fotispigi Δημ. June 21, 2018 Δημ. June 21, 2018 lineage-15.1-20180621-Experimental-2-x2 21.06.2018 ΗΟΜΕ MADE INFO Rom made by me for a friend of mine and i'm sharing here, if you want to try it.. Based on LOS sources by @ThE_MarD Experimental focus fix kernel by Ryzen CHANGELOG - Latest PreBuilt GAPPS 21.06 on board - Face Unlock - Weather provider on board - Extra settings on board - Le EXTRAS on board - Enforcing kernel by default - SeLinux changer on board - Viper4Android on board - IR Remote control on board - Focus Fix switch(experimental) - AKT Profiles on board - Extra V4A settings inside sound settings - Sound scripts for better and louder sound from EUI30s - KPM profiles on board with stock stable LOS CPU-Battery profile - Updated GPU blobs,CNE, IMS, GPS, Vulkan, QMI, RIL, Thermal, Time services - LBS services based on GMS should be more responsive - More ringtones inside - More stuff.. ROM Download https://drive.google.com/uc?id=1geT36Jtr8aR59cooeJISxe980IFDV6H4&export=download Recomended TWRP quota fs https://drive.google.com/file/d/1tFVb4J2nQx1-OtAy4ck_IjUnms1l_w55/view?usp=sharing INSTALLATION From any rom except LOS..If you are with LOS dirty should work..or 2 caches wipe.. Make format cache+data with f2fs Reboot to recovery one more wipe except internal Flash ROM.. Wait until finish and reboot to system..make your settings.. Boot again to recovery... Flast Root zip which provided bellow.. Reboot to system...Finish TIP:In case after clean installation doesn't boot and stays at logo flash one more time rom dirty.. Magisk ModdedZip https://drive.google.com/uc?authuser=0&id=109YSFu_1d8jMAw9kwfDYWWlbSzJ_Gi2b&export=download EXTRA LOS Ryzen FocusFix based kernel 21.06.2018 https://drive.google.com/file/d/10eToz3NJqUYawA66IBeKPKfnr67O1Pgz/view Gcamera recomended Pixel2Mod-Arnova8G2-MinimalSettings-Tolyan009-v4.2 https://www.celsoazevedo.com/files/android/google-camera/dev-tolyan009/ Xposed https://forum.xda-developers.com/showthread.php?t=3034811 Chris την περναμε απο πανω η θα ερθει σε update? Παράθεση Le max 820 6/64 gold my device AOSiP 10-Q by CrisBalGreece 10/1/2020 f2fs files TWRP 3.3.1 HERO VIII_6700k 4.3GHz 1.168v_CORSAIR 16G 3.3GHz_280x gaming
zombie_wireless Δημ. June 21, 2018 Δημ. June 21, 2018 Ποσες ωρες sot σου βγαζει η μπαταρια;; Επισης,μπορεις καποια στιγμη να δοκιμασεις βιντεοκληση και να μας πεις αν κατα τη διαρκεια της παγωσει η μπροστα καμερα αν πχ δει καμια λαμπα η ηλιο;; Έχοντας κλείσει 24άωρο από γρήγορη φόρτιση, είχα 3 ώρες και κάτι ψηλά sot και μπαταρία αν όχι 20%, λίγο πιο κάτω. Διάρκεια κλήσεων μιάμιση ώρα. Δεν χρησιμοποιώ facebook και η χρήση είναι για browsing, niber, 9gag και φωτογραφίες. Wifi ανοιχτό όταν το χρειάζομαι και κλείσιμο το βράδυ. Με κλειστό wifi το βράδυ, σε διάρκεια 9 ωρών είχα battery drain 7%. Μ' ανοιχτό καταναλώνει αρκετά περισσότερο. Κατέβασα και το forcedoze από playstore, αλλά δεν είμαι σίγουρος κατά πόσο βοηθάει. Φωτεινότητα οθόνης στο αυτόματο κι είναι υπέρ αρκετή. Βιντεοκλήση από viber μπορώ να δοκιμάσω μόνο. Αυτό εννοείς; Μηπως εννοεις την 17/04; Aπο που την κατεβασες: Ναι, την 17/04 λέω. Μπερδεύτηκα :P Πρέπει να την είχα κατεβάσει από κάποιο link του google drive γιατί ήταν offline το επίσημο site όταν ήθελα να την περάσω, αλλά μπορείς να την βρεις εδώ: https://download.pixelexperience.org/changelog/x2/PixelExperience_x2-8.1.0-20180417-1845-OFFICIAL.zip/ και πιο συγκεκριμένα εδώ: https://download.pixelexperience.org/changelog/x2/PixelExperience_x2-8.1.0-20180417-1845-OFFICIAL.zip/ Παράθεση
fotispigi Δημ. June 21, 2018 Δημ. June 21, 2018 Chris την περναμε απο πανω η θα ερθει σε update? Tελικα την περασα απο πανω! ολα μια χαρα!! :up: Αυτο που βλεπω ειναι οτι εχω twrp 3.2.1-0 ενω εχω φλασαρει (με επιτυχια) το 3.2.1-1 επισης περασει και τα δυο fix του chris με επιτυχια αλλα δεν αλλαξε αυτο το 3.2.1-0 ειναι λογικο? Παράθεση Le max 820 6/64 gold my device AOSiP 10-Q by CrisBalGreece 10/1/2020 f2fs files TWRP 3.3.1 HERO VIII_6700k 4.3GHz 1.168v_CORSAIR 16G 3.3GHz_280x gaming
GUZGUN Δημ. June 21, 2018 Δημ. June 21, 2018 Δοκιμασα την Pixel Experience 07/04. Πολυ καλη εμπειρια για πρωτη oreo. Κολλημα κανενα. Μιλαω με bleutooth. Ο ηχος δεν ηταν ο καλυτερος, αλλα ηταν δυνατος. Google camera χρησιμοποιω εδω και καιρο την εκδοση του SerJo87 χωρις ν' αντιμετωπιζω κανενα απολυτως προβλημα: ουτε μαυρες οθονες, ουτε πρασιναδες, ουτε force close τοσο σε oreo οσο και σε nougat. Η προηγουμενη rom που φορουσα ηταν η rr nougat. Με την pixel oreo κραταει περισσοτερο η μπαταρια κι ειναι πιο γρηγορη σαν rom.Καλή φαινεται η serjo camera αλλά στη selfie με hdr+ πρασινίζει όπως και tolyan ενώ η GoogleCamera-Pixel2Mod-Arnova8G2-V8 η τελευταία δεν πρασινίζει. Στάλθηκε από το Le X820 μου χρησιμοποιώντας Tapatalk Παράθεση Sony Ericsson k700, samsung wave GT8500 samsung galaxy s3 GTi9300, LG G3 32gb 3gb Ram LeEco le max 2 x820 6/64gb Xiaomi mi mix 2s 6/64 Xiaomi mi 9t pro 6/128 Poco F4 8/256 Vivo x80 Pro
vasillis2 Δημ. June 21, 2018 Δημ. June 21, 2018 Κάνε dirty flash ξανά όπως είσαι.. Φταίει το TWRP..έφτιαξαα καινούργιο σήμερα.. Τα αλλά που παίζουν εξω έχουν θέμα με f2fs στα data.. Αν έβαλες αυτό απο το multi tool το δικό μου δεν κάνει για LOS καινούργιες... Βάλε αυτό όπως είσαι μέσα απο το προηγούμενο που έχεις.. https://mega.nz/#!4SAnTQYb!kuWaOQPbr4AfQpw5ssrZHtUn0rryBrWjU0iRtI0f054 Πατάςinstall image κάτω δεξια επιλέγεις recovery.. Μια ερωτηση που δεν ξερω αν εχει απαντηθη Ειμαι με την 28s V.12 και λεω να δοκιμασω την lineage-15.1-20180621-Experimental-2-x2 του Cris Πρεπει να κανω Backup την Internal storage λογω του οτι μαλλον θα σβησει? :O:) Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
CrisBal Δημ. June 21, 2018 Δημ. June 21, 2018 Μια ερωτηση που δεν ξερω αν εχει απαντηθη Ειμαι με την 28s V.12 και λεω να δοκιμασω την lineage-15.1-20180621-Experimental-2-x2 του Cris Πρεπει να κανω Backup την Internal storage λογω του οτι μαλλον θα σβησει? :O:) Δεν χρειάζεται να την κάνεις format μόνο τα data Kai cache f2fs..;) Παράθεση LeMax2-X820 LegionOS / LeMax2-X822 DerpFest Xiaomi RN3Pro-MIUI10_9.3.14 Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
vasillis2 Δημ. June 21, 2018 Δημ. June 21, 2018 Δεν χρειάζεται να την κάνεις format μόνο τα data Kai cache f2fs..;) Νασαι παντα καλα Θα δοκιμασω Ειχα βολευτη με την 28s αλλα με τρωει το ..χερι μου.. Δεν καταλαβαινω καλα το f2fs αλλα πιστευω θα το ..βρω :lol: Ευχαριστω Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
colossus_r Δημ. June 21, 2018 Δημ. June 21, 2018 lineage-15.1-20180621-Experimental-2-x2 21.06.2018 ΗΟΜΕ MADE INFO Rom made by me for a friend of mine and i'm sharing here, if you want to try it.. Based on LOS sources by @ThE_MarD Experimental focus fix kernel by Ryzen Αυτά είναι τα ωραία... Με ρυθμούς πολυβολου έρχονται. Σε ευχαριστούμε πολύ γιατί η Experimental όπως την λες είναι η πιο σταθερή και καλή oreo από όσες έχω δοκιμάσει. Έχει αυτά που θέλω πάει σφαίρα και τρέχει απροβληματιστα. Και νομίζω ότι το ΚΡΜ κάνει πολύ καλή δουλειά και με λιγότερα προβλήματα από το ΑΚΤ. Και μια ερώτηση άσχετη με την ρομ. Υπάρχει λύση για διαφορετικό Ringtone σε κάθε sim? Ότι έχω δοκιμάσει από το store είναι μάπα. Παράθεση Share the KnowHow: Lumia 950-930, Surface 3, Yoga 3 Pro 8/512MB [Το δικο μου 930][Προσθήκη εορτών στο ημερ/γιο] [Aπο Android σε Windows Phone ] [Mango ROM με Ελληνικά-RSPL/HSPL] http://i831.photobucket.com/albums/zz234/colossusr/Avatar4.jpg~original
vasillis2 Δημ. June 21, 2018 Δημ. June 21, 2018 Νασαι παντα καλα Θα δοκιμασω Ειχα βολευτη με την 28s αλλα με τρωει το ..χερι μου.. Δεν καταλαβαινω καλα το f2fs αλλα πιστευω θα το ..βρω :lol: Ευχαριστω Τελικα δεν ειμαι σιγουρος οτι το βρηκα ειμουνα με την τελευταια του Χριστου TWRP RECOVERY 3.2.1-1 εκανα το εγκατασταση εικονας κατω δεξια τωρα το twrp γραφει 3.2.1.0 (επισης κατι εγραφε να το εγκαταστησω σαν εφαρμογη συστηματος?) αυτο τι κανω? Αν ειναι σωστα μεχρι εδω μπορει καποιος φιλος να μου πει τι ακριβως κινησεις πρεπει να κανω μετα για να αλλαξω σε f2fs και να κανω εγκατασταση τη ρομ? Ευχαριστω Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
colossus_r Δημ. June 21, 2018 Δημ. June 21, 2018 Τελικα δεν ειμαι σιγουρος οτι το βρηκα ειμουνα με την τελευταια του Χριστου TWRP RECOVERY 3.2.1-1 εκανα το εγκατασταση εικονας κατω δεξια τωρα το twrp γραφει 3.2.1.0 (επισης κατι εγραφε να το εγκαταστησω σαν εφαρμογη συστηματος?) αυτο τι κανω? Αν ειναι σωστα μεχρι εδω μπορει καποιος φιλος να μου πει τι ακριβως κινησεις πρεπει να κανω μετα για να αλλαξω σε f2fs και να κανω εγκατασταση τη ρομ? Ευχαριστω Δες εδω εχει εχει αναλυτικες οδηγιες για το πως θα πας σε f2fs http://www.myphone.gr/forum/showthread.php?p=7572600#post7572600 σε ενδιαφερει αυτο: 2) Μεσα στο νεο μας TWRP παμε κατα σειρα: Wipe --> Advanced Wipe --> Επιλεγουμε data και παταμε Repair or Change System --> Change File Sytem --> F2FS (κατω δεξια) --> Swipe to change. Τα data μας μολις εγιναν f2fs. Ακολουθουμε την ιδια διαδικασια για την Cache. Παράθεση Share the KnowHow: Lumia 950-930, Surface 3, Yoga 3 Pro 8/512MB [Το δικο μου 930][Προσθήκη εορτών στο ημερ/γιο] [Aπο Android σε Windows Phone ] [Mango ROM με Ελληνικά-RSPL/HSPL] http://i831.photobucket.com/albums/zz234/colossusr/Avatar4.jpg~original
misigun Δημ. June 21, 2018 Δημ. June 21, 2018 lineage-15.1-20180621-Experimental-2-x2 21.06.2018 ΗΟΜΕ MADE INFO Rom made by me for a friend of mine and i'm sharing here, if you want to try it.. Based on LOS sources by @ThE_MarD Experimental focus fix kernel by Ryzen CHANGELOG - Latest PreBuilt GAPPS 21.06 on board - Face Unlock - Weather provider on board - Extra settings on board - Le EXTRAS on board - Enforcing kernel by default - SeLinux changer on board - Viper4Android on board - IR Remote control on board - Focus Fix switch(experimental) - AKT Profiles on board - Extra V4A settings inside sound settings - Sound scripts for better and louder sound from EUI30s - KPM profiles on board with stock stable LOS CPU-Battery profile - Updated GPU blobs,CNE, IMS, GPS, Vulkan, QMI, RIL, Thermal, Time services - LBS services based on GMS should be more responsive - More ringtones inside - More stuff.. ROM Download https://drive.google.com/uc?id=1geT36Jtr8aR59cooeJISxe980IFDV6H4&export=download Recomended TWRP quota fs https://drive.google.com/file/d/1tFVb4J2nQx1-OtAy4ck_IjUnms1l_w55/view?usp=sharing INSTALLATION From any rom except LOS..If you are with LOS dirty should work..or 2 caches wipe.. Make format cache+data with f2fs Reboot to recovery one more wipe except internal Flash ROM.. Wait until finish and reboot to system..make your settings.. Boot again to recovery... Flast Root zip which provided bellow.. Reboot to system...Finish TIP:In case after clean installation doesn't boot and stays at logo flash one more time rom dirty.. Magisk ModdedZip https://drive.google.com/uc?authuser=0&id=109YSFu_1d8jMAw9kwfDYWWlbSzJ_Gi2b&export=download EXTRA LOS Ryzen FocusFix based kernel 21.06.2018 https://drive.google.com/file/d/10eToz3NJqUYawA66IBeKPKfnr67O1Pgz/view Gcamera recomended Pixel2Mod-Arnova8G2-MinimalSettings-Tolyan009-v4.2 https://www.celsoazevedo.com/files/android/google-camera/dev-tolyan009/ Xposed https://forum.xda-developers.com/showthread.php?t=3034811Το link δεν δουλεύει; Στάλθηκε από το LEX820 μου χρησιμοποιώντας Tapatalk Παράθεση AEX Pie-9
vasillis2 Δημ. June 21, 2018 Δημ. June 21, 2018 Δες εδω εχει εχει αναλυτικες οδηγιες για το πως θα πας σε f2fs http://www.myphone.gr/forum/showthread.php?p=7572600#post7572600 σε ενδιαφερει αυτο: νασε καλα σ ευχαριστω Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
GUZGUN Δημ. June 21, 2018 Δημ. June 21, 2018 Επειδή αναφέρθηκε ότι πρέπει να αποφεύγουμε την επαναφορά εφαρμογών με titanium στην linageos ισχύει κάτι τέτοιο τελικά? Παράθεση Sony Ericsson k700, samsung wave GT8500 samsung galaxy s3 GTi9300, LG G3 32gb 3gb Ram LeEco le max 2 x820 6/64gb Xiaomi mi mix 2s 6/64 Xiaomi mi 9t pro 6/128 Poco F4 8/256 Vivo x80 Pro
kidonakisg Δημ. June 21, 2018 Δημ. June 21, 2018 Παιδια φιλος εχει το ιδιο με μενα και το πουλαει για να παει σε καποιο rugged phone...εχει την εκδοση 6 ram 64 rom αγορασμενο απο geekbuying 24 Νοεμβριου 2017..αν ενδιαφερεται καποιος ας στειλει pm. Παράθεση Le max2 6/64 (rr oreo rom)
zombie_wireless Δημ. June 21, 2018 Δημ. June 21, 2018 Καλή φαινεται η serjo camera αλλά στη selfie με hdr+ πρασινίζει όπως και tolyan ενώ η GoogleCamera-Pixel2Mod-Arnova8G2-V8 η τελευταία δεν πρασινίζει. Στάλθηκε από το Le X820 μου χρησιμοποιώντας Tapatalk Την εχω κανενα διμηνο αυτην. Δεν βγαζει πρασινες φωτογραφιες με την μπροστα camera, ειτε ειναι ενεργοποιημενο το hdr ειτε οχι. Και νομιζω γι' αυτο την ειχα κρατησει. Παράθεση
GUZGUN Δημ. June 22, 2018 Δημ. June 22, 2018 Την εχω κανενα διμηνο αυτην. Δεν βγαζει πρασινες φωτογραφιες με την μπροστα camera, ειτε ειναι ενεργοποιημενο το hdr ειτε οχι. Και νομιζω γι' αυτο την ειχα κρατησει.Εμένα πάντως με ενεργοποιημενο το hdr+ η μπροστινή βγάζει πρασινοπές φωτός. Εκτός αν έχεις αλλάξει καμία ρύθμιση. Στάλθηκε από το Le X820 μου χρησιμοποιώντας Tapatalk Παράθεση Sony Ericsson k700, samsung wave GT8500 samsung galaxy s3 GTi9300, LG G3 32gb 3gb Ram LeEco le max 2 x820 6/64gb Xiaomi mi mix 2s 6/64 Xiaomi mi 9t pro 6/128 Poco F4 8/256 Vivo x80 Pro
VOYAGER13 Δημ. June 22, 2018 Δημ. June 22, 2018 Mετά από αρκετό καιρό με την Pixel Experience δοκίμασα και εγώ την LOS του Chrisbal . Έκανα την αλλαγή σε f2fs και έβαλα και το camera fix που προτείνει. Μέχρι στιγμής είναι θετικές οι εντυπώσεις και μου φαίνεται και λίγο πιο γρήγορη. Bugs δεν έχω βρει.Θέλω να δω και την μπαταρία της για να δω αν θα μείνω ή θα γυρίσω πίσω. Παράθεση Δημήτρης
CrisBal Δημ. June 22, 2018 Δημ. June 22, 2018 New FULL ROM LeIta.v6.3b8: Google Drive: https://drive.google.com/open?id=1fRl73VbjjHcon-PZo7Tt4F3c4wqI54O- AndroidFileHost: https://www.androidfilehost.com/?fid=962339331459002491 - CHANGELOG FOR UPDATE V6.3b8 (06/21/2018) - New Kernel by(CBG) - Added Spanish translations for LetvSetupWizard - Added Spanish translations for Phone Manager alerts - Added Spanish translations for Settings - Updated Google Play Store to latest beta - Updated Google Quick Search to latest beta - Updated Google Instant apps - Latest EMUI pack with 1190 icons Παράθεση LeMax2-X820 LegionOS / LeMax2-X822 DerpFest Xiaomi RN3Pro-MIUI10_9.3.14 Xiaomi RN9Pro-MIUI-12.5.5-RJWMIX
nikose704 Δημ. June 22, 2018 Δημ. June 22, 2018 Εχω την Miui Nougat του Χρηστου. Υπαρχει τροπος να βγαλουμε το εικονιδιο καποιας εφαρμογης στην οθονη κλειδωματος?? Για το τηλεχειριστηριο ενδιαφερομαι βασικα. Παράθεση Mi Note 10 .
misigun Δημ. June 22, 2018 Δημ. June 22, 2018 Chris στην τελευταία los που εφτιαξες νομιζω δεν δουλεύει η γρήγορη φόρτιση.κάποιος να το τσεκαρη; Στάλθηκε από το LEX820 μου χρησιμοποιώντας Tapatalk Παράθεση AEX Pie-9
hecorian Δημ. June 22, 2018 Δημ. June 22, 2018 CrisBal πως γινεται να μου δουλεύει το fingerprint με το official Los και AICP και με το δικό σου όχι (Αλλαξες τπτ?) ... ωραια δουλειά παντως βλεπω διαφορά στη μπαταρία κανα μισαωρο Παράθεση
GUZGUN Δημ. June 22, 2018 Δημ. June 22, 2018 CrisBal πως γινεται να μου δουλεύει το fingerprint με το official Los και AICP και με το δικό σου όχι (Αλλαξες τπτ?) ... ωραια δουλειά παντως βλεπω διαφορά στη μπαταρία κανα μισαωρο το fp με την lineageos δουλεύει πιο γρήγορα και από το γρήγορα. ----- προσθήκη μηνύματος 3 λεπτά μετά την υποβολή του προηγούμενου ----- ενω δεν εκανα wipe στην internal,οταν εκανα τη διαδικασια f2fs στο data και στο cache τελικα εχασα ολη την εσωτερικη μνημη :( Kαι σε μένα το ίδιο. Παράθεση Sony Ericsson k700, samsung wave GT8500 samsung galaxy s3 GTi9300, LG G3 32gb 3gb Ram LeEco le max 2 x820 6/64gb Xiaomi mi mix 2s 6/64 Xiaomi mi 9t pro 6/128 Poco F4 8/256 Vivo x80 Pro
kwstassrp Δημ. June 22, 2018 Δημ. June 22, 2018 Έχω μια μικρή απορία, έχω το smartwarch colmi i2 σε eui 28s v12a , σε Lineage 15.1 του The Mard , ενώ το έχω συνδέσει κανονικά , και χτυπάει για κάθε notification και όλα δουλεύουν καλά , σε MIUI 9.5.2 CBG κάνει την σύζευξη κανονικά , αλλά δεν χτυπάει ούτε σε μισό notification , δεν μπορώ να καταλάβω με τίποτα τι γίνεται ! Υ.Γ πάει για πούλημα Παράθεση
vasillis2 Δημ. June 23, 2018 Δημ. June 23, 2018 (edited) Εκανα εγκατασταση την lineage-15.1-20180621-Experimental-2-x2 21.06.2018 ΗΟΜΕ MADE συμφωνα με τις οδηγιες. Να σημειωσω εδω επειδη ειχε προαναφερθει Μετα την μετατροπη των αρχειων σε f2fs χαθηκε ο εσωτερικος χωρος του τηλ. Ετσι την περασα με OTG. Ερωτηση Οταν παω να περασω το EXTRA LOS Ryzen FocusFix με βάση τον πυρήνα 21.06.2018 μου βγαζει 3 επιλογες. system image boot recovery Ποια πρεπει να τικαρω?:O ----- προσθήκη μηνύματος 11 λεπτά μετά την υποβολή του προηγούμενου ----- Εκανα εγκατασταση την lineage-15.1-20180621-Experimental-2-x2 21.06.2018 ΗΟΜΕ MADE συμφωνα με τις οδηγιες. Να σημειωσω εδω επειδη ειχε προαναφερθει Μετα την μετατροπη των αρχειων σε f2fs χαθηκε ο εσωτερικος χωρος του τηλ. Ετσι την περασα με OTG. Ερωτηση Οταν παω να περασω το EXTRA LOS Ryzen FocusFix με βάση τον πυρήνα 21.06.2018 μου βγαζει 3 επιλογες. system image boot recovery Ποια πρεπει να τικαρω?:O Επισης να πω οτι μετα απο απενεργοποιηση δυσκολευετε να μπουταρει Το κανει μετα απο 3 εως 5 προσπαθειες Επισης ξεχασα να πω μετα την εγκατασταση της ρομ και ρεμπουτ στο συστεμ ξαναμπηκε σε ρεκοβερυ 2η ντερτυ εγκατασταση ρεμπουτ στο συστεμ και ξανα σε ρεκοβερυ 3η προσπαθεια και περασε.. 1η εντυπωση: Πολυ γρηγορη ρομ!!! Edited June 23, 2018 by vasillis2 Παράθεση Le max 2 x829/6x128/ - RROS-Q-8.7.3-20210920-x2-Official
GUZGUN Δημ. June 23, 2018 Δημ. June 23, 2018 Εκανα εγκατασταση την lineage-15.1-20180621-Experimental-2-x2 21.06.2018 ΗΟΜΕ MADE συμφωνα με τις οδηγιες. Να σημειωσω εδω επειδη ειχε προαναφερθει Μετα την μετατροπη των αρχειων σε f2fs χαθηκε ο εσωτερικος χωρος του τηλ. Ετσι την περασα με OTG. Ερωτηση Οταν παω να περασω το EXTRA LOS Ryzen FocusFix με βάση τον πυρήνα 21.06.2018 μου βγαζει 3 επιλογες. system image boot recovery Ποια πρεπει να τικαρω?:O ----- προσθήκη μηνύματος 11 λεπτά μετά την υποβολή του προηγούμενου ----- Επισης να πω οτι μετα απο απενεργοποιηση δυσκολευετε να μπουταρει Το κανει μετα απο 3 εως 5 προσπαθειες Επισης ξεχασα να πω μετα την εγκατασταση της ρομ και ρεμπουτ στο συστεμ ξαναμπηκε σε ρεκοβερυ 2η ντερτυ εγκατασταση ρεμπουτ στο συστεμ και ξανα σε ρεκοβερυ 3η προσπαθεια και περασε.. 1η εντυπωση: Πολυ γρηγορη ρομ!!!Και μενα τα έκανε όλα αυτά που λες. Ευτυχώς δεν χρειάστηκε το focus fix. To βάσεις στο boot. Στάλθηκε από το LEX820 μου χρησιμοποιώντας Tapatalk Παράθεση Sony Ericsson k700, samsung wave GT8500 samsung galaxy s3 GTi9300, LG G3 32gb 3gb Ram LeEco le max 2 x820 6/64gb Xiaomi mi mix 2s 6/64 Xiaomi mi 9t pro 6/128 Poco F4 8/256 Vivo x80 Pro
