ένα τεστάκι για να μην ξεχνιόμαστε. Lineage rev5 με bs kernel.
Poco F4 8/256
Vivo x80 Pro
Όλα μια χαρά λοιπόν...
Πιο twrp εχεις;
----- προσθήκη μηνύματος 49 δευτ. μετά την υποβολή του προηγούμενου -----
Με βάζεις στην πρίζα τώρα....
Εγώ? Η lineage. Και έχει και λίγο ακόμα περιθώριο για παραπάνω αν το δροσισω λίγο το κινητό.
Poco F4 8/256
Vivo x80 Pro
Πιο twrp εχεις
[/color]
Πέρασα το 3.2.2.0 αλλά μου βγάζει κόκκινα στο ventor επίσης δεν κάνει εκκαθάριση dalvid cache και δεν αλλάζει το ex4 σε sfsf.. Κάτι δεν μου άρεσε και ξαναγύρισα στου cris, το ventor πρέπει να είναι ext4?
Edited by nick1967
Πιο twrp εχεις
[/color]
Και εγώ το 3.2.2.0 έχω αλλά το γνήσιο, όχι πειραγμενο... Δεν έχει μέσα vendor καο τετοια
Έχεις κάποιο λινκ να το κατεβάσω
Ωραιος...αν και νομιζω οτι τη διαφορα τη κανει ο κερνελ..την oc version εχεις βαλει και το τσιμπησες στο χρονισμο;;
Καλο ακουγεται.!
Αλλα με καποιο ψαξιμο και με τη μεταφραση google ..μαλλον δυσκολα τα πραγματα
Τωρα αν καποιος φιλος αγγλομαθης μπορουσε να το μεταφερει εδω σε απλα ελληνικα και για μας
τους ποιο ασχετους ..καλα θα ηταν..:rolleyes:
Μολις βρω λιγο χρονο θα προσπαθησω να το μεταφερω εδω σε ελληνικα..με καθε επιφυλαξη ομως γιατι δε το εχω δοκιμασει.
αυτή που είχε βάλει ο Cris μέσα στην Rev5.
Poco F4 8/256
Vivo x80 Pro
Πέρασα τη νέα miui 10 N πάνω από την 9.5 dirty όπως περιγράφει ο Cris στο σχετικό link. Πέρασε κανονικά δίχως προβλήματα αλλά μετά τη επανεκκίνηση κολλαει στο λογότυπο της miui 10. Το έκανα τρεις φορές περιμένοντας πρώτα 5 μετά 10 και τέλος 15 λεπτά. Δεν μπήκε ποτέ στο σύστημα. Πίσω πάλι στην 9.5.
Mi Note 10 .
για αλλαγή σπασμένης οθόνης LeMax2 x820?Απο που να αγορασω?και κολα μαζι.Ευχαριστω
Πήγαινε πρώτη σελίδα έχει μερικά link... Τα πάντα έχει το παρον νήμα μόνο καφέ δεν κάνει Edited by nick1967
